Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Thanks @rhysb! Ill give it a try!
did you ever found a solution ?
I have similer problems
@rhysb Hmmm, i modified the code to suit my need but doesnā€™t seem to be working.
What have I dont wrong?
type: custom:mushroom-number-card
entity: number.target_climate_temperature
card_mod:
  style:
    mushroom-state-info$: |
      .secondary:after {
        content: " ";
      ha-card {
        {% set value = states(config.entity) | int %}
        --rgb-state-number: var(--rgb-
        {%- if value < 20.0 -%}
          blue
        {%- elif value > 21.0 -%}
          red
        {%- else -%}
          grey
        {%- endif -%});
Could it be the decimals? The entity moves in 0.5 degree steps.
Update: Definitaly the decimals. If i remove the 0 after the decimal from one or the other value it works only for that one.
I am stumped! The output value from what I see is in Ā°C. If i put the degree symbol in after the value, then its blue regardless of what I set.
      ha-card {
        {%- if value < 20 Ā°C -%}
          blue
        {%- elif value > 21 Ā°C -%}
          red
        {%- else -%}
          grey
        {%- endif -%});
You would need to use | float instead of | int. You canā€™t include the unit in the comparison.
Try something like this:
card_mod:
  style:
      .secondary:after {
        content: " Ā°C";
      ha-card {
        {% set value = states(config.entity) | float %}
          blue
          red
        {%- else -%}
          grey
        {%- endif -%});
@rhysb Ok have tried that. had to make some modifications but it works now.
      ha-card {
        {%- if value <= 20.0 -%}
          blue
        {%- elif value >= 20.5 -%}
          red
        {%- else -%}
          grey
        {%- endif -%});
Needed the equal signs too. Thanks!!!
I havenā€™t @Michael_Dahl ā€¦
Seems the issue also happens if I use a variant that doesnā€™t introduce the variables and just uses classic if, else etcā€¦
@rhysb, could you possibly shed some light on this?
@Michael_Dahl I was just messing about and I think this solved it:
{% if (is_state('light.living', 'on')) and (is_state('switch.shellypluglivingmultimedia', 'on'))  %}
    green
{% elif is_state('light.living', 'on')   %}
    orange
{% elif is_state('switch.shellypluglivingmultimedia', 'on')   %}
    blue
{% endif %}
So itā€™s more ā€˜sequentialā€™ if you wish.
Just rebooted HA (because of the 2023.4.2 update) and seems all is well now.
how to set the battery icon before the charge level?
secondary: ICON BATTARY ā€˜{{ state_attr(entity, ā€œbatteryā€) }}%ā€™
type: custom:mushroom-template-card
primary: |-
  {% if is_state(entity, 'on') %}
  open
  {% else %}
  close
  {% endif %}
secondary: '{{ state_attr(entity, "battery") }}%'
icon: |-
  mdi:window-open-variant
  {% else %}
  mdi:window-closed-variant
  {% endif %}
entity: binary_sensor.okno_spalnia_contact
layout: vertical
icon_color: |-
  red
  {% else %}
  green
  {% endif %}
Perfect thank you :smiling_face_with_three_hearts:
Start with the hvac_modes buttons would have fit the cover, but unfortunately thatā€™s how it is.
One more question, can I change the icon for auto mode, if so how?
type: custom:mushroom-climate-card
entity: climate.heizung_detlef
primary_info: state
secondary_info: last-updated
hvac_modes:
  - 'off'
  - heat
  - auto
show_temperature_control: true
tap_action:
  action: none
hold_action:
  action: more-info
double_tap_action:
  action: none
card_mod:
  style:
      .primary:after {
        content: " | {{ states('sensor.wandthermostat_detlef_humidity') | round(0) }} %";
      mushroom-climate-hvac-modes-control {
        transform: scalex(-1);
Hi, Iā€™m new to Mushroom, and am really liking it! Itā€™s so polished and feels so professional.
I was wonderingā€¦ is there a thread or a site where I can view nice custom cards? Like what is available on the Minimalist website. Itā€™s nice to go to a central location and see effectively a gallery of whatā€™s possible.
Otherwise, as far as Iā€™m aware, the only option is to browse through all 6,000 posts in this thread, which would take a very long time, but also be difficult for maintenance purposes as there are no repos that get updated, etc.
If anyone can point me in the right direction, Iā€™d be really grateful! Thanks!
Take a look here : Mushroom Inspiration
Oh yes! Thank you! :pray:
I have a problem.
I click on lightsā€“> parterā€“>back and I canā€™t get to the previous window. I tried several options but I still didnā€™t succeed!
primary: ''
secondary: Lights
icon: mdi:lightbulb-group
icon_color: orange
layout: vertical
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      title: Camere
      content:
        type: vertical-stack
        cards:
          - square: false
            columns: 3
            type: grid
            cards:
                primary: ''
                secondary: Parter
                icon_color: orange
                layout: vertical
                tap_action:
                  browser_mod:
                      title: Parter
                      content:
                        cards:
                          - square: false
                            columns: 2
                            type: grid
                            cards:
                                primary: Back
                                icon: mdi:arrow-left
                                tap_action:
                                  browser_mod:
                                    service: navigate
                                      navigation_path: back
                                      popup: true
                                card_mod: null
                                style: |
                                  ha-card {
                                    width: 140px;
                                    margin-left: auto;
                                    margin-right: auto;
                                    background: rgba(var(--rgb-green), 0.1);
                                    margin-bottom: 12px !important;
card_mod:
  style: |
    ha-card {
      background: rgba(var(--rgb-primary-text-color), 0.025);
      width: 66px;
      border-radius: 30px;
      margin-left: auto;
      margin-right: auto;
      margin-top: 4px;
      margin-bottom: -10px;
@rhysb I have another one for you that maybe you can help. Its based on an animated icon changing based on state.
So I was looking at your animation examples (all are amazing!) and came across an animation I would like to use; your Battery 2 animation.
icon: mdi:battery-high
icon_color: green
primary: 'Battery #2'
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        --icon-animation: charge 3s steps(1) infinite;
      @keyframes charge {
        0% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
        20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
        40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
        60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
So I have a template card with the following set up for my EVā€™s charge state.
secondary: Status
icon: |
  {% set state=states(entity) %}
  {% if state =='readyForCharging' %}
  mdi:ev-station
  {% elif state =='charging' %}
  mdi:battery-alert
  {% elif state =='notReadyForCharging' %}
  mdi:battery-alert
  {% else %}
  mdi:battery-high
  {% endif %}
icon_color: |-
  {% set state = states(entity) %}
  green
  green
  red
  {% else %}
  grey
  {% endif %}
entity: sensor.charging_state
tap_action:
  action: none
hold_action:
  action: none
double_tap_action:
  action: none
primary: |2-
   {% set d ={
    'readyForCharging': 'Ready to Charge',
    'charging': 'Charging',
    'notReadyForChargin': 'Not Ready'
    {{ d.get(states(entity)) }}
How would I incorporate the animation for lets say for charging state? I will attempt to do others once you show me
Looking for some inspiration here.
Has anybody tackled making a card to control a smart oven?
Currently using simple-thermostat with some button cards and wellā€¦ as you can see, itā€™s ugly! LOL
Looking for ideas to mushroomize this!
Hi folks!
Iā€™m not going to lie. Iā€™m a complete newbie/novice and I donā€™t really know what Iā€™m doing when it comes to code or even home assistant etc. But Iā€™m trying to learn.
Iā€™ve got a question. Iā€™m trying to create a new mobile friendly dashboard using Mushroom. Iā€™m using a template card to make a nice little welcome message.
Thanks to the helpful resources online Iā€™ve managed to find a templace code to put the day and date on the secondary information line. However, I was wondering if there was a way to change the format?
Currently itā€™s set out for example ā€œToday is Monday, 2023-04-09ā€. However Iā€™d like to if possible have it say ā€œMonday 9th April 2023ā€.
Hereā€™s the code I currently have.
{% set time = now().weekday() %}
{% if (time >= 0) %}
Today is Monday, {{ now().date()}}
{% elif (time >= 1) %}
Today is Tuesday, {{ now().date()}}
{% elif (time >= 2) %}
Today is Wednesday, {{ now().date()}}
{% elif (time >= 3) %}
Today is Thursday, {{ now().date()}}
{% elif (time >= 4) %}
Today is Friday, {{ now().date()}}
{% elif (time >= 5) %}
Today is Saturday, {{ now().date()}}
{% elif (time >= 6) %}
Today is Sunday, {{ now().date()}}
{% else %}
Today is fudged....
{% endif %}
Does anyone know if thereā€™s a change to this code that I can make or does anyone know how to code the format I want?
All help is greatly appreciated and apologies for being such a noob.
EDIT: Just noticed itā€™s showing as Mondayā€¦ Uhoh!
thank you for such quick respondā€¦
iā€™ve created script as you replied and put yaml cpde for reminder but it failed to work,
Screenshot 2023-04-10 015233
icon: mdi:timer
primary: Days to Reminder
icon_color: grey
secondary: >-
  {{ (states(entity) | as_datetime | as_local - now()).days + 1 }}
  days
hold_action:
  action: call-service
  service: script.reset_reminder
  data: {}
  target: {}
entity: input_datetime.reminder_date
card_mod:
  style:
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-blue)) {{ ((states(config.entity) | as_datetime | as_local - now()).days + 1) / 30 * 100 }}% 0%, var(--card-background-color) 0% 100%);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
        background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
Screenshot 2023-04-10 015538
Kiosk-Mode 1.8.2 is out now and fixes the issue. If you still have problems make sure to clear your browser cache.
Have you created the input_datetime.reminder_date helper?
unfortunately, no :sweat_smile:
