Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
Thanks for pointing that out. Must have been a copy and paste error. I’d have to dig for the Pi Hole version, but here is a sprinkler version.
Automation
alias: Sprinkler Timer
description: ""
  - platform: state
    entity_id:
      - input_boolean.sprinklers_on
    to: "on"
condition: []
  - service: timer.start
      duration: "{{ states('input_number.sprinkler_number') | int*60 }}"
      entity_id: timer.sprinkler_timer
  - service: switch.turn_on
      entity_id:
        - switch.back_yard_main
    data: {}
      entity_id: switch.back_yard_main
    data: {}
  - delay:
      hours: 0
      minutes: 0
      seconds: "{{ states('input_number.sprinkler_number') | int*60}}"
      milliseconds: 0
  - service: switch.turn_off
      entity_id:
    data: {}
    data: {}
      entity_id:
Script
alias: Sprinkler Timer Finish
  - service: timer.finish
    metadata: {}
    data: {}
    data: {}
      device_id: bb9a5ee6cfed42eecfcf9ba0f166e19c
    data: {}
      entity_id: input_boolean.sprinklers_on
icon: mdi:timer-off-outline
Card Code
type: custom:stack-in-card
cards:
  - type: custom:mushroom-title-card
    title: Sprinklers
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 15% 15% 70%
      margin: '-10px 0px 0px 0px'
    cards:
        entity: input_boolean.sprinklers_on
        icon: mdi:sprinkler-variant
        tap_action:
          action: toggle
          confirmation:
            text: Are you sure you want to start the timer?
        hold_action:
          action: call-service
          confirmation:
            text: Are you sure you want cancel the timer?
          service: script.sprinkler_timer_finish
        icon_color: transparent
        card_mod:
          style: >
            ha-card {
              border: none !important;
              --icon-symbol-size: 40px;
             background:none;
            ha-state-icon { {% if is_state('input_boolean.sprinklers_on', 'on')
            %}color: lime !important;
              animation: sprinkle 4s ease-in-out infinite
                {%else%}
                 color: red !important;
            @keyframes sprinkle {
            0%, 10%, 20%, 30%, 40%, 60%, 70%, 80%, 90%, 100% { clip-path:
            inset(0 40% 0 40%); transform: rotate(0deg); }
            1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform:
            rotate(0deg); }
      - type: custom:button-card
        entity: timer.sprinkler_timer
        show_name: true
        show_state: true
        show_label: false
        show_icon: false
        height: 40px
        styles:
          img_cell:
            - background-color: rgba(var(--color-theme),0,05)
            - border-radius: 50%
            - place-self: center
            - width: 20px
            - height: 20px
          card:
            - background-color: '#3d5afe02'
            - border: none
            - border-radius: 14px
            - font-size: 12px
            - font-weight: normal
            - height: 70px
            - color: |
                  if(states['input_boolean.sprinklers_on'].state == 'off') return 'red'
                  else return 'lime';
            - align_self: middle
          name:
            - font-size: 12px
            - padding-bottom: 2px
            - color: |
                grey
      - type: custom:mushroom-number-card
        entity: input_number.sprinkler_number
        tap_action:
          action: toggle
        layout: horizontal
        display_mode: slider
        card_mod:
          style:
            mushroom-shape-icon$: |
              .shape {
                background: none !important;
                --shape-color:none;
            mushroom-number-value-control$:
              mushroom-slider$: |
                .slider {
                 position: absolute !important;
                 width: 96% !important;
                 left: 12px;
                 height: 44px !important;
                 margin-top:2px;
                 --bg-color: rgba(169, 169, 169, 0.2);
                 --main-color: {{ 'rgba(0, 255, 0, .42)' if is_state(switch.back_yard_main', 'on') else 'rgba(255, 0, 0, .2)' }}  ;
              ha-state-icon {
                color: transparent;
              ha-card {
                  background: none;
            mushroom-state-info$: |
              .container {
                flex-direction: row !important;
                width: 79%;
                top: 17px;
                align-items: baseline;
              .primary {
                color: transparent !important;
                position: relative;
                flex-shrink: 1;
                flex-grow: 1;
              .primary:after {
                content: "{{states('input_number.sprinkler_number')| int(0)}} Min ";
                position: absolute;
                color: {{ 'lime' if is_state('switch.back_yard_main', 'on') else 'red' }}  ;
                left: -1px;
                font-weight: 400;
                top: 3px;
                width: max-content;
                z-index: 2
              .secondary {
                position: relative;
                flex-shrink: 1;
                flex-grow: 0;
              .secondary:after {
                content: "{{ 'ON' if is_state('switch.back_yard_main', 'on') else 'OFF' }}  ";
                position: relative ;
                font-weight: 400;
                top: 2px;
                right: 10px;
                padding-right: 10px;
                z-index: 2;
card_mod:
  style: |
    ha-card {
    background-image: url("/local/pics/wood.png");
    border: none;
I’m trying to modify simple-weather-card:
in the way to put some custom text (marked red) basically translation weather info, and also is it possible somehow to change individual small icons (marked blue). If I put the card_mod option (below) all small icons are the same.
type: custom:simple-weather-card
entity: weather.home
primary_info:
  - wind_bearing
  - wind_speed
secondary_info:
  - humidity
  - precipitation_probability
card_mod:
  style: |
    .weather__icon {
      {% set condition = states(config.entity) %}
      {% if condition == 'partlycloudy' and is_state('sun.sun', 'below_horizon') %}
        {% set condition = condition + '-night' %}
      background-image: url("/local/weather_icons/{{ condition }}.svg") !important;
    .weather__icon--small {
      background-image: url("/local/weather_icons/windy.svg") !important;
This modification (with animated weather icons) was made by the user: rhysb so all the credits to him…
This thread is for Mushroom Card related issues. I’d look for a simple-weather-card thread or post here
How can i move the Badge? Thanks
Unbenannt
card_mod
mushroom-badge-icon {
        margin-top: 38px !important;
        margin-right: 16px !important;
Sorry for another question. Does anyone know if I can add the current energy useage sensor to this card as illustrated below? (Ignore my dodgy writing haha!) I’ve tried a multitude of things but can’t seem to get anything working. Is it just impossible maybe?
nope it’s definitely possible :wink:
type: custom:mushroom-entity-card
entity: switch.loungetv
card_mod:
  style:
      .secondary:after {
        content: 'Power: {{states('sensor.loungetv_power')}}W';
        margin-left: 20px;
      ha-card {
        border: 0px;
Aww that is magic. Thank you very much!
How can i force the list to always drop below in a mushroom select card?
Thank you!
I don’t know if I should post it here or in the card mod topic, but I have the following problem. My dashboard looks like the left one on the image…
When I refresh it, it looks like the right image.
Why is this problem? How can I fix it? The cards do not show the card mod configuration when refreshing. Thanks
What version of Card-Mod are you using ?
Is it the latest version by any chance ? 3.50 or maybe 3.44 ?
Rollback to 3.43 and then try again if so
I used 3.50. I tried it with 3.43 and i have the same problem.
how can i change the card height und icon size for mushroom-template-badge ?
An example…
type: custom:mushroom-template-card
primary: Badge Size
entity: xxxx.xxxx
icon: mdi:curtains
icon_color: white
badge_icon: mdi:battery
badge_color: red
tap_action:
  action: toggle
card_mod:
  style: |
       --badge-icon-size: 15px;
       --badge-size: 20px;
       left: 27px;
       top:-10px;
Hiya.
Trying to give my chip background a different colour based on the AC mode(heat_cool, cool, heat, fan_only, dry but no joy. Any help would be appreciated.
Would be really happy if I can show the degrees its set at as well but I’ll take what I can.
thanks
type: custom:mushroom-chips-card
chips:
  - type: action
    tap_action:
      action: navigate
      navigation_path: '#ACLiving'
    icon: mdi:air-conditioner
    card_mod:
      style: |
        ha-card {
            --chip-background: |
              {% if is_state('climate.living_ac_living_ac', 'heat_cool') %}
                rgba(180, 165, 0, 0.2);
              {% elif is_state('climate.living_ac_living_ac', 'heat') %}
                rgba(255, 123, 0, 0.2);
              {% elif is_state('climate.living_ac_living_ac', 'cool') %}
                rgba(255, 165, 0, 0.2);
              {% elif is_state('climate.living_ac_living_ac', 'fan_only') %}
                rgba(255, 250, 0, 0.2);
              {% elif is_state('climate.living_ac_living_ac', 'dry') %}
                rgba(0, 165, 0, 0.2);
                rgba(255, 255, 255, 0.2); /* Default color */
            padding: 0.5px !important;
            border-radius: 100px !important;
I haven’t tested, but try removing | (above the red dot)
This seems to have some effect.
                chip:
                  type: template
                  tap_action:
                    action: toggle
                  entity: input_boolean.kiosk_mode_toggle
                  icon: mdi:menu
                  card_mod:
                    style: |
                      ha-card {
                        border: 2px solid rgb(220,220,220,0.8) !important;
                        {% if is_state('climate.air_conditioning', 'heat_cool') %}
                        --chip-background: rgba(180, 165, 0, 0.2);
                        {% elif is_state('climate.air_conditioning', 'heat') %}
                        --chip-background: rgba(255, 123, 0, 0.2);
                        {% elif is_state('climate.air_conditioning', 'cool') %}
                        --chip-background:  rgba(255, 165, 0, 0.2);
                        {% elif is_state('climate.air_conditioning', 'fan_only') %}
                        --chip-background: rgba(255, 250, 0, 0.2);
                        {% elif is_state('climate.air_conditioning', 'dry') %}
                        --chip-background: rgba(0, 165, 0, 0.2);
                        --chip-background: rgba(255, 255, 255, 0.2); /* Default color */
When I make these types of templates for colours I create a template sensor.
Reference in Card, lovelace dashboard
                    card_mod:
                      style: |
                        ha-card {
                          {{states('sensor.swc_dewpoint_colour_outside')}}
Sensor, goes in configuration.yaml file
The output of the template in the sensor must be below 250 characters for this to work. Sensor State character limit.
  # TEMPLATE SENSORS -----------------------------------------------------------
    sensors:
      # Template Simple Weather Card - Dewpoint Colour - Outside
      swc_dewpoint_colour_outside:
        unique_id: 8883f463-f1fe-4e46-97ef-ab827670f130
        friendly_name: "SWC Dewpoint Colour Outside"
        value_template: >-
          {% if is_state('sensor.text_dewpoint_comfort_outside','Very Dry') %}
          --ha-card-background: radial-gradient(circle, deepskyblue, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Dry') %}
          --ha-card-background: radial-gradient(circle, mediumaquamarine, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Pleasant') %}
          --ha-card-background: radial-gradient(circle, limegreen, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Comfortable') %}
          --ha-card-background: radial-gradient(circle, yellowgreen, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Sticky Humid') %}
          --ha-card-background: radial-gradient(circle, yellow, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Muggy') %}
          --ha-card-background: radial-gradient(circle, gold, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Sweltering') %}
          --ha-card-background: radial-gradient(circle, orange, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
          {% elif is_state('sensor.text_dewpoint_comfort_outside','Stifling') %}
          --ha-card-background: radial-gradient(circle, crimson, 55%, rgba(100, 100, 100, 0.15), rgba(100, 100, 100, 0.15)) !important;
It’s a typo… you cant have two of these | unless there is a code break.
yeah lol I knew it was something silly of me.
Oh that interesting. So does the template go in the configuration.yaml and the Ref card is the frontenbut it?
