Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Iā€™m not sure I understand your question, but here is an example of a card that I use for my lights:
type: custom:local-conditional-card
default: hide
card:
  type: vertical-stack
  title: Lampes
  cards:
    - square: false
      type: grid
      cards:
          layout: vertical
          primary: Led
          secondary_info: none
          entity: switch.lampe_led
          icon: mdi:wall-sconce-round-variant
          icon_color: |-
            {% if is_state('switch.lampe_led', 'on') %}
              black
            {% else %}
              grey
            {% endif %}
          card_mod:
            style: |
              ha-card {
                {% if is_state(config.entity, 'on') %}
                  background-color: rgba(147,112,219, 1);
                {% else %}
                  background-color: rgba(var(--rgb-card-background-color));
                {% endif %}
          layout: vertical
          primary: Guirlande
          entity: switch.lampe_guirlande
          icon: mdi:string-lights
          icon_color: |-
            {% if is_state('switch.lampe_guirlande', 'on') %}
              black
            {% else %}
              grey
            {% endif %}
          card_mod:
            style: |
              ha-card {
                {% else %}
                {% endif %}
          layout: vertical
          primary: Chevet
          entity: switch.lampe_chevet
          icon: mdi:lamp
          icon_color: |-
            {% if is_state('switch.lampe_chevet', 'on') %}
              black
            {% else %}
              grey
            {% endif %}
          card_mod:
            style: |
              ha-card {
                {% else %}
                {% endif %}
      columns: 3
    - square: false
      type: grid
      cards:
        - features:
            - type: light-brightness
          type: tile
          entity: light.lampe_canape
          card_mod:
            style: |
              .background {
                  background: color-mix(in srgb, var(--tile-color) 50%, var(--card-background-color));
                {% endif %}
      columns: 1
lights
You can add as many cards as you want, they just need to start with local-conditional-card with the same ID (in my example id: light)
default: hide
When you press the button, it shows or hides the cards with the different IDs that you will have defined in the ā€œtap_actionā€ parameters of the button
            tap_action:
              action: fire-dom-event
              local_conditional_card:
                action: set
                ids:
                  - home: hide
                  - light: toggle
                  - portail: hide
                  - camera: hide
                  - media: hide
                  - divers: hide
                  - monitoring: hide
                  - device: hide
                  - serveur: hide
                  - net: hide
                  - meteo: hide
                  - plan: hide
                  - search: hide
                  - temperature: hide
                  - humidite: hide
Thatā€™s the solution. Thanks
Hi There,
is there a mushroom card that can be used to load a image as icon?
Mushroom template card
Great I see the Picture option nowā€¦ Not using the template card that much ā€¦ thanks!!
thanks, im trynh to change the button on your card:
and then i should add ā€œlocal-condition-cardā€ so i can press a button to show the menĆ¹ā€¦ i have two problems:
1- i dont manage to change the entity in the first card
2- i dont understand how to set a button to touch to show the card (for example light card that you posted)
can you help me?
Edit: got it. added card_mod styling to my custom theme:
my-custom-theme:
  card-mod-theme: my-custom-theme
  card-mod-card: |
    ha-card {
      text-shadow: 0px 5px 5px rgba(0,0,0,0.3);
Lots of knowledgeable people on this thread and couldnā€™t get an answer elsewhere so trying here :slightly_smiling_face:
Is it possible to style ā€œtext-shadowā€ globally via theme / some type of ā€œanchorā€; or can it only be done at the card level? ex with mushroom cards:
   style: |
            ha-card {
it obviously works at the card level but Iā€™d like to make it ā€œdefaultā€ for all dashboard text.
Thanks!
Hello everyone!
I would like to have this overview for my 3D printer (Bambulabs X1C):
Threedy 2.0
Unfortunately, I do not get any further than that:
2023-10-24_06h46_38
Code
type: custom:vertical-stack-in-card
cards:
  - type: custom:stack-in-card
    cards:
        primary: Bambulab X1C
        secondary: |-
          {% if is_state('sensor.y1_print_status','running') %}
            {{ (states("sensor.y1_print_progress") |float ) | round(0) }}% |
            {% set ct = states('sensor.y1_remaining_time') | int %}
            {{ (ct | float // 60) | round(0) }}h {{ (ct | float % 60) | round(0) }}m
          {% else %}
            {{states('sensor.y1_print_status') }}
          {% endif %}
        icon: mdi:printer-3d-nozzle
        icon_color: |-
            blue
          {% endif %}
        badge_color: red
        badge_icon: null
        entity: light.y1_chamber_light
        tap_action:
          action: none
        fill_container: true
        layout: horizontal
        multiline_secondary: false
        card_mod:
          style:
            mushroom-shape-icon$: |
              .shape {
                background: radial-gradient(var(--card-background-color) 60%,
                transparent calc(60% + 1px)),
                conic-gradient(rgb(var(--rgb-blue)) {{ states('sensor.y1_print_progress') }}% 0%,
                var(--card-background-color) 0% 100%);
                z-index: 1;
              .shape:after {
                {% if is_state('sensor.geschirrspuler_operation_state', 'Run') %}
                  content: '';
                  height: 100%;
                  width: 100%;
                  position: absolute;
                  border-radius: var(--icon-border-radius);
                  background: var(--shape-color);
                {% endif %}
              mushroom-state-info {
                z-index: 1;
              mushroom-badge-icon {
                z-index: 1;
  - type: custom:mushroom-chips-card
    chips:
      - type: entity
        entity: sensor.y1_nozzle_temperature
        icon: mdi:printer-3d-nozzle-heat
      - type: entity
        entity: sensor.y1_bed_temperature
        icon: mdi:heating-coil
      - type: template
        content: |-
        icon: mdi:alarm
Can someone help me there? Thanks!
using dimitriā€™s styling guide
this one was looking straightforward but doesnā€™t work.
using the same code as the example from the guide.
changing the indentation doesnā€™t work either
can you help pinpoint the issue?
Did you get it to mimic the tile card?
Chips do not have a .shape or even a mushroom-shape-icon.
Look in my chip section of my guide.
To get a border around a chip it is this simple:
chips:
  - type: entity
    entity: person.dimitri_landerloos
    card_mod:
      style: |
        ha-card {
          border: 2.5px outset green !important;
Hi @tomg1970,
Could you share your code for this great display, please?
Thank you Dimitri,
I guess Iā€™m looking at the wrong section but I found this under your ā€œchips cardā€ section:
For future reference, can you point me to the correct info?
Thx :+1:
No, you are looking at the right section. That is just definitely wrong. Will get that fixed.
Thanks for pointing that out! :slight_smile:
EDIT: now fixed :slight_smile:
Phew.
Thought I was going mad :crazy_face:
Thx againšŸ‘
Very nice, thank you !
I like to mop my floors 3 times, how could this been integrated in your script ā€œRun Vacuumā€ ?
This is not working and I donā€™t know why :
      - service: vacuum.send_command
          command: app_segment_clean
          params:
            - segments: |
                {% set vacrooms = namespace(roomid=[]) %}
                {% for rooms in state_attr('sensor.roborock_rooms','rooms') -%}
                  {% if is_state(rooms.boolean,'on') %}
                    {% set room = rooms.id %}
                    {% set vacrooms.roomid = vacrooms.roomid + [room] %}
                  {% endif %}
                {%- endfor %}
                {{ vacrooms.roomid }}
              repeat: 3
          entity_id: vacuum.roborock_q8_max
Which one exactly do you mean?
Hi @Guizmos , finally Im finishing to configure my phone dashboard.
Anyway, my last question to finisce bottom bar, I donā€™t manage to configure ''The Search? in your bar. Im installing Open Ai and created input.text, anyway I donā€™t obtain answer.
Can you help me please?
@Tsar ā€¦ I am adding you to the other thread. Scripts relative to vacuum have nothing to do with Mushroom, please ask there. You will get invite as it was created as a PM.
That said, I would try ā€œrepeatsā€ and not ā€œrepeatā€, if I use developer tools and set up mine which uses roborock.vacuum_clean_segment:
service: roborock.vacuum_clean_segment
  segments:
    - 17
    - 2
  repeats: 2
Your latest!
