Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
one thing Ive noticed ā€¦ change your theme from say mushroom to mushroom shadow and watch your problems disappear
123
321
devi vedere lā€™animazione per i chip
I donā€™t know what to suggest, I pasted your code into my dashboard and it worked fine.
Is your indentation correct? Have you tried pasting the code further up or down your page to see if it shows up?
Iā€™m trying some state-based confirmation in a mushroom template card. Hereā€™s what I have:
type: custom:mushroom-template-card
entity: switch.living_room_table_lamp
tap_action:
  action: toggle
  confirmation:
    text: >-
      {% set state = (states.switch.living_room_table_lamp.state) %} {% if state
      == 'on' %}
        null
      {% else %}
        Are you sure you want to turn on the stove?
      {% endif %}
hold_action:
  action: more-info
primary: Living Room Stove
secondary: >-
  {% set state = (states.switch.living_room_table_lamp.state) %} {% set changed
  = as_timestamp(states.switch.living_room_table_lamp.last_changed) %} {% set
  diff2 = as_timestamp(now()) - changed %} {% if diff2 <= 1 %}
    Just turned {{state}}
  {% elif diff2 <= 59 %}
    Turned {{state}} {{diff2 | round(0) }} seconds ago
  {% elif diff2 <= 3599 and ((diff2/60) | round(0)) == 1 %}
    Turned {{state}} 1 minute ago
  {% elif diff2 <= 3599 %}
    Turned {{state}} {{ (diff2/60) | round(0) }} minutes ago
  {% elif diff2 <= 86399 and ((diff2/3600) | round(0)) == 1 %}
    Turned {{state}} 1 hour ago
  {% elif diff2 <= 86399 %}
    Turned {{state}} {{(diff2/3600) | round(0) }} hours ago
  {% elif diff2 >= 86400 and ((diff2/86400) | round(0)) == 1 %}
    Turned {{state}} 1 day ago
  {% elif diff2 >= 86400 %}
    Turned {{state}} {{(diff2/86400) | round(0) }} days ago
  {% else %}
    Unknown
  {% endif %}
icon: |-
  {% if is_state('switch.living_room_table_lamp', 'on') %}
    mdi:fire
  {% else %}
    mdi:fire-off
  {% endif %}
icon_color: |-
    deep-orange
  {% else %}
    #6f6f6f
  {% endif %}
style: |
  ha-card {
    background-color: rgba(255, 0, 0, 0.24);
  {% else %}
    background-color: rgba(7, 103, 215, 0.24);
  {% endif %}
Just assume all references to ā€œlampā€ mean ā€œstove;ā€ during testing, I donā€™t want the stove going on and off.
What I want is for confirmation to appear only when the stove is off; if the stove is on, I donā€™t need confirmation to shut it off. All of the other state-based stuff is working: icon, color, secondary text, background colorā€¦ however, my confirmation dialog appears with the full text including {% %}, etc.
EDIT: This doesnā€™t work, either:
tap_action:
  action: toggle
  confirmation:
    text: |-
        {% if state == 'off' %}
      {% endif %}
Same issueā€¦ the full text between {% and %} appears in the confirmation box.
I know its possible to split ui-lovelace.yaml and views
But is it possible to split even further?
building a dashboard with one view and going to use a lot of browser_mod.popup
- type: vertical-stack
    cards:
     include! /bla bla bla
or anyone know if its possible to do in browser_mod.popup
data: !include file?
Thanks @SteffenDE,
I used your card example and modified for my purposes:
This is what I have now (bottom card):
Washing Gif
However the drum is flashing and i would like to get it spinning like the top one.
Any ideas on how you can modify the animation?
Here is the code:
type: custom:vertical-stack-in-card
card_mod:
  style: |
    ha-card {
      height: 130px !important;
horizontal: false
cards:
    card_mod:
      style:
        mushroom-shape-icon$: >
          {% if
          is_state('sensor.electrolux_sawa_washing_machine_wm1_appliancestate',
          'Running') %}
            ha-icon {
              --icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
              transform-origin: 50% 110%;
            @keyframes shake {
              0%, 100% { transform: translate(0, 0) rotate(0); }
              20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
              40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
              60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
              80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
            @keyframes drum {
              40%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
          {% endif %}
    entity: sensor.electrolux_sawa_washing_machine_wm1_appliancestate
    layout: horizontal
    multiline_secondary: false
    primary: |2-
       {% set d ={
        'Delayed start': 'Delayed Start',
        'Running': 'Running',
        'Cycle is finished': 'Cycle Ended',
        'Off': 'Off'
        {{ d.get(states(entity)) }}
    secondary: >
      Time to End -
      {{states('sensor.electrolux_sawa_washing_machine_wm1_timetoend')}} Min
      {{states('sensor.electrolux_sawa_washing_machine_wm1_cyclephase')}}
      {{states('sensor.electrolux_sawa_washing_machine_wm1_cyclesubphase')}}
    icon: >-
      {% if
      'Running') %}
        mdi:washing-machine
      {% elif
      'Cycle is finished') %}
        mdi:washing-machine-alert
      {% else %}
        mdi:washing-machine
      {% endif %}
    icon_color: >-
      {% set state=states(entity) %}
      {% if state=='Running' %}
      blue
      {% elif state== 'Delayed start' %}
      ornage
      {% elif state== 'Cycle is finished' %}
      purple
      {% else %}
      grey
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
  - type: custom:mushroom-chips-card
    alignment: center
    chips:
      - type: template
        icon: mdi:tshirt-crew-outline
        entity: sensor.electrolux_sawa_washing_machine_wm1_programuid
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: '{{states(''sensor.electrolux_sawa_washing_machine_wm1_programuid'') }} '
      - type: template
        icon: mdi:thermometer
        entity: sensor.electrolux_sawa_washing_machine_wm1_analogtemperature
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
          {{states('sensor.electrolux_sawa_washing_machine_wm1_analogtemperature')
          }}Ā°C
      - type: template
        icon: mdi:alpha-s-circle-outline
        entity: sensor.electrolux_sawa_washing_machine_wm1_analogspinspeed
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
          {{states('sensor.electrolux_sawa_washing_machine_wm1_analogspinspeed')
      - type: template
        entity: binary_sensor.electrolux_sawa_washing_machine_wm1_doorlock
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
          {% set d ={ 'off': 'Locked', 'on': 'Unlocked',  } %}
          {{d.get(states(entity)) }}
        icon: |-
          {% if state=='off' %}
          mdi:lock
          {% else %}
          mdi:lock-open-outline
          {% endif %}
Thanks in advance!
The code ypu posted is for which card? You should post the code for both cards. I would assume that an indent ist not right. You should compare carrs line by line or minimize them as much as possible. Linke create the Template with animation and if this works go to the next step.
By the was nice idea - I will copy it, if it is working :slight_smile:
The code is for the bottom card. The top card code is as follows:
type: custom:stack-in-card
cards:
    icon: |-
      mdi:washing-machine
      mdi:washing-machine
      {% else %}
      mdi:washing-machine
      {% endif %}
    icon_color: blue
    primary: |2-
       {% set d ={
        'Off': 'Off'
    secondary: |
    card_mod:
      style:
        icon: |-
          mdi:washing-machine
          {% else %}
          mdi:washing-machine-off
          {% endif %}
          ha-icon {
          {{ '--icon-animation: shake 400ms ease-in-out infinite;' if
          is_state(config.entity, 'Running') }}
            transform-origin: 50% 58%;
          @keyframes shake {
    icon: mdi:washing-machine
    icon_color: red
    card_mod: null
    style:
      mushroom-shape-icon$: |
        ha-icon {
          --icon-animation: spin 1s linear infinite;
          clip-path: circle(21.7% at 50% 58%);
        .shape {
          --shape-color: none;
        ha-card {
          width: 80px;
          top: -82px;
    entity: sensor.electrolux_sawa_washing_machine_wm1_cyclephase
    alignment: center
    chips:
      - type: template
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
          }}Ā°C
      - type: template
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
      - type: template
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
        content: >-
        icon: |-
          mdi:lock
          {% else %}
          {% endif %}
I abandoned the top card idea because I could not get the spin (drum) to work on condition and I could not set the height of the card.
The code I posted previously (bottom card) is a modification on @SteffenDE 's card.
The bottom card works but as I said the drum doesnā€™t spin.
The spinning drum is a modification on @rhysb animated washing machine which can be found here:
https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/3272
USE THIS:
            cards:
                primary: Cucina
                secondary: >-
                  {{ states('sensor.temperatura_soffitta') | round(0) }}Ā°C | {{
                  states('sensor.asciugatrice_consumo') | round(0)}}W
                icon: mdi:fridge
                entity: light.cancello
                hold_action:
                  action: call-service
                  service: browser_mod.popup
                  target: {}
                    dismissable: true
                    autoclose: false
                    title: Cucina
                    content:
                      cards:
                          chips:
                            - type: back
                            - type: entity
                              entity: sensor.temperatura_soffitta
                              double_tap_action:
                                action: none
                              icon_color: purple
                              use_entity_picture: false
                              tap_action:
                                action: none
                              hold_action:
                                action: none
                            - type: entity
                              entity: sensor.umidita_soffitta
                              double_tap_action:
                                action: none
                              icon_color: cyan
                              tap_action:
                                action: none
                              hold_action:
                                action: none
                        - type: custom:mushroom-light-card
                          entity: light.comodino_mattia
                          use_light_color: true
                          show_color_temp_control: true
                          show_color_control: true
                          show_brightness_control: true
                          layout: horizontal
                          entity: light.camera_mattia
                tap_action:
                  action: toggle
                icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
                fill_container: true
                layout: horizontal
                card_mod:
                  style: |
                    :host([dark-mode]) {
                      background: rgba(var(--rgb-primary-background-color), 0.2);
                    :host {
                      background: rgba(var(--rgb-primary-text-color), 0.025);
                      --mush-icon-size: 100px;
                      height: 84px;
                      margin-left: -28px !important;
                chips:
                  - type: conditional
                    conditions:
                      - entity: light.cancello
                        state: 'on'
                    chip:
                      type: template
                      icon_color: disabled
                      icon: mdi:lightbulb-outline
                      tap_action:
                        action: more-info
                  - type: conditional
                    conditions:
                      - entity: light.comodino_mattia
                        state: 'on'
                    chip:
                      type: template
                      icon: mdi:lamp-outline
                      tap_action:
                        action: more-info
                  - type: conditional
                    conditions:
                      - entity: binary_sensor.input_asciugatrice
                        state: 'on'
                    chip:
                      type: template
                      double_tap_action:
                        action: none
                      icon_color: grey
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                  - type: conditional
                    conditions:
                        state: 'on'
                    chip:
                      type: template
                      icon_color: white
                  - type: conditional
                    conditions:
                        state: 'on'
                    chip:
                      type: template
                      double_tap_action:
                        action: none
                      icon: mdi:microwave
                      icon_color: grey
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                alignment: end
                card_mod:
                  style:
                    mushroom-conditional-chip:nth-child(3):
                      mushroom-template-chip$: |
                        ha-icon {
                          {{ 'animation: shake 400ms ease-in-out infinite;' if is_state('binary_sensor.input_asciugatrice', 'on') }}
                        @keyframes shake {
                    mushroom-conditional-chip:nth-child(4):
                        mushroom-chip {
                          cursor: default !important;
                        ha-icon {
                          position: absolute;
                          left: -27px;
                          {{ 'animation: spin 1s linear infinite;' if is_state('binary_sensor.input_asciugatrice', 'on') }}
                        @keyframes spin {
                          100% { transform: rotate(360deg); }
                    mushroom-conditional-chip:nth-child(5):
                        ha-icon:before {
                          content: "";
                          position: absolute;
                          width: 25%;
                          height: 25%;
                          margin: 11%;
                          animation: cook 1s linear infinite;
                        @keyframes cook {
                          0%, 100% { background: linear-gradient(90deg, white 0%, transparent 50%, transparent 100%); }
                          33% { background: linear-gradient(90deg, transparent 0%, white 50%, transparent 100%); }
                          66% { background: linear-gradient(90deg, transparent 0%, transparent 50%, white 100%); }
                      .chip-container :nth-child(4) {
                        --chip-background: none;
                        --chip-box-shadow: none;
                        --chip-border-width: 0;
                        width: 0px;
                        margin-left: calc(-1 * var(--chip-spacing));
                      ha-card {
                          --chip-spacing: 0;
            card_mod:
              style: |
                ha-card {
                  height: 120px;
                  {% if is_state('light.cancello', 'on') %}
                     background: rgba(255, 152, 0, 0.1);
                  {% endif %}
Try with This :
Guys how would I go about changing the badge icon text color to adapt to light/dark mode? Currently itā€™s black.
blacktxtbadge
          mushroom-badge-icon:after {
            content: "{{ expand(states.light.living_room_all_lights) | selectattr( 'state', 'eq', 'on') | list | count }}";
            position: absolute;
            display: flex;
            justify-content: center;
            align-items: center;
            background: rgb(var(--rgb-orange));
            color: black;
            font-weight: bolder;
            border-radius: 50%;
            top: 0;
            width: 100%;
            height: 100%;
            font-size: 0.8em;
Never got a response on this one ā€” is it possible to override the ā€˜standbyā€™ color for a media card? Iā€™d like it to be blue, regardless of state.
Is it possible to get help please?
I want to change the code and I donā€™t know how. If the value is over 20, letā€™s say rotate the icon. Can someone help me change this please?
icon_washer_2:
  styles:
    custom_fields:
      icon:
        - width: 78%
        - margin-left: -6%
  custom_fields:
    icon: >
        let center = `
          <path d="M31.8,23.1c3.8,3.8,3.8,9.8,0,13.6c-3.8,3.8-9.8,3.8-13.6,0L31.8,23.1"/>
          <path fill="none" d="M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3s14.4-6.4,14.4-14.4S33,15.4,25,15.4z"/>
        base = `
          <path fill="#9da0a2" d="M10.6,1.1h28.7c2.6,0,4.8,2.1,4.8,4.8v38.4c0,2.6-2.1,4.8-4.8,4.8H10.6c-2.6,0-4.8-2.1-4.8-4.8V5.8C5.8,3.2,8,1.1,10.6,1.1 M13.1,5.8c-1.4,0-2.4,1.1-2.4,2.4c0,1.4,1.1,2.4,2.4,2.4s2.4-1.1,2.4-2.4S14.3,5.8,13.1,5.8 M20.2,5.8c-1.4,0-2.4,1.1-2.4,2.4 c0,1.4,1.1,2.4,2.4,2.4c1.4,0,2.4-1.1,2.4-2.4S21.5,5.8,20.2,5.8 M25,15.4c-8,0-14.4,6.4-14.4,14.4S17,44.3,25,44.3 s14.4-6.4,14.4-14.4S33,15.4,25,15.4z"/>
        style = `
          <svg viewBox="0 0 50 50">
            <style>
              @keyframes rotate {
                0% {
                  visibility: visible;
                  transform: rotate(0deg) translateZ(0);
                100% {
                  transform: rotate(720deg) translateZ(0);
              .start {
                animation: rotate 2.8s ease-in;
                transform-origin: center 60%;
                fill: #5daeea;
                visibility: hidden;
                will-change: transform;
              .on {
                animation: rotate 1.8s linear infinite;
                fill: #5daeea;
                animation-delay: 2.8s;
                visibility: hidden;
              .end {
                animation: rotate 2.8s;
                fill: #9ca2a5;
                animation-timing-function: cubic-bezier(0.61, 1, 0.88, 1);
              .start_timeout {
                fill: #5daeea;
                visibility: hidden;
              .end_timeout {
                fill: #9ca2a5;
            </style>
        if (variables.state_on) {
          return `${style}${base}<g class="start">${center}</g><g class="on">${center}</g></svg>`;
        if (!variables.state_on) {
          return `${style}${base}<g class="end">${center}</g></svg>`;
        if (variables.state_on && variables.timeout > 2000) {
          return `${style}${base}<g class="start_timeout">${center}</g></svg>`;
        } else {
          return `${style}${base}<g class="end_timeout">${center}</g></svg>`;
hi can you please share your code for the page layout ? i would like to how you implemented the bottom bar and so on.
thank you.
Hello all.
Just came across this and was wondering is this something I am doing wrong or an issue?
I have an Aqara Motion Sensor (and Contact) I want to capture the Date and Time when it was triggered last time. I use following:
{{ as_timestamp(states.switch.dining_room_light.last_updated)|timestamp_custom ("%d/%m %H:%M") }}
But the problem are,
1] it gets reset when the system is rebooted.
2] They both have a same date/time stamp, so when the motion is triggered, date time is also updated for Contact sensor and vice a versa
Please someone can look up?
Thank you
@rhysb Would it be possible to ask for a animation for cover?
mdi: blinds
Have you tried deleting color: black?
The timestamps will get reset with every restart, as the values from the sensor are read ā€œfreshā€ at a system (re)start. The only way to safe your value is setting up a helper that can save this value. In this case it would be an input_datetime.
Very nice, thanks for this! Any thoughts on how to make each one appear conditionally?
Then it just becomes white!
