Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
You have to be more specific like which part ?
A little bit OT for this thread, but I use MIB Browser to do an SNMP Walk. Make sure you load the appropriate MIBs for printers, usually RFC1213 and Printer-MIB. Most of the OIDs are standardized with minor differences, such as the number of toner/ink supplies and the order of them, while the base OID remains the same.
Yeah I was using a different program and there was thousands of OIDā€™s. Still trying to find a few but got the card looking very nice! Thanks for saving me some time and making a great looking card!
Sorry :slight_smile:
I mean the icons on this room card, i struggling to find the right code to get it to work for me.
Thanks for posting these and for being so willing to help the community throughout this thread. These examples are great and get the creativity flowing for sure. Couple of quick questions:
  • in the first two side-by-side examples, it appears weā€™re looking at the base ā€˜welcome screenā€™ as it has the overall dashboard indicators e.g. presence, door, alarm, weather. However, the stuff underneath is different in each example (now playing is first in one, rooms is first in the other). Can I infer from this the top pane is ā€˜lockedā€™ such that you can scroll vertically below the header and see the rest of the content? I fiddled briefly with trying to do this in CSS with contentContainer and such but never quite made it work. Or, does the top scroll off as you scroll down?
  • generally, what strategy would you consider if you were to adapt the mobile-friendly layout you have here to a wider screen e.g. a wall-mounted tablet? The room cards should be easy - they could be popups or just navigate to a new page. But for the ā€˜front pageā€™, I think itā€™d be basically creating a grid and carving out the sections of the primary layout into cards that made sense in my own implementation, is that right?
Thanks again, still fighting through getting mine to even somewhat look like yours and others here, but the sharing and collaboration is so very helpful.
No, the top pane is not locked, it scrolls off the top. The ā€˜Currently Playingā€™ uses Universal Media Player to show any playing media and is hidden if there is nothing playing. I wanted a quick way to pause, skip or adjust volume without having to go into a room card. This way the media player doesnā€™t take up space when it is not needed. I also use Universal Media Players in rooms that have more than one media source, ie TV, Squeezebox & Plex, to reduce clutter.
I havenā€™t started on a tablet layout yet, but would probably have a side card with room navigation down the left and expand content out to the right.
This is probably a simple one, but I canā€™t for the life of me work it outā€¦ can anyone tell me what the magic code is to make a template chip follow the icon of the entity rather than having to specify it manually as part of the yaml ?
Iā€™m thinking there must be a template way to get the entities icon ??
Post your code here.
Adding some more informationā€¦
I inspected the elements of my chip cards and found that there are two color styles being defined for my icons. Its unfortunately defaulting to the rgb(225,225,225) making all of my chip icons white. I have no idea why or where this value is coming from.
This was seen by inspecting an existing chip, but I created a new light chip with a color light and saw the same issue. This is also only being applied to the chip cards. All other cards, even other mushroom cards (from the ones I tested), are working as expected.
I feel like iā€™m closer to figuring out whatā€™s wrong but I have no idea what I need to do to fix it.
Thanks!
Any chance you can share your 3d printer card? I tried modifying the printer one to it, but didnā€™t look as nice. TIA!
What am I doing wrong with my if statements? I just keep getting a broken picture icon
{% if is_state("input_boolean.night_mode_green", "off") %}
      /local/mushroom_icons/green_mode1.png
{% if is_state("input_boolean.night_mode_red", "on") %}
      /local/mushroom_icons/red_mode1.png
                {% endif %}
Should be elif
{% elif is_state("input_boolean.night_mode_red", "on") %}
{% endif %}
Sure, here is my 3D Printer Card. This is still a WIP though:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: auto 33px
      margin: '-4px -4px -8px -4px'
    cards:
        primary: 3D Printer
        entity: switch.3d_printer_power
        secondary: '{{ states(entity) | title }}'
        icon: mdi:printer-3d
        icon_color: '{{ ''light-blue'' if is_state(entity, ''on'') else ''disabled'' }}'
        tap_action:
          action: toggle
        hold_action:
          action: none
        card_mod:
          style: |
            ha-card {
              background: none;
              --ha-card-box-shadow: 0px;
        entity: input_boolean.3d_printer_dropdown
        primary: ''
        secondary: ''
        icon: >-
          {{ 'mdi:chevron-down' if is_state(entity, 'off') else 'mdi:chevron-up'
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style: |
            ha-card {
              align-items: flex-end;
              background: none;
            mushroom-shape-icon {
              --shape-color: none !important;
  - type: conditional
    conditions:
      - entity: input_boolean.3d_printer_dropdown
        state: 'on'
    card:
      cards:
          cards:
            - type: picture-entity
              show_state: false
              show_name: false
              camera_view: auto
              entity: camera.3d_printer_camera
        - type: custom:stack-in-card
          mode: horizontal
          keep:
            background: true
            border_radius: true
            margin: true
          cards:
              entity: button.octoprint_pause_job
              icon: mdi:pause
              icon_color: orange
              layout: vertical
              tap_action:
                action: toggle
              card_mod:
                style: |
                  ha-card {
                    background: rgba(var(--rgb-orange), 0.1);
                    width: 66px;
                    border-radius: 50%;
                    margin-left: auto;
                    margin-right: auto;
              entity: button.octoprint_resume_job
              icon: mdi:play
              icon_color: green
              layout: vertical
              tap_action:
                action: toggle
              card_mod:
                style: |
                  ha-card {
                    background: rgba(var(--rgb-green), 0.1);
                    width: 66px;
                    border-radius: 50%;
                    margin-left: auto;
                    margin-right: auto;
              entity: button.octoprint_stop_job
              icon: mdi:stop
              icon_color: red
              layout: vertical
              tap_action:
                action: toggle
              card_mod:
                style: |
                  ha-card {
                    background: rgba(var(--rgb-red), 0.1);
                    width: 66px;
                    border-radius: 50%;
                    margin-left: auto;
                    margin-right: auto;
          card_mod:
            style: |
              ha-card {
                #background: none;
          layout:
            grid-template-columns: 197px auto
          cards:
              cards:
                - type: custom:mushroom-entity-card
                  entity: sensor.octoprint_current_state
                  icon_color: green
                  tap_action:
                    action: url
                    url_path: http://octopi.biscuit.local/?#tab_plugin_dashboard
                  icon: si:octopusdeploy
                  card_mod:
                    style: |
                      ha-card {
                        --badge-size: 0px !important;
                  primary_info: name
                  secondary_info: state
                  entity: sensor.octoprint_estimated_finish_time
                  icon_color: light-blue
                  tap_action:
                    action: none
                  primary_info: name
                  name: Est. Finish Time
                  entity: sensor.3d_printer_power_power
                  icon_color: '{{ ''amber'' if states(entity) | int > 0 else ''disabled'' }}'
                  tap_action:
                    action: none
                  primary: Power Use
                  secondary: '{{ states(entity) }} W'
                  icon: mdi:flash
              card_mod:
                style: |
                  ha-card {
                    margin-top: 6px;
                    background: none;
              cards:
                - type: custom:apexcharts-card
                  header:
                    show: false
                  series:
                    - entity: sensor.octoprint_job_percentage
                      color: rgb(3, 169, 244)
                      show:
                        legend_value: false
                  chart_type: radialBar
                  apex_config:
                    legend:
                      show: false
                    chart:
                      height: 230px
                    plotOptions:
                      radialBar:
                        hollow:
                        dataLabels:
                          name:
                            show: false
                          value:
                            show: false
                        track:
                          strokeWidth: 80%
                          margin: 0
                    fill:
                      type: gradient
                      gradient:
                        shade: light
                        type: horizontal
                        shadeIntensity: 0.3
                        inverseColors: false
                        opacityFrom: 1
                        opacityTo: 1
                        stops:
                          - 0
                          - 50
                          - 55
                          - 90
                  primary_info: state
                  secondary_info: name
                  layout: vertical
                  card_mod:
                    style: |
                      ha-card {
                        margin-top: -165px;
                        width: 140px;
                        margin-left: auto;
                        margin-right: auto;
              card_mod:
                style: |
                  ha-card {
                    background: none;
          cards:
            - type: grid
              square: false
              columns: 2
              cards:
                  cards:
                      series:
                        - entity: sensor.octoprint_actual_bed_temp
                          color: rgb(103, 58, 183)
                          max: 110
                          show:
                            legend_value: false
                        - entity: sensor.octoprint_target_bed_temp
                          max: 110
                          show:
                            legend_value: false
                      apex_config:
                        plotOptions:
                          radialBar:
                            offsetY: -15
                            startAngle: -105
                            endAngle: 105
                            hollow:
                            dataLabels:
                              name:
                                show: false
                              value:
                                show: false
                        legend:
                          show: false
                        chart:
                          height: 220px
                        fill:
                          type: gradient
                          gradient:
                            shade: light
                            type: horizontal
                            shadeIntensity: 0.3
                            opacityFrom: 1
                            opacityTo: 1
                            stops:
                              - 0
                              - 50
                              - 55
                              - 90
                      primary: Bed Temp
                      secondary: >-
                        {{ states(entity) | round(1) }} Ā°C / {{
                        states('sensor.octoprint_target_bed_temp') | round (1)
                        }} Ā°C
                      icon: mdi:thermometer-lines
                      icon_color: deep-purple
                      layout: vertical
                      card_mod:
                        style: |
                          ha-card {
                            margin-top: -80px;
                            width: 175px;
                            margin-left: auto;
                            margin-right: auto;
                  cards:
                      series:
                        - entity: sensor.octoprint_actual_tool0_temp
                          color: rgb(233, 30, 99)
                          max: 240
                          show:
                            legend_value: false
                        - entity: sensor.octoprint_target_tool0_temp
                          max: 240
                          show:
                            legend_value: false
                      apex_config:
                        plotOptions:
                          radialBar:
                            offsetY: -15
                            startAngle: -105
                            endAngle: 105
                            hollow:
                            dataLabels:
                              name:
                                show: false
                              value:
                                show: false
                        legend:
                          show: false
                        chart:
                          height: 220px
                          stack: true
                        fill:
                          type: gradient
                          gradient:
                            shade: light
                            type: horizontal
                            shadeIntensity: 0.3
                            opacityFrom: 1
                            opacityTo: 1
                            stops:
                              - 0
                              - 50
                              - 55
                              - 90
                      primary: Tool Temp
                      secondary: >-
                        states('sensor.octoprint_target_tool0_temp') | round (1)
                        }} Ā°C
                      icon: mdi:printer-3d-nozzle
                      icon_color: pink
                      layout: vertical
                      card_mod:
                        style: |
                          ha-card {
                            margin-top: -80px;
                            width: 175px;
                            margin-left: auto;
                            margin-right: auto;
          card_mod:
            style: |
              ha-card {
                background: none;
@rhysb thank you. Now how do I add a final statement saying if neither of those conditions are met, display a different picture?
Like this:
{% else %}
      /local/some_other_picture.png
{% endif %}
What theme are you using?
Iā€™ve switched between a few with the same results on all of them.
Iā€™ve tried minimalist-desktop from the minimalist theme integration.
Iā€™ve used the mushroom theme from HACS
And Iā€™ve even tried using the ā€˜defaultā€™ theme.
Have you tried in a different browser? Also try disabling any browser extensions/plugins if you have any
try to use this. can you tell me what this is? ā†’ input_boolean.amps_dropdown
That is a toggle helper to store the state of the dropdown. You can name it whatever you want.
