Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
As you can see in your attributes your state is ā€˜hvac_modesā€™ and not like davidnestico ā€˜hvac_actionā€™. Change that in your template to that.
Yes tried that but it then lists the value of that. So I get an enumeration of the array.
Iā€™m not sure if you do what I said or if I get what you say. :wink:
{{ state_attr('climate.kantoor', 'hvac_modes') }}
Should get you whatver state attribute you hvac has right now.
If youā€™re fine with the state for itself you could just use:
{{ states('climate.kantoor') }}
Check these outcomes in Developer Tools and maybe have another look to understand what what means.
just the state is perfect for me. Thanks. and I will fiddle with the templating a bit just de educate myself a bit, thanks!
What I mean by the first part is the following, if I do:
This shows:
Never the less; it is solved. tnx
Do you have a nest thermostat? Thatā€™s what I have so it displays that.
Have you tried the code a posted?
Here are two screeshots with just the code from above an changed px.
300px:
150px:
The person card is not templatable but you can pretend to do it.
Iā€™ve built this card combination the other day that should fit your needs:
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-person-card
        entity: person.YOU #<-- your person entity here
        use_entity_picture: true
        layout: vertical
        hold_action:
          action: none
        hide_name: true
        hide_state: true
        fill_container: true
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            content: >-
              {{ state_attr('sensor.hd1913_geocoded_location', 'locality') }} #<--your geocode entity
            card_mod: null
            style: |
              ha-card {
                --chip-box-shadow: 0px 0px;
The green icon is still depending on the home/away status for your person entity. And of course you could mix up the template to show special state for ā€˜homeā€™.
You are awesome man. It worked like a charm. Thank you very much for your help.
Thanks Mate. IĀ“m stupid.
Yes i used this code. But: I copied the title with it which of course didnt worked :man_facepalming:
Saved the day!
Here is my combination welcome card. Tried to find a good way to display family status with more than two members. I will be adding better away & location status once I work that out.
Light mode:
Dark mode:
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: {}
    cards:
        chips:
          - type: menu
          - type: alarm-control-panel
            entity: alarm_control_panel.home_alarm
            content_info: none
          - type: template
            entity: lock.front_door
            icon: >-
              {{ 'mdi:lock' if is_state('lock.front_door', 'locked') else
              'mdi:lock-open' }}
            icon_color: '{{ ''green'' if is_state(''lock.front_door'', ''locked'') else ''red'' }}'
            content: null
            tap_action:
              action: more-info
          - type: conditional
            conditions:
              - entity: group.all_lights
                state: 'on'
            chip:
              type: template
              icon: mdi:lightbulb
              content: >-
                {{ expand(states.group.all_lights) | selectattr( 'state', 'eq',
                'on') | list | count }}
              tap_action:
                action: more-info
              icon_color: grey
          - type: conditional
            conditions:
              - entity: group.all_windows
                state: 'on'
            chip:
              type: template
              icon_color: grey
              icon: mdi:window-open
              content: >-
                {{ expand(states.group.all_windows) | selectattr( 'state', 'eq',
              tap_action:
                action: more-info
          - type: conditional
            conditions:
              - entity: group.external_doors
                state: 'on'
            chip:
              type: template
              icon_color: grey
              icon: mdi:door-open
              content: >-
                {{ expand(states.group.external_doors) | selectattr( 'state',
                'eq', 'on') | list | count }}
              tap_action:
                action: more-info
          - type: conditional
            conditions:
              - entity: group.water_leak
                state: 'on'
            chip:
              type: template
              icon_color: light-blue
              icon: mdi:water-alert
              tap_action:
                action: more-info
              card_mod:
                style: |
                  ha-card {
                    animation: blink 1s linear infinite;
                  @keyframes blink {
                    50% {opacity: 0;}
          - type: conditional
            conditions:
              - entity: group.smoke_alarm
                state: 'on'
            chip:
              type: template
              icon_color: red
              icon: mdi:fire-alert
              tap_action:
                action: more-info
              card_mod:
                style: |
                  ha-card {
                  @keyframes blink {
                    50% {opacity: 0;}
        card_mod:
          style: |
            :host {
              --ha-card-background: var(--card-background-color);
      - square: false
        columns: 2
        type: grid
        cards:
          - type: horizontal-stack
            cards:
                chips:
                  - type: conditional
                    conditions:
                      - entity: person.rhys
                        state: home
                    chip:
                      type: entity
                      entity: person.rhys
                      content_info: nam
                      card_mod:
                        style: |
                          ha-card {
                              --chip-background: rgba(var(--rgb-state-person-home), 0.4);
                              margin-top: 5px;
                              margin-bottom: 10px;
                  - type: conditional
                    conditions:
                      - entity: person.sarah
                        state: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                      - entity: person.elijah
                        state: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                      - entity: person.michaela
                        state: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                              margin-top: 5px;
                alignment: start
                card_mod:
                  style: |
                    ha-card {
                      margin-left: 8px;
            cards:
                chips:
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      entity: person.rhys
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.rhys', 'not_home') %}
                              --chip-background: rgba(var(--rgb-state-person-not-home), 0.4);
                            {% elif is_state('person.rhys', 'unknown') %}
                              --chip-background: rgba(var(--rgb-state-person-unknown), 0.4);
                            {% else %}
                              --chip-background: rgba(var(--rgb-state-person-zone), 0.4);
                            {% endif %}
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.sarah', 'not_home') %}
                            {% elif is_state('person.sarah', 'unknown') %}
                            {% else %}
                            {% endif %}
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.elijah', 'not_home') %}
                            {% elif is_state('person.elijah', 'unknown') %}
                            {% else %}
                            {% endif %}
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.michaela', 'not_home') %}
                            {% elif is_state('person.michaela', 'unknown') %}
                            {% else %}
                            {% endif %}
                              margin-top: 5px;
                alignment: end
                card_mod:
                  style: |
                    ha-card {
                      margin-right: 8px;
      - type: custom:mushroom-title-card
        title: |-
          {% set time = now().hour %}
          {% if (time >= 18) %}
           Good Evening, {{user}}!
          {% elif (time >= 12) %}
           Good Afternoon, {{user}}!
          {% elif (time >= 5) %}
           Good Morning, {{user}}!
          {% else %}
           Hello, {{user}}
          {% endif %}
        subtitle: ''
      - type: custom:simple-weather-card
        entity: weather.dark_sky
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              background: none;
        cards:
            primary: ''
            secondary: House
            icon: mdi:home
            layout: vertical
            icon_color: blue
            tap_action:
              action: navigate
              navigation_path: house
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  border-radius: 30px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
            primary: ''
            secondary: Lights
            icon: mdi:lightbulb
            icon_color: amber
            layout: vertical
            tap_action:
              action: navigate
              navigation_path: lights
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
            primary: ''
            secondary: Secure
            icon: mdi:shield
            icon_color: green
            layout: vertical
            tap_action:
              action: navigate
              navigation_path: security
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
            primary: ''
            secondary: Media
            icon: mdi:speaker
            layout: vertical
            icon_color: red
            tap_action:
              action: navigate
              navigation_path: media
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
            primary: ''
            secondary: Net
            icon: mdi:lan
            layout: vertical
            icon_color: cyan
            tap_action:
              action: navigate
            card_mod:
              style: |
                ha-card {
                  width: 66px;
                  margin-left: auto;
                  margin-right: auto;
                  margin-bottom: 2px;
card_mod:
  style: |
    ha-card {
      padding: 2px;
      background: rgba(var(--rgb-primary-text-color), 0.01);
Edit: Tidy up code a bit
This is amazing and exactly what Iā€™ve wanted, and not had the ability to do, so Iā€™ve stolen it.
Got your dashboard on GitHub?
No sorry, not yet. Iā€™ll keep posting more Mushroom cards as I refine them :slight_smile:
This tweak adds color to the card background. The color light version will adjust with the light color.
It looks great in dark mode, but not so much in light mode. Does anyone know how to detect the dark/light mode of lovelace?
Normal light version:
      - type: custom:mushroom-light-card
        entity: light.elijahs_light
        fill_container: false
        hide_state: false
        use_light_color: false
        show_brightness_control: true
        show_color_temp_control: false
        show_color_control: false
        collapsible_controls: true
        card_mod:
           style: |
             ha-card {
               {% if is_state(config.entity, 'on') %}
                  background: rgba(255, 152, 0, 0.1);
               {%- else -%}
               {%- endif %}
Colored light version:
        entity: light.elijahs_night_light
        use_light_color: true
        show_color_control: true
        tap_action:
          action: toggle
        card_mod:
           style: |
             ha-card {
               {% set r = state_attr(config.entity, 'rgb_color')[0] %}
               {% set g = state_attr(config.entity, 'rgb_color')[1] %}
               {% set b = state_attr(config.entity, 'rgb_color')[2] %}
               background: rgba( {{r}}, {{g}}, {{b}}, 0.1 );
Made this Thermostat Card today with some of the code I saw in here if anyone wants it.
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        style: |
          ha-card {
            padding-bottom: 1px !important;
        primary: Thermostat
        secondary: |
          Currently: {{ state_attr('climate.thermostat', 'hvac_action') }}
        icon: |-
          {% set mode = states('climate.thermostat') %}
          {% if mode == 'off' %}
          mdi:power
          {% elif mode == 'cool' %}
          mdi:snowflake
          {% elif mode == 'heat' %}
          mdi:fire
          {% elif mode == 'heat_cool' %}
          mdi:autorenew
          {% else %}
          mdi:home-thermometer
          {% endif %}
        icon_color: |-
          {% set status = state_attr('climate.thermostat','hvac_action') %}
          {% if status == 'off' %}
          grey
          {% elif status == 'cooling' %}
          blue
          {% elif status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        tap_action: none
      - type: vertical-stack
        cards:
          - type: custom:simple-thermostat
            style: |
              ha-card {
                --st-spacing: 0px;
              ha-card .current--value {
                color: #ffffff;
              header {
                margin-bottom: 12px !important;
                padding-bottom: 0px !important;
              ha-card .thermostat-trigger {
                color: #9e9e9e;
            entity: climate.thermostat
            header:
              icon: false
            decimals: '0'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '1'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
    alignment: justify
    chips:
      - type: template
        content: |
          {{ state_attr(entity, 'fan_mode') }}
        icon: mdi:fan
        icon_color: green
        tap_action: none
      - type: template
        content: '{{state_attr(entity, ''current_temperature'')}} Ā°F'
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          {% else %}
          grey
          {% endif %}
      - type: weather
        entity: weather.karr_daynight
        show_conditions: true
        show_temperature: true
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) }}% Humidity'
        entity: sensor.karr_relative_humidity
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
    style: |
      ha-card {
        --st-font-size-toggle-label: 6px
        --st-spacing: 0px;
        --st-default-spacing: 0px;
        --st-mode-background: #262626;
        margin-left: 12px;
        margin-right: 12px;
      ha-card .mode-item.active.off {
        background: #363636;
        color: #9e9e9e;
      ha-card .mode-item.active.cool {
        background: #1d3447;
        color: #2196f3;
      ha-card .mode-item.active.heat {
        background: #472421;
        color: #f44336;
      ha-card .mode-item.active.heat_cool {
        background: #493516;
        color: #ff9800;
      ha-card .mode-item.active {
        background: #263926;
        color: #4caf50;
      ha-card .mode-item.active:hover {
        color: #9e9e9e;
      ha-card .mode-item:hover {
        color: #9e9e9e;
      ha-card .mode-item {
        --st-spacing: 10px;
        border-radius: 10px;
      ha-card .modes {
        grid-gap: 12px
    header: false
    setpoints: false
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
        icons: true
        names: false
      step: row
    control:
      hvac:
        'off':
        heat:
        cool:
        heat_cool:
  - type: grid
    square: false
    columns: 3
    cards:
      - type: custom:mushroom-entity-card
        entity: sensor.thermostat_air_temperature
        primary_info: state
        secondary_info: name
        icon_color: green
        entity: sensor.karr_temperature
        primary_info: state
        icon_color: blue
        style: |
          ha-card {
            --st-spacing: 0px;
            --st-default-spacing: 1.3px;
            margin-right: 12px;
            color: #4caf50;
            color: #9e9e9e;
            color: #9e9e9e;
            --st-spacing: 6px;
          ha-card .modes {
            grid-gap: 12px
        header: false
        setpoints: false
        hide:
          temperature: true
          state: true
        layout:
          mode:
            headings: false
            icons: true
            names: false
          step: row
        control:
          hvac:
            'off': false
            heat: false
            cool: false
            heat_cool: false
          fan:
            Auto low:
              icon: mdi:fan-auto
            Low:
              icon: mdi:fan
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.thermostat_air_temperature
        name: Inside Temperature
        color: '#4caf50'
      - entity: sensor.karr_temperature
        name: Outside Temperature
        color: '#2196f3'
        y_axis: secondary
    hours_to_show: 24
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      fill: fade
@r_s_bell can you please post some code for the vertical and horizontal configurations of your room chips? I canā€™t get it working to get these in a kind of table.
HI all,
Iā€™m using following code
   entity: sensor.solaredge_current_power
   icon: mdi:solar-power
   icon_color: |-
        {% set icsp=states('sensor.solaredge_current_power') %}
        {% if icsp='0' %}
          red
        {% else %}
          green
        {% endif %}
The icon remains WHITE
For all other sensors, this works, except for this one. I believe it has something to do with the current status 0.0, but Iā€™m not sure.
Can anyone help ?
Thanks in advance !
Kr,
Bart
Thisā€™ll work:
        {% set icsp = states('sensor.solaredge_current_power') %}
        {% if icsp == '0.0' %}
          red
        {% else %}
          green
        {% endif %}
Looking for clarificationā€¦
I have read and followed all of the posts here and still uncertain on status of card-mod with these mushroom cards and the mushroom theme.
My goal is being able to modify the font sizes on mushroom template cards on a per card basis. While in my tests I am able to change the card color, font sizing eludes me. And while I understand that card-mod is not supported by the author here, I am wondering what others are using for style customization at the card level.
Thanks and cheers!
Wow, really nice!!! Iā€™m going to try to get this working for me too. Again; really nice!
For me the green icon is dependent if I am in a zone or not. Is there a way to specify to only have it be green when I am in the zone designated home?
