Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Yes, it also works very slowly for me and does not respond on the phone or tablet, very strange why
Will do, thank you for the input!
Thank you @andyblac
height: 200px !important; did it :pray:
With the adjustment of the card size, the icon becomes very small. Is there a way to adjust the icon location / offset after force its size?
Hello, I’m trying to do one card but need your help because I’m a beginner :smiley:
This is what I got so far:
ezgif-1-696c14dcca
What I want to change is the lights information on the chips card, I want it to be a conditional card/entity, if no lights of that group are on then it doesn’t show up, if any light is on it shows up, and instead of telling the state ON I want it to show up the number of lights turned on in that group.
Here is the chip card code:
cards:
  - type: custom:vertical-stack-in-card
    cards:
        icon: mdi:door
        entity: light.hall_de_entrada_luz_hall_95
        icon_color: >-
          {% set count =
          states|selectattr('entity_id','in',state_attr('light.luzes_entrada','entity_id'))|selectattr('state','eq','on')|list|count
          %} {% if count > 0 %} orange {%endif%}
        tap_action:
          action: navigate
          navigation_path: entrada
        hold_action:
          action: toggle
        multiline_secondary: true
        primary: Entrada
        card_mod: null
        style: |
          ha-card {
            box-shadow: 0px 0px;
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: sensor.temperatura_entrada_2
            icon_color: red
            card_mod: null
            style: |
              ha-card {
          - type: entity
            entity: light.luzes_entrada
            icon_color: amber
            card_mod: null
            style: |
              ha-card {
        alignment: center
Anyone can help me please?
Thanks.
I manage to do the first part, conditional card. Now I need help changing the on state to number os devices in that group turned on…
ezgif-4-71c0d046d9
cards:
    icon: mdi:door
    icon_color: >-
      {% set count =
    tap_action:
      action: navigate
    hold_action:
      action: toggle
    primary: Entrada
    card_mod: null
    style: |
      ha-card {
    chips:
      - type: entity
        icon_color: red
        card_mod: null
        style: |
          ha-card {
      - type: conditional
        conditions:
          - entity: light.luzes_entrada
            state: 'on'
        chip:
          type: entity
          icon_color: amber
          icon: mdi:lightbulb-group
          tap_action:
            action: toggle
    alignment: center
Here is my code which I know needs tidying up but it’ll give you a number when any of the lights listed are on.
type: conditional
conditions:
  - entity: light.downstairs_lights
    state: 'on'
chip:
  type: template
  content: |-
    {% set total = 0 %}
    {% if is_state('light.hallway_driveway_light_1', 'on') %}
      {% set total = total + 1 %}
    {% endif %}
    {% if is_state('light.kitchen_lights', 'on') %}
    {% endif %}
    {% if is_state('light.living_dining_room_lights_1', 'on') %}
    {% endif %}
    {% if is_state('light.living_dining_room_lights_2', 'on') %}
    {% endif %}
    {% if is_state('light.wc_light_fan_1', 'on') %}
    {% endif %}
    {% if is_state('light.gym_lights_1', 'on') %}
    {% endif %}
    {% if is_state('light.gym_lights_2', 'on') %}
    {% endif %}
    {% if is_state('light.pantry_lights', 'on') %}
    {% endif %}
    {% if is_state('light.downstairs_landing_light', 'on') %}
    {% endif %}
    {{total}} lights are on
  icon_color: |-
      orange
    {% elif is_state("light.kitchen_lights", "on") %}
      orange
    {% elif is_state("switch.kitchen_cabinet_lights", "on") %}
      orange
    {% elif is_state("light.living_dining_room_lights_1", "on") %}
      orange
    {% elif is_state("light.living_dining_room_lights_2", "on") %}
      orange
    {% elif is_state("light.gym_lights_1", "on") %}
      orange
    {% elif is_state("light.gym_lights_2", "on") %}
      orange
    {% elif is_state("light.pantry_lights", "on") %}
      orange
    {% elif is_state("light.wc_light_fan_1", "on") %}
      orange
    {% elif is_state("light.downstairs_landing_light", "on") %}
      orange
    {% else %}
      grey
    {% endif %}
  tap_action:
    action: toggle
  double_tap_action:
    action: none
  hold_action:
    action: none
try now readjusting the icon size try % instead of px, you can do above 100% ie 140% to compensate for the resize of card.
Thank you @andyblac
I’m looking at how to adjust the position of the icon (up/down)
Does anyone have a nice pop up card design that displays everything that is on, I’m looking for inspiration
hi, did you finally get that bar to work? I really like the design of it but I can’t get it to work completely. thanks :))
Since the new 2.8 series where the title card was moved to ha-card the height is suddenly very off with me, messing up my layouts on my tablet displays. The height is a lot bigger, especially when I only use the subtitle (to create a smaller title). See example below. Created this realtime by downgrading to 2.7.1 and refreshing cache properly.
Just to confirm:
  • this is the only yaml for the card, so no card_mod here:
type: custom:mushroom-title-card
title: ''
subtitle: Weer
  • I do have a theming in place with the mushroom css variables for the title where only the padding differs from the default values I found on the mushroom CSS github. Could it be that the padding isn’t correctly used?
    mush-title-padding: 12px 12px 6px
    mush-title-spacing: 12px
    mush-title-font-size: 24px
    mush-title-font-weight: normal
    mush-title-line-height: 1.2
I use this:
mush-title-padding: 8px 8px 0px
to put the title quite close to the card, but just test the value yourself.
For some reason i get these weird blocky lines underneath 22
I now updated my theme to this. Limiting all these values a little. Now my layout is restored.
It is odd though that the ha-card had such different padding values than the previous card.
    mush-title-spacing: 8px
    mush-title-line-height: 1.1
Here is the light chip on my room card.
Replace group.lights_office with a light group
- type: template
  entity: group.lights_office
  icon: '{{ iif(is_state(entity, "on"), "mdi:lightbulb-on", "mdi:lightbulb") }}'
  icon_color: '{{ iif(is_state(entity, "on"), "amber", "disabled") }}'
  card_mod:
    style:
        {% if is_state(config.entity, "on") %}
        ha-card:after {
          content: "{{ expand(config.entity) | selectattr('state', '==', 'on') | list | count }}";
          position: absolute;
          color: var(--amber-color);
          font-weight: bolder;
          top: -2px;
          right: 2px;
          font-size: 12px;
        {% endif %}
Hello you all,
when using Mushroom Chips, how is it possible to have the name of the entity and the value of the entity shown in the chip?
Example:
HVAC 22°C
I think it probably only works using a template. But how? Thank you in advance!
Under ha-card add box-shadow: none;
All good! It was actually a mushroom bug. It was fixed in the latest version :slight_smile:
Love your work!
Apparently I lack knowledge on the subject.
Where can I add the Rooms JSON file?
And also the code for “Roborock Rooms”?
I need your help :slight_smile:
What would be the best way to assign / layout the two chip cards in the template card
2023-07-01 22_00_59-Main – Home Assistant und 3 weitere Seiten - Persönlich – Microsoft​ Edge
i want them to be like that
2023-07-01 22_04_10-2023-07-01 22_00_59-Main – Home Assistant und 3 weitere Seiten - Persönlich – Mi
The Coding at the moment looks like:
type: custom:stack-in-card
cards:
  - type: horizontal-stack
    cards:
        primary: Homeassistant
        secondary: '{{ states(''sensor.docker_homeassistant_status'') }}'
        icon: mdi:home-assistant
        icon_color: blue
        badge_icon: >
          {% if is_state('update.wud_container_local_homeassistant', 'on') %}
            mdi:update
          {% elif is_state('update.wud_container_local_homeassistant',
          'unknown') %}
            mdi:help
          {% else %}
            disabled
          {% endif %}
        badge_color: >
            disabled
          'unknown')  %}
            orange
          {% else %}
            transparent
          {% endif %}
        multiline_secondary: false
        tap_action:
          action: none
        hold_action:
          action: none
        double_tap_action:
          action: none
        style: |
          ha-card {
            margin-top: 5px;
            margin-right: -10px;
        chips:
          - type: template
            icon: mdi:chip
            tap_action:
              action: navigate
              navigation_path: home
        chips:
          - type: template
            icon: mdi:memory
            tap_action:
              action: navigate
