Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
{{ state_attr('timer.garage', 'remaining') }}
Both attributes, remaining or duration, only show the timer amount, 10 minutes in this case.
2022-07-07_17-40-56
Could you send a screenshot of the timer in the States tab of Developer Tools?
Youā€™ll need to use templating to read the finishes_at, then subtract the current time from it.
I think I may have tried something similar that I found in another post but it didnā€™t auto-refresh/countdown I had to manually refresh the page to change the time. Itā€™s entirely possible I just did something wrong though. I will re-visit the finishes_at angle. Thanks for the replies.
You can always send your code that didnā€™t auto update for us to look at.
Mind sharing your drop down remote card and icons? They look super cool!
Doing a quick google search for the finishes_at attribute, I found the template below. In testing, I noticed that the template does auto-update, just every minute instead of continuously like the entity. Iā€™m
fine with this, not going to lie itā€™s not as cool as the continuous countdown but it will work. Thanks for pointing me in the right direction.
{% set f = state_attr('timer.garage', 'finishes_at') %}
{{ 'Idle' if f == None else
(as_datetime(f) - now()).total_seconds() | timestamp_custom('%H:%M:%S', false) }}
Same, how did you implement the dropdown? The lights one looks similar to my request, so itā€™d be nice if I could know how to implement it for now, and if you gave it a :+1:.
A countdown card which shows the seconds counting down would be very cool, the only way I could get this to work which I use as a generic kitchen timer and a more complex Smoker timer is custom:flipdown-timer-card. It works but not as customizable as Mushrooms.
How can I make Entity card to show image instead of icon?
I used following definition, but it still shows default icon.
type: custom:mushroom-entity-card
entity: switch.plug_voron
fill_container: false
primary_info: name
tap_action:
   action: toggle
icon: entity-picture
entity-picture: /config/www/voron_logo.png
Is it possible to do 2 actions inside of an action? This doesnā€™t seem to work.
This is inside of a pop-up, I want to navigate to another page but for it to work seamlessly the pop-up needs to be closed so Iā€™m trying to do that automatically.
  primary: ''
  secondary: Secure
  icon: phu:reolink-842
  layout: vertical
  icon_color: red
  tap_action:
    - action: navigate
      navigation_path: cameras
    - action: fire-dom-event
      browser_mod:
        command: close_popup
        deviceID:
          - this
  picture: local/icons/custom_icons/camera.svg
Can anyone advise how to merge these two style entries ? - I have both working on their own but not sure the correct syntax to merge them togetherā€¦ Iā€™m trying to swap around the template card so that the icon appears on the right side instead.
How do I add this:
    mushroom-state-item:
        .container {
          flex-direction: row-reverse !important;
into this:
    primary: Home
    icon: mdi:home
    icon_color: blue
    card_mod:
      style: |
        mushroom-card {
          background: rgba(10,70,170,0.2);
          padding: 6px;
          border-radius: 12px
        ha-card {
          box-shadow: none !important;
          padding-top: 0px !important;
          padding-bottom: 10px !important;
          --card-primary-font-size: 18px;
          --card-primary-font-weight: 300 !important;
@piitaya I figured I should reply here to not take the issue off topic.
Thatā€™s interesting because using this doesnā€™t work for me on either entity or light cards only on template cards.
Works
    primary: ''
    secondary: Scenes
    icon: phu:scene-relax
    layout: vertical
    icon_color: blue
    tap_action:
      action: navigate
      navigation_path: scenes
    picture: local/icons/custom_icons/spotlight2.png
    card_mod:
      style: |
        mushroom-shape-icon {
          --shape-color: none !important;
          --shape-color-disabled: none !important;}
        ha-card {
          background: transparent;
          width: 66px;
          border-radius: 30px;
          margin-left: auto;
          margin-right: auto;
          margin-bottom: 2px;
Doesnā€™t work.
- type: custom:mushroom-entity-card
    entity: script.strips_1_and_2_night
    tap_action:
      browser_mod:
        command: popup
        deviceID:
          - this
Pop-up cards are supplied for this card, just not needed to post for this issue to keep it simple.
Editā€¦ I noticed the request is for
entity_picture Iā€™m referring to actual pictures.
You can add you picture to your entities using Customizing entities - Home Assistant
Then, you can use 'icon-type: entity-picture` to use it in any card.
For information, all card options are available from the UI editor. If youā€™re adding additional option to yaml, it certainly wonā€™t work.
How can I show an entity attribute as second information?
entity: sensor.rpi_monitor_raspberrypi
secondary_info: ???????
Iā€™ve also tried using an ā€œtemplateā€. Even that doesnā€™t work:
      raspberry_pi_cpu_load_15:
        friendly_name_template: "Raspberry Pi CPU Load 15 Minutes"
        value_template: "{{state_attr('sensor.rpi_monitor_raspberrypi', 'load_15min_prcnt')}}"
        unit_of_measurement: 'Ā°C'
Thanks!
    card_mod:
      style:
            .container {
          mushroom-card {
            padding: 6px;
            border-radius: 12px
          ha-card {
Something like that.
I see, I was trying to see if I could avoid hard coding for each entity and use this in an auto entities by having all auto generated cards use a single picture by simply adding this (picture: ...) the way I did in the Template card.
Is it possible to add support for specifying a picture path to all mushroom cards?
Feature Request
Works perfectly, many thanks :smiley:
Thanks a lot.
I took the icons from https://www.pngegg.com/. There are millions of options in this site. Just search for what you want and as for download, if the size of the png is large, use the resize option at the right side of the screen before downloading.
and as for the code :
square: false
columns: 1
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: null
    cards: null
  - square: false
    columns: 7
    type: grid
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: conditional
            conditions:
              - entity: input_boolean.amps_dropdown
                state: 'off'
            chip:
              type: entity
              entity: scene.klima_ac
              content_info: name
              use_entity_picture: true
              tap_action:
                action: more-info
        card_mod:
          style: |
            ha-card {
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-spacing: 0px;
              --chip-padding: 15px;
              margin-left: 5px;
              width: 400px;
        alignment: start
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: action
              icon_color: amber
              tap_action:
                action: call-service
                service: scene.turn_on
                data: {}
                  entity_id: scene.klima_ac
              icon: mdi:plus
        card_mod:
          style: |
            ha-card {
              margin-left: 30px;
              margin-bottom: -12px;
              width: 400px
        alignment: start
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: action
              icon_color: amber
              tap_action:
                data: {}
                  entity_id: scene.klima_kapat
              icon: mdi:minus
        card_mod:
          style: |
            ha-card {
              margin-left: 20px;
              width: 400px
        alignment: start
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: entity
              entity: scene.tv_ac
              content_info: name
              tap_action:
                action: more-info
        card_mod:
          style: |
            ha-card {
              --chip-padding: 10px;
              margin-left: 20px;
              width: 400px;
        alignment: start
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: action
              icon_color: amber
              tap_action:
                data: {}
                  entity_id: scene.tv_ac
              icon: mdi:plus
        card_mod:
          style: |
            ha-card {
              margin-left: 25px;
              width: 400px
        alignment: start
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: action
              icon_color: amber
              tap_action:
                data: {}
                  entity_id: scene.tv_kapat
              icon: mdi:minus
        card_mod:
          style: |
            ha-card {
              margin-left: 10px;
              width: 400px
        alignment: start
        chips:
          - type: template
            icon: |-
              {% if is_state(entity, 'off') %}
                mdi:chevron-down
              {% elif is_state(entity, 'on') %}
                mdi:chevron-up
              {% endif %}
            tap_action:
              action: toggle
            icon_color: disabled
        card_mod:
          style: |
            ha-card {
              --chip-padding: 0px;
              --chip-icon-size: 20px;
              margin-right: -4px;
        alignment: end
    card_mod:
      style: |
        ha-card {
          margin-left: -6px;
          width: 400px
      alignment: start
    layout: {}
    cards:
      - type: horizontal-stack
        cards:
          - type: vertical-stack
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  secondary_info: none
                  layout: vertical
                  primary_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                      entity: scene.klima_kapat
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  entity: scene.tv_ac
                  layout: vertical
                  primary_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      entity: scene.tv_ac
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                      entity: scene.tv_kapat
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  entity: scene.anfi_ac
                  layout: vertical
                  primary_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.anfi_ac
                      entity: scene.anfi_kapat
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.anfi_kapat
        cards:
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  entity: scene.hdmi_1
                  layout: vertical
                  primary_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.hdmi_1
                      entity: scene.hdmi_2
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.hdmi_2
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  entity: scene.ses_yukselt
                  layout: vertical
                  primary_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.ses_yukselt
                      entity: scene.ses_azalt
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service_data: {}
                          entity_id: scene.ses_azalt
            cards:
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  entity: light.star_projector
                  layout: vertical
                  primary_info: name
                  name: Star Projector
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                card:
                  cards:
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service: light.turn_on
                        service_data: {}
                          entity_id: light.star_projector
                      layout: vertical
                      primary_info: name
                      hide_icon: true
                      tap_action:
                        service: light.turn_off
                        service_data: {}
card_mod:
  style: |
    ha-card {
      padding: 5px;
      background: #1a1a1a;
