Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Looked so much and it was right in front of me :sweat_smile:
Thanks a million!
Hi everyone
I have a Hoval homevent house ventallation system which I can control via MQTT (integration is MQTT template sensors in the yaml)
Everything works as expected, my only struggle is the mushroom-humidifier-card dispaying the configured target humidity as a secondary info.
This is what I have at the moment:
Secondary info on both cards is on the default, which should be state.
Dev tools for the entites:
I understand that the state is literally ā€˜onā€™ and the ā€˜50%ā€™ target humidity is only in the attributes, but the same is true for the fan control too, and that picks up the 50% percentage.
If I interpret the source code correctly, it should pick up the humidity?
https://github.com/piitaya/lovelace-mushroom/blob/dc54101a9b787b55794eee38620886306deba318/src/cards/humidifier-card/humidifier-card.ts#L119
If anyone has any hints if Iā€™m doing someething wrong please let me know
I interpret the source code differently. The target humidity only shows when onCurrentHumidityChange is triggered.
If you enact a humidity change the target humidity appears when the slider is engaged, not as the secondary info.
Iā€™m eager for additional opinionsā€¦
Iā€™m almost there, thanks for the help!! :). Is there a way to change the SVG image that it lookslike the mdi:fire in color red? (Like the image in the top right corner). Or do i have to edit the image itself?
The image is working with this code:
Screenshot 2024-01-15 at 10.48.56
type: custom:mushroom-template-card
primary: Badkamer
secondary: '{{ states(''sensor.temperatuur_ruimte_taster_badkamer_1_5'') }} Ā°C'
icon: mdi:shower-head
entity: light.lampen_badkamer_1_5
badge_color: |-
  {% if is_state('switch.radiator_badkamer_1_5', 'on') %}
    red
  {% endif %}
icon_color: |-
  {% if is_state('light.lampen_badkamer_1_5', 'on') %}
    orange
  {% endif %}
hold_action:
  action: toggle
tap_action:
  action: navigate
  navigation_path: /badkamer-kim-en-jos
layout: vertical
badge_icon: |-
    mdi:fire
  {% endif %}
card_mod:
  style: |
    {% if is_state('switch.vloerverwarming_badkamer_1_5', 'on') %}
      ha-state-icon::after {
        content: "";
        position: absolute;
        top: +60%;
        right: -11%;
        display: flex;
        justify-content: center;
        align-items: center;
        width: 15px;
        height: 15px;
        border-radius: 50%;
        background-repeat: no-repeat;
        background-image: url("/local/animated/fire.svg") !important;
        background-position: top;
        background-size: cover;
    {% endif %}
Youā€™ll have to edit the image yourself or download another one. There are plenty of available colored images for that icon.
Adding overflow: visible will make it worse, it will hide the rest of stack:
type: custom:stack-in-card
mode: vertical
keep:
  margin: false
card_mod:
  style: |
    ha-card {
      overflow: hidden;
cards:
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: custom:mushroom-climate-card
        entity: climate.living_room_ac
        layout: vertical
        hvac_modes:
          - heat_cool
          - heat
          - cool
          - 'off'
        tap_action:
          action: more-info
        icon: mdi:air-conditioner
        card_mod:
          style: |
            ha-card {
              border: none;
              border-right: 1px solid #333;
        entity: climate.office_ac
        layout: vertical
        hvac_modes:
          - heat_cool
          - heat
          - cool
          - 'off'
        tap_action:
          action: more-info
        card_mod:
          style: |
            ha-card {
              border: none;
    card_mod:
      style: |
        ha-card {
          border: none;
          margin-bottom: none !important
    mode: horizontal
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: sensor.living_room_ac_relative_humidity_measurement
        alignment: center
        card_mod:
          style: |
            ha-card {
              --chip-padding: 0 !important;
              --chip-border-width: 0 !important;
              --chip-height: 44px;
      - type: custom:mushroom-select-card
        entity: input_select.living_room_ac_timer
        icon: mdi:progress-clock
        name: Living Room AC Timer
        primary_info: none
        secondary_info: none
        icon_type: none
        card_mod:
          style: |
            ha-card {
              border: none;
              overflow: visible;
            .type-custom-mushroom-select-card {
              padding: 0 10px 0 0;
        chips:
          - type: entity
            entity: sensor.office_ac_relative_humidity_measurement
        alignment: center
        card_mod:
          style: |
            ha-card {
              border: none;
        entity: input_select.office_ac_timer
        name: Office AC Timer
        primary_info: none
        icon_type: none
        card_mod:
          style: |
            ha-card {
              border: none;
              padding: 0 12px 0 0;
    card_mod:
      style: |
        ha-card {
          border: none;
          padding-bottom: 12px;
Also, how can I can not 25-25-25-25% but like 15-35-15-35% columns width?
@MrGrey suggested Adding overflow: visible and I hoped it would help. I have to crash, but layout-card with the grid option will help you a ton.
An example
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 20% 80%
      margin: 0px 0px 0px 0px
    cards:
thank you! I had to put in both stacks and this layout-card is awesome.
my card dont animate based on state. What im doing wrong?
Can anyone help? thanks in advance
entity: binary_sensor.lxc_pialert_106_status
icon: mdi:washing-machine
icon_color: amber
primary: Washing Machine
card_mod:
  style: |
    ha-state-icon { {
      {{'animation: shake 400ms ease-in-out infinite, drum 2s ease infinite; transform-origin: 50% 110%;' if is_state(config.entity, 'on')}}
    @keyframes shake {
      0%, 100% { transform: translate(0, 0) rotate(0); }
      20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
      40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
      60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
      80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    @keyframes drum {
      50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
I changed cards and now I no longer know where to go to put the code you recommended (ā€“icon-size: 60px !important;) to increase the image, and I would also like to know how to eliminate the edges of the cards
type: horizontal-stack
cards:
  - type: horizontal-stack
    cards:
        cards:
            cards:
              - type: custom:mushroom-person-card
                entity: person.mario
                alignment: left
                style: |
                  ha-card {
                    height: 170px !important;
                    width: 240px !important;
                    padding: 12px 20px 12px 20px !important;
                use_entity_picture: true
                icon_type: entity-picture
                entity_picture: "/local/pictures/person_mario.png"
                layout: vertical
                tap_action:
                  action: more-info
                  browser_mod:
                    command: popup
                    deviceID: this
                    title: mario
                    card:
                      type: custom:mod-card
                      style: |
                        ha-card {
                          padding-right: 5px;
                          padding-left: 5px;
                          padding-bottom: 5px;
                      card:
                        type: vertical-stack
                        cards:
                          - type: custom:mushroom-entity-card
                            entity: sensor.iphone_x_mario_geocoded_location
                            primary_info: none
                            icon: mdi:map-marker
                            icon_color: yellow
                            cards:
                              - type: map
                                entities:
                                  - entity: device_tracker.iphone_x_mario
                                aspect_ratio: '2'
                style: |
                  ha-card {
                    --chip-box-shadow: none;
                    --chip-background: none;
                    --chip-spacing: none;
                    --chip-height: 43px;
                chips:
                - type: template
                  icon_color: |
                    {% set state = states('sensor.iphone_x_mario_battery_state') %}
                    {% if state == 'In carica' %}
                      green
                    {% elif state == 'Non in carica' %}
                      #6f6f6f
                    {% endif %}
                  entity: sensor.iphone_x_mario_battery_state
                  content: '{{ states(entity) }}'
                  icon: mdi:power-plug
                  tap_action:
                    action: more-info
                - type: template
                  entity: sensor.iphone_x_mario_battery_level
                  content: '{{ states(entity) }} %'
                  icon: |
                    {% set bl = states('sensor.iphone_x_mario_battery_level') | int %}
                    {% if bl < 10 %} mdi:battery-outline
                    {% elif bl < 20 %} mdi:battery-10
                    {% elif bl < 30 %} mdi:battery-20
                    {% elif bl < 40 %} mdi:battery-30
                    {% elif bl < 50 %} mdi:battery-40
                    {% elif bl < 60 %} mdi:battery-50
                    {% elif bl < 70 %} mdi:battery-60
                    {% elif bl < 80 %} mdi:battery-70
                    {% elif bl < 90 %} mdi:battery-80
                    {% elif bl < 100 %} mdi:battery-90
                    {% elif bl == 100 %} mdi:battery
                    {% else %} mdi:battery-unknown
                    {% endif %}
                  icon_color: |
                    {% if bl < 10 %} red
                    {% elif bl < 20 %} red
                    {% elif bl < 30 %} red
                    {% elif bl < 40 %} orange
                    {% elif bl < 50 %} orange
                    {% elif bl < 60 %} green
                    {% elif bl < 70 %} green
                    {% elif bl < 80 %} green
                    {% elif bl < 90 %} green
                    {% elif bl < 100 %} green
                    {% elif bl == 100 %} green
                    {% else %} grey
                    {% endif %}
                  tap_action:
                    action: more-info
                - type: entity
                  entity: proximity.home
                  icon_color: white
                  card_mod: null
                  style: |
                    ha-card {
                      box-shadow: 0px 0px;
Trying to replicate the People card using Template card in order to add additional secondary sensors info, but struggling to get the Badge icon to show for all zones created not just home/away.
Iā€™ve used input_selectors, but wasnā€™t sure if this was the correct way and didnā€™t like this method, as I have to specify each zone individually which isnā€™t a viable solution, so I removed the code.
entity: person.hazio
primary: hazio
secondary: >-
  {{ states('person.hazio')|capitalize }} Ā· {{
  states('sensor.hazio_iphone_battery_level') }}%
picture: |
  {{ state_attr(config.entity, 'entity_picture') }}
badge_icon: |
tap_action:
  action: more-info
badge_color:
icon: ''
multiline_secondary: false
How do I go abouts achieving this? thanks
This all looks correct. do you have card mod installed from HACS?
yes, i already reinstalledā€¦
can you try this instead? you have extra { } in front and behind your ha-state-icon
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      {{'animation: shake 400ms ease-in-out infinite, drum 2s ease infinite; transform-origin: 50% 110%;' if is_state(config.entity, 'on') }}
    @keyframes shake {
    @keyframes drum {
Please help me with an attached image, I would like to create a single card by inserting the status and battery level, enlarging the image and the status, am I clear? kindly I need some help
Screenshot 2024-01-15 150446
cards:
    cards:
        cards:
            cards:
                alignment: left
                style: |
                  ha-card {
                layout: vertical
                tap_action:
                  action: more-info
                  browser_mod:
                    command: popup
                    deviceID: this
                    title: mario
                    card:
                      style: |
                        ha-card {
                          padding-right: 5px;
                          padding-left: 5px;
                      card:
                        cards:
                            primary_info: none
                            icon_color: yellow
                            cards:
                              - type: map
                                entities:
                                aspect_ratio: '2'
                style: |
                  ha-card {
                chips:
                - type: template
                  icon_color: |
                      green
                      #6f6f6f
                    {% endif %}
                  tap_action:
                    action: more-info
                - type: template
                  icon: |
                    {% endif %}
                  icon_color: |
                    {% else %} grey
                    {% endif %}
                  tap_action:
                    action: more-info
                - type: entity
                  icon_color: white
                  card_mod: null
                  style: |
                    ha-card {
yes, it works, i see after i will reply you :slight_smile: many thanks , now i can anymate the chipcardā€¦
chips:
  - type: template
    icon: mdi:pi-hole
    icon_color: red
card_mod:
  style: |
    ha-state-icon {
    @keyframes wink {
      0%, 100% { transform: scale(1, 1); }
      19% { transform: scale(1.05, 0.6); }
      20% { clip-path: polygon(0 100%, 100% 100%, 100% 49%, 86% 51%, 79% 59%, 70% 66%, 57% 71%, 43% 71%, 29% 65%, 21% 57%, 13% 49%, 0 49%); }
      25% { transform: scale(1, 1); }
      28% { transform: scale(0.95, 1.05); }
      30% { clip-path: inset(0 0 0 0); }
You are very likely correct. Iā€™m hoping to achieve a similar behavior as to what the fan card does, hence in all screenshot I tried including the fan entity and fan card. Would it be better to raise this on github as a bug report or feature request? Thanks
chips are a little more complicated as for animations you need to drill from the main chip card to the specific chip like this:
chips:
  - type: template
    icon: mdi:eye
    icon_color: red
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
        {{'animation: wink 4s ease-in-out infinite;' if is_state('binary_sensor.lxc_pialert_106_status', 'on')}}
      @keyframes wink {
nth-child(1) needs to match the number that the chip actually is in your main chip card, so if the animation is for the 3rd chip in your code, change the number to 3.
You also mean you cant use config.entity anymore as you arent targetting the chip directly, so you need to specify your entity.
does this get you closer?
mode: horizontal
cards:
    alignment: left
    card_mod:
      style: |
        ha-card {
          --icon-size: 100px !important;
    entity_picture: /local/pictures/person_mario.png
    layout: vertical
    tap_action:
      action: more-info
      browser_mod:
        command: popup
        deviceID: this
        title: mario
        card:
          card_mod:
            style: |
              ha-card {
                padding-right: 5px;
                padding-left: 5px;
          card:
            cards:
                primary_info: none
                icon_color: yellow
                cards:
                  - type: map
                    entities:
                    aspect_ratio: '2'
    card_mod:
      style: |
        ha-card {
    chips:
      - type: template
        icon_color: |
            green
            #6f6f6f
          {% endif %}
        entity: sensor.sm_g991b_battery_state
        tap_action:
          action: more-info
      - type: template
        entity: sensor.sm_g991b_battery_level
        icon: |
          {% endif %}
        icon_color: |
          {% else %} grey
          {% endif %}
        tap_action:
          action: more-info
      - type: entity
        icon_color: white
        card_mod:
          style: |
            ha-card {
you had a bunch of sections where it is just style: | with no card_mod in front. this is required. should always be like this:
card_mod:
  style: |
just remembered that you can do this with the native tile cards actually instead. so maybe just look at using that one for this instead :slight_smile:
