Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Anyway to use the Media player card with entity-filter?
did you solved it?
I have the same problem just with bond.
I made a shell command which i want to connect to the oscillating button.
Post your full card so we can see what you are doing.
Yes, you can do so like this.
Mushroom Opaque Shape
Mushroom Opaque Shape - Light
Mushroom Opaque Shape - Dark
type: custom:mushroom-template-card
primary: Mushroom
icon: mdi:mushroom
icon_color: red
card_mod:
  style: |
    ha-card {
      --ha-card-background: rgba(var(--rgb-card-background-color), 0.8) url('/local/mushroom.png') center / cover;
      background-blend-mode: saturation;
    mushroom-shape-icon {
      --shape-color: color-mix(in srgb, var(--icon-color) 20%, var(--card-background-color)) !important;
This replaces the current rgba(var(--rgb-[color]), 0.2) with color-mix(in srgb, var(--icon-color) 20%, var(--card-background-color)). color-mix is a very new CSS command and while it is supported by Chrome & Edge, it may not be supported by other browsers yet.
Button Card seems to handle the @keyframes weirdly. They only seem to work when applied to the first card and require a page refresh. Perhaps it’s how extra_styles are handled :thinking:.
Apart from that there are a few issues. --shape-color only exists for Mushroom Cards. You can’t use the HEX color, --color-blue, with rgba(). Lastly, img_cell is empty.
Here is a working example for you. It needs to be the first button-card on the page.
Button Card Animation
type: custom:button-card
icon: mdi:motion-sensor
styles:
  img_cell:
    - animation: motion 1s infinite
    - background-color: color-mix(in srgb, var(--blue-color) 20%, transparent)
    - height: 42px
    - width: 42px
    - border-radius: 50%
  icon:
    - animation: clip 2s linear infinite
    - color: var(--blue-color)
    - height: 21px
    - width: 21px
extra_styles: |
  @keyframes clip {
    50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
  @keyframes motion {
    0%, 100% { background-color: color-mix(in srgb, var(--blue-color) 20%, transparent) }
    50% { background-color: color-mix(in srgb, var(--blue-color) 30%, transparent) }
BTW, I’m not really an expert on button-card, I’ve only used it for this and my previous example to you :wink:.
Today is {{ now().strftime('%A, %-d %B %Y') }}
@rhysb how do I reduce the space between chip icon and text
You can adjust the spacing between the Chip Icon and Content like this:
type: custom:mushroom-chips-card
chips:
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 1 Cookie
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 2 Cookies
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 3 Cookies
card_mod:
  style:
    mushroom-template-chip:
        ha-icon {
          margin-right: 20px;
If you would like to do it for a specific Chip you can so like this:
chips:
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 1 Cookie
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 2 Cookies
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: 3 Cookies
card_mod:
  style:
    mushroom-template-chip:nth-child(3)$: |
        ha-icon {
          margin-right: 20px;
Hey, @rhysb cheers. CSS is not my strong suite, but how do I add this to my existing card_mod Styling?
type: custom:stack-in-card
cards:
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: weather
            entity: weather.bells_creek
            show_conditions: true
            show_temperature: true
          - type: template
            entity: sensor.solarnet_power_grid
            content: '{{ states(''sensor.solarnet_power_grid'', with_unit=True) }}'
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
            icon: mdi:swap-horizontal-circle
            icon_color: |-
              {% set state=states('sensor.solarnet_power_grid') %}
              {% if is_number(state) and state | float <= 0 %}
              green
              {% elif is_number(state) and state | float >= 0 %}
              red
              {% endif %}
          - type: template
            entity: sensor.symo_10_0_3_m_1_power_ac
            content: |-
              {% set state=states('sensor.symo_10_0_3_m_1_power_ac') %}
              {{ states('sensor.symo_10_0_3_m_1_power_ac', with_unit=True) }}
              {% elif state=='unavailable' %}
              Offline
              {% endif %}
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
            icon: mdi:gauge
            icon_color: |-
              {% if is_number(state) and state | float >= 0 %}
              green
              {% elif is_number(state) and state | float <= 0 %}
              red
              red
              {% endif %}
          - type: template
            entity: sensor.solarnet_power_load
            content: '{{ states(''sensor.solarnet_power_load'', with_unit=True) }}'
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
            icon: mdi:home-lightning-bolt
            icon_color: red
          - type: template
            entity: sensor.house_downstairs_average_humidity
            content: >-
              {{ states('sensor.house_downstairs_average_humidity',
              with_unit=True) }}
            icon: mdi:water-percent
            icon_color: green
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
          - type: template
            entity: sensor.house_downstairs_average_temperature
            content: >-
              {{ states('sensor.house_downstairs_average_temperature',
              with_unit=True) }}
            icon: mdi:thermometer
            icon_color: blue
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
        card_mod:
          style: |
            ha-card {
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-spacing: px;
    card_mod:
      style: |
        ha-card {
          background-size: cover;
          background-color: rgba(243, 243, 243, 0.9);
          height: 40px;
          margin: 5px;
          padding:1px;
Try like this:
card_mod:
  style:
    .chip-container>*:
        ha-icon {
          margin-right: 20px;
      ha-card {
        --chip-spacing: 0px;
That works! thank you
Thanks that works brilliant! Have you any idea why this one is not working?
icon: mdi:garage
name: Animation Garage Test
styles:
  img_cell:
    - height: 42px
    - width: 42px
  icon:
    - animation: door 3s steps(1) infinite alternate
    - height: 21px
    - width: 21px
extra_Styles: |
  @keyframes door {
    0% { clip-path: inset(0 0 0 0); }
    25%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 73%, 32% 73%, 31% 100%, 0 100%); }
    50%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 61%, 32% 61%, 31% 100%, 0 100%); }
    75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 48%, 32% 48%, 31% 100%, 0 100%); }
Note: Found something interesting to keep using card_mod for animations with a custom:button-card. Will dm you some examples but all have one same issue that the animation is part of the img_cell so the animation starts outside the icon.
Is it possible to use mdi icons in primary/secondary field of a template card?
thank you :smiley:
I prefer BJK :slight_smile:
is it possible always have the lower part of the roomcard button, and not only when an entity is active ?
@rhysb maybe you got a solution for this, since i can´t get it working:
since i´m using a bottom-navigation-bar on my mobile (iOS using HA-App) and the back-arrow of a sub-view looks a little bit off (see screenshot) i´d like to move it a little bit up
with chrome i inspected the page and found .mdi-icon-button so i added padding-bottom: 20px, this actually moves the arrow up in chrome
so i tried and added this to my theme file but that doesn´t work in the mobile app.
      .mdc-icon-button {
        padding-bottom: 10px;
moving the main-title however works
      .main-title {
For Minimalist you are more likely to get a good answer over in the Minimalist UI thread. However you should be able to remove the border lines by adding ha-card-border-width: 0px to your theme. If you use the Minimalist Themes then it should already be added.
As I noted with button-card you need to add the @keyframes to the first button on a page. Additionally the icon would need to be correctly sized and centered.
First button:
styles:
  img_cell:
    - height: 42px
    - width: 42px
  icon:
    - height: 21px
    - width: 21px
extra_styles: |
  @keyframes clip {
  @keyframes motion {
  @keyframes boing {
    0% { transform: scale3d(1, 1, 1); }
    7% { transform: scale3d(0.75, 1.25, 1); }
    10% { transform: scale3d(1.25, 0.75, 1); }
    12% { transform: scale3d(0.85, 1.15, 1); }
    16% { transform: scale3d(1.05, 0.95, 1); }
    19% { transform: scale3d(0.95, 1.05, 1); }
    25% { transform: scale3d(1, 1, 1); }
  @keyframes door {
Subsequent button:
icon: mdi:garage
styles:
  img_cell:
    - height: 42px
    - width: 42px
  icon:
    - height: 21px
    - width: 21px
    - display: flex
Not sure I understand what you are asking :thinking:.
