Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
This one by @ingo.niehues is really nice. but it will not be a slider, just the current level.
There are a lot of others on this thread in general. just browse through it :slight_smile:
Hi!
I’m trying to get the Mushroom Template Card styled the same as the HA Tile card.
This is from the HA Frontend source (ha-tile-info.ts):
      .primary {
        font-weight: 500;
        font-size: 14px;
        line-height: 20px;
        letter-spacing: 0.1px;
        color: var(--primary-text-color);
      .secondary {
        font-weight: 400;
        font-size: 12px;
        line-height: 16px;
        letter-spacing: 0.4px;
I’ve got my Mushroom Template Card styled as follows:
card_mod:
  style: |
    ha-card {
      --icon-size: 40px;
      --card-primary-font-size: 14px;
      --card-primary-font-weight: 500;
      --card-primary-line-height: 20px;
      --primary-text-color: rgb(var(--primary-text-color));
      --card-secondary-font-size: 12px;
      --card-secondary-font-weight: 400;
      --card-secondary-line-height: 16px;
      --secondary-text-color: rgb(var(--primary-text-color));
The only thing missing are the letter-spacings. Does anybody know how I can set the primary letter-spacing to 0.1px and the secondary to 0.4px? I’ve tried ‘–card-primary-letter-spacing’ but that does not work. Adding ‘letter-spacing: 0.1px’ works but that is for the entire card.
Thanks!
Tinus
Hey,
i want to use the select card to select the fan speed of my vacuum but it is not an entity it is the vacuum entity. Is there a way to get these in the select card?
it is not possible to use the attribute of an entity as the entity in a card. you have to have an input_select entity for the select card.
I would create an input_select helper. add your fan speeds to it, and use that in the input select card.
you will then need to create and automation that checks if you changed the input_select and if you did, changes the fan attribute of your vacuum to what was selected in the input_select. and i would also add to your automation the opposite so when you change the vacuum fan state manually it would change the input_select to the correct fan speed as well. just to ensure that it doesnt go out of sync.
Yes you are correct. But there is one important matter. When you do not use this host, the cards may fly around during the first loading of the card.
Can you give an example of this behaviour? I have been entirely unable to use anything that changes location and/or size of the card through :host
If you check the last line of this code you will see that
           margin-left: 30px !important;
           margin-right: 30px !important;
Has been used inside host. You can also achieve this through ha-card. But this time chips start to float like this:
Merhaba-–-Home-Assistant
type: custom:vertical-stack-in-card
cards:
  - type: conditional
    conditions:
      - entity: input_boolean.live_tiles_topbar_hide
        state: 'on'
    card:
      type: horizontal-stack
      cards:
        - type: custom:vertical-stack-in-card
          cards:
            - type: horizontal-stack
              cards:
                - type: custom:mushroom-chips-card
                  card_mod:
                    style: |
                      :host {
                        padding-top: 5px;
                        padding-left: 10px;
                        padding-right: 10px;
                        padding-bottom: 5px;
                        --ha-card-background: white;
                      ha-card {
                        --chip-icon-size: 20px;
                       --chip-background: none;
                       --chip-border: none !important;
                       --chip-box-shadow: none;
                       --chip-font-size: 14px;
                        --chip-spacing: 2px;
                  chips:
                    - type: template
                      icon: phu:aqara-temperature
                      icon_color: >
                        {% set state =
                        states('sensor.aqara_outdoor_temperature')|float(-1)
                        %}   {%if state>= 29 %}   red {% elif state>=26 %}
                        red   {% elif state>=23 %}   green  {% elif state>= 20
                        %}  green  {% elif state>= 18 %}   green {% elif state>=
                        16 %}   blue    {% else %}   grey {% endif %}
                      content: '{{ states(''sensor.aqara_outdoor_temperature'')  }}°C'
                    - type: template
                      icon: mdi:home-thermometer
                      icon_color: >
                        {% set state = states('sensor.genel_sicaklik')|float(-1)
                        red   {% elif state>=23 %}   green  {% elif state>= 22
                        %}  green {% elif state>= 20 %}  blue {% elif state>= 18
                        %}   green {% elif state>= 16 %}   blue    {% else %}
                        grey {% endif %}
                      content: '{{ states(''sensor.genel_sicaklik'')  }}°C'
                    - type: template
                      entity: entity.entity
                      tap_action:
                        action: fire-dom-event
                        browser_mod:
                          service: browser_mod.popup
                            content:
                              cards:
                                - type: vertical-stack
                                  cards:
                                      primary: Offline Devices
                                      picture: /local/png/offline.png
                                      secondary: >
                                        {{ states('sensor.unavailable_entities')
                                      card_mod:
                                        style: |
                                          ha-card {
                                            background: none;
                                            margin-left: 0px;
                                            --icon-size: 98px;
                                            --primary-text-color: rgb(var(--rgb-amber));
                                            --secondary-text-color: rgb(var(--rgb-white));
                                            --card-primary-font-size: 15px;
                                            --card-secondary-font-weight: 500;
                                            --card-secondary-font-size: 14px;
                                    - type: custom:hui-element
                                      card_type: markdown
                                      content: >
                                        {%- if
                                        states('sensor.unavailable_entities')|lower
                                        not in ['unknown','unavailable','none']
                                          {%- if states('sensor.unavailable_entities')|int == 0 -%}
                                            No unavailable entities.
                                          {%- else -%}
                                            {%- for entity in state_attr('sensor.unavailable_entities','entities') -%}
                                            - {{ entity }}{%- if not loop.last -%}{{ '\n' }}{%- endif -%}
                                            {%- endfor -%}
                                          {%- endif -%}
                                        {%- endif -%}
                                      card_mod:
                                        style: |
                                          ha-card {
                                            background: none;
                                            margin-top: -20px;
                                            margin-left: 0px;
                                            --icon-size: 98px;
                              card_mod:
                                style: |
                                  ha-card {
                                    background: black;
                            style: |
                              --popup-background-color: black;
                              --popup-border-radius: 0px;
                              --popup-padding-x: 30px;
                              --popup-padding-y: 30px;
                            right_button: Kapat
                      icon: >
                        {% set state=states(entity) %} {% if state=='0' %}
                        mdi:audio-video {% else %} mdi:audio-video-off {% endif
                      icon_color: |-
                        {% if state=='0' %}
                        grey
                        {% else %}
                        red
                        {% endif %}
                      content: '{{ states(''sensor.unavailable_entities'')   }}'
                    - type: template
                      entity: light.all_house_lights
                      content: |
                        {{ states('sensor.open_light_and_switches_total') }}
                      icon: |-
                        {% if state=='off' %}
                        mdi:lightbulb-off-outline
                        {% elif state=='on' %}
                        mdi:lightbulb
                        {% else %}
                        mdi:door
                        {% endif %}
                      icon_color: |-
                        grey
                        amber
                        {% else %}
                        grey
                        {% endif %}
                      tap_action:
                        action: call-service
                        service: input_boolean.toggle
                          entity_id: input_boolean.live_tiles_room_cards
                      double_tap_action:
                        service: light.turn_off
                        data: {}
                          entity_id: light.all_house_lights
                  alignment: justify
          card_mod:
            style: |
              ha-card {
                  background: black;
                  margin-top: 0px;
                  margin-bottom: 0px;
                  width: auto;
                  background-color: none;
                  border-radius: 15px !important;
                  height: auto;
                  box-shadow: none !important;
              :host {
              --mush-icon-size: 75px;
               margin-top: 0px !important;
               margin-bottom: 5px !important;
              height: 40px !important;
card_mod:
  style: |
    ha-card {
        box-shadow: 10px;
        border-radius: 10px;
        height: auto;
        margin-top: 0px;
        margin-left: auto;
        margin-right: auto;
        margin-bottom: 0px;
        width: auto;
I see what you mean now.
Top through ha-card bottom through :host.
SmartSelect_20230915_125722_Home Assistant
Likely not encountered this because i try and avoid using margin.
I do always have the floating in because i style size and position through ha-card. But i see the benefit of :host with margin, but since it doesnt work for any other type of movement it seems a bit limited :confused:
i want to use your card but as soon i add an icon to the rooms the chips are not even anymore. Is there a way to fix this?
I use margin a lot in my designs. ha-card messes up everything but host is fine. It doen’t float around. But unfortunately it does not work under all circumstances. :host also works with height and some others too if I am not wrong.
I cant get height to work at all with :host which would definitely make me use it more if i could :slight_smile:
It does work. As you can see in the last line of the code :
                  :host {
                    height: 250px;
                    padding-right: 5px;
                    padding-left: 5px;
                     background: none;
cards:
  - type: conditional
    conditions:
        state: 'on'
    card:
      cards:
          cards:
              cards:
                  secondary: >
                    {% if is_state('binary_sensor.sonoff_sokak_kapi_sensor',
                    'on') %}
                      open
                    {% elif is_state('binary_sensor.sonoff_sokak_kapi_sensor',
                    'off') %}
                       closed
                    {% else %}    {% endif %}
                  primary: Door is
                  icon: null
                  icon_color: red
                  fill_container: false
                  multiline_secondary: false
                  layout: horizontal
                  picture: null
                  tap_action:
                    action: navigate
                    navigation_path: /dashboard-homekit/heating
                  card_mod:
                    style:
                      mushroom-state-info$: |
                        .primary {
                          font-size: 16px !important;
                          position: relative;
                          overflow: visible !important;
                          margin-top: -39px;
                          margin-left: 0px;
                          --primary-text-color: rgb(var(--rgb-white));
                          font-weight: bold;
                          text-overflow: ellipsis;
                          text-align: left;
                          width: 70px;
                          text-indent: 5px;
                          border-radius: 0px;
                        .secondary {
                          position: relative;
                          margin-top: -24px;
                          margin-left: 61px;
                          --secondary-text-color: var(--amber-color);
                        ha-card {
                          height: 100px !important;
                  secondary: >
                    {% if is_state('alarm_control_panel.ha_alarm', 'disarmed')
                      disarmed
                    {% elif is_state('alarm_control_panel.ha_alarm',
                    'armed_away') %}
                       loaded
                    {% elif is_state('alarm_control_panel.ha_alarm', 'arming')
                       arming
                    {% else %}
                      check
                    {% endif %}
                  primary: Alarm is
                  icon: null
                  icon_color: red
                  layout: horizontal
                  picture: null
                  card_mod:
                    style:
                        .primary {
                          position: relative;
                          margin-top: -39px;
                          margin-left: -13px;
                          font-weight: bold;
                          text-align: left;
                          width: 70px;
                          text-indent: 5px;
                          border-radius: 0px;
                        .secondary {
                          position: relative;
                          margin-top: -24px;
                          margin-left: 58px;
                          width: auto;
                        ha-card {
                        :host {
                          width: -10px;
                  secondary: |
                    {% if is_state('input_boolean.trv_close_open', 'on') %}
                      on
                    {% elif is_state('input_boolean.trv_close_open', 'off') %}
                       closed
                  primary: Heating is
                  icon: null
                  icon_color: red
                  layout: horizontal
                  picture: null
                  tap_action:
                    action: navigate
                  card_mod:
                    style:
                        .primary {
                          position: relative;
                          margin-top: -39px;
                          margin-left: 0px;
                          font-weight: bold;
                          text-align: left;
                          width: 70px;
                          text-indent: 5px;
                          border-radius: 0px;
                        .secondary {
                          position: relative;
                          margin-top: -24px;
                          margin-left: 85px;
                        ha-card {
                        :host {
          card_mod:
            style: |
              ha-card {
                  background: none;
                  margin-right: 0px;
                  margin-bottom: 0px;
                  width: auto;
                  border-radius: 0px !important;
                  :host {
                    height: 250px;
                    padding-right: 5px;
                    padding-left: 5px;
                     background: none;
card_mod:
  style: |
    ha-card {
        box-shadow: 10px;
        height: auto;
        margin-top: 0px;
        margin-left: auto;
        margin-right: auto;
        margin-bottom: 0px;
        width: auto;
Works kind off. If you apply directly to template card you get very different results with ha-card vs :host
both height 200px
I can certainly see the benefit of :host but ill need to get in the habit of saving my changes before judging whether it works i guess.
I am too used to seeing my changes happen in editor which doesnt happen with :host
Sorry I didn’t get that. You can preview :host changes in the editor. You don’t have to save in order to see it.
And as you can see in my previous example I applied the card directly into vertical-stack card but it can also be applied to mushroom template card. The hint here is, if you gonna apply it to a template card you must avoid using that template card under a conditional card.
Look at my example above. Only thing done to each is height: 200px !important;
ha-card
type: custom:mushroom-template-card
primary: Hello, {{user}}
secondary: How are you?
icon: mdi:home
card_mod:
  style: |
    ha-card {
:host
icon: mdi:home
card_mod:
  style: |
    :host {
No result in editor:
Once saved reserves 200px of space. But doesnt make the card itself 200px like ha-card does.
there is a card under here which isnt shown in the screenshot
It can be applied like that. And you can see changes in the editor.
cards:
    icon: mdi:home
    card_mod:
      style:
          :host {
Hi, I’m working in a custom sidebar, and I want to modify a mushroom-template-card as you can see in the red box
So far I have it this way.
When the view is active, the template card should light up as you can see.
I share the code with you.
type: custom:stack-in-card
cards:
  primary: Control Lights
  icon: mdi:lightbulb-group
  tap_action:
	action: navigate
	navigation_path: kiosk
  icon_color: white
  fill_container: true
  layout: horizontal
  card_mod:
	style: |
	  :host([dark-mode]) {
		background: #2D2D2D;
	  :host {
		background: #E0E4FD;
		--mush-icon-size: 60px;
	  mushroom-shape-icon {
		--shape-color: transparent !important;
	  ha-card {
		padding: 3px !important;
card_mod:
style: |
  ha-card {
	border-radius: 30px;
  ha-card:active {
	  transform: translatey(1.5px);
	  transition: 0s;
	  box-shadow: 0px 0.5px 2px 0px rgba(0, 0, 0, 0.16);
I am having problems with the text and icon alignment, and also as you can see, the padding doesn’t look very good
Could you please help me out?
I tried to use this card but somehow the bar itself isn’t displayed, i only get text.
Any ideas, wrong sensor format maybe?
Did you install the custom bar-card ?
Edit:
You probably did.
The issue is with the color of the bar.
replace: color: rgb(var(–mush-green)) with
color: lightgreen for example
Thanks that fixed it indeed :wink:
Maybe you also know or anyone else?
Can you add volume control to template card?
Searched this thread, github page and via google but cound’t find an answer other then it probably is not possible with the template card itself.
