Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
card_mod:
  style: |
    ha-state-icon {
      {% if is_state('switch.ventilator','on') %}
        animation: spin 1s linear infinite;
      {% else %}
      {% endif %}
You only need this.
@arythm
try like this.
card_mod:
  style: |
    ha-card {
      border: inset gold;
      background-color:  rgb( 255 215 0 / 0.1);
    ha-state-icon {
      {% if states('timer.waschmaschine')!= 'idle' %}
        animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
        transform-origin: 50% 110%;
      {% else %}
      {% endif %}
    @keyframes shake {
      0%, 100% { transform: translate(0, 0) rotate(0); }
      20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
      40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
      60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
      80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    @keyframes drum {
      50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
I really appreciate the quick reply. It works perfectly again. <3
Now I can adjust the rest of the code myself.
I would do it like this.
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        {% if is_state('media_player.gh_mini', 'playing') %}
          --shape-animation: ping 2s infinite;
        {% else %}
        {% endif %}
      @keyframes ping {
        0% {box-shadow: 0 0 5px 1px rgba(var(--rgb-teal), 0.7);}
        100% {box-shadow: 0 0 5px 15px transparent;}
      ha-state-icon {
          animation: music 2s ease-in-out infinite alternate;
          transform-origin: 50% 100%
        {% else %}
        {% endif %}
      @keyframes music {
        0%, 100% { transform: translateY(0px) scaleX(1); }
        20% { transform: translateY(2px) scaleX(0.9); }
        40% { transform: rotateY(10deg) rotateZ(-10deg); }
        60% { transform: translateY(-4px) scaleX(1.1); }
        80% { transform: rotateY(-10deg) rotateZ(10deg); }
So split up your animation that is for the ā€œbackgroundā€ or the outside shape of the icon. and then seperately for your animation that is for the mdi icon itself.
Mushroom Input Time Card
Mushroom_Input_Time
My meager offeringā€¦ I really wanted a card like this and managed to hack one together. The example shows a ā€œcardā€ configured to a simple ā€œmorning lightsā€ automation that is triggered by an even simpler ā€œmorning lightsā€ time helper. The ā€œcardā€ allows the user to edit the time (without a popup) and to enable/disable the automation entirely. Itā€™s been received well in my family and I can imagine several places this might be useful.
Disclaimer: Iā€™m a beginner. Iā€™ve been using this ā€œcardā€ for a few weeks, on different platforms, without any issues, but Iā€™ve likely made some rookie mistakes.
Requirements: Aside from Lovelace and Mushroom, this ā€œcardā€ (its not really a card) requires card-mod and vertical-stack-in-card or equivalent(s).
Credit and many thanks to @Ildar_Gabdullin for his endless examples of input_datetime CSS styling.
Code
type: custom:vertical-stack-in-card
horizontal: true
cards:
    primary: Morning Lights
    secondary: >-
      {{ iif (is_state('automation.bedroom1_morning_lights', 'on'), 'Enabled
      at:', 'Disabled') }}
    icon: >-
      'mdi:alarm-light-outline', 'mdi:alarm-light-off-outline') }}
    icon_color: >-
      {{ iif (is_state('automation.bedroom1_morning_lights', 'on'), 'green',
      'grey') }}
    entity: automation.bedroom1_morning_lights
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        :host {
          --primary-text-color:
              {% if is_state('automation.bedroom1_morning_lights', 'on') %}
                var(--primary-text-color)
              {% else -%}
                var(--secondary-text-color)
              {% endif %}
  - type: entities
    entities:
      - entity: input_datetime.bedroom1_morning_lights
        secondary_info: none
        card_mod:
          style:
            hui-generic-entity-row $: |
              state-badge { display: none; }
              div.info.pointer { display: none; }
            ha-time-input:
              $ ha-base-time-input $:
                ha-textfield:
                    .mdc-text-field {
                      height: 40px !important;
                    .mdc-line-ripple::after,
                    .mdc-line-ripple::before {
                      border-bottom-style: none !important;
                    .mdc-text-field__ripple {
                      display: none !important;
                ha-select $: |
                  .mdc-select__anchor {
                  .mdc-select__ripple {
              :host {
                --mdc-text-field-fill-color: transparent;
                --mdc-select-fill-color: transparent;
                {% if is_state('automation.bedroom1_morning_lights','off') %}
                  --mdc-text-field-ink-color: var(--disabled-text-color);
                  --mdc-select-ink-color: var(--disabled-text-color);
                  --mdc-text-field-idle-line-color: var(--disabled-text-color);
                  --mdc-select-idle-line-color: var(--disabled-text-color);
                  --mdc-select-dropdown-icon-color: var(--disabled-text-color);
                  --paper-item-icon-color: var(--disabled-text-color);
                  pointer-events: none;
                {% endif %}
    card_mod:
      style: |
        #states {
          padding-top: 12px;
          padding-bottom: 12px;
          padding-left: 0px;
          align-self: end;
        #states > div{
          border: 1px solid rgba(127,127,127,0.5);
          border-radius: 6px !important;
          box-shadow: 3px 2px 5px rgba(0,0,0,0.16);
Edit: I fixed the last line of code so it works properly in dark mode (rookie mistake). :slight_smile:
MrGrey.
Thanks for helping me out. It worked! Yay :grin:
Unfortunately my animation doesnā€™t work anymore.
Can you help me?
Thanks.
card_mod:
  style:
      ha-icon {
        {{ '--icon-animation: sunny 8s ease-in-out infinite alternate;'
        if is_state(config.entity, 'on') }}
      @keyframes sunny {
        70% { transform: rotate(360deg) scale(1); }
        80% { transform: scale(1); }
        90% { transform: scale(1.15); }
        100% { transform: scale(1); }
Look up in some of the recent posts.
You need to remove --icon-animation and replace with just animation
Then you need to use ha-state-icon instead of ha-icon. But this also means removing mushroom-shape-icon$: | and just using style: |
good thinking, it worked! thank you, I will now rewrite all of my animations and will follow that approach from now on!
thanks again
Doesnā€™t quite fit in here, but maybe someone knows a solution.
I have a popup card about browser mode. Can I set the popup card to close when I click on a room?
Anyone know if itā€™s possible to address a template chip icon directly for animation, rather than using nth-child from the mushroom-chips-card to select it? - The issue is iā€™m using decluttering card with some conditional chips so depending on what is visible the ā€˜nthā€™ number changes meaning the wrong chip animates.
Iā€™d like to use clip animation but place it directly in the card mod for just that chip, but I canā€™t see to get it to work.
Short and sweet. No.
you have to go via the nth-child.
i dont know what the decluttering card does exactly but if you have a conditional chip with a template chip inside of it it would be the conditional chip that you are getting the nth-child of.
        mushroom-conditional-chip:nth-child(1):
          mushroom-template-chip$: |
            ha-state-icon {
              animation: charge 3s linear infinite;
            @keyframes charge {
              0%, 80% { clip-path: inset(0 0 0 0); }
              70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
              60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
              50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
              40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
              30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
              20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
              10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Therefore the numbers should never change. (but again, not sure what the decluttering card does).
post your yaml and ill see if i can help :slight_smile:
Hi
With Update 3.0.5
I canā€™t get my FIRE animation to work
Can you help me?
Thanks in advance
primary: Fire
icon: mdi:fire
icon_color: red
card_mod:
  style: |
    ha-states-icon {
      animation: fire 1.5s infinite;
      transform-origin: 50% 85%;
      @keyframes fire {
          0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
          95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
          100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
tiniest of error.
ha-states-icon should be ha-state-icon.
works fine after :slight_smile:
type: custom:mushroom-template-card
icon: mdi:truck-cargo-container
icon_color: red
primary: Vroom
secondary: ''
card_mod:
  style: |
    ha-state-icon {
      animation: vroom 2s ease-in-out infinite;
      .shape {
      clip-path: inset(55% 55% 55% 55%);
      @keyframes vroom {
        49% { opacity: 1;}
        50% { transform: translate(32px); opacity: 0; }
        51% { transform: translate(-30px); opacity: 0; }
        52% { opacity: 1; }
Works nicely, except the truck ā€œleavesā€ the icon and enters from outside of the icon. Canā€™t figure out, how to fix that, in the demo at the top of the page, it worked just fine. The truck should stay within the bounds of the icon (red circle)!
Thanks a lot some days we need an outside perspective
Nice popup! :+1: Mind sharing the code? :slight_smile:
Anyway, if nothing else or simpler comes up, you could try it via a script. Set the tap_action to call a script, where you can have as many actions/service calls as you want. Would be in this case the action you want to call by pushing the button, and afterwards you can call the browser_mod.close_popup service to, yeah, close the popup. :slight_smile:
Great Idea! Thank you. I will try it.
Here is my Popup Code:
type: custom:popup-card
entity: input_boolean.menu
card:
  type: vertical-stack
  cards:
    - type: custom:button-card
      show_icon: false
      show_state: true
      show_name: true
      tap_action:
        action: none
      styles:
        card:
          - background-color: transparent
        name:
          - font-size: 30px
          - color: var(--primary-color)
          - font-weight: lighter
      card_mod:
        style: |
          ha-card { border-radius: 50px;
          background: transparent;
          box-shadow: none;
    - type: horizontal-stack
      cards:
        - type: custom:stack-in-card
          cards:
              primary: Badezimmer
              entity_id: climate.heizung_ankleidezimmer
              secondary: >-
                {{ state_attr('climate.heizung_badezimmer',
                'current_temperature') }} Ā°C
              icon: mdi:shower
              entity: group.badezimmer_licht
              tap_action:
                action: navigate
                navigation_path: badezimmer
              hold_action:
                action: toggle
              icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
              fill_container: true
              layout: horizontal
              multiline_secondary: false
            - type: custom:mushroom-chips-card
              chips:
                - type: conditional
                  conditions:
                    - entity: group.badezimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon_color: disabled
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: switch.tasmota2
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:fan
                    card_mod:
                      style: |
                        @keyframes rotation {
                          0% {
                            transform: rotate(0deg);
                          100% {
                            transform: rotate(360deg);
                        ha-card {
                          animation: rotation 2s linear infinite;
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-box-shadow: none;
                    --chip-background: none;
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.badezimmer_licht', 'on') %}
                   background: rgba(255, 152, 0, 0.1);
                {% endif %}
          cards:
              primary: Schlafzimmer
              icon: mdi:bed
              entity: group.schlafzimmer_licht
              tap_action:
                action: navigate
                navigation_path: schlafzimmer
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.schlafzimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: binary_sensor.fenstersensor_schlafzimmer_contact
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:window-open-variant
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.schlafzimmer_licht', 'on') %}
                {% endif %}
      cards:
          cards:
              primary: Kinderzimmer
              secondary: >-
                {{ state_attr('climate.heizung_kinderzimmer',
              icon: mdi:teddy-bear
              entity: group.kinderzimmer_licht
              tap_action:
                action: navigate
                navigation_path: kinderzimmer
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.kinderzimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: group.kinderzimmer_fenster
                      state: 'on'
                  chip:
                    type: template
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.kinderzimmer_licht', 'on') %}
                {% endif %}
          cards:
              primary: Ankleidezimmer
              secondary: >-
                {{ state_attr('climate.heizung_ankleidezimmer',
              icon: mdi:wardrobe
              entity: ankleidezimmer_licht
              tap_action:
                action: navigate
                navigation_path: ankleidezimmer
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.ankleidezimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: binary_sensor.fenstersensor_ankleidezimmer_contact
                      state: 'on'
                  chip:
                    type: template
                - type: conditional
                  conditions:
                    - entity: binary_sensor.presence_ankleiderzimmer_presence
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:motion-sensor
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.ankleidezimmer_licht', 'on') %}
                {% endif %}
      cards:
          cards:
              primary: Wohnzimmer
              secondary: >-
                {{ state_attr('climate.heizung_wohnzimmer',
              icon: mdi:television
              entity: group.wohnzimmer_licht
              tap_action:
                action: navigate
                navigation_path: wohnzimmer
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.wohnzimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: binary_sensor.terrassentursensor_contact
                      state: 'on'
                  chip:
                    type: template
                - type: conditional
                  conditions:
                    - entity: binary_sensor.presence_wohnzimmer
                      state: 'on'
                  chip:
                    type: template
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.wohnzimmer_licht', 'on') %}
                {% endif %}
          cards:
              primary: Essbereich
              secondary: null
              icon: mdi:table-chair
              entity: light.shelly_kuche_essbereich_channel_2
              tap_action:
                action: navigate
                navigation_path: essbereich
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: light.shelly_kuche_essbereich_channel_2
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: sensor.rolladen_essbereich_level
                      state: closed
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('light.shelly_kuche_essbereich_channel_2', 'on') %}
                {% endif %}
      cards:
          cards:
              primary: KĆ¼che
              secondary: null
              icon: mdi:countertop
              entity: group.kuche_licht
              tap_action:
                action: navigate
                navigation_path: kuche
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.kuche_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: group.kuche_fenster
                      state: 'on'
                  chip:
                    type: template
                - type: conditional
                  conditions:
                    - entity: binary_sensor.presence_kuche_presence
                      state: 'on'
                  chip:
                    type: template
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.kuche_licht', 'on') %}
                {% endif %}
          cards:
              primary: Arbeitzimmer
              icon: mdi:chair-rolling
              entity: group.arbeitszimmer_licht
              tap_action:
                action: navigate
                navigation_path: arbeitszimmer
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: group.arbeitszimmer_licht
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: binary_sensor.fenstersensor_arbeitszimmer_contact
                      state: open
                  chip:
                    type: template
                - type: conditional
                  conditions:
                    - entity: binary_sensor.presence_az_presence
                      state: 'on'
                  chip:
                    type: template
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.arbeitszimmer_licht', 'on') %}
                {% endif %}
      cards:
          cards:
              primary: Atelier
              secondary: >-
                {{ state_attr('climate.heizung_atelier', 'current_temperature')
                }} Ā°C
              icon: mdi:face-woman-shimmer
              entity: climate.heizung_atelier
              tap_action:
                action: navigate
                navigation_path: atelier
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: binary_sensor.fenstersensor_atelier_contact
                      state: 'on'
                  chip:
                    type: template
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('group.atelier_licht', 'on') %}
                {% endif %}
          cards:
              primary: Waschraum
              secondary: >-
                {{ states('sensor.feuchtigkeitssensor_waschraum_temperature') |
                round(0) }} Ā°C
              icon: mdi:washing-machine
              entity: light.2_deckenlicht_luftung_wasc_channel_1
              tap_action:
                action: navigate
                navigation_path: waschraum
              hold_action:
                action: toggle
              layout: horizontal
              chips:
                - type: conditional
                  conditions:
                    - entity: light.2_deckenlicht_luftung_wasc_channel_1
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:lightbulb
                - type: conditional
                  conditions:
                    - entity: light.2_deckenlicht_luftung_wasc_channel_2
                      state: 'on'
                  chip:
                    type: template
                    icon: mdi:fan
                    card_mod:
                      style: |
                          0% {
                          100% {
                        ha-card {
              alignment: end
              card_mod:
                style: |
                  ha-card {
                    --chip-spacing: 0;
                    top: -36px;
          card_mod:
            style: |
              ha-card {
                height: 66px;
                {% if is_state('light.2_deckenlicht_luftung_wasc_channel_1', 'on') %}
                {% endif %}
      cards:
          primary: Garten
          icon: mdi:tree
          entity: sensor.garten_licht
          tap_action:
            action: navigate
            navigation_path: garten
          hold_action:
            action: toggle
          layout: horizontal
          chips:
            - type: conditional
              conditions:
                - entity: sensor.garten_licht
                  state: 'on'
              chip:
                type: template
                icon: mdi:lightbulb
            - type: conditional
              conditions:
                - entity: sensor.garten_steckdosen
                  state: 'on'
              chip:
                type: template
                icon: mdi:power-socket-eu
            - type: conditional
              conditions:
                - entity: sensor.garten_bewasserung
                  state: 'on'
              chip:
                type: template
                icon: mdi:sprinkler
          alignment: end
          card_mod:
            style: |
              ha-card {
                --chip-spacing: 0;
                top: -36px;
      card_mod:
        style: |
          ha-card {
            height: 66px;
            {% endif %}
Hello
for some reason the animation does not work with any of the template cards
however, it is perfect with the climate card
type: custom:mushroom-climate-card
entity: climate.c6c489b1
hvac_modes:
  - heat_cool
  - heat
  - cool
  - fan_only
  - dry
show_temperature_control: true
collapsible_controls: false
name: Air Conditioner
card_mod:
  style: |
    mushroom-shape-icon {
      {% if is_state(config.entity, 'heat_cool') %}
        --card-mod-icon: mdi:autorenew;
        animation: spin 3s ease-in-out infinite alternate;
      {% elif is_state(config.entity, 'heat') %}
        --card-mod-icon: mdi:fire;
        animation: heat 2s infinite;
      {% elif is_state(config.entity, 'cool') %}
        --card-mod-icon: mdi:snowflake;
        animation: cool 6s ease-in-out infinite;
      {% elif is_state(config.entity, 'dry') %}
        --card-mod-icon: mdi:water-percent;
        animation: dry 1.5s linear infinite;
      {% elif is_state(config.entity, 'fan_only') %}
        --card-mod-icon: mdi:fan;
      {% else %}
        --card-mod-icon: mdi:air-conditioner;
      {% endif %}
      display: flex;
    @keyframes cool {
      0%, 100% { transform: rotate(25deg); }
      25% { transform: rotate(-25deg); }
      50% { transform: rotate(50deg); }
      75% { transform: rotate(-50deg); }
    @keyframes heat {
      0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
      10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
      20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
      30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
      40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
      50% { --icon-color: rgba(var(--rgb-red), 0); }
    @keyframes dry {
      0%, 100% { --icon-symbol-size: 21px; }
      10%, 90% { --icon-symbol-size: 22px; }
      20%, 80% { --icon-symbol-size: 23px; }
      30%, 70% { --icon-symbol-size: 24px; }
      40%, 60% { --icon-symbol-size: 25px; }
      50% { --icon-symbol-size: 26px; }
primary: Spin
icon: mdi:fan
icon_color: teal
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 1s linear infinite;
I copied both from here, the card mod is installed
There was a breaking change effecting some animations. The following works.
primary: Spin
icon: mdi:fan
icon_color: teal
card_mod:
  style: |
      ha-state-icon {
In general:
style:
becomes:
style: |
ha-icon
becomes:
ha-state-icon
and
--icon-animation: ...
becomes:
animation: ...
Clear as mud. :sweat_smile:
MrGrey.
@rhysb Im following youā€™re great animations guide that you made and am trying to use it to apply a lightbulb animation when the light is toggled on, problem Iā€™m facing is the toggle is obviously fast so its not enough time for it to play the animation.
Any way around this? I tried speeding it up a little but didnā€™t work.
type: custom:mushroom-light-card
entity: light.huego
show_brightness_control: true
icon: mdi:lightbulb
hold_action:
  action: toggle
card_mod:
  style: |
    ha-card:active ha-state-icon {
      animation: eureka 2.8s infinite;
    @keyframes eureka {
      0%, 45%, 55%, 100% { transform: translateY(0) scale(1); clip-path: polygon(20% 100%, 21% 38%, 36% 22%, 62% 21%, 79% 37%, 80% 100%, 53% 100%, 55% 67%, 62% 62%, 66% 55%, 67% 46%, 62% 38%, 55% 34%, 47% 34%, 39% 37%, 34% 44%, 33% 53%, 36% 60%, 41% 64%, 45% 66%, 45% 76%, 56% 76%, 54% 100%); }
      10%, 40% { transform: translateY(-5px) scale(1.12); clip-path: inset(0 0 0 0); }
      50% { transform: translateY(-2px) }
