Not sure if this helps but I combined attributes to create a sensor that was based off the direction and speed. That helped pair down the if then results.
sensors:
fan_direction:
friendly_name: "Fan Direction"
unique_id: fan1
value_template: "{{ state_attr('fan.bedroom_fan', 'direction') }}"
fan_direction_speed:
friendly_name: "Fan Direction Speed"
unique_id: fan2
value_template: |
{% set direction = state_attr('fan.bedroom_fan', 'direction') %}
{% set speed = state_attr('fan.bedroom_fan', 'percentage') %}
{{[direction,speed]|join("")}}
mushroom-slider support min max properties so this should be possible to add. Don’t have any workaround we can do right now and have to wait for the feature to be added. I need this feature as well so might create a PR to add this when I get the time.
Edit: actually, there’s already a pending PR that add this exact feature:
That really looks insane!!!
Would love to create this for my (47) Hue devices, wow!
If you’re ever able to document how you achieved this, that would be awesome.
Thanks for sharing!
looks like this section is also being used to color the inside of the custom icons. clearly handmade sizing 1 by 1. Well done on that btw, that takes some effort @LiQuid_cOOled :
Wow, that looks really cool. Thanks for the tag, I will definitely incorporate that. I can’t wait to see how it looks. It’s just too bad for you that it doesn’t work with HTTPS again. Unfortunately, I still haven’t found another solution. I have the same problem on my companion app via HACloud, too
Thanks.
I think I would be thankful forever, if @LiQuid_cOOled wants to share his formatted code, although I would understand it is just too much work to “just share”…
Nice find with the pending PR, I’ll hope that gets implemented.
Looking at it though, it seems like it’s been left un-merged, likely because the change in behaviour would be a breaking change.
Maybe the PR could be modified to have a toggle switch for minimum value of 1 instead of zero?
