Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
What result do you get ?
@TommyWelle
You cant use templates in a none template chip (or card for that matter). Not unless you use card mod at least.
Since you are using a light chip you will need to use card mod. Like this:
type: custom:mushroom-chips-card
chips:
  - type: light
    entity: light.office_desk_light
    use_light_color: true
card_mod:
  style:
    mushroom-light-chip:nth-child(1)$: |
      ha-state-icon {
        {% if states('light.office_desk_light') == 'off' %}
          color: grey;
        {% endif %}
Sorry but nope. Thats unfortunately the simple answer.
The only improvements you can possibly make are to try and make the transition quicker.
  1. Use a faster viewing device. So a better phone. Not really an easy ask all of the time.
  2. Use a faster connection to your HA instance. Check that your ping isnt high to your HA instance.
  3. Have a faster HA machine. Makes a marginal difference. Its mostly down to the viewing device.
It would do yes. You can fix this with more card mod. Again it should be in the guide how to try and position the bar and buttons for example.
Yeah, thats what i thought.
Your code worked, thanks alot. :slight_smile:
One more question, how do i now merge the card_mod code i had before into the new one? :stuck_out_tongue:
UNTESTED
type: custom:stack-in-card
          cards:
              primary: Toalett
              secondary: |-
                {{ states('sensor.hue_motion_do_temp') }}°C |
                {{ states('sensor.aqara_multisensor_gangen_fukt') }} %
              icon: mdi:toilet
              entity: light.dolys_dz
              icon_color: |-
                {% if is_state('light.dolys_1', 'on') %}
                  orange
                {% elif is_state('light.dolys_2', 'on') %}
                  orange
                {% endif %}
              tap_action:
                action: toggle
              hold_action:
                action: navigate
                navigation_path: /lovelace-panel/toalett
              multiline_secondary: false
              layout: horizontal
              fill_container: false
              card_mod:
                style: |
                  ha-state-icon::after {
                    content: '{{ expand(states.light) |selectattr('state', 'eq', 'on') |selectattr('entity_id', 'in', area_entities('Do')) |rejectattr('entity_id', 'search', 'dz') |map(attribute='entity_id') |list | count }}';
                    position: absolute;
                    top: -11%;
                    right: -11%;
                    display: flex;
                    justify-content: center;
                    align-items: center;
                    width: 15px;
                    height: 15px;
                    font-size: 9px;
                    font-weight: 700;
                    {% if expand(states.light)
                      |list | count > 0
                      background-color: rgba(var(--rgb-disabled), 0.5);
                    {% else %}
                    {% endif %}
                    border-radius: 50%;
                  {% if states('binary_sensor.hue_motion_do_motion') == 'on' %}
                    ha-state-icon::before {
                      content: 'directions_walk';
                      position: absolute;
                      font-family: 'Material Icons';
                      top: -11%;
                      left: -11%;
                      display: flex;
                      width: 15px;
                      height: 15px;
                      font-size: 11px;
                      background: rgba(var(--rgb-disabled), 0.5);
                      color: rgba(var(--rgb-red), 1);
                      border-radius: 50%;
                      animation: blink 1s linear infinite;
                  {% endif %}
                  @keyframes blink {
                    50% {opacity: 0;}
            - type: custom:mushroom-chips-card
              chips:
                - type: light
                  content_info: none
                  card_mod:
                    style: |
                      ha-card {
                        --chip-box-shadow: none;
                        --chip-background: none;
                        --chip-icon-size: 0.8em;
                        background: radial-gradient( var(--card-background-color) 60%, none calc(60% + 1px)), conic-gradient(var(--icon-color) {{state_attr(config.entity,'brightness') | float / 2.55}}% 0%, var(--card-background-color) 0% 100%) !important;
              alignment: end
              card_mod:
                style:
                    ha-state-icon {
                        color: grey;
                      {% endif %}
                    ha-card {
                      --chip-spacing: 0;
                      margin-top: 10px;
So if he changes the type to template it would work ?
That works perfectly, thank you so much :slight_smile:
Yes but then he loses the “use light color” on the icon, unless he adds that back via a template or card mod instead.
I’m working on a thermostat card and want to theme it to match my mushroom cards. I’m struggling with the the card mod to color the mode buttons to match mushroom icons.
thermostat
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              background: none;
              --ha-card-box-shadow: 0px;
        primary: Thermostat
        secondary: |
          {{ state_attr('climate.lyric_1f1f94', 'hvac_action') }}
        icon: |-
          {% set mode = states('climate.lyric_1f1f94') %}
          {% if mode == 'off' %}
          mdi:power
          {% elif mode == 'cool' %}
          mdi:snowflake
          {% elif mode == 'heat' %}
          mdi:fire
          {% elif mode == 'heat_cool' %}
          mdi:autorenew
          {% else %}
          mdi:home-thermometer
          {% endif %}
        icon_color: |-
          {% set status = state_attr('climate.lyric_1f1f94','hvac_action') %}
          {% if status == 'off' %}
          grey
          {% elif status == 'cooling' %}
          blue
          {% elif status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        tap_action: none
      - type: custom:simple-thermostat
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              background: none;
              --st-spacing: 0px;
            header {
              margin-bottom: 12px !important;
              padding-bottom: 0px !important;
            ha-card .thermostat-trigger {
              color: #9e9e9e;
        entity: climate.lyric_1f1f94
        header:
          icon: false
        decimals: '0'
        fallback: 'Off'
        hide:
          temperature: true
          state: true
        layout:
          mode:
            names: false
            icons: false
            headings: false
          step: row
        step_size: '1'
        control:
          hvac:
            'off': false
            heat: false
            cool: false
            heat_cool: false
    card_mod:
      style: |
        ha-card {
          border-width: 0px;
          background: none;
          --st-spacing: 0px;
          --st-default-spacing: 0px;
          --st-mode-background: var(--primary-background-color);
          margin-left: 12px;
          margin-right: 12px;
          margin-bottom: 12px;
        ha-card .mode-item.active.off {
          background: #363636;
          color: var(--disabled-color);
        ha-card .mode-item.active.cool {
          background: #1d3447;
          color: var(--blue-color);
        ha-card .mode-item.active.heat {
          background: #472421;
          color: var(--red-color);
        ha-card .mode-item.active.heat_cool {
          background: #493516;
          color: var(--orange-color);
        ha-card .mode-item {
          --st-spacing: 10px;
          border-radius: 10px;
        ha-card .modes {
          grid-gap: 12px
    header: false
    setpoints: false
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
        icons: true
        names: false
      step: row
    control:
      hvac:
        'off':
        heat:
        cool:
        heat_cool:
Can you be more specific with the code that isn’t working and/or circle the section on your picture that you are struggling with?
I have a mushroom template card with a secondary “date line”
                secondary: >-
                  {% set mon = ["Januari", "Februari", "Maart", "April", "Mei", "Juni", "Juli", "Augustus", "September", "Oktober", "November", "December"] %}
                  van 1 tot {{ (now().day-1) }} {{ (mon[now().month-1])}}
when it is the first day of the month (and also second I think), this is not ok
can someone help me optimize this ?
edit: something like this
if date is the first of the month
it has to be 1 and not “van 1 tot”
else
the code I have
edit: solution
              {% if (now().day == 1) %}
                1 {{ (mon[now().month-1])}}
              {% else %}
              {% endif %}
Updated today mushroom card from v3.2.4 to v3.4.0 and now is my secondary information white and not the theme collor, how can i change this back?
Do all you card mods look like this? Post an example of your code if that’s not the issue
card_mod:
   style: |
this is my code:
type: custom:mushroom-template-card
icon: hue:room-living
entity: light.beneden
layout: vertical
secondary: >-
  {% if is_state("light.woonkamer", "on") %}Aan{% else %}Uit{% endif %} /
  {{states('sensor.woonkamer_bme680_temperature')}} °C /
  {{states('sensor.woonkamer_bme680_humidity')}} % /
  {{states('sensor.woonkamer_senseair_co2')}} CO2
primary: Woonkamer/Keuken
multiline_secondary: true
icon_color: '{{ iif(is_state(entity, "on"), "blue", "") }}'
tap_action:
  action: navigate
  navigation_path: /mobile-woonkamer
hold_action:
  action: toggle
fill_container: true
bofore update it looked this way:
and now:
Is this what you were looking for, it wasnt eactly clear to me.
layout: vertical
secondary: >-
icon_color: |
  {% if states(config.entity) == 'on' %}
      blue
       {% else %}
       red
    {% endif %}
tap_action:
  action: navigate
hold_action:
  action: toggle
I’ll need time to straight out the text. Been up all night.
Time for sleep than :wink:
But i mean the secondary text is white after the update en before the update is was yellow/orange.
and i want the secondary text in the color from my theme.
I’ll get it. That’s why I stopped. Those colors aren’t defined in the code you posted so either there is more to he card or they a sourced from a theme
Yeah before update v3.4.0 they came out my theme (slate) in the changelog in find this:
  • Use tile style as default style for mushroom card by @piitaya in #1348
    so that looks to me the problem, but can’t find to change it back.
I’ll get it, will follow up later today.
