hi all,
i hope anybody of you can help me with my problem in my mobile layout.
On my PC (Edge) everything looks fine
But on my iPhone not so good
The code for i looks like that:
type: custom:stack-in-card
cards:
- type: custom:layout-card
layout_type: grid
layout:
width: 100%
grid-template-columns: 60% auto
grid-template-rows: auto
cards:
primary: Whats-Up-Docker
secondary: '{{ states(''sensor.docker_whats_up_docker_status'') }}'
icon: mdi:docker
entity: sensor.docker_whats_up_docker_status
icon_color: blue
tap_action:
action: more-info
fill_container: true
card_mod:
style: |
:host {
--mush-icon-size: 76px;
height: 50px;
margin-left: -25px !important;
ha-card {
box-shadow: none;
- type: horizontal-stack
cards:
- type: custom:mushroom-chips-card
chips:
- type: template
content: '{{ states(''sensor.docker_whats_up_docker_cpu'') }} %'
icon: mdi:chip
entity: sensor.docker_whats_up_docker_cpu
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-height: 40px;
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
- type: template
content: '{{ states(''sensor.docker_whats_up_docker_memory_percent'') }} %'
icon: mdi:memory
entity: sensor.docker_whats_up_docker_memory_percent
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-spacing: 0;
alignment: end
when i modify the code like that - (change grid-template-columns from 60% to 50%)
cards:
layout_type: grid
layout:
width: 100%
grid-template-columns: 50% auto
cards:
icon: mdi:docker
icon_color: blue
tap_action:
action: more-info
card_mod:
style: |
:host {
height: 50px;
ha-card {
box-shadow: none;
cards:
chips:
- type: template
icon: mdi:chip
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-spacing: 0;
- type: template
icon: mdi:memory
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-spacing: 0;
alignment: end
Then the Problem is, that the primary-text is not shown completely
I hope anybody of you can help me to get it solved
If my code has other hickups, plz tell me - i am still learning
Does this work for you? Changed some of the sensors when testing so just change them back
cards:
layout_type: grid
layout:
width: 100%
grid-template-columns: auto
cards:
secondary: '{{ states(''sensor.docker_whats_up_docker_status'') | int }}'
icon: mdi:docker
icon_color: blue
tap_action:
action: more-info
card_mod:
style: |
:host {
height: 50px;
ha-card {
box-shadow: none;
width: 232px;
cards:
chips:
- type: template
content: '{{ states(''sensor.processor_use'') }}%'
icon: mdi:chip
entity: sensor.processor_use
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-spacing: 0;
width: 65px !important;
- type: template
content: '{{ states(''sensor.disk_use_percent'') }}%'
icon: mdi:memory
entity: sensor.disk_use_percent
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: 5px;
--chip-spacing: 0;
alignment: end
card_mod:
style: |
ha-card {
position: absolute;
top: 10px;
right: 20px;
--chip-spacing: 1px;
If you put any value behind your current template it will work. I think it is because your template is evaluating to a number so the template card is treating it as such. Put like this for example and it will work.
{{ states('sensor.processor_use') | round(1, 'floor') }}%
Bit of a workaround rather than solution. But it works.
Below where it says alignment, try this.
alignment: end
card_mod:
style: |
ha-card {
Let me know if this works. Otherwise we will need to reduce the size of the chips themselves
hi dimitri,
thx alot for your help - but there is still one problem
i am not 100% sure, with which values i can play a bit to get the right side larger
danwooller
(Dan Wooller)
August 6, 2023, 4:05pm
7594
Negative chip spacing gets them closer together
I’m using
--chip-spacing: -12px !important;
to get chips close enough together for my cards
danwooller
(Dan Wooller)
August 6, 2023, 4:08pm
7595
For the icon colour try using elif instead of a number of different if statements.
ffm777
(Carlo)
August 6, 2023, 4:34pm
7596
MrGrey:
Disclaimer: I’m a beginner. I’ve been using this “card” for a few weeks, on different platforms, without any issues, but I’ve likely made some rookie mistakes.
The card is very nice. Thank you! However, the input_datetime keeps disappearing on my system. I fixed it by replacing the vertical-stack-in-card by the stack-in-card in horizontal mode. Works perfectly now.
Azrael79
(Azrael)
August 6, 2023, 5:16pm
7597
Great man - sometimes its so easy
Almost ashamed that I have not tried this
siwilson
(Simon Wilson)
August 6, 2023, 6:44pm
7598
I haven’t but I am happy to do so if I knew where and how.
darko1515
(Darko1515)
August 6, 2023, 7:53pm
7599
Thanks. It worked flawlessly.
darko1515
(Darko1515)
August 6, 2023, 8:01pm
7600
Thanks for the suggestion. Not sure if I’m not doing something right but doesn’t seem to work.
I would like to have the sofa icon light up no matter how may light are on.
2 lights on:
1 light on:
icon_color: |-
{% if is_state('light.candelabru_living', 'on') %} orange {% endif %}
{% if is_state('light.instalatie_wifi', 'on') %} orange {% endif %}
{% if is_state('light.veioza', 'on') %} orange {% endif %}
tap_action:
Like this:
cards:
primary: Living Room
secondary: |-
{{ states('sensor.bedroom_temperature_humidity_temperature') }}°C |
{{ states('sensor.bedroom_temperature_humidity_humidity') }} %
icon: mdi:sofa
entity: light.bedroom_lights
icon_color: |-
{% if is_state('light.bedroom_main_light', 'on') %}
orange
{% elif is_state('light.wled_segment_1', 'on') %}
orange
orange
{% endif %}
tap_action:
action: navigate
navigation_path: /mushroom-one/living
hold_action:
action: none
multiline_secondary: false
layout: horizontal
fill_container: false
double_tap_action:
action: none
card_mod:
style: |
ha-card
{background: transparent;
border-style: none;
:host {
--mush-icon-size: 77px;
height: 66px;
margin-left: -17px !important;
chips:
- type: light
entity: light.bedroom_main_light
double_tap_action:
action: none
content_info: none
icon: mdi:string-lights
tap_action:
action: more-info
hold_action:
action: none
use_light_color: true
card_mod: null
style: |
ha-card
border-style: none;
- type: entity
entity: light.wled_segment_1
double_tap_action:
action: none
icon: mdi:television-classic
icon_color: primary
use_entity_picture: false
tap_action:
action: more-info
hold_action:
action: none
content_info: none
card_mod: null
style: |
ha-card
border-style: none;
- type: light
entity: light.wled_segment_2
double_tap_action:
action: none
icon: mdi:floor-lamp
content_info: none
tap_action:
action: more-info
hold_action:
action: none
card_mod: null
style: |
ha-card
border-style: none;
- type: entity
entity: climate.bedroom_heating
double_tap_action:
action: none
icon: mdi:air-conditioner
icon_color: primary
content_info: none
tap_action:
action: more-info
hold_action:
action: none
card_mod: null
style: |
ha-card
border-style: none;
alignment: end
MrGrey
August 7, 2023, 1:21am
7602
Too funny… I chose to use vertical-stack-in-card because it appeared newer and stack-in-card is no longer updated. Shortly after reading your note, I had a small problem with vertical-stack-in-card clipping some corners so I decided to try stack-in-card and it worked perfectly.
I guess newer isn’t always better.
MrGrey.
darko1515
(Darko1515)
August 7, 2023, 5:19am
7603
Thanks Dimitri. Apreciat it.
Now it works properly.
Proud of my dashboard. Took a while to read this mushroom thread but worth it.
j.otte
(J Otte)
August 7, 2023, 6:17am
7604
do more people have this problem? that the mushroom animation cards don’t do the animation?
with the last core update whats is maybe the problem how can wh that fix it?
Almost anywhere in your card mod yaml you have “ha-icon” it should now be “ha-state-icon” there are a few exceptions. But unless you are animating the icons on like buttons it should fix that aspect.
Then anywhere you have “–icon-animation” it should now be just “animation”
But if you have “–shape-animation” you should leave that.
Also if you have anywhere where your structure looks like this:
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
--icon-animation: rotation 1s linear infinite;
@keyframes rotation {
100% {
transform: rotate(360deg);
It will now need to be simplified down to this:
card_mod:
style: |
ha-state-icon {
100% {transform: rotate(360deg);}
j.otte
(J Otte)
August 7, 2023, 9:05am
7606
thanks we are going to try
danwooller
(Dan Wooller)
August 7, 2023, 10:11am
7607
darko1515:
icon_color: |-
{% elif is_state('light.instalatie_wifi', 'on') %} orange
{% elif is_state('light.veioza', 'on') %} orange {% endif %}
tap_action:
If you have a series of if statements then you’re setting the color each time, but with elif it only matches once.
Good evening, would anybody be able to help here im really struggling to get my head around what i need to do.
I would like to change the entity icon colour based on the state of the entity.
I have the below:
type: custom:mushroom-entity-card
entity: sensor.myenergi_zappi_24887740_plug_status
layout: vertical
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
I tried adding below but it doesent work:
icon_color: |2
{% if is_state('sensor.myenergi_zappi_2440_plug_status', 'EV Connected') %}
amber
{% elif is_state('sensor.myenergi_zappi_2740_plug_status', 'EV Disconnected') %}
red
{% elif is_state('sensor.myenergi_zappi_2440_plug_status', 'Charging') %}
green
{% endif %}
Any assistance would be appreciated
