Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
For the same card i already provided you, or for an entirely new card?
Current Card
type: custom:mushroom-template-card
primary: Test
icon: mdi:fountain
icon_color: amber
entity: light.lounge_corner_lamp
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(var(--icon-color) {% if states('sensor.washing_machine_washer_job_state') != 'none' %} {{(((((as_timestamp(states('sensor.washing_machine_washer_completion_time')) - as_timestamp(states('input_datetime.washing_machine_start_time')))) - (as_timestamp(now()) - (as_timestamp(states('input_datetime.washing_machine_start_time'))))) / (as_timestamp(states('sensor.washing_machine_washer_completion_time')) - as_timestamp(states('input_datetime.washing_machine_start_time')))) * 100) | round(0)}}% {% else %} 100% {% endif %} 0%, var(--card-background-color) 0% 100%);
      ha-state-icon {
        {% if is_state(config.entity, 'on') %}
          animation: fountain 1.5s ease infinite;
        {% endif %}
      mushroom-shape-icon:after {
        content: '24';
        position: absolute;
        top: -11%;
        right: -11%;
        display: flex;
        justify-content: center;
        align-items: center;
        width: 15px;
        height: 15px;
        font-size: 9px;
        font-weight: 700;
        background-color: rgba(var(--rgb-amber), 0.5);
        border-radius: 50%;
      @keyframes fountain {
        0%, 100% { clip-path: polygon(0 100%,0 0, 100% 0, 100% 100%); }
        50% { clip-path: polygon(0 100%, 0 47%, 100% 47%, 100% 100%); }
        60% { clip-path: polygon(0 100%, 100% 100%, 100% 37%, 79% 36%, 71% 21%, 56% 25%, 44% 25%, 31% 20%, 20% 36%, 0 36%); }
        70% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 71% 22%, 81% 1%, 24% 0, 31% 21%, 20% 36%, 0 36%); }
        80% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 76% 28%, 100% 0, 0 0, 23% 28%, 20% 36%, 0 36%); }
      ha-card {
         padding: 5px 0px 0px 0px !important;
      :host {
        --icon-size: 35px !important;
        --card-primary-font-size: 9px !important;
        --card-secondary-font-size: 9px!important;
New Card
primary: Hello, {{user}}
secondary: How are you?
icon: mdi:fountain
card_mod:
  style: |
    ha-state-icon {
      {% endif %}
    ha-card {
    :host {
Its just using layout: vertical in the template cards. But things needed moving around after that. Its just playing around with the values in these sections until it looks the way it should:
          ha-card {
            top: -118px;
            background: none !important;
          .shape {
            --shape-color: none;
            --icon-size: 20px;
            top: 16px;
            left: 18px;
          ha-card {
            top: -183px;
            right: 10px;
Its never easy to overlap cards, so its always a bit of playing around until it looks right.
Thank you. And yes, I already tried the vertical layout of course, and next to that … I already concluded that it is about playing with the values, but I couldn’t find which one(s) :sweat_smile:
Thanks for pointing out, I’ll go and play :sunglasses:
How did you clear the text? What did you write In the script to do so?
@image969 I will answer here but see below note. This is two step process because what needs to be done is:
  1. Erase the data on the Vizio TV search screen
  2. Erase the content in the Home Assistant search box
For step (1), I send the “backspace” command via REST for every character that is in the Home Assistant search box. “Backspace” is codeset 0, code 8. For step (2) I set the Home Assistant search box to a blank.
clear_vizio_search:
  alias: Clear Vizio Search
  sequence:
  - repeat:
      count: '{{ states(''input_text.vizio_search'') | length }}'
      sequence:
      - service: rest_command.vizio_processkey
          ip: 192.168.1.232
          port: '7345'
          auth: XXXXXXXX
          codeset: '0'
          code: 8
  - service: input_text.set_value
      value: ' '
      entity_id: input_text.vizio_search
  mode: single
  icon: mdi:trash-can
NOTE: Getting a bit off topic for Mushroom. If you have future questions perhaps post here:
I appreciate the help, and I feel like I may have over complicated my last question. I didn’t realize your coding was specific to Vizio.
My goal is specifically having a visible text input on a mushroom card which you gave me and it works great for playing music on different Alexa devices in my house.
All I wanted to do as far as clearing when I click on the text box to type in a new song I don’t want to have to backspace the previous letters I typed in. I just want to click one button and it clears the text from the box. So I can start typing something new
Then the second part of the script works. Add a delete button and call:
      value: ' '
Of course using your entity input_text. Note that using ‘’ and not ’ ’ will not work, it also has been reported but you need a space which will clear the text field.
Awesome, thanks again for the help
I read your post, before you took it down. Def sounds cool. IF and when Im ready for that I might reach out.
I think I’d be more interested in something like that for my PLex library. But thats a project for another day. Im using PlexMeetsHomeassistant right now and its garbage.
And Im way off the Mushroom topic here. So thanks again
Does anyone have a solution for me? I do apriciatate any help?. I got it somewhat to work when off but it only shows an icon. How can i make it take up the whole space like a cover? The full layout is a few post up.
Code
entity: input_boolean.crucial_velocity_helper
layout: vertical
picture: '{{''/local/images/CrucialVelocityRadio.jpg'' if not is_state(entity, ''on'') }}'
fill_container: false
multiline_secondary: false
tap_action:
  action: call-service
  service: input_boolean.toggle
    entity_id: input_boolean.crucial_velocity_helper
double_tap_action:
card_mod:
  style:
      ha-card {
        {{ 'background: center / cover no-repeat url("/local/images/Music1.gif");' if is_state(config.entity, 'on') }}
        width: 100px;
        height: 100px;
        margin: auto;
      mushroom-state-item {
        height: 96px;
        --icon-size: 100px;
I have edited this card with many if that I have used to change states and colors, when windows open and closed, etc…
My question is it possible to simply, or the way I made is correct
Thanks a lot
style: |
  ha-card {
    width: 360px;
    border: none;
    background-color: #E2E2E2;
    box-shadow: 2px 2px 4px 0px rgba(89,89,89,1);
cards:
  - type: custom:mushroom-cover-card
    entity: cover.velux_internal_cover_blinds_2
    show_buttons_control: true
    show_position_control: true
    card_mod:
      style:
        mushroom-cover-position-control$: >
          mushroom-slider { {% if states('cover.velux_internal_cover_blinds_2')
          == 'open'%}
            --slider-bg-color: #89DF83!important;
          {% else %}
            --slider-bg-color: #FF483F!important;
          {% endif %}  {% if states('cover.velux_internal_cover_blinds_2') ==
          'opening'%}
          {% endif%} {% if state_attr ('cover.velux_internal_cover_blinds_2',
          'current_position') == 100 %}
            --slider-color: #89DF83!important;
          {% else %}
            --slider-color: #B9B7B7!important;
          {% endif %} }
        mushroom-shape-icon$: >
          .shape {  {% if states ('cover.velux_internal_cover_blinds_2') ==
          'open'%}
            --icon-color: #008B19!important;
          {% else %}
            --icon-color: white!important;
          {% endif %} {% if states ('cover.velux_internal_cover_blinds_2') ==
          'open'%}
            --shape-color: #89DF83!important;
          {% else %}
            --shape-color: #FF483F!important;
          'opening'%}
          {% endif %} }
        mushroom-cover-buttons-control$:
          mushroom-button:nth-child(1):
              .button {
                 background: white!important;
              ha-icon {
                --card-mod-icon-color: #FF9800;
          mushroom-button:nth-child(2):
              .button {
              ha-icon {
        mushroom-button$: |
          .button {
           ha-icon {
        mushroom-state-info$: |
          .container {
            --card-primary-font-size: 15px;
            --card-secondary-font-size: 15px;
            --primary-text-color: #FF9800;
            --secondary-text-color: #008CB6;
            font-family: Copperplate;
        style: |
          ha-card {
            border: none;
primary: ''
icon: mdi:fountain
icon_color: amber
entity: switch.fountain
card_mod:
  style:
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(var(--icon-color) {{  (states("counter.fountain_timer"))|int*100 }}% 0%, var(--card-background-color) 0% 100%);
      ha-state-icon {
        {% endif %}
        content: '24';
        position: absolute;
        top: -11%;
        right: -11%;
        display: flex;
        width: 15px;
        height: 15px;
        font-size: 9px;
        font-weight: 700;
        border-radius: 50%;
      ha-card {
      :host {
Screenshot 2023-12-06 at 1.23.15 PM
please check the code, what am I doing wrong, The icon background colour is not showing like below icon
Screenshot 2023-12-06 at 1.25.59 PM
Nothing wrong. Thats what i showed you would happen.
You can get it back if you set a color like this:
--card-background-color: rgba(87, 72, 30, 1);
But you have to set a static color. Otherwise it will not work. The color also has to have 100% opacity (hence the 1 at the end).
primary: ''
icon: mdi:fountain
icon_color: amber
card_mod:
  style:
      .shape {
        --card-background-color: rgba(255, 255, 30, 0.5);
      ha-state-icon {
        {% endif %}
        content: '24';
        position: absolute;
        top: -11%;
        right: -11%;
        display: flex;
        width: 15px;
        height: 15px;
        font-size: 9px;
        font-weight: 700;
        border-radius: 50%;
      ha-card {
      :host {
I’m not getting the icon shape color changed. I used the code form the mushroom style guide thread:
Any idea?
Thank you, a lot, for helping.
Kind regards
Benedikt
Can I see the code for the house temp card please? Thanks.
1ec37d38c1694a57ff2f9eb237ad8ce0dfb61da2
Found it and put celcius/percentage in it as well.
Thanks for the initial config @PskNorz !
type: custom:stack-in-card
cards:
    primary: Kantoor
    secondary: >-
      {{ states('sensor.office_temperature') | round(1) }}°C  | {{
      states('sensor.office_humidity') }} %
    icon: mdi:thermometer-water
    card_mod:
      style: |
        ha-card {
          z-index: 1;
          --ha-card-border-width: 0;
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.office_temperature
        color: green
      - entity: sensor.office_humidity
        color: '#3399ff'
        y_axis: secondary
    height: 50
    hours_to_show: 24
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      fill: fade
    card_mod:
      style: |
        ha-card {
          position: absolute !important;
          height: 100%;
          width: 100%;
          top: 0px;
        ha-card:after {
          content: "";
          position: absolute;
          width: 100%;
          height: 100%;
          background: linear-gradient(to right, var(--card-background-color) 20%, transparent);
Hopefully this should clear it up :slight_smile:
This was the solution :slight_smile: Thank you! Didn’t see this post berfore… Once we’re in touch: Is it possible to have a shadow for the icon itself (not the shape)?
Thank you so very much.
How can i achieve the same thing if i use mushroom chip?
Can you plz share the code.
Regards
Love it, thank you.
