Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Yes! It’s working, thank you @danwooller
could anyone please help with changing the lock icon from a closed to open one? I have it changeing colour with state but an icon change would finish it off my code is below
cards:
    entity: binary_sensor.alarm_front_door_locked
    icon: mdi:lock
    icon_color: '{{ ''green'' if is_state(entity, ''off'') else ''red'' }}'
    tap_action:
      action: call-service
      service: switch.turn_on
      data: {}
        entity_id: switch.sonoff_10008bf604_1
    secondary_info: none
    layout: vertical
    card_mod:
      style: |
        ha-card {
          --icon-size: 100px;
           background: transparent;
           border-style: none;
{{ is_state("binary_sensor.alarm_front_door_locked", "on") | iif("mdi:lock", "mdi:lock-open") }}
I have a card where I want to display either “Clear” or “Detected” for my motion sensor, but I also want to show the last changed state. The best I’ve got so far is “Clear | 13:42” for example. Which is firstly an hour behind my UK time and secondly I’d prefer it said “Clear | 3 minutes ago” for example. Is this possible?
type: custom:mushroom-template-card
    primary: Hall Motion
    secondary: |-
      {% if is_state("binary_sensor.hall_motion_sensor_occupancy", 'off') %}
        Clear | {{ states.binary_sensor.hall_motion_sensor_occupancy.last_changed.astimezone().strftime('%H:%M') }}
      {% elif is_state("binary_sensor.hall_motion_sensor_occupancy", 'on') %}
        Detected | {{ states.binary_sensor.hall_motion_sensor_occupancy.last_changed.astimezone().strftime('%H:%M') }}
      {% endif %}
    entity: binary_sensor.hall_motion_sensor_occupancy
Looking for a nice HVAC mushroom setup, can you share your with the code?
OMG! Thank u so much!!
A simpler approach might be something like this:
type: custom:mushroom-entity-card
entity: binary_sensor.dining_room_motion_occupancy
secondary_info: last-updated
name: Dining Room Motion
card_mod:
  style:
    mushroom-state-info$: |
      .secondary:before {
        content: "{{ 'detected' if is_state(config.entity, 'on') else 'clear' }} / ";
You are comparing to the strings “true” or “false”. Just use true and false without the quotes.
Has anyone an idea / can help me pls? :slight_smile:
what’s the path to the view you want to go to?
it would be in this syntax:
/ui-develop/home_assistant
and you can check in the browser path… obviously :wink:
also, please only post the relevant section of you current config, which would be:
    tap_action:
      action: navigate
      navigation_path: wek
and not the full card. Help us help you
@rhysb I;m sure you have solution for that :slight_smile:
I have a number in badge - it is state of the pollution - aqi
I’m trying to change the background of the badge based on the aqi value
am I close?
        card_mod:
          style:
            mushroom-shape-icon$: |
              ha-icon {
                --icon-animation: molecule 2s ease-in-out infinite;
                transform-origin: 50% 75%;
              @keyframes molecule {
                0%, 100% { transform: rotate(-15deg); }
                50% { transform: rotate(15deg); }
              ha-card {
                background: rgba(var(--rgb-primary-text-color), 0.1);
                width: 80px;
                border-radius: 35px;
                margin-left: auto;
                margin-right: auto;
                margin-top: 4px;
                margin-bottom: -10px;
              :host {
                --mush-icon-size: 60px;
              ha-card:after {
                **{% set background_color = states('sensor.airly_caqi') | int %}**
**                {% if background_color > 90 %} **
**                  background: green;**
**                {% elif background_color > 60 %}**
**                  background: light-green;**
**                {% elif background_color > 50 %}**
**                  background: lime;**
**                {% elif background_color > 40 %}**
**                  background: yellow;**
**                {% elif background_color > 30 %}**
**                  background: amber;**
**                {% elif background_color > 20 %}**
**                  background: orange;**
**                {% elif background_color > 10 %}**
**                  background: deep-orange;**
**                {% else %}**
**                  background: red;**
**                {% endif %}**
                content: "{{ states('sensor.airly_caqi') }}";
                position: absolute;
                display: flex;
                justify-content: center;
                align-items: center;
                color: var(--card-background-color);
                font-weight: bolder;
                border-radius: 50%;
                top: 5px;
                right: -1px;
                width: 26px;
                height: 26px;
                font-size: 15px;
strong text
in this example is just defined as “white”
Oh, that’s it. Thanks)
Gave you a hint before :grinning_face_with_smiling_eyes:. Your tap_action is in the wrong place, you can’t have it on a condition. It needs to be on the card or chip of the conditional, like this:
      - type: conditional
        conditions:
          - entity: binary_sensor.wek_couch_prasenz
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          card_mod:
            style: |
              ha-card {
                animation: blink 1s linear infinite;
              @keyframes blink {
                50% {opacity: 0;}
          icon: mdi:motion-sensor
Looks Ok :thinking:. Is what you have not working?
in the screen, the background is set to white only to show what I’m looking for,
the conditional background (depending on aqi state) is not working for me
Oh, I see. You are using the Mushroom color names. CSS will only recognize the HTML color names, but these may be a bit different to the Mushroom ones.
You can use the Mushroom color names like this:
card_mod:
  style:
      ha-icon {
      ha-card {
        width: 80px;
        margin-left: auto;
        margin-right: auto;
        margin-top: 4px;
      :host {
      ha-card:after {
        {% set background_color = states(config.entity) | int %}
        background: var(--
        {%- if background_color > 90 -%}
          green
        {%- elif background_color > 60 -%}
          light-green
        {%- elif background_color > 50 -%}
          lime
        {%- elif background_color > 40 -%}
          yellow
        {%- elif background_color > 30 -%}
          amber
        {%- elif background_color > 20 -%}
          orange
        {%- elif background_color > 10 -%}
          deep-orange
        {%- else -%}
          red
        {%- endif -%}-color);
        content: "{{ states(config.entity) }}";
        position: absolute;
        display: flex;
        border-radius: 50%;
        top: 5px;
        right: -1px;
        width: 26px;
        height: 26px;
        font-size: 15px;
Something to go with my Mushroom Welcome Card, a Mushroom Person Pop-up.
Mushroom Person Pop-up Card:
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: person.rhys
    content_info: none
    use_entity_picture: true
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: Rhys
          content:
            type: vertical-stack
            cards:
              - type: custom:mushroom-entity-card
                entity: person.rhys
                layout: horizontal
                icon_type: entity-picture
                primary_info: state
                secondary_info: last-changed
                tap_action:
                  action: none
                hold_action:
                  action: none
                card_mod:
                  style:
                    mushroom-shape-avatar$: |
                      .picture {
                        /* Style shadow ring around person avatar */
                        box-shadow: 0px 0px 4px 2px var(--state-person);
                        margin-right: var(--mush-title-spacing, 12px);
                      ha-card {
                        /* Remove default card styling */
                        --ha-card-background: none;
                        box-shadow: none;
                        --ha-card-border-width: 0;
                        /* Increase icon size */
                        --icon-size: 72px;
                        /* Center card */
                        margin: auto;
                        width: fit-content;
                        /* Add padding to bottom of card */
                        padding: 0px 0px var(--mush-title-spacing, 12px) 0px !important;
                        /* Make card non-responsive to select and pointer */
                        user-select: none;
                        pointer-events: none;
                        transition: all 0s;
                      :host {
                        /* Define Person State colors. Can be added to theme */
                        --state-person-home: var(--green-color);
                        --state-person-not-home: var(--red-color);
                        --state-person-zone: var(--blue-color);
                        --state-person-unknown: var(--grey-color);
                        /* Set Person State color */
                        --state-person:
                        {% if is_state(config.entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entity) | replace('_', '-') }})
                        {% else %}
                          var(--state-person-zone)
                        {% endif %};
                        /* Match styling to Mushroom Title */
                        --mush-card-primary-font-size: var(--mush-title-font-size, 24px);
                        --mush-card-primary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-primary-line-height: var(--ush-title-line-height, 1.2);
                        --mush-card-secondary-font-size: var(--mush-title-font-size, 16px);
                        --mush-card-secondary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-secondary-line-height: var(--ush-title-line-height, 1.2);
              - type: history-graph
                entities:
                  - entity: person.rhys
                hours_to_show: 24
                title: Timeline
                card_mod:
                  style:
                      .card-header {
                        /* Style timeline title */
                        padding: 0px 24px !important;
                        font-size: var(--mush-card-primary-font-size, 14px) !important;
                        font-weight: var(--mush-card-primary-font-weight, bold) !important;
                        line-height: var(--mush-card-primary-line-height, 1.5) !important;
                        color: var(--primary-text-color) !important;
                      ha-card {
                        --ha-card-box-shadow: none;
                        user-select: none;
                      .content {
                        /* Add padding on right */
                # Hide if distance to home is 0.
              - type: horizontal-stack
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.rhys_travel_time_to_home
                        state_not: '0'
                    card:
                      primary: >-
                        {{ states(entity) }} {{ state_attr(entity,
                        'unit_of_measurement') }}
                      secondary: >-
                        {{ state_attr(entity, 'distance') | round(1) }}
                        km
                      icon: mdi:map-marker-path
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                            .primary:after {
                              /* Add destination details */
                              content: "\Ato Home";
                              white-space: pre;
                              text-overflow: ellipsis;
                            ha-card {
                              /* Center card on row */
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                # Hide if distance to work is 0.
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.rhys_travel_time_to_work
                        state_not: '0'
                    card:
                      primary: >-
                      secondary: >-
                        km
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                            .primary:after {
                              content: "\Ato Work";
                              white-space: pre;
                            ha-card {
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                    primary: '{{ states(entity) }}%'
                    secondary: >
                      {{ 'charging' if
                      is_state('binary_sensor.rhys_phone_is_charging',
                      'on' ) else 'discharging' }}
                    icon: >
                      {% set battery_level = (states(entity) | int / 10)
                      | round(0) | int * 10 %}
                      {% if battery_level == 100 %}
                        mdi:battery
                      {% elif battery_level > 0 %}
                        mdi:battery-{{ battery_level }}
                      {% else %}
                        mdi:battery-alert-variant-outline
                      {% endif %}
                    icon_color: |-
                      {% set battery_level = states(entity) | int %}
                      {% if battery_level > 90 %}
                        green
                      {% elif battery_level > 60 %}
                        light-green
                      {% elif battery_level > 50 %}
                        lime
                      {% elif battery_level > 40 %}
                        yellow
                      {% elif battery_level > 30 %}
                        amber
                      {% elif battery_level > 20 %}
                        orange
                      {% elif battery_level > 10 %}
                        deep-orange
                      {% else %}
                        red
                      {% endif %}
                    entity: sensor.rhys_phone_battery_level
                    layout: vertical
                    badge_icon: >-
                      {% if
                      'on') %}
                        mdi:lightning-bolt
                      {% elif states(entity) | int < 10 %}
                        mdi:exclamation-thick
                      {% endif %}
                    badge_color: >-
                      {{ 'red' if states(entity) | int < 10 else
                      'light-blue' }}
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                    double_tap_action:
                      action: none
                    card_mod:
                      style:
                          .shape {
                            /* Radial progress bar */
                            background: radial-gradient(var(--card-background-color) 60%,
                                                        transparent calc(60% + 1px)),
                                        conic-gradient(var(--icon-color) {{ states(config.entity) }}% 0%,
                                                        var(--card-background-color) 0% 100%);
                          .shape:after {
                            /* Add back icon shape */
                            content: "";
                            height: 100%;
                            width: 100%;
                            position: absolute;
                            border-radius: var(--icon-border-radius);
                            background: var(--shape-color);
                          ha-icon {
                            /* Icon charging animation */
                            {{ '--icon-animation: charge 3s linear infinite;' if is_state('binary_sensor.rhys_phone_is_charging', 'on') }}
                          @keyframes charge {
                            0%, 80% { clip-path: inset(0 0 0 0); }
                            10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
                            20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
                            30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
                            40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
                            50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
                            60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
                            70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
                    # Hide if not connected to WiFi.
                  - type: conditional
                    conditions:
                      - entity: sensor.rhys_phone_wifi_connection
                        state_not: <not connected>
                    card:
                      primary: >-
                        {{ states('sensor.rhys_phone_wifi_connection')
                      secondary: >-
                        {% set signal_level = states(entity) | int %} {%
                        if signal_level != -1 %}
                          {{ signal_level }} dBm
                        {% endif %}
                      icon: >-
                        {% set signal_level = states(entity) | int | abs
                        %} {% if signal_level > 90 %}
                          mdi:wifi-strength-outline
                        {% elif signal_level > 80 %}
                          mdi:wifi-strength-1
                        {% elif signal_level > 70 %}
                          mdi:wifi-strength-2
                        {% elif signal_level > 60 %}
                          mdi:wifi-strength-3
                        {% elif signal_level > 1 %}
                          mdi:wifi-strength-4
                        {% else %}
                          mdi:wifi-strength-off
                        {% endif %}
                      entity: sensor.rhys_phone_wifi_signal_strength
                      layout: vertical
                      fill_container: false
                      icon_color: cyan
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style: |
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
              - type: custom:mushroom-chips-card
                chips:
                  - type: template
                    tap_action:
                      action: none;
                    hold_action:
                      service: notify.mobile_app_rhys_phone
                        message: Ringing phone...
                        title: Find Phone
                          ttl: 0
                          importance: high
                          priority: high
                          tag: Find
                          channel: alarm_stream
                    icon: mdi:target
                    icon_color: red
                    content: Find Phone
                alignment: center
                card_mod:
                  style: |
                    ha-card {
                      /* Style Chip like Mushroom button */
                      --chip-background: rgba(var(--rgb-red), 0.2);
                      --chip-border-radius: var(--mush-control-border-radius, 12px);
                      --chip-height: var(--mush-control-height, 42px);
                      --chip-box-shadow: none;
                      user-select: none;
                    ha-card:active {
                      /* Add effect to give feedback on button press */
                      --chip-background: rgba(var(--rgb-red), 0.4);
              - type: map
                entities:
                dark_mode: false
                hours_to_show: 24
                aspect_ratio: '4:3'
                card_mod:
                  style:
                    ha-map $ ha-entity-marker $: |
                      .marker {
                        /* Style person marker & adjust position to avoid blocking waypoints */
                        border: 3px solid var(--state-person) !important;
                        border-radius: 50% 50% 50% 0px !important;
                        transform: rotate(-45deg) translate(50%, -50%);
                        overflow: visible !important;
                        background: var(--state-person) !important;
                      .entity-picture {
                        /* Correct orientation of person avatar */
                        transform: rotate(45deg);
                        border-radius: 50%;
                    ha-map $: |
                      path:first-child {
                        /* Style accuracy radius */
                        stroke: var(--state-person);
                        fill: color-mix(in srgb, var(--state-person) 50%, transparent);
                        stroke-width: 0px;
                      path:nth-child(even) {
                        /* Styling for waypoints */
                        stroke: var(--purple-color);
                        stroke-width: 4px;
                      path:nth-child(odd):not(:first-child) {
                        /* Styling for lines */
                        stroke-width: 4px;
                      .leaflet-control-attribution {
                        /* Style attribution text */
                        background: rgba(var(--rgb-card-background-color), 0.4) !important;
                        font-size: 10px;
                      .leaflet-container a {
                        /* Set color of zoom icons & attribution text */
                        color: var(--secondary-text-color);
                      .leaflet-control-zoom-in,
                      .leaflet-control-zoom-out {
                        /* Style zoom buttons like Chips */
                        border-radius: var(--mush-chip-border-radius, 19px) !important;
                        padding: 3px;
                        background: rgb(var(--rgb-secondary-text-color), 0.2) !important;
                        margin: 8px 12px 0px;
                        border: var(--ha-card-border-width, 1px) solid var(--ha-card-border-color, var(--divider-color, #e0e0e0)) !important;
                      .leaflet-top {
                        /* Move zoom buttons to bottom of map */
                        bottom: 0px !important;
                      .leaflet-control-zoom {
                        /* Allow buttons to be moved */
                        position: absolute !important;
                        /* Adjust spacing for border */
                        bottom: calc(2 * var(--ha-card-border-width, 1px) + 56px);
                        /* Remove extra margin */
                        margin: 0px !important;
                        /* Remove zoom control border */
                        border: none !important;
                      .leaflet-container:after {
                        /* Fade out map at top */
                        content: "";
                        position: absolute;
                        height: 100%;
                        width: 100%;
                        background: linear-gradient(to top, transparent 65%, var(--card-background-color));
                    ha-icon-button $ mwc-icon-button $: |
                      button {
                        /* Size center button to match Chip */
                        height: var(--mush-chip-height, 36px) !important;
                        width: var(--mush-chip-height, 36px) !important;
                        --mdc-icon-size: 22px;
                      ha-card {
                        /* Remove default card styling without affecting child elements */
                        box-shadow: none;
                        border-width: 0;
                        border-radius: 0px 0px var(--ha-card-border-radius, 12px) var(--ha-card-border-radius, 12px);
                        transition: all 0s;
                      :host {
                        /* Set person state color */
                        --state-person:
                        {% if is_state(config.entities[0].entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entities[0].entity) | replace('_', '-') }})
                        {% else %}
                        {% endif %};
                      ha-icon-button {
                        /* Position center button */
                        bottom: 12px;
                        left: 12px !important;
                        top: auto !important;
                        /* Style center button to match Chip */
                        color: var(--deep-orange-color) !important;
                        background: color-mix(in srgb, var(--deep-orange-color) 20%, transparent);
                        border-radius: var(--mush-chip-border-radius, 19px);
          card_mod:
            style: |
              :host {
                /* Remove border from poup */
                --popup-padding-x: 0px;
                --popup-padding-y: 0px;
                --popup-min-width: 450px;
              .content {
                /* Remove extra bottom border */
                margin: -18px -24px -24px !important;
    card_mod:
      style: |
        /* Color border around avatar to show person status */
        ha-card {
          --chip-background:
            rgb(var(--rgb-state-person-{{ states(config.entity) | replace('_', '-') }} ))
          {% else %}
            rgb(var(--rgb-state-person-zone))
          {% endif %};
        /* Slightly enlarge & bring to front on hover */
        ha-card:hover {
          transform: scale(1.2);
          transform-origin: top center;
          z-index: 1;
          transition: all 1s;
wow that looks fantastic! I have person cards on my dash, so I will try and use your code. Keep up the great work you do. – thank you
thanks for your reply, I am only just getting started and I do just copy other peoples code.
at what point in my code should I copy it too? I have tried using it next to the icon: field, that didnt work, Does it require its own line with a prefix before? Any other help you are able to give would be appeciated.
edit . after the | you have “iif” is this correct or should it be “if”
It goes into the icon: field where you currently have mdi:lock. You’ll need to put it in quotes or paste it in the Visual Editor and it will do that for you.
iif is an alternate way of doing an if statement.
