Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Thanks for the clarification, I’ll edit the post :+1:
Sure no problem and thank you in advance!
Hello, can you please help me?
I would like my fan to spin when they are on.
I’m not doing well at all.
type: custom:mushroom-chips-card
chips:
  - type: template
    tap_action:
      action: more-info
    entity: fan.chlazeni_goodwe_ventilator
    icon: mdi:fan
card_mod:
  style: |
    ha-icon {
      animation: spin 1s linear infinite;
    ha-icon[icon-animation='none'] {
      animation: none;
This should work for you. There may be an easier way, but this is what I use.
chips:
  - type: template
    tap_action:
      action: more-info
    icon: mdi:fan
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
        animation: rotate 1s linear infinite;
      @keyframes rotate {
          100% { transform: rotate(360deg); }
@LiQuid_cOOled Thank you very much. It works perfectly. Can I ask how to set the fan to not spin if the entity is off?
This should do it
chips:
  - type: template
    tap_action:
      action: more-info
    icon: mdi:fan
card_mod:
  style:
      ha-state-icon {
        {{ 'animation: rotate 2s linear infinite;' if is_state('fan.chlazeni_goodwe_ventilator', 'on') }}
       @keyframes rotate {
How can I replace an icon with a local image?
Can you share the code you are working with?
@LiQuid_cOOled Thank you very much for your help. Everything works great. I wish you a wonderful Christmas.
You can make these changes via customize.yaml
Example:
@dimitri.landerloos
I have changed the size of the buttons, in cover card, i saw your tutorial :wink:, but the problem is the slider i can’t change the size…I already tried slider-track-background but doesn’t work.
Do you known how to do it?
      mushroom-button:nth-child(1):
          ha-icon {
            --card-mod-icon-color: #6A6A6A;
          .button {
            background: #E2E2E2!important;
            width: 70px!important;
Take a look at this section in the guide :slight_smile:
Clearly i need to change wording slightly as i am saying it doesnt apply when making buttons smaller, but i mean it doesnt apply when making the slider smaller.
Didn’t work
mushroom-cover-position-control$: |
      mushroom-slider {
        {% if states ('cover.shellyswitch25_68c63af92f48') == 'open'%}
          --slider-bg-color: #89DF83!important;
        {% else %}
          --slider-bg-color: #FF483F!important;
        {% endif %}
        {% if states ('cover.shellyswitch25_68c63af92f48') == 'opening'%}
        {% endif %}
        {% if state_attr ('cover.shellyswitch25_68c63af92f48', 'current_position') == 100 %}
          --slider-color: #89DF83!important;
        {% else %}
          --slider-color: #B9B7B7!important;
        {% endif %}
      mushroom-slider$: |
        .slider {
          width: 120px!important;
is it possible to make a mushroom select card change its icon and color with each state?
for example:
if my ‘home_status = home’
icon: mdi:home account
icon_color: green
and if ‘home_status = away’
icon: mdi:home-export-outline
icon_color: red
Post your full card mod section. But the indentation is clearly wrong. You have 2 | in a row. 1 for mushroom-cover-position-control$: | and then 1 for mushroom-slider$: |
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          width: 120px;
Not allowed. 2 | in a row.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          width: 120px;
Allowed.
This will probably also do it on its own:
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          width: 120px !important;
          {% if states (config.entity) == 'open'%}
            --bg-color: #89DF83 !important;
          {% else %}
            --bg-color: #FF483F !important;
          {% endif %}
          {% if states (config.entity) == 'opening'%}
          {% endif %}
          {% if state_attr (config.entity, 'current_position') == 100 %}
            --main-color: #89DF83 !important;
          {% else %}
            --main-color: #B9B7B7 !important;
          {% endif %}
Yes with card mod. Just an example so replace with your entity and your entity states.
type: custom:mushroom-select-card
entity: input_select.speaker_group_dropdown
card_mod:
  style: |
    mushroom-shape-icon {
      {% if states(config.entity) == 'Upstairs Speakers' %}
        --card-mod-icon: mdi:home-account;
        --icon-color: rgb(var(--rgb-red)) !important;
        --shape-color: rgba(var(--rgb-red), 0.2) !important;
      {% elif states(config.entity) == 'Downstairs Speakers' %}
        --card-mod-icon: mdi:home-export-outline;
        --icon-color: rgb(var(--rgb-green)) !important;
        --shape-color: rgba(var(--rgb-green), 0.2) !important;
      {% else %}
        --card-mod-icon: mdi:bug;
        --icon-color: rgb(var(--rgb-blue)) !important;
        --shape-color: rgba(var(--rgb-blue), 0.2);
      {% endif %}
Thanks Dimitri… its worked
How we know to use this configurations?
Sorry dont understand your question?
How you know do you have put muhsroom-sliders$: ?
After you have put --bg-color: and main-color:
How i can know that? Developer Tools?
Thanks, this works.
