Looks really good! i might even steal this idea for myself.
well done!
well done!
thanks works fine!
Last question itās possible add a progress bar.
I have the start time and finish time of stream.
Hi, sorry if Im a little bit out of topics, but may I ask about your esphome code for the air quality sensors (mh z19, bme680, and the PM 2.5) that you build? also some wiring diagrams if you not busyā¦thanks so much
Seems that Iām kind of stuck doing the configuration of those nice animations. Iāve just pasted some examples into my dashboard and tried to adapt for my entities used. Anyway, I cannot see any animation.
Cardmod and Mushroom is latest version.
Any hints?
type: horizontal-stack
cards:
icon: mdi:lightning-bolt
icon_color: amber
primary: Charge
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
--icon-animation: charge 1s linear infinite;
@keyframes charge {
0%, 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, 100% { transform: translate(0, 0); }
5% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
15% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
25% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
35% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
45% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
55% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
65% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
75% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
85% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
95% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
icon: mdi:flash
icon_color: red
primary: Bezug
secondary: '{{ states(''sensor.leistung_netzbezug_evcc'') }} W'
card_mod:
style:
ha-icon {
--icon-animation: flash 4s linear infinite;
@keyframes flash {
0%, 4%, 8%, 12%, 16%, 20%, 24%, 28%, 32%, 100% { transform: translate(0px,0px); }
2% { transform: translate(-0.3px, 0px); }
6% { transform: translate(0.3px, 0px); }
10% { transform: translate(-0.2px, 0px); }
14% { transform: translate(0.2px, 0px); }
18% { transform: translate(-0.2px, 0px); }
22% { transform: translate(0.5px, 0px); }
26% { transform: translate(-0.5px, 0px); }
34% { transform: translate(-1px, 5px); --icon-color: rgb(var(--rgb-amber)); }
38% { transform: translate(0px, 0px); --icon-color: rgb(var(--rgb-white)); }
40% { --icon-color: rgb(var(--rgb-amber)); }
Cards are shown, but no animation is running.
ha-state-icon {
has to be separated from mushroom-shape-icon$:
with .: |
This should get you headed in the right direction
icon: mdi:flash
icon_color: red
primary: Bezug
card_mod:
style: |
ha-state-icon {
@keyframes flash {
a little more complexā¦
type: custom:vertical-stack-in-card
cards:
icon: m
card_mod:
style:
.shape {
--icon-symbol-size: 60px !important;
--icon-size: 60px !important;
--shape-color: none;
ha-state-icon {
width: 40px;
height: 10px;
color: blue;
background:
radial-gradient(farthest-side,red 90%,#0000) left /10px 10px,
radial-gradient(farthest-side,blue 90%,#0000) center/10px 10px,
radial-gradient(farthest-side,red 90%,#0000) right /10px 10px,
linear-gradient(currentColor 0 0) center/100% 4px;
background-repeat: no-repeat;
position: relative;
animation: s6 2s infinite linear;
ha-state-icon:before,
ha-state-icon:after {
content: "";
position: absolute;
inset:0;
background:inherit;
animation:inherit;
--s:calc(50% - 5px);
animation-direction: reverse;
--s:calc(5px - 50%);
@keyframes s6 {
0% {transform: translate(var(--s,0)) rotate(0)}
100% {transform: translate(var(--s,0)) rotate(1turn)}
card_mod:
style: |
ha-card {
box-shadow: none;
--ha-card-border-width: 0px;
background-color: rgba(100, 100, 100, .1);
ok, thats working, but not sure if I got it
At least the basic integration is not working at allā¦ like in the example, just quoted, no spinning fan or pulse.
icon: mdi:pulse
icon_color: red
primary: Pulse
card_mod:
style:
ha-icon {
--icon-animation: pulse 2s ease-in-out infinite;
Please compare this code to yours and check out https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/7716:
@dimitri.landerloos has a very detailed guide.
type: custom:mushroom-template-card
primary: Spin
icon: mdi:fan
icon_color: teal
card_mod:
style: |
ha-state-icon {
animation: spin 1s linear infinite;
Aye, so itās just ha-state-icon and not the mushroom-shape-icon code like in the example.
yes and animation:
vs--icon-animation:
More complex animations will require keyframes to execute.
Hi all,
It looks like something is changed within the cards? Last week I updated my HACS integrations and after that my card is changed. Before the update, this map was a single entity, see the image below for reference:
After the update, the map has separate buttons:
I havenāt changed anything in the code. Does anyone know how this problem can be solved?
type: custom:stack-in-card
mode: horizontal
cards:
- type: custom:mushroom-media-player-card
entity: media_player.zeppelin_wireless
icon: mdi:soundbar
volume_controls: []
fill_container: false
show_volume_level: true
use_media_info: false
collapsible_controls: true
tap_action:
action: none
media_controls: []
primary_info: name
secondary_info: state
style: |
ha-card {
background-color: transparent;
box-shadow: none;
border: solid 0px rgba(100, 100, 100, 0.3);
font-family: Arial, Helvetica, sans-serif;
- type: custom:mushroom-entity-card
fill_container: true
secondary_info: none
layout: vertical
icon_color: indigo
primary_info: none
tap_action:
action: call-service
service: media_player.volume_mute
is_volume_muted: true
entity_id: media_player.zeppelin_wireless
icon: mdi:volume-mute
style: |
ha-card {
box-shadow: none;
layout: vertical
icon_color: indigo
primary_info: none
tap_action:
service: script.radio_volume_down
data: {}
icon: mdi:minus
style: |
ha-card {
box-shadow: none;
layout: vertical
icon_color: indigo
primary_info: none
tap_action:
service: script.radio_volume_up
data: {}
icon: mdi:plus
style: |
ha-card {
box-shadow: none;
Check out the breaking changes in card_mod 3.40
Iām trying to set icon color based on the state of the entity in my 3d printer. the state attribute is a hex code for the color of the filament. however the yellow makes the circle surrounding the icon disappear. anyone know how to rectify this? the hexcode for the yellow is #FFFF0AFE if that makes a diff
horizontal: true
cards:
primary: AMS 1
secondary: '{{ states(''sensor.p1s_01p00a3b2500877_ams_1_tray_1'') }}'
icon: mdi:circle-slice-8
entity: counter.aircon_clean_pipes
icon_color: "{{ state_attr('sensor.p1s_01p00a3b2500877_ams_1_tray_1', 'color') }}"
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
primary: AMS 2
secondary: '{{ states(''sensor.p1s_01p00a3b2500877_ams_1_tray_2'') }}'
icon_color: "{{ state_attr('sensor.p1s_01p00a3b2500877_ams_1_tray_2', 'color') }}"
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
primary: AMS 3
secondary: '{{ states(''sensor.p1s_01p00a3b2500877_ams_1_tray_3'') }}'
icon_color: "{{ state_attr('sensor.p1s_01p00a3b2500877_ams_1_tray_3', 'color') }}"
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
primary: AMS 4
secondary: '{{ states(''sensor.p1s_01p00a3b2500877_ams_1_tray_4'') }}'
icon_color: "{{ state_attr('sensor.p1s_01p00a3b2500877_ams_1_tray_4', 'color') }}"
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
type or paste code here
Ah, perfect. Thank you. The solution was:
Replace
style: |
For:
card_mod:
style: |
Clearing cache is a temporary fix, it just reverts back after a couple of days use.
Try and split the 2 last characters from your hex code. Reason being is that your hex code has an alpha channel and this doesnt work with the alpha channel of the icon background.
Should be able to do it like this:
{{'#FFFF0AFE'[:7]}}
Sounds like an issue with your browser more than something i can help you with unfortunately.
Is it the IOS having this issue by any chance?
Like i said notoriously hard to FULLY clear browser cache on IOS/MAC/Safari.
No worries. Yes, I have fully cleared cache/data on the browser. It seems to be a WebKit issue more than anything as Safari on Mac is the only one affected.
I know in the meantime how to change the color of the icon via card-mod. Just tried to achieve the same more centrally via a theme. But when I use the following I get only a white icon. Any idea?
I tried with
mush-rgb-state-cover-open: pink
mush-rgb-state-cover-closed: orange
but this lead only to a white icon, I do not understand why
A few questions
Are you placing those settings in a new renamed theme file in the themes/mushroom
folder ? You have to create your own file. Editing the stock mushroom theme will not work. If yes ensure you are using that theme in your profile.
Are you using the mushroom-cover -card? Those settings will not alter a mush room-template-card.
I am assuming yes to both questions and believe your issue is the way you entered the colors. The colors have to match the code like this:
mush-rgb-state-cover-open: var(--mush-rgb-pink)
mush-rgb-state-cover-closed: var(--mush-rgb-orange)
The stock color is blue and when I added green it worked perfect. Donāt forget to do a quick restart.
