what yellow color name did you use in the chip “434 w”?
Its just using amber ![]()
I installed a new Home assistant on my Pi4.
When i try to find a custom mushroom card nothing is showing up.
I did got the warning when installing mushroom that LOVELACE was not in storage mode. I have to add the source like this url: /hacsfiles/lovelace-mushroom/mushroom.js type: module
How can i get LOVELACE in storage mode or add the source manually?
Did you activate advanced mode? Go and check in your profile.
hi, fancy card - is there the possibility to share your “garbage” cards code?
is it possible to display the battery in the vacuum?
For the time being it would be enough for me if I could at least put this in the name.
example:
name: '[[[ return '(entity.attributes.friendly_name) - ${states[''sensor.vacuum_baterie''].state}' ]]]'
It’s already there:
And thank you! ![]()
Can you please share the code how you did the person popup?
- type: entity
entity: person.person
use_entity_picture: true
tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: person Info
card:
type: custom:vertical-stack-in-card
cards:
- type: entities
entities:
- entity: person.person
secondary_info: last-updated
show_header_toggle: false
state_color: false
- type: history-graph
entities:
hours_to_show: 24
refresh_interval: 0
- type: conditional
conditions:
state: home
card:
type: glance
entities:
- entity: sensor.person_eta_work
- entity: sensor.person_phone_geocoded_location
- entity: sensor.person_phone_battery_level
- entity: binary_sensor.person_phone_wifi_state
show_name: true
show_icon: true
show_state: true
- type: conditional
conditions:
state_not: home
card:
type: glance
entities:
- entity: sensor.person_eta_home
show_name: true
show_icon: true
show_state: true
- type: map
entities:
- entity: device_tracker.person
- entity: zone.home
- entity: zone.1
- entity: zone.2
- entity: device_tracker.sonata
hours_to_show: 0
aspect_ratio: '16:12'
Thank you very much!
Trying to edit some theme variables but nothing i add makes any effect.
I add my variables to mushroom.yaml
I am sure i am doing something wrong. Could anyone show me a typical snippet on how you add your variable?
Clear your browser cache
Have you reloaded via frontend.reload_themes ?
I’m trying to affect the alignment of template, fan, and entity cards that are combined in a horizontal stack-in-card. I can do this easily with chip cards, but cannot seem to get it to work with these other type of cards.
Here’s what I’m using in both cases:
- type: custom:stack-in-card
mode: horizontal
card_mod:
style: |
ha-card {--chip-box-shadow: none;}
alignment: justify
cards:
Any suggestions?
I tried it and it doesn’t work.
An example would be good, but I didn’t find anything.
Did you succeed?
The Github page provides a full example how to use the theme.
Is there a way to put a chip at the end (right hand edge) of a template card?
I want to have a drop-down type toggle chip that then expands and contracts further information if possible?
Yes, I have created my own theme accordingly.
For example, when I change: mush-rgb-state-entity: var (-- mush-rgb-blue) on mush-rgb-state-entity: var (-- mush-rgb-lime)
nothing changes, the color is still blue
Just an idea
template card
chip (alignment right) with input boolean
conditional card based on the input boolean
card mod stuff
