Love this!!
or ā¦ maybe itās just default ālightā color you see ā¦ try change orange to āredā ā¦ you might find that nothing works
so try to look for card-mod , to make your desired effect ( there are bunch of similar card-mod here in this topic, so itā shouldnāt be hard to find) ā¦ EDIT: card-mod is not ideal for this(simple light switch) color wont change, unless/untill you refresh page, or it refresh it self
PS: and skip the icon_color: , or use mushroom-template-card
Hi rhysb,
Do you have blueprint of thisā¦ this is amazing for phoneā¦ ilike it so much
I have created a ultra lite version of my modern dashboard. The main difference of this card from the previous one is this time I havenāt used any booleans. Just copy and paste the code and start to use it.
Page Properties:
- One single page for your home.
- Wonderful colors.
- Ambilight effect on everywhere.
- Glowing lights all around the page, dynamic to the state of the devices.
- Hidden sections through Swipe Card.
- Last motion detected room is shown with art effected pictures
- Advanced light control card.
- Exclusive person card (Thanks to Rhysb).
- Animated design.
- Live dynamic cards.
- Live Android Tv control card with remote control. See what is on your TV screen.
- Full page display thanks to Kiosk Mode.
- Netflix Card (Start shows on your Android Tv from your Dashboard)
- What to wear suggestions (with pictures) for your home depending on house temperature.
- Animated weather card.
- Easy calendar and camera access.
- Live birthday Card with pictures.
- Animated Spotify control.
- Control all your Media Players
- Room cards.
- Light control based on room presence. Close all house lights expect the room you are in.
- Multimedia files are included. I have also added additional multimedia files for you to customise your screen.
My other work :
Screenshots:
Thanks for pointing out the template type. I looked at it 100 times and did not see it.
Fixed it and now it works
Thanks for your help, I managed to create these based on your original card!
Here is the code if anyone wants to use it (or maybe help improve it ):
type: grid
square: false
cards:
secondary: >-
{{ states(config.entity) | replace('_only', '') | replace('_', '/') |
title }}
icon: none
entity: climate.3family_room
layout: vertical
icon_color: ''
tap_action:
action: more-info
card_mod:
style:
mushroom-shape-icon$: |
.shape:after {
content: "{{ state_attr(config.entity, 'current_temperature') | round(0) }}Ā°";
position: absolute;
font-size: var(--card-primary-font-size);
font-weight: bolder;
{% set status = state_attr('climate.3family_room','hvac_action')
{% if status == 'off' %}
color: grey
{% elif status == 'cooling' %}
color: blue
{% elif status == 'heating' %}
color: red
{% else %}
color: grey
{% endif %}
.shape {
box-shadow: var(--ha-card-box-shadow) !important;
ha-card {
--ha-card-background: none;
box-shadow: none;
--ha-card-border-width: 0;
mushroom-shape-icon {
--shape-color: white !important;
secondary: >-
{% if is_state("lock.front_door", "unlocked")
Door Unlocked
{% else %}
Door Locked
{% endif %}
icon: >-
mdi:lock-open
{% else %}
mdi:lock
{% endif %}
entity: lock.front_door
layout: vertical
icon_color: >-
red
{% else %}
green
{% endif %}
tap_action:
action: more-info
card_mod:
style:
.shape:after {
position: absolute;
.shape {
ha-card {
box-shadow: none;
secondary: |-
{{ states(config.entity) }}
Persons Home
icon: mdi:account-supervisor-circle
entity: zone.home
layout: vertical
icon_color: orange
primary: ''
tap_action:
action: more-info
card_mod:
style:
.shape:after {
position: absolute;
.shape {
ha-card {
box-shadow: none;
secondary: |-
Lights On
icon: hue:bulb-group-classic-3-alt
entity: sensor.current_lights_on
layout: vertical
icon_color: orange
tap_action:
action: more-info
card_mod:
style:
.shape:after {
position: absolute;
.shape {
ha-card {
box-shadow: none;
columns: 4
iāve been there my self, chips light, chip template etc. , they are somehow more limited, so eventually i also ended up with modding mushroom-template-card, it has way more options
Working on colourizing the tile card and am having a hard time using var(ātile-color) as a background colour for the tile, is it possible to convert the hex colour it uses to rgb or even just reduce the opacity when using the hex? Trying to use the tile color variable for entities that have dynamic color icons like battery entities or the alarm tile.
Hereās an example using set background colours, would like to use the tile color variable to simplify card-mod code.
Summary
type: tile
entity: sensor.andrews_iphone_battery_level
card_mod:
style:
ha-tile-info$: |
.secondary {
opacity: 80%;
ha-card {
--primary-text-color: var(--tile-color);
{% if states(config.entity)|int < 30 %}
background: rgba(var(--mush-rgb-red),0.1);
{% elif states(config.entity)|int < 70 %}
background: rgba(var(--mush-rgb-orange),0.1);
{% elif states(config.entity)|int <= 100 %}
background: rgba(var(--mush-rgb-green),0.1);
{% endif %}
hello thanks for checking this & where should i add this exactly canāt find where to put this?
@rhysb Sorry to bother you with this but I have no idea how to fix this. Is it possible to only change the app-header-background-color for one page view. I know it can be done inside a themes file but this affects the whole UI. The goal is to make the header color the same as my Welcome card but I prefer to have the header color the same as my primary-background-color on all other page views and pop-ups. Thanks in advance for any help.
mushroom-conditional-chip {
height: var(--chip-height);
padding: 8px;
This code worked, but it was causing a change in gap between the adjacent chips.
So i modified it to
padding-bottom: 8px;
mushroom-conditional-chip:first-child {
padding-left: 8px;
Now it works perfectlyā¦
Except at some times, the chips just run away a little apart (vertically) and becomes ok when the page is refreshed. Donāt know why it happensā¦ anywayā¦ the requirement is doneā¦
try this
card_mod:
style: |
.tile {
{% if states(config.entity)|float(0) > 26 %}
--tile-color: var(--rgb-red-color);
{% elif states(config.entity)|float(0) > 21 %}
--tile-color: var(--rgb-green-color);
{% else %}
--tile-color: var(--rgb-blue-color);
{% endif %}
Fan switch with Timer option
I am trying to create a fan switch which has an option to set a toggle timer directly from the button itself. I already created the scripts and everything is working ok. Now i am trying to implement it onto a single button.
I am trying to achieve something like this
the right side button is the toggle timer script & the left one is the direct on-off switch. This layout was inspired from this lock card here
https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/2412
i adjusted the margins, padding etc as per the desktop, but when it comes to a mobiles screen, its a messā¦ So i am trying to recreate the same with a layout card instead of the grid card used in the exampleā¦because the layout card column widths are more well defined. and no need to use negative margin values to adjust elements
this is the furthermost i could reach.
please excuse the colors. ā¦ i was trying to identify each element while applying card mod styling.
this is the code
Fan On-Off-Toggle-Timer Card
type: custom:stack-in-card
mode: horizontal
cards:
entity: switch.gf_br01_fan1
primary: Bedroom Fan
secondary: |
{% if is_state(entity,'on') %}
ON
{% else %}
OFF
{% endif%}
icon: mdi:fan
icon_color: |
green
{% else %}
red
{% endif%}
tap_action:
action: toggle
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 65% 35%
cards:
- type: custom:mushroom-number-card
entity: input_number.gf_br01_fan01_toggle_duration
display_mode: buttons
layout: horizontal
icon_type: none
secondary_info: none
primary_info: none
- type: custom:mushroom-entity-card
primary_info: none
layout: horizontal
tap_action:
action: toggle
entity: script.gf_br01_fan01_toggle_script
icon: mdi:power
icon_color: green
card_mod:
style:
hui-horizontal-stack-card$:
mushroom-template-card$: |
ha-card {
border: none;
background: teal !important;
layout-card$:
grid-layout$:
mushroom-number-card$: |
ha-card {
border: none;
padding-left: 0px !important;
padding-right: 0px !important;
background: teal;
:host {
--layout-margin: 0px 4px 0px 4px;
mushroom-entity-card$: |
ha-card {
border: none;
background: yellow;
:host {
border: none;
background: grey;
ha-card {
background: green;
now i am stuck at the last step.
in this Chrome DOM inspector, i need to set the margin values to
margin: var(--masonry-view-card-margin, 0px 4px 0px);
if is add this margin value to the element.style { }
portion just above that in the DOM window, i can ajust each of those elements individually. and i am able to achieve the final result
Like thisā¦
how do i implement this margin value into the yaml codeā¦??.. please help ā¦!!
you can have as many themes you like, it wont affect anything unless you āload itā ā¦ and where you load it ā¦ so copy your existing modify it for that particular View(rename it, and make sure you followed the guide-lines for several views, meaning folder-reference in config.yaml), In the view click the 3 dots, click edit-dashboard, click the ālowerā pencil to the left, choose theme
Hi. I create climate card and i have a problem. Sia any chance to change icons whis i select by RED colorā¦ and also add buttons for preset mode for climate ? I dont see any optionā¦
type: custom:vertical-stack-in-card
cards:
- type: grid
square: false
columns: 2
cards:
primary: '{{state_attr(entity, ''current_temperature'')}} Ā°C'
secondary: Temperatura wody
entity: climate.ciepla_woda
icon: mdi:water-thermometer
icon_color: green
- type: custom:mini-graph-card
entities:
- entity: climate.ciepla_woda
attribute: current_temperature
color: var(--green-color)
hours_to_show: 24
line_width: 3
font_size: 50
animate: false
show:
icon: false
state: false
legend: false
fill: fade
- type: horizontal-stack
cards:
- type: custom:mushroom-climate-card
primary_info: none
icon_type: none
show_temperature_control: true
primary_info: none
icon_type: none
hvac_modes:
- auto
- heat
- 'off'
cards:
- type: grid
square: false
columns: 2
cards:
entity: climate.parter_podlogowka
icon_color: green
entities:
- entity: climate.parter_podlogowka
hours_to_show: 24
line_width: 3
font_size: 50
animate: false
show:
icon: false
state: false
legend: false
fill: fade
cards:
primary_info: none
icon_type: none
primary_info: none
icon_type: none
hvac_modes:
- auto
- heat
- cool
- 'off'
Thatās awesome. Thanks a lot.
Would someone managed to add animation?
Can I change the background color as well as the icon color according to the entity state?
You can color the Tile background like this:
Tile Background Color
Light, switch or other On/Off Entity:
- features:
- type: light-brightness
type: tile
entity: light.office_light
card_mod:
style: |
.background {
{% if is_state(config.entity, 'on') %}
background: color-mix(in srgb, var(--tile-color) 10%, var(--card-background-color));
{% endif %}
Other Entities:
- type: tile
entity: sensor.rhys_phone_battery_level
card_mod:
style: |
.background {
The Tile will automatically change color based on the battery level.
You can style a Mushroom Fan Timer Card like this:
cards:
- type: custom:mushroom-fan-card
entity: fan.bathroom_fan
icon_animation: true
card_mod:
style: |
ha-card {
--ha-card-border-width: 0px;
entity: input_number.bathroom_fan_timer
primary_info: none
icon_type: none
card_mod:
style: |
ha-card {
position: absolute;
top: 0px;
right: 54px;
width: calc(50% - 54px);
entity: script.bathroom_fan_timer
primary_info: none
icon: mdi:power
card_mod:
style: |
ha-card {
position: absolute;
top: 0px;
right: 0px;
width: fit-content;
card_mod:
style: |
ha-card {
{{ '--ha-card-background: color-mix(in srgb, var(--teal-color) 10%, var(--card-background-color));' if is_state('fan.bathroom_fan', 'on') }}
Any of the animations should work.
Thanks for the answer. Tested but doesnāt seems to work, iām using YAML mode so i think thats why itās not working? There seems no way to blend the header with the Welcome Card so it becomes āone cardā but keeping another header color for all other views. Maybe @rhysb have some magic left to fix this?
