Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
mushroom-entity-card is not suitable. I want to use different icons for three states. And in mushroom-template-card it is just possible to implement it.
Use it as your main entity.
is it possible to change icons in mushroom-entity-card depending on the state of other sensors? I want to make three different icons depending on two sensors (door sensor and key lock sensor):
  1. The door is open
  2. The door is closed
  3. The door is locked with a key
Like this :slightly_smiling_face:
  entity: binary_sensor.zigbee_main_door_key
  primary: Main door
  secondary: >
  icon: >
  icon_color: >
  tap_action:
    action: more-info
Just change the mdi icons that you want
No, you have to use mushroom-template-card.
it’s work! Thanks! It’s so elementary!
Hi guys,
I am hoping someone might be able to help me with this. I am new to card_mod and themes and have been trying to create room cards using stack-in-card, mushroom chips and custom button card for icon/navigation.
I want to use chips to show a simple glance of what is on on the room, if window is open, motion etc. I have it working through conditions but if everything is active at one it pushes the last chip to the next line. I was hoping to find a way of adjusting the gap between chips to be able to accommodate everything on one line. Ideally I wouldn’t want to change the gap between chips on the whole pages just on a room by room basis.
Thanks in advance.
Single braces! Thank you. This problem was driving me crazy.
{0}
always looking for ideas that I can steal :slight_smile:
part of my start page:
You are missing the card-mod integration: GitHub - thomasloven/lovelace-card-mod: 🔹 Add CSS styles to (almost) any lovelace card
hi, you can show how you added sensor.charging and sensor.battery_level on person card?
thanks.
If you are using the normal HA Grid card, you will need to add square: false to the grid (or in the visual editor it should be a toggle at the top labeled “Render as square”, or something close to that.
worked like a charm! thanks
Here you go…
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon_color: |2-
                    {% set state=states('binary_sensor.sm_s21_fabian_is_charging') %}
                    {% if state=='on' %}
                    green
                    {% elif state=='off' %}
                    #6f6f6f
                   {% endif %}
        entity: binary_sensor.sm_s21_fabian_is_charging
        icon: mdi:power-plug
        tap_action:
          action: more-info
      - type: template
        entity: sensor.sm_s21_fabian_battery_level
        icon: |2
                    {% set bl = states('sensor.sm_s21_fabian_battery_level') | int %}
                    {% if bl < 10 %} mdi:battery-outline
                    {% elif bl < 20 %} mdi:battery-10
                    {% elif bl < 30 %} mdi:battery-20
                    {% elif bl < 40 %} mdi:battery-30
                    {% elif bl < 50 %} mdi:battery-40
                    {% elif bl < 60 %} mdi:battery-50
                    {% elif bl < 70 %} mdi:battery-60
                    {% elif bl < 80 %} mdi:battery-70
                    {% elif bl < 90 %} mdi:battery-80
                    {% elif bl < 100 %} mdi:battery-90
                    {% elif bl == 100 %} mdi:battery
                    {% else %} mdi:battery-unknown
                    {% endif %}
        icon_color: |2-
                    {% if bl < 10 %} red
                    {% elif bl < 20 %} red
                    {% elif bl < 30 %} red
                    {% elif bl < 40 %} orange
                    {% elif bl < 50 %} orange
                    {% elif bl < 60 %} orange
                    {% elif bl < 70 %} green
                    {% elif bl < 80 %} green
                    {% elif bl < 90 %} green
                    {% elif bl < 100 %} green
                    {% elif bl == 100 %} green
                    {% else %} grey
                    {% endif %}
        tap_action:
          action: more-info
Hey all,
@pedolsky thank you for your help in the other channel.
I know some of you have asked for this card in the repo for :mushroom: Mushroom. I also understand the complexities for the dev to get the card built. With some trial and error, I have managed to create a card I am happy with what I have achieved.
This card is used with Google Calendar, Mushroom chips and Mushroom Person card, to navigate to various dashboards we use around the house.
Let me know if there is a better place to share the YAML and ask me anything.
card:
  type: vertical-stack
  cards:
    - type: custom:mushroom-title-card
      title: |2-
                   {%- if now().hour < 12 -%}Morning
                   {%- elif now().hour < 18 -%}Afternoon
                   {%- else -%}Evening{%- endif -%}, {{user}}
      subtitle: >-
        ♻️ {{state_attr('calendar.bins', 'message')}} on {{
        as_timestamp(state_attr("calendar.bins","start_time") |
        default(now(),true) )| timestamp_custom('%-d %b') }}
    - type: horizontal-stack
      cards:
          card_mod:
            style: |
              :host {
                padding-top: 10px;
                padding-left: 10px;
                padding-bottom: 25px;
                --ha-card-background: white;
          chips:
            - type: action
              icon_color: red
              tap_action:
                action: navigate
                navigation_path: media-control
              icon: mdi:remote
              hold_action:
                action: none
              double_tap_action:
                action: none
            - type: action
              icon_color: blue
              tap_action:
                action: navigate
                navigation_path: audio
              icon: mdi:radio
            - type: action
              icon_color: blue-grey
              icon: ios:hifispeaker-fill
              tap_action:
                action: navigate
                navigation_path: media-settings
            - type: action
              icon_color: amber
              hold_action:
                action: none
              double_tap_action:
                action: none
              icon: mdi:lightbulb-group
              tap_action:
                action: navigate
                navigation_path: all-lights
            - type: action
              icon_color: green
              icon: mdi:timeline-clock
              hold_action:
                action: none
              double_tap_action:
                action: none
              tap_action:
                action: navigate
                navigation_path: automations
          alignment: justify
      cards:
        - type: custom:mushroom-person-card
          card_mod:
            style: |
              :host {
                padding-left:10px;
                --ha-card-background: #292929;
          entity: person.dan
          fill_container: true
          icon: mdi:face-man
          tap_action:
            action: navigate
            navigation_path: dan
          hold_action:
            action: none
          double_tap_action:
            action: none
          card_mod:
            style: |
              :host {
                padding-left:10px;
          entity: device_tracker.chloe
          icon: mdi:face-woman
card_mod:
  style: |
    ha-card {
      background: #1c1c1c;
      padding-left: 25px;
      padding-right: 25px;
Can anyone advise if it’s possible to set padding on the mushroom title card using card mod ? - It doesn’t seem to have a ha-card element so isn’t working like the other cards, and I can’t figure out the right selector for it.
i put them on vertical stack but chips card are below person card. could u show how to put them together?
thanks a lot.
hej,
here the whole card, there is also a popup window included for detailed location
type: custom:stack-in-card
mode: vertical
cards:
    entity: person.fabian
    use_entity_picture: true
    hide_name: true
    layout: vertical
    tap_action:
      action: fire-dom-event
      browser_mod:
        command: popup
        deviceID: this
        title: Fabian
        card:
          type: custom:mod-card
          style: |
            ha-card {
               padding-right: 15px;
               padding-left: 15px;
               padding-bottom: 15px;
          card:
            cards:
              - type: custom:mushroom-entity-card
                entity: sensor.places_fabian_locatie
                primary_info: none
                icon: mdi:map-marker
                icon_color: yellow
                cards:
                  - type: map
                    entities:
                      - entity: device_tracker.life360_fabian_verschoor
                    aspect_ratio: '2'
    chips:
      - type: template
        icon_color: |2-
                    green
                    #6f6f6f
                   {% endif %}
        tap_action:
          action: more-info
      - type: template
        icon: |2
                    {% endif %}
        icon_color: |2-
                    {% elif bl < 60 %} green
                    {% else %} grey
                    {% endif %}
        tap_action:
          action: more-info
    alignment: center
How do you make your fan icons spin?
