Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Hi, is there a possibility of adding PIR Sensors, Contact Sensors, Vibration Sensors and Water Sensors. These would really make this project complete.
Can you change the Mushroom Cover Card from open to Up and closed to down?
Try thisā€¦
        icon: >-
          {% if states('sensor.sensore_ingresso_illuminance_lux') | int >= 20 %}
          mdi:brightness-5
          {% else %}
          mdi:brightness-4
          {% endif %}
        icon_color: >-
          yellow
          {% else %}
          grey
          {% endif %}
The Mushroom template card can handle the sensors you listed. Check it out, itā€™s extremely customizable especially with card mod installed.
Looks really nice! I try to merge two codes but I do not know how. May somebody help me please?!
Both codes are working independantly but I would like to get both together :see_no_evil:
Many thanks in advance!!!
Code for animation
      - type: custom:mushroom-entity-card
        entity: binary_sensor.balkontur_battery
        icon: ''
        tap_action:
          action: more-info
        card_mod:
          style: |
            mushroom-shape-icon {
              display: flex;
              {% if is_state(config.entity, 'on')%}
                animation: blink 2s linear infinite;
              {% endif %}
            @keyframes blink {
              50% {opacity: 0;}
Code for removing background + changing color
        icon: ''
        tap_action:
          action: more-info
        card_mod:
          style:
            mushroom-shape-icon$: |
              .shape {
                background: none !important;
              ha-state-icon {
               color:
                 {% if is_state(config.entity, 'on') %}
                   var(--error-color)
                 {% else %}
                 {% endif %};
This should get you what you are looking for
icon: ''
tap_action:
          action: more-info
card_mod:
          style:
              .shape {
              ha-state-icon {
                   color: var(--error-color) !important;
                 {% else %}
                 {% endif %}
                  @keyframes blink {
                 50% {opacity: 0;}
It works, many thanks for the fast solution!!!
Any idea why I cant have space between word in my mushroom card? It also shows in the power chip card in the bottom right where it seems to be a space between Value and Unitā€¦
No, it should not be Kitchen Roomā€¦ its just an example of my problem.
type: horizontal-stack
cards:
  - type: custom:vertical-stack-in-card
    cards:
        icon: mdi:knife
        icon_color: |
          {% if is_state(entity, 'on') %}
          amber
          {% else %}
          #03A9F4
          {% endif %}
        primary: Kitchen Room
        secondary: '{{ states(''sensor.aqara_vardagsrum_temperature'')|round(2) }}Ā°C'
        layout: horizontal
        tap_action:
          action: navigate
          navigation_path: /dashboard-mushroom/kitchen
        double_tap_action:
          action: toggle
        hold_action:
          action: none
        badge_icon: >
          #{% if
          is_state('binary_sensor.lumi_lumi_sensor_motion_aq2_occupancy_2',
          'on') %}
          #  mdi:motion-sensor
          #{% else %}
          #  mdi:motion-sensor-off
          #{% endif %}
        badge_color: >
          #{% if
          'on') %}
          #  blue
          #{% else %}
          #  grey
          #{% endif %}
        fill_container: false
        multiline_secondary: false
        entity: light.takbelysning_kok
        card_mod:
          style:
            mushroom-state-info$: |
              .primary {
                font-size: 16px !important;
                position: relative;
                top: -50px;
                left: -155px;
                overflow: visible !important;
                white-space: normal !important;
              .secondary {
                position: relative;
                top: -52px;
                left: -155px;
              .shape {
                position: relative;
                left: -43px;
                top: 55px;
              :host {
                --mush-icon-size: 146px;
              ha-card {
                background: none;
            style: |
              mushroom-badge-icon {
                left: 135px;
                top: 8px;
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            card_mod:
              style: |
                ha-card {
                  --chip-background: none;
                  --chip-box-shadow: none;
                  --chip-border-width: 0;
                  --chip-height: 2px;
                  --chip-padding: 5em
          - type: light
            entity: light.kitchen_group
            card_mod:
              style: |
                ha-card {
                  --chip-icon-size: 35px;
                  --chip-font-size: 0;
          - type: template
            card_mod:
              style: |
                ha-card {
                  --chip-height: 70px;
          - type: entity
            entity: sensor.varmepump_garage_power
            icon: mdi:lightning-bolt
        alignment: end
        card_mod:
          style:
              ha-card {
                width: 40%;
                margin-left: 59%;
                top: -165px;
                --chip-icon-size: 25px;
    card_mod:
      style: |
        ha-card {
          height: 178px;
          margin-left: auto;
          margin-right: auto;
          border-style: none;
          box-shadow: none;
    cards:
        icon: mdi:sofa
        icon_color: |
           amber
          {% else %}
          #03A9F4
          {% endif %}
        primary: Vardagsrum
        layout: horizontal
        tap_action:
          action: navigate
          navigation_path: /dashboard-mushroom/living-room
        double_tap_action:
          action: toggle
        hold_action:
          action: none
        badge_icon: >
          {% if
          'on') %}
            mdi:motion-sensor
          {% else %}
          {% endif %}
        badge_color: >
          {% if
          'on') %}
            blue
          {% else %}
            grey
          {% endif %}
        entity: light.takbelysning_vardagsrum
        card_mod:
          style:
              .primary {
                position: relative;
                top: -50px;
                left: -155px;
              .secondary {
                position: relative;
                top: -52px;
                left: -155px;
              .shape {
                position: relative;
                left: -43px;
                top: 55px;
              :host {
              ha-card {
                background: none;
            style: |
                left: 135px;
                top: 8px;
        chips: []
        alignment: end
        card_mod:
          style:
              ha-card {
                width: 40%;
                margin-left: 60%;
                top: -35px;
                background: none;
                --chip-border-width: thin;
    card_mod:
      style: |
        ha-card {
          height: 178px;
          margin-left: auto;
          margin-right: auto;
          border-style: none;
          box-shadow: none;
Thank you very much, Iā€™m grateful
in all my trials I had never come to this ā€œintā€
| int >= 20 %}
int simply refers to integers (whole numbers), without decimals, such as 123 or -123.
Check out Java Variables hereā€¦
Thank you very much! I love it! :heart_eyes:
Hi all. I just discovered in this thread the possibility to animate icons. That looks great and thought Iā€™d start with a ā€˜simpleā€™ example of one of the media players. However, even when copying the basic config it doesnā€™t animate. Possible that I am missing a prerequisite?
type: custom:mushroom-template-card
icon: mdi:speaker
icon_color: '{{ ''primary'' if is_state(entity, ''playing'') }}'
entity: media_player.living_room_speaker
layout: vertical
secondary: ''
primary: ''
badge_icon: ''
card_mod:
  style:
      .shape {
        --icon-animation: beat 1.3s ease-out infinite both;
        transform-origin: 50% 60%;
      @keyframes beat {
        0% { transform: scale(1); }
        10% { transform: scale(1.1); }
        17% { transform: scale(1.05); }
        33% { transform: scale(1.25); }
        60% { transform: scale(1); }
look at the updated animations that i have linked to many times in this thread :slight_smile:
                  - type: template
                    entity: light.bureau_verlichting_kast
                    icon:  mdi:led-strip-variant
                    icon_color: >
                      {% if is_state("light.bureau_verlichting_kast", 'on') %}
                        [86,86,86]
                      {% else %}
                        [36,36,36]
                      {% endif %}
                    card_mod:
                      style: |
                        ha-card {
                          pointer-events: none;
It looks like the card mod is not working because I still can point the icon. What is wrong here ?
try like this:
chips:
  - type: template
    entity: light.office_desk_lamp
    icon_color: |
        [86,86,86]
      {% else %}
        [36,36,36]
      {% endif %}
  - type: template
    icon_color: |
        [86,86,86]
      {% else %}
        [36,36,36]
      {% endif %}
card_mod:
  style: |
    mushroom-template-chip:nth-child(1) {
i added a second chip just to show that it applies only to the first chip because of the nth-child(1) if you need to apply to multiple chips add the same bit of code and increment the number.
Many thanks!!! I will have a look later on and see how I can integrate that in my card(s). Thank you!
                          entity: input_boolean.airco_tvruimte_krachtig
                          icon: >
                            {% if is_state("input_boolean.airco_tvruimte_krachtig", 'on') %}
                            mdi:toggle-switch
                            {% else %}
                            mdi:toggle-switch-off
                            {% endif %}
                          icon_color: >
                              [102, 204, 0]
                            {% else %}
                              [200, 62, 77]
                            {% endif %}
                          fill_container: true
                          tap_action:
                            action: call-service
                            service: script.airco_tvhoek_krachtig
                            service_data:
                              entity_id: script.airco_tvhoek_krachtig
                          card_mod:
                            style: |
                              ha-card {
                                padding-top: 15px;
                                padding-right: 4px;
this is the script when the button is pressed
alias: Airco_tvhoek_krachtig
sequence:
      entity_id:
        - input_boolean.tvruimte_airco_krachtig
    data: {}
  - service: climate.set_preset_mode
      entity_id:
        - climate.tv_ruimte
      preset_mode: boost
  - service: input_boolean.turn_off
    data: {}
      entity_id: input_boolean.tvruimte_airco_vraagbesturing
  - delay:
      hours: 0
      minutes: 2
      seconds: 0
      milliseconds: 0
      entity_id:
    data: {}
      entity_id:
        - climate.tv_ruimte
      preset_mode: none
mode: single
icon: mdi:fan
if I look at my input_boolean.airco_tvruimte_krachtig, it never gets on. What is wrong ? The boost function works, but my icon does not change colourā€¦
I wantt to have on the top a bar of chips for state icons. If they are on, you see de icon. I have that working only I want to have the every chip on his same position when the state is active. I have this and the icons. Now the position changes of the other icons when another becomes active. The only thing I can think about is setting the color when itā€™s off to the same as the background. Any other ideas?
alignment: center
card_mod:
  style: |
    ha-card {
       --chip-font-size: 25px;
chips:
  - type: template
    entity: binary_sensor.garage2
    icon: mdi:garage-open
    card_mod:
      style: |
        ha-card {
          border: none !important;
          {% if not is_state('binary_sensor.garage2', 'on') %}
            display: none !important;
          {% endif %}
  - type: template
    entity: lock.schuurdeur
    icon: mdi:door-closed-lock
    card_mod:
      style: |
        ha-card {
          {% if not is_state('binary_sensor.schuurdeur2', 'on') %}
          {% endif %}
  - type: template
    icon: mdi:monitor
    icon_color: gray
    card_mod:
      style: |
        ha-card {
          {% if not is_state('binary_sensor.tv_on', 'on') %}
          {% endif %}
  - type: template
    icon: mdi:speaker
    icon_color: gray
    card_mod:
      style: |
        ha-card {
          {% if not is_state('binary_sensor.radio_on', 'on') %}
          {% endif %}
@kroonen You can define the type of positioning method used for an element . I think this is what you are trying to accomplish.
I added
position: absolute; left: 20px;
and then added 40px to each element to space them out. Adjust the px value to space them out the way you want.
Card code
alignment: center
card_mod:
  style: |
    ha-card {
chips:
  - type: template
    card_mod:
      style: |
        ha-card {
          position: absolute;
          left: 20px;
          {% endif %}
  - type: template
    card_mod:
      style: |
        ha-card {
          position: absolute;
          left: 60px;
          {% endif %}
  - type: template
    icon: mdi:monitor
    icon_color: gray
    card_mod:
      style: |
        ha-card {
          position: absolute;
          left: 100px;
          {% endif %}
  - type: template
    icon: mdi:speaker
    icon_color: gray
    card_mod:
      style: |
        ha-card {
          position: absolute;
          left: 160px;
          {% endif %}
                  - type: template
                    icon_color: >
                        [86,86,86]
                      {% else %}
                        [36,36,36]
                      {% endif %}
I want the icon in the color of the attribute of the entity. How do I it ?
brightness: 255
rgb_color: 255, 0, 128
