Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
:+1: one other question. Is there a way to use a template sensor with color code to use as icon color?
Help.
The color og secondary text color is not responding to the template
type: custom:mushroom-template-card
primary: Bad
secondary: |-
  {{states ('sensor.sensor_bad_1_etg_temperature')}}°C
  {{states ('sensor.sensor_bad_1_etg_humidity')}}%
icon: mdi:bathtub
entity: switch.double_switch_2_current_value
icon_color: |-
  {% if is_state('switch.double_switch_2_current_value', 'on')%}
    orange
  {% else %}
    blue
  {% endif %}
badge_icon: mdi:fan
badge_color: |-
    blue
  {% endif %}
layout: vertical
tap_action:
  action: navigate
  navigation_path: /lovelace/bad
hold_action:
  action: toggle
fill_container: true
card_mod:
  style: |
    mushroom-badge-icon {
      {% if is_state('switch.double_switch_2_current_value_2', 'on')%}
        animation: spin 1s linear infinite;
      {% else %}
        display: none;
      {% endif %}
    ha-state-icon {
      --icon-symbol-size: 30px;
    secondary-text-color {
      {% if is_state('climate.floor_thermostat', 'heat') %}
        red
      {% elif is_state('climate.floor_thermostat', 'off') %}
        #03A9F4
      {% else %}
        #6c6c75
      {% endif %}
I respect your time @dimitri.landerloos , hope you’re able to help me out some day.
Or @LiQuid_cOOled eventually?
Many thanks and have a great day!
There is a lot going on with your card mod. Play around with this and we’ll go from there.
card_mod:
  style: |
             animation: spin 750ms linear infinite;
      ha-card {
      --icon-symbol-size: 10px;
      --secondary-text-color: blue !important;
      --primary-text-color: green !important;
        {% else %}
      --secondary-text-color: red !important;
      --primary-text-color: yellow !important;
         {% endif %}
We can consolidate the code, but check out @dimitri.landerloos guide about .: | and animations.
Hi everyone, I’m going crazy, I can’t get this animation to work, please help me. Thank you.
icon: mdi:radiator
icon_color: '{{ ''red'' if states(''sensor.casa_delle_fate_riscaldamento'') | float > 1 }}'
primary: null
secondary: '{{states(''sensor.termosifoni_temperature'') + ''%'' }}'
card_mod:
  style: |
    ha-state-icon {
      {% if is_state('sensor.casa_delle_fate_riscaldamento') | float > 1 }
        --card-mod-icon: mdi:radiator-off
      {% else %}
        --card-mod-icon: mdi:bulb;
        animation: clip 1.5s linear infinite;
      {% endif %};
    @keyframes clip {
      0% { clip-path: inset(50% 0 0 0); }
      100% { clip-path: inset(0 0 0 0); }
    mushroom-shape-icon {
      --shape-color: transparent !important;
      visibility: hidden;
Sorry to tell you this - its really annoying when its something simple, but you are just missing a % at the end of your if statement:
{% if is_state('sensor.casa_delle_fate_riscaldamento') | float > 1 %}
I don’t believe it!!! I’m stupid, really stupid!!! Thank you very much, sorry if I wasted your time
Never any need to apologise :slight_smile:
And if i want an other badge showing up on left side with this template:
{% if is_state(‘climate.floor_thermostat’, ‘heat’) %}
How is that?
(tried an other 2 badge code, but i did not get it to work
primary: Bad
secondary: |-
icon: mdi:bathtub
icon_color: |-
    orange
  {% endif %}
badge_icon: |-
  mdi:fan
badge_color: |-
    blue
  {% endif %}
layout: vertical
tap_action:
  action: navigate
hold_action:
  action: toggle
card_mod:
  style: |
      {% else %}
        display: none;
      {% endif %}
sorry i don’t undestand your response.
i would like that the text scrolling automatically without overlapping with primary field
you probably dont understand because that reply isnt to you :wink:
ok sorry :slight_smile:
by the way for my issue you can help me? :slight_smile:
As if anyone was looking for inspiration for a card for a washing machine, I made one for the Siemens IQ800 WM6HXFf42PL but it works with any via Home Connect Alt.
Show me what your integrations for a washing machine look like.
Something like this?
type: horizontal-stack
cards:
   icon: mdi:washing-machine
   entity: switch.wasmachine_smartplug
   tap_action:
     action: fire-dom-event
   browser_mod:
     service: browser_mod.popup
       title: Active Power
       content:
         type: custom:history-explorer-card
         header: Wasmachine
         defaultTimeRange: 24h
         decimation: true
         graphs:
           - type: line
             entities:
               - entity: sensor.wasmachine_smartplug_power
   badge_icon: mdi:power
   badge_color: |-
     {% if states("sensor.b") | float(0) > 5 %}
      blue
     {% endif %}
   icon_color: |-
     {% if states("sensor.wasmachine_smartplug_power") | float(0) > 5 %}
      blue
     {% endif %}
   primary: Was
   secondary: |
     {{ states('sensor.energie_vandaag_wasmachine')|float(0) | round(2) }} kWh
   card_mod:
     style:
      mushroom-badge-icon$: |
         .badge {
          position: relative;
          top: 1px;
          left: 70px;
          --badge-icon-size: 12px;
          --badge-size: 20px;
        ha-state-icon {
          {{'animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;' if states('sensor.wasmachine_smartplug_power') | float > 5 }}
          transform-origin: 50% 110%;
        @keyframes shake {
          0%, 100% { transform: translate(0, 0) rotate(0); }
          20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
          40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
          60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
          80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
        @keyframes drum {
          50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
   tap_action:
   browser_mod:
       title: Active Power
       content:
         header: Wasmachine
         decimation: true
         graphs:
           - type: line
             entities:
   badge_color: |-
     {% if states('sensor.wasmachine_smartplug_power') | float(0) > 5 %}
      blue
     {% endif %}
   icon_color: |-
      blue
     {% endif %}
   primary: Was
   secondary: |
   card_mod:
     style:
         .badge {
          position: relative;
          top: 1px;
          left: 70px;
          --badge-size: 20px;
        ha-state-icon {
          {{'animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;' if states('sensor.b') | float > 5 }}
        @keyframes shake {
        @keyframes drum {
   tap_action:
   browser_mod:
       title: Active Power
       content:
         header: Wasmachine
         decimation: true
         graphs:
           - type: line
             entities:
   badge_color: |-
      blue
     {% endif %}
   icon_color: |-
      blue
     {% endif %}
   primary: Was
   secondary: |
   card_mod:
     style:
         .badge {
          position: relative;
          top: 1px;
          left: 70px;
          --badge-size: 20px;
        ha-state-icon {
        @keyframes shake {
        @keyframes drum {
                          primary: Stand
                          icon: mdi:sun-snowflake-variant
                          icon_color: >
                            {% if is_state("climate.tv_ruimte", 'heat') %}
                              [200, 62, 77]
                            {% elif is_state("climate.tv_ruimte", 'cool') %}
                              [128, 223, 255]
                            {% elif is_state("climate.tv_ruimte", 'dry') %}
                              [200, 142, 77]
                            {% elif is_state("climate.tv_ruimte", 'fan_only') %}
                              [200, 209, 251]
                            {% else %}
                              [84, 84, 84]
                            {% endif %}
                          tap_action:
                            action: toggle
                          secondary: >
                            {% if not is_state("climate.tv_ruimte", 'off') and if is_state("input_boolean.tvruimte_airco_krachtig", 'on') %}
                              Boost
                              {% if not is_state("climate.tv_ruimte", 'off')}
                              {% elif state=='heat' %}
                                Verwarmen
                              {% elif state=='cool' %}
                                Koelen
                              {% elif state=='dry' %}
                                Drogen
                              {% else %}
                                Ventileren
                              {% endif %}
                            {% endif %}
                          entity: input_boolean.airco_stand_beschikbaar
                          layout: horizontal
                          multiline_secondary: false
what is wrong here ?
Can you post the entire card code?
The combined IF statements are incorrect and you have two {%endif%} statements.
If you have 2 if statements you need 2 ends, or not ?
(I edited the post before)
What are you trying to achieve with the second if statement? If it’s off and input is off too?
I have a boost function on the airco. When the boost function is on (input-boolean) and the airco is on (if not is_state(“climate.tv_ruimte”, ‘off’) then I want “Boost” on the second line and not one of the other words. so else if it is heat,cool, dry or fan only I want the dutch translated words on it
See if this works
secondary: >
    {% if states('climate.tv_ruimte') == 'on' and states('input_boolean.tvruimte_airco_krachtig') == 'on' %}
    Boost
    {% elif is_state('climate.tv_ruimte', 'heat') %}
      Verwarmen
    {% elif is_state('climate.tv_ruimte', 'cool') %}
      Koelen
    {% elif is_state('climate.tv_ruimte', 'dry') %}
      Drogen
    {% else %}
      Ventileren
    {% endif %}
