Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
These all work and correspond to the actual color.
  --rgb-state-climate-auto
  --rgb-state-climate-cool
  --rgb-state-climate-dry
  --rgb-state-climate-fan-only
  --rgb-state-climate-heat
  --rgb-state-climate-heat-cool
  --rgb-state-climate-idle
  --rgb-state-climate-off
I’ve started making a TV card using rounded styling its looking pretty good so far
Thank you so much Dimitri!
It as worked…
How i know i need to put this mushroom-cover-position-control$:?
Take a look at the guide in my profile. First post section titled: “what the $ and .: | symbols do”.
That will explain how you can do it :slight_smile:
Excelent work, i had not seen, thanks a lot, for your work and help :clap: :clap:
I love this! but struggling to solve my own needs on this issue How do i create an badge with a spinning green fan if <switch.double_switch_2_current_value_2> is on for this card?
type: custom:mushroom-template-card
primary: Bad
secondary: |-
  {{states ('sensor.sensor_bad_1_etg_temperature')}}°C
  {{states ('sensor.sensor_bad_1_etg_humidity')}}%
icon: mdi:bathtub
entity: switch.double_switch_2_current_value
icon_color: |-
  {% if is_state('switch.double_switch_2_current_value', 'on')%}
    orange
  {% endif %}
layout: vertical
tap_action:
  action: navigate
  navigation_path: /lovelace/bad
hold_action:
  action: toggle
fill_container: true
Thank you. This works as expected:
type: custom:mushroom-climate-card
entity: climate.2e_ac
icon: mdi:air-conditioner
fill_container: false
show_temperature_control: true
collapsible_controls: true
layout: horizontal
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        {% if is_state(config.entity, "heat") %}
          --shape-animation: pingheat 1.5s infinite;
        {% elif is_state(config.entity, "cool") %}
          --shape-animation: pingcool 1.5s infinite;
        {% elif is_state(config.entity, "dry") %}
          --shape-animation: pingdry 1.5s infinite;
        {% elif is_state(config.entity, "fan_only") %}
          --shape-animation: pingfan 1.5s infinite;
        {% endif %}
      } @keyframes pingheat {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-state-climate-heat),1); }
        100% { box-shadow: 0 0 5px 15px transparent; }
      } @keyframes pingcool {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-state-climate-cool),1); }
      } @keyframes pingdry {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-state-climate-dry),1); }
      } @keyframes pingfan {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-state-climate-fan-only),1); }
cheers,
You could just use the built in badges for the majority of that and then animate it.
primary: Bad
secondary: |-
icon: mdi:bathtub
icon_color: |-
    orange
  {% endif %}
badge_icon: |-
  mdi:fan
badge_color: |-
    blue
  {% endif %}
layout: vertical
tap_action:
  action: navigate
hold_action:
  action: toggle
card_mod:
  style: |
    mushroom-badge-icon {
        animation: spin 1s linear infinite;
      {% else %}
        display: none;
      {% endif %}
Does anyone know how I can set the bottom bar to “automatic” distance, for any desired device?
now there is always wasted space under the last bar, and I would like everything to fill the screen.
Climate card:
Any way to increase the container size of the temperature controls?
entity: climate.thermostats_2e
layout: vertical
primary_info: none
icon_type: none
secondary_info: none
card_mod:
  style:
    mushroom-climate-temperature-control$:
      mushroom-input-number$: |
        .value {
          font-size: 3rem;
          padding: 1rem
        #container {
          background: red;
          height: 5rem ;
          padding: 1rem;
        #container .button:nth-child(1) {
          --control-icon-size: 4rem;  }
        #container .button:nth-child(3) {
      ha-card {
       width: 20rem;
       height: 10rem !important;
       padding: 0rem !important;
       border: solid ;
       background: yellow ;
try like this:
entity: climate.office_heating
layout: vertical
primary_info: none
icon_type: none
card_mod:
  style:
        .value {
          font-size: 3rem;
          padding: 1rem
        #container {
          background: red;
          padding: 1rem;
          height: 200px !important;
      mushroom-button-group$: |
        .container {
      ha-card {
        width: 20rem;
        border: solid ;
Why do I end up with an offset between the 2 containers ?
ps: styles and colors for testing purposes only :grinning:
entity: climate.thermostat_2e_fireplace
layout: horizontal
primary_info: none
icon: mdi:thermometer
card_mod:
  style:
        .value {
          font-size: 2rem;
          padding-left: 1rem
          padding-right: 1rem
        #container {
          background: red;
          padding: 1rem;
          height: 4rem !important;
          width: 20rem !important;
          --control-icon-size: 3rem;
        .container {
          background: green;
      .shape {
        --icon-symbol-size: 3rem;
        --icon-size: 4rem;
      ha-card {
        width: 30rem;
        height: 5rem !important;
        border: solid ;
        align-items: center;
try to throw a justify-content: flex-start !important; in your button group container.
its currently flex end so it wont fit.
That was it :slightly_smiling_face: Thank you!
hi Dimitri.
Can you help to set “secondary” in Christmas tree card (animated)… if I add secondary It give me an error.
Anyway, I have two Christmas tree, and I need two card. could you show me a different Christmas tree card so I can avoid errors to turn on the lights?
thanks
Trying to figure out the switch to dark-mode, but can’t quite figure out how to adjust the colors based on the state of the host. I’ve removed the references to :host here for clarity. It currently looks like the first image, which is fine when in light mode, but I’m trying to have it adjust to the second when dark mode is detected.
Screenshot 2023-11-27 183321
Screenshot 2023-11-27 183904
type: custom:stack-in-card
cards:
  - type: custom:mushroom-fan-card
    entity: fan.air_purifier
    primary_info: name
    show_oscillate_control: false
    show_percentage_control: true
    icon: mdi:blank
    tap_action:
      action: none
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style:
        mushroom-fan-percentage-control$: |
          mushroom-slider {
              --main-color: #7fdee9 !important;
              --bg-color: #ccf2f6 !important;
          .shape {
            --shape-color: none !important;
    primary: null
    layout: horizontal
    icon: mdi:air-purifier
    icon_color: '{{ ''cyan'' if is_state(entity, ''on'') else ''disabled'' }} '
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    badge_icon: mdi:power
    badge_color: '{{ ''#3CB371'' if is_state(entity, ''on'') else ''#DAA520'' }} '
    card_mod:
      style: |
        {% if is_state(config.entity, 'on') %}
        ha-state-icon {
            animation: air {{ 25 / state_attr(config.entity , 'percentage') }}s infinite;
        @keyframes air {
          0%, 100% { clip-path: inset(0 0 0 0); }
          25% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 98% 32%, 63% 42%, 65% 58%, 100% 43%); }
          75% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 100% 44%, 64% 61%, 64% 73%, 100% 72%); }
          50% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 78% 38%, 64% 43%, 64% 72%, 100% 73%); }
        {% else %}
        {% endif %}
        ha-card {
          width: 69px;
          top: -121px;
    primary: null
    layout: horizontal
    entity: switch.air_purifier_auto_mode
    icon: mdi:fan-auto
    icon_color: '{{ ''#FF8360'' if is_state(entity, ''on'') else ''disabled'' }} '
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    card_mod:
      style: |
        {% else %}
        {% endif %}
        ha-card {
          width: 69px;
          top: -186px;
          float: right;
    primary: null
    layout: horizontal
    entity: light.air_purifier_led
    icon: >-
      {{ 'mdi:lightbulb-on' if is_state(entity, 'on') else 'mdi:lightbulb-off'
    icon_color: '{{ ''#FEDC97'' if is_state(entity, ''on'') else ''disabled'' }} '
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    card_mod:
      style: |
        {% else %}
        {% endif %}
        ha-card {
          width: 43px;
          top: -252px;
          left: -69px;
          float: right;
card_mod:
  style: |
    ha-card {
      height: 122px;
You can use @media queries in card mod like this for example (but works for anything, just keep in mind the element needs to be in the @media query, and not the variables).
Dark Mode:
Light Mode:
card_mod:
  style: |
    @media (prefers-color-scheme: dark) {
      ha-card {
        background-color: darkblue;
    @media (prefers-color-scheme: light) {
      ha-card {
        background-color: lightblue;
just bear in mind that doing this does start making your code harder to read - so i would limit the use if possible :slight_smile:
You are going to have to show me what you have tried already.
Does anyone know how to vertical alignment this mushroom entity card as described in the picture?
Thank you!
yes!
first card:
cards:
    entity: switch.smart_switch_2101058756376290838848e1e94400bc_outlet
    icon: mdi:pine-tree
    icon_color: green
    primary: Luci Albero di Natale
    icon: mdi:star-four-points
    icon_color: yellow
    primary: Star
    card_mod:
      style:
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: star 8s ease infinite alternate;
          @keyframes star {
            0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
            50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
    icon: mdi:gift
    icon_color: red
    card_mod:
      style:
          .shape {
            --icon-size: 20px;
            top: 16px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -132px;
          ha-state-icon {
            animation: surprise 4s ease infinite;
          @keyframes surprise {
            0%, 20%, 100% { transform: translateY(0); }
            2.5% { transform: translateY(-2px) rotate(-27deg); }
            5% { transform: translateY(-2px) rotate(21deg); }
            7.5% { transform: translateY(-2px) rotate(-15deg); }
            10% { transform: translateY(-2px) rotate(9deg); }
            12.5% { transform: translateY(0); }
            15% { transform: translateY(-1.2px) }
card_mod:
  style: |
    ha-card {
      height: 66px;
second old card before your update for others mass lights:
cards:
    entity: switch.koogeek_o1eu_b56a4b_outlet3
    icon: mdi:pine-tree
    icon_color: green
    primary: Addobbo Portale
    icon_color: yellow
    primary: Star
    card_mod:
      style:
          ha-icon {
            --icon-animation: star 8s ease infinite alternate;
          @keyframes star {
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
    icon: mdi:grain
    icon_color: red
    card_mod:
      style:
          ha-icon {
            --icon-animation: flash 2s steps(1) infinite, lights 2s infinite;
            clip-path: polygon(51% 15%, 24% 74%, 74% 74%);
          @keyframes flash {
            50% { transform: rotateY(180deg); }
          @keyframes lights {
            0%, 100% {--icon-color: rgb(var(--rgb-red)); }
            6.25% { --icon-color: rgb(var(--rgb-deep-orange)); }
            12.5% { --icon-color: rgb(var(--rgb-orange)); }
            18.75% { --icon-color: rgb(var(--rgb-amber)); }
            25% { --icon-color: rgb(var(--rgb-yellow)); }
            31.25% { --icon-color: rgb(var(--rgb-lime)); }
            37.5% { --icon-color: rgb(var(--rgb-light-green)); }
            43.75% { --icon-color: rgb(var(--rgb-green)); }
            50% { --icon-color: rgb(var(--rgb-teal)); }
            56.25% { --icon-color: rgb(var(--rgb-cyan)); }
            62.5% { --icon-color: rgb(var(--rgb-light-blue)); }
            68.75% { --icon-color: rgb(var(--rgb-blue)); }
            75% { --icon-color: rgb(var(--rgb-indigo)); }
            81.25% { --icon-color: rgb(var(--rgb-deep-purple)); }
            87.5% { --icon-color: rgb(var(--rgb-purple)); }
            93.75% { --icon-color: rgb(var(--rgb-pink)); }
          .shape {
          ha-card {
            width: 66px;
            top: -132px;
    icon: mdi:gift
    icon_color: red
    card_mod:
      style:
          ha-icon {
            --icon-animation: surprise 4s ease infinite;
          .shape {
            --icon-size: 18px;
            top: 18px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -198px;
card_mod:
  style: |
    ha-card {
      height: 66px;
thank you
