Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Oh and remove the | from behind your style :slight_smile:
This! This is it! Thank you.
No problemo :slight_smile:
i will split your problems up into the 3 sections you have and first i want to see if i have understood you correctly.
  1. do you want to remove the background of the lightbulb icon or of the dropdown menu icon?
  2. yes. you can use the below:
    card_mod:
      style:
        mushroom-light-brightness-control$: |
          mushroom-slider {
            --bg-color: #d1eced !important;
            --main-color: teal !important;
Rest of your code. just remove any reference to other background color in the ha-card section.
  1. is there any reason it needs to be 200%? i changed it to 100% and seems fine to me?
    the issue you have with your center not being clickable is because your chip is technically taking up the space. i added a border so you can see.
    just add the below:
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: |-
          {% if is_state(entity, 'off') %}
            mdi:chevron-down
          {% elif is_state(entity, 'on') %}
            mdi:chevron-up
          {% endif %}
        tap_action:
          action: toggle
        entity: input_boolean.living_room_toggle
        icon_color: 31,31,31
        card_mod:
          style: |
            ha-card {
               --chip-icon-size: 0.7em;
               --chip-padding: 0px 6px;
               --chip-height: 35px;
               --chip-border-radius: 100px;
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: white;
          margin: 34px 215px;
          width: 0px;
let me know if you need more help on this one.
Yeah, doesnt change from current color.
This is what I currently have:
/* Define Person State colors. Can be added to theme */
                        --state-person-Home: var(--red-color);
                        --state-person-home: var(--red-color);
                        --state-person-not-home: var(--indigo-color);
                        --state-person-zone: var(--light-blue-color);
                        --state-person-unknown: var(--grey-color);
                        /* Set Person State color */
                        --state-person:
                        {% if is_state(config.entity, ['Home', 'home','not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entity) | replace('_', '-') }})
                        {% else %}
                          var(--state-person-zone)
                        {% endif %};
Thanks for the help! Trying to remove the lightbulb background. The background on the chip is desired.
I might be doing something wrong with the width. When I don’t set it to 200% it only covers half the card. Removing the width on the chip might fix that though…. I’ll mess around with it tonight but this seems like it’ll get me going in the right direction. Thank you!
Then sorry i am really not sure. the only thing i would ask, and this may seem like a dumb question. but do you have Card Mod installed?
it works for me hence why i really dont know at this point.
@dimitri.landerloos Hey I was able to accomplish what I needed thanks to your help. I went back and looked at a few of your other posts as well. Thanks again! Here are the final results:
google lights
Very happy to hear it! post your yaml it looks gorgeous :slight_smile:
Love the look! Do you mind sharing the final code? Thx.
Good day, I updated the below animation with ha-state-icon but it’s no longer working. Any guidance is much appreciated
    type: custom:mushroom-entity-card
      entity: '[[entity]]'
      layout: horizontal
      tap_action:
        action: toggle
      card_mod:
        style:
          mushroom-shape-icon$: |
            ha-state-icon {
              {% if is_state('[[entity]]', 'on')%}
                animation: rotation 2s linear infinite;
              {% endif %}
            @keyframes rotation {
              0% {
                transform: rotate(0deg);
              100% {
                transform: rotate(360deg);
you cant use ha-state-icon under mushroom-shape-icon anymore it seems.
try like this:
layout: horizontal
tap_action:
  action: toggle
card_mod:
  style: |
    ha-state-icon {
      {% endif %}
      0% {transform: rotate(0deg);}
      100% {transform: rotate(360deg);}
Yes, that works .
Thank you very much for your help.
If you want to count which light from a special list of lights are “on” you can define a template-sensor like this:
    #eingeschaltete_lichter:
      - unique_id: eingeschaltete_lichter
        state: "{{expand(state_attr('light.verwendete_lichter', 'entity_id'))|selectattr('state','eq','on')|map(attribute='entity_id')| reject('is_hidden_entity')|list|count|int(default=0)}}"
It counts the lights that are in state “on” and in group “light.verwendete_lichter”. You can create a group of lights as a helper direct from ui.
you could use a mushroom-chips-card for that. It will look like this:
Here is the yaml-code for that card:
alignment: start
chips:
  - type: template
    content: Speicherschutz
    tap_action: none
    icon: mdi:shield-outline
    card_mod:
      style: |
        ha-card {
          padding: 0px !important;
          border: none !important;       #don`t show border line for that chip
          font-size: 3.5rem !important;  #set font-size for that chip
          background: none !important;   #don't show backgroud for that chip
  - type: entity
    entity: sensor.esp_jk_bms_temperature_sensor_1
    icon_color: red
    card_mod:
      style: |
        ha-card {
          #border: none !important;
          font-size: 2.5rem !important;
          background: rgba(var(--rgb-primary-text-color), 0.05) !important;
  - type: entity
    entity: sensor.esp_jk_bms_temperature_sensor_2
    icon_color: red
    card_mod:
      style: |
        ha-card {
Hi, whats is wrong ?
      card_mod:
          style:
            mushroom-shape-icon:
                {% if is_state('script.sifao_2_hora','off') %}
                  ha-state-icon {
                    animation: spin 1s linear infinite;
                {% else %}
                {% endif %}
                ha-card {
                  --secondary-text-color:
                      green
                    {% else %}
                     red
                    {% endif %}
don’t spin
Do post the full card yaml next time. makes it easier to trouble shoot.
but try like this. just replace the entities with your own :slight_smile:
card_mod:
  style: |
    ha-state-icon {
      {% if is_state('media_player.office_speaker','off') %}
      {% else %}
      {% endif %}
    ha-card {
        green
      {% else %}
       red
      {% endif %}
google lights
Sure, here you go. If anyone takes it and cleans it up or does it more efficiently please let me know. I’m a big time beginner so this is all new to me. Having more fun learning how to do css and theme than actually setup my devices and use them :sweat_smile:
type: custom:stack-in-card
cards:
  - square: false
    columns: 2
    type: grid
    cards:
      - type: custom:mushroom-light-card
        entity: light.living_room_lights
        show_brightness_control: true
        tap_action:
          action: toggle
        icon_color: none
        card_mod:
          style:
              mushroom-slider {
                --bg-color: rgb(255,239,201) !important;
                --main-color: rgb(255,224,130) !important;
              mushroom-light-brightness-control {
                position: absolute;
                top: 0px;
                left: 0px;
                width: 100%;
                opacity: 1;
                --control-height: 102px;
                --control-border-radius: var(--ha-card-border-radius, 12px);
                --rgb-disabled: var(--rgb-card-background-color);
              mushroom-state-item {
                z-index: 1;
                max-width: fit-content;
                margin-bottom: 0px;
                pointer-events: none;
              mushroom-shape-icon {
                pointer-events: auto;
                --shape-color: transparent !important;
                --shape-color-disabled: transparent !important;
                {% if is_state(config.entity, 'on') %}
                --card-mod-icon: fapro:light-group-fill;
                --card-mod-icon-color: rgb(115,92,0);
                {% else %}
                --card-mod-icon: fapro:light-group;
                --card-mod-icon-color: rgb(31,31,31);
                {% endif %}
                ha-card {
                  --icon-symbol-size: 0.6em;
                  padding: 30px 10px !important;
                  width: 204% !important;
                  border-radius: 35px !important;
                  --card-primary-font-weight: 700;
                  --card-secondary-font-weight: 700;
                  --keep-background: true;
                  --primary-text-color: rgb(115,92,0);
                  --secondary-text-color: rgb(115,92,0);
                {% else %}
                  background: rgb(242,246,252);
                  --primary-text-color: rgb(31,31,31);
                  --secondary-text-color: rgb(31,31,31);
                {% endif %}
              ha-card:active {
                transform: scale(0.975);
                transition: 0s;
        chips:
          - type: template
            icon: |-
                mdi:chevron-down
                mdi:chevron-up
              {% endif %}
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
                 --chip-height: 40px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              padding: 31px 23px 0px 0px;
            ha-card:active {
              transition: 0s;
  - type: conditional
    conditions:
      - entity: input_boolean.living_room_toggle
        state: 'on'
    card:
      type: horizontal-stack
      cards:
          entity: light.main_light
          tap_action:
            action: toggle
          icon_color: none
          card_mod:
            style:
                mushroom-slider {
                  position: absolute;
                  top: 0px;
                  left: 0px;
                  width: 100%;
                  opacity: 1;
                  z-index: 1;
                  margin-bottom: 0px;
                  --card-mod-icon: fapro:lightbulb-google-fill;
                  {% else %}
                  --card-mod-icon: fapro:lightbulb-google;
                  {% endif %}
                  ha-card {
                    margin: 10px 0px 0px 0px !important;
                    width: 98% !important;
                  {% else %}
                  {% endif %}
          entity: light.reading_light
          tap_action:
            action: toggle
          icon_color: none
          card_mod:
            style:
                mushroom-slider {
                  position: absolute;
                  top: 0px;
                  left: 0px;
                  width: 100%;
                  opacity: 1;
                  z-index: 1;
                  margin-bottom: 0px;
                  {% else %}
                  {% endif %}
                  ha-card {
                    margin: 10px 0px 0px 5px !important;
                  {% else %}
                  {% endif %}
The font is google sans and the icons are from googles material design icon database. Can save the svgs and use as custom icons.
Leaving this comment here, but i have since realised that because i am using Margin it doesnt look good an all screen sizes. so beware of that. it works on pc screen size but not on phone. you can probably play with the margins to get it to work on just a phone if that is all you want to use it for. but for now back to the drawing table for me on how to solve this problem :slight_smile:
Add this:
              margin: 31px 23px 0px 172px;
              width: 44px;
              border-radius: 100px !important;
to your below code block:
        chips:
          - type: template
            icon: |-
                mdi:chevron-down
                mdi:chevron-up
              {% endif %}
            tap_action:
              action: toggle
            entity: input_boolean.thermostat_dropdown
            card_mod:
              style: |
                ha-card {
        alignment: end
        card_mod:
          style: |
            ha-card {
              width: 44px;
and remove your padding.
prevents what you currently have which is this:
instead becomes this:
No weird clicking around the chip :wink:
