Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
:heart: Love this project! But I do have a few questions how can I merge a mushroom card and a power gauge, specifically by adding a toggle button below the power gauge? Secondly, is it possible to have multiple toggle buttons within a mushroom entity card?
Thanks for the help, but doesn’t work
Curious it should work. Have you tried adding the !important syntax? Clear the cache? I used the same for some mushroom-title cards today with no problems.
--title-font-size: 10px !important;
- type: custom:mushroom-title-card
  title: Quarto
  card_mod:
  style: |
   ha-card {
I put like that, didn’t work
Ok but in your example some spaces are missing before style. Maybe only a fault of your copy & paste but it must exactly look like this with the spaces before the words, otherwise it doesn’t work.
  title: Quarto
  card_mod:
    style: |
      ha-card {
Hello there, how to adapt this card to new HACS 2.0 ?
Can we mix auto-entities card and mushroom card ?
I don’t have HACS 2.0 so can’t help with that.
Sure, you can mix any type of card if you use the custom stack-in-card.
you sure can, like this ?
type: custom:auto-entities
card:
  type: grid
  columns: 2
  square: false
card_param: cards
filter:
  include:
    - domain: light
      state: 'on'
      options:
        type: custom:mushroom-light-card
        use_light_color: true
        show_brightness_control: true
        show_color_control: true
        collapsible_controls: true
        show_color_temp_control: true
        layout: vertical
  exclude: []
show_empty: true
Thank you! Got it now and it works smooth :grinning:
Actually I’m wondering how to make the left tile look like the right one:
The area around the left icon glows less green then in the right tile.
Can the text “Türschloss” and “Tür” centered in any way?
Can someone help or have any suggestions for me?
Thank you.
type: horizontal-stack
cards:
  - type: tile
    entity: binary_sensor.turschloss_wohnung
    card_mod:
      style: |
        :host {
          justify-content: center;
          text-align: center;
          align-items: center;
          {% set state = states('binary_sensor.turschloss_wohnung') | float(0) %}
          {% if states('binary_sensor.turschloss_wohnung', 'on') %}
            --card-mod-icon-color: green;
            --icon: mdi:door-open;
          {% elif states('binary_sensor.turschloss_wohnung', 'off') %}
            --card-mod-icon-color: red;
            --icon: mdi:door;
  - type: tile
    entity: lock.turschloss_wohnung
    card_mod: null
    style: |
      :host {
        text-align: center;
        {% set state = states('lock.turschloss_wohnung') %}
        {% if state == 'unlocked' %}
        --card-mod-icon: mdi:lock-closed;
        {% elif state == 'locked' %}
        --card-mod-icon: mdi:lock;
show_name: true
show_icon: true
And sometimes, that’s strange, the left icon is grey and I don’t know how, it went back to green when I switch between tabs. And sometimes not.
how looks the right card_mod string to modify this "width:?
i tried this one, but is not working, maybe someone can help
i try to move the selection field 4px to the right
mushroom-select-option-control$:
              mushroom-select$:
                naturalmenuwidth$: |
                  fixedmenuposition {
                    width: 104% !important;
Guys, I am having troubles making animation with mushroom cards. I have installed card_mod3 and it works with (no mushroom) cards. But with mushroom no luck.
Anyone had same issue?
hi everyone,
since mushroom version 4.x the card-mods that i was using are no longer working on my phone.
I’m using card_mod with “padding: 0px !important” to reduce the padding around the cards, but after updating the mushroom integration, this variable is ignored when opening a dashboard on my phone. Does anyone have a solution for this (see example of a card below):
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    cards:
      - type: custom:mushroom-number-card
        view_layout:
          grid-column: 1 / 5
          grid-row: 1 / 2
        entity: input_number.fan_setting_input
        display_mode: slider
        icon_color: green
        layout: horizontal
        primary_info: none
        secondary_info: none
        card_mod:
          style: |
            ha-card {
            border: none;
            --icon-size: 30px;
            --control-height: 30px;
            padding: 0px !important;
      - type: custom:mushroom-entity-card
        view_layout:
          grid-column: 1 / 2
          grid-row: 2 / 3
        entity: input_boolean.fan_timer_1
        icon_color: green
        layout: horizontal
        tap_action:
          action: toggle
        card_mod:
          style: |
            ha-card {
            border: none;
            --card-primary-font-size: 12px;
            --card-secondary-font-size: 12px;
            --icon-size: 30px;
        view_layout:
          grid-column: 2 / 3
          grid-row: 2 / 3
        entity: input_boolean.fan_timer_2
        icon_color: green
        layout: horizontal
        tap_action:
          action: toggle
        card_mod:
          style: |
            ha-card {
            border: none;
            --icon-size: 30px;
        view_layout:
          grid-column: 3 / 4
          grid-row: 2 / 3
        entity: input_boolean.fan_timer_3
        icon_color: green
        layout: horizontal
        tap_action:
          action: toggle
        card_mod:
          style: |
            ha-card {
            border: none;
            --icon-size: 30px;
        view_layout:
          grid-column: 4 / 5
          grid-row: 2 / 3
        entity: sensor.fan_timer_numerical
        icon_color: green
        primary_info: state
        layout: horizontal
        card_mod:
          style: |
            ha-card {
            border: none;
            --icon-size: 30px;
Only me who now gets the wonderful “custom element does not exist” for mushroom after the latest mushroom update?
Could of course be something else but earlier today I updated to the latest mushroom release. Did I miss something?
I had the same problem. Someone commented somewhere that clearing the cache helps. It does not matter if it’s in a browser or the companion apps.
Thanks, it solved it! Rather obvious now when I think a little bit more but never had to do that manually before. The “reload” pop-up that you get when updating or download any frontend package from hacs always worked before (using the companion app)
EDIT: For anyone else having this issue. You just need to use position: relative; on your main card’s css to fix this.
After a recent update I am facing the following issue. I use conditional chip cards on my already existing cards in order to display some elements. After one of the latest updates, the chip cards produce a container that sits on top of the actual card, disregarding the z-index and preventing from using the tap actions. Here is a screeenshot of the element as seen on the inspector. And also the code.
Screenshot 2024-08-29 001052
cards:
    primary: Kitchen
    secondary: >-
      {{ states('sensor.living_room_remote_temperature') | round(1)  }}°C - {{
      states('sensor.living_room_remote_humidity') | round(1)  }}%
    icon: >-
      {% if is_state('automation.auto_kitchen_light_toggle', 'off') or
      is_state('input_boolean.kt_off_blocker', 'on') %}
      mdi:pause
      phu:rooms-kitchen
    tap_action:
      action: navigate
      navigation_path: /lovelace-mushroom/kitchen
    icon_color: >-
      {% if is_state('light.kitchen_light', 'on') or
      is_state('light.kitchen_lights_led_strip', 'on') or
      is_state('light.kitchen_lights_spots', 'on') %}
        orange
      {% elif is_state('automation.auto_kitchen_light_toggle', 'off') or
        red
    hold_action:
      action: call-service
      service: script.kt_auto_light
      target: {}
    double_tap_action:
      service: light.toggle
        entity_id:
          - light.kitchen_lights
      data: {}
    badge_color: >-
      {% if is_state('automation.auto_kitchen_light_toggle', 'on') and
      is_state('input_boolean.kt_off_blocker', 'off') and
      is_state('input_boolean.kt_movement', 'on') %}
        orange
    badge_icon: >-
        mdi:walk
    card_mod:
      style: |
        :host {
          --ha-card-border-width: 0px;
          z-index: 1;
    chips:
      - type: conditional
        conditions:
          - entity: input_boolean.dishwasher
            state: 'on'
        chip:
          type: template
          icon_color: green
          icon: mdi:dishwasher
          card_mod:
            style: |
              ha-card {
                {% if states('binary_sensor.refridgerator_door_contact') == 'on' %}
                  right: -44px;
                  top: -26px;
                  z-index: 0;
                {%else%}
                  right: 0px;
                  z-index: 0;
      - type: conditional
        conditions:
          - entity: binary_sensor.refridgerator_door_contact
            state: 'on'
        chip:
          type: template
          icon_color: red
          icon: mdi:fridge-alert
    alignment: end
    card_mod:
      style: |
        ha-card {
          z-index: 0;
          top: -42px;
        :host {
card_mod:
  style: |
    ha-card {
      height: 58px;
Any ideas?
Hi all,
I’m trying to realize a mushroom template card to cast on a nest hub to show a timer. So I’ve made a specific dashboard and inserted the card with specific height to have a nice look on the nest hub. I’ve used the following code:
type: custom:mushroom-template-card
primary: '{{ states(entity) }}'
entity: sensor.timer_aiuto_cucina_tempo_rimanente
layout: horizontal
fill_container: true
icon: mdi:timer
card_mod:
  style:
    mushroom-state-info$: |
      .container {
        --card-primary-color: var(--primary-color);
        --card-primary-font-size: 50px;
      .primary {
        height: fit-content;
    mushroom-shape-icon$: |
      .shape {
        --icon-symbol-size: 40px;
        --icon-size: 60px;
        border: 5px outset var(--primary-color);
        --shape-animation: ping 1s infinite;
      @keyframes ping {
        0% {box-shadow: 0 0 0 0 rgba(var(--rgb-blue), 0.7);}
        70% {box-shadow: 0 0 0 10px transparent;}
        100% {box-shadow: 0 0 0 0 transparent;}
      ha-card {
        height: 250px !important;
      ha-state-icon {
        animation: wobbling 0.5s linear infinite alternate;
      @keyframes wobbling {
        0% {transform: rotate(-15deg);}
        100% {transform: rotate(15deg);}
mushroom-timer
As you can see if I set a font size over 28px the text is cut off.
I tried also to edit the height in the container section but nothings happen.
      .container {
        height: fit-content !important;
Do you have any suggestion? Thanks in advace
Hello everyone, there is a menu button in the chips, but is it possible to make a page edit button? A pencil icon, I would just make it available only to administrators.
Solved with the help of ChatGPT, he suggested me to change the line-height in the container section but even then it didn’t work.
Found that it had to be done in the primary text section.
  layout: horizontal
  icon: mdi:timer
  card_mod:
    style:
        .container {
          --card-primary-font-size: 140px;
        .primary {
          line-height: 200% !important;
Here is the result:
mushroom-timer-ok
The new badges has the possibilities to add a title/name in each badge. Is it possible to add something similar for the chips card? I would really love it to have a title/name in it.
