Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
Can someone have a look and tell me if this is formatted correctly? This is a section from a mushroom-template-card. The code works, but as you can see, the editor doesn’t seem to like it, and when I save the code, I get a warning that “comments will be deleted”, so the editor is seeing the hex color codes as comments, but they aren’t actually deleted and they do work as expected on the dashboard. I’ve tried a couple of different things formatting wise, but they all result in no color changes. Basically, should this be different?
you need single quote " ’ " around color hex codes eg. ‘#00d0b1
I would swear I tried that and fixed the comment issue, but broke the color change. I’ve just gone back and done it though and its working now, so I must not have done it properly the first time. Thank you.
Is there a way to use another entity’s image as an icon in a mushroom chips card?
chip:
  type: entity
  entity: sensor.personiphoneble
  tap_action:
    action: none
  hold_action:
    action: none
  double_tap_action:
    action: none
  content_info: state
  icon: person.person
Update: Best way I found to do this is to use the chips card then template option then rely on referencing the state or image indirectly.
Dear Community,
it’s possible add a button/switch in right corner???
immagine
my goal is turn off and turn on the NAS.
my code is:
type: vertical-stack
cards:
  - type: custom:bubble-card
    card_type: pop-up
    hash: '#nas'
    name: Network Area Storage
  - type: grid
    columns: 1
    square: false
    cards:
        card_type: separator
        icon: mdi:nas
        styles: |
          .separator-container div:last-child {
            opaticy: 1|important;
  - type: custom:vertical-stack-in-card
    mode: horizontal
    cards:
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.nas007_ping
            color: '#14ff8d'
        hours_to_show: 8
        points_per_hour: 8
        hour24: true
        line_width: 1
        bar_spacing: 10
        update_interval: 30
        height: 70
        aggregate_func: avg
        group: true
        animate: true
        show:
          labels: false
          fill: gradient
          state: false
          icon: false
        card_mod:
          style: |
            ha-card {
              border-radius: 8px;
              margin-bottom: -60px;
              background: none;
              box-shadow: none;
              --ha-card-border-width: 0;
        primary: Nas007
        secondary: >-
          {% set
          attr=state_attr('binary_sensor.nas007_stploop_com','round_trip_time_avg')
          %}  {% set state=states('binary_sensor.nas007_stploop_com',
          'round_trip_time_avg') %}  {% if attr==None%}
            🟥 0 ms - Down
          {% elif attr>10%}
            🟨 {{ state_attr('binary_sensor.nas007_stploop_com', 'round_trip_time_avg') }} ms - Raggiungibile
          {% elif attr<10%}
            🟩 {{ state_attr('binary_sensor.nas007_stploop_com', 'round_trip_time_avg') }} ms - Raggiungibile
        picture: /local/loghi/zyxel.png
        tap_action:
          action: navigate
          navigation_path: '#nas007'
        card_mod:
          style: |
            ha-card {
              --icon-size: 35px;
              --icon-border-radius: 0;
              height: !important;
              background: transparent;
Let me know
Thanks!
Does anyone have code for this Area card? thanks
  - type: horizontal-stack
    cards:
      - type: "custom:stack-in-card"
        cards:
            chips:
              - type: template
                entity: climate.eetplaats
                icon: mdi:air-conditioner
                icon_color: X,x,x
I added the chips card and changed the icon color to the same color as the background. Because I want to reserve the empty space to have a cleaner nicer stack in card.
Is there a better way to get that empty space ?
afbeelding
So to make it short… I dont want the airco icon, but still want the grey space around it …
if I am understanding you correctly. you can just add padding to the template card.
type: custom:mushroom-entity-card
entity: sun.sun
card_mod:
  style: |
    ha-card {
      padding-bottom: 50px !important ;
It was not what I wanted (because the chips card gives me a little difference in color by a card mod style). But what you gave me is better :wink:
thanks
the only problem I’ve got now, is that the padding bottom is not clickabele. The tap action on the custom:mushroom-template-card stops at the padding bottom…
if you want the whole card clickable you could do this with custom layout card
type: custom:layout-card
layout_type: custom:grid-layout
cards:
  - type: custom:stack-in-card
    view_layout:
      grid-column-start: 1
      grid-row-start: 1
    cards:
        card_mod:
          style: |
            ha-card {
        primary: home
        icon: mdi:home
      - type: custom:layout-card
  - type: button
    view_layout:
      grid-row-start: 1
    tap_action:
      action: toggle
    card_mod:
      style: |
        ha-card {
          background: none ;
          border-style: none;
    cards:
        cards:
            view_layout:
              grid-row-start: 1
            cards:
                primary: '{{ states(''input_text.ruimte_1'')}}'
                icon: mdi:lightbulb
                entity: switch_keuken_verlichting #switch_ruimte1_verlichting
                tap_action:
                  action: toggle
                icon_color: >
                  {% if is_state("switch_ruimte1_verlichting", 'on') %}
                    orange
                    138,153,119
                fill_container: true
                layout: horizontal
                multiline_secondary: false
                card_mod:
                  style: |
                    :host([dark-mode]) {
                      background: rgba(var(--rgb-primary-background-color), 0.2);
                    :host {
                      background: rgba(var(--rgb-primary-text-color), 0.025);
                    ha-card {
                      padding-bottom: 55px !important ;
          - type: button
            view_layout:
              grid-row-start: 1
            tap_action:
              action: toggle
            card_mod:
              style: |
                :host {
                ha-card {
like this ?
your missing
under
plus ha-card needs background none
ha-card {
          background: none;
one more thing I noticed which I didn’t include is add this to the button so it hides icon and name
show_name: false
show_icon: false
Is there anyway to rotate the mdi:icon 90 degrees in general and then still make the animation work? Basically I’m trying to rotate the sprinkler animation in order for it to point the sprayer up at all times and then when I turn the entity on it’s associated with for the animation to work. I’m trying to use it for a sundeck bubbler in my pool and this was the closest looking icon I could find that would look good if it was pointing the sprayer up instead of to the right.
This will rotate the icon.
type: custom:mushroom-template-card
icon: mdi:sprinkler
icon_color: cyan
primary: Sprinkler
card_mod:
  style: |
    ha-state-icon {
      rotate: -90deg;
      margin: 10px 0px 22px 22px;
      animation: sprinkle 2s linear infinite;
      transform-origin: 29% 88%;
    @keyframes sprinkle {
      0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
      1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
      6%, 21%, 36%, 51% { transform: rotate(2deg); }
Awesome! thank you!!
Looking for some assistance if possible, i would like to remove the white background when the card is un-collapsed
type: custom:collapsable-cards
title: Group control
cards:
  - type: custom:auto-entities
    filter:
      include:
        - domain: automation
          area: beau_s_room
          options:
            type: tile
            icon_tap_action:
              action: toggle
            tap_action:
              action: more-info
            color: primary
        - domain: script
          area: beau_s_room
          options:
            type: tile
            icon_tap_action:
              action: toggle
            tap_action:
              action: more-info
            color: primary
    show_empty: false
    card_param: cards
    card:
      square: false
      type: grid
      columns: 2
    sort:
      method: state
      reverse: false
card_mod:
  style: |
    ha-card {
      background: transparent !important;
      box-shadow: none !important;
Your post is not Mushroom related. I would suggest posting in the appropriate thread.
afbeelding
I don’t get it right :face_with_hand_over_mouth:
  # Ruimte 1#
    cards:
        cards:
            cards:
                view_layout:
                  grid-row-start: 1
                cards:
                    icon: mdi:lightbulb
                    tap_action:
                      action: toggle
                    icon_color: >
                      {% if is_state("switch_ruimte2_verlichting", 'on') %}
                        orange
                        138,153,119
                    layout: horizontal
                    card_mod:
                      style: |
                        :host {
                        ha-card {
              - type: button
                view_layout:
                  grid-row-start: 1
                tap_action:
                  action: toggle
                show_name: false
                show_icon: false
                card_mod:
                  style: |
                    ha-card {
                      background: none ;
                      border-style: none;
                    :host {
    # Ruimte2
        cards:
            primary: '{{ states(''input_text.ruimte_2'')}}'
            icon: mdi:lightbulb
            entity: switch_keuken_verlichting #switch_ruimte2_verlichting
            tap_action:
              action: toggle
            icon_color: >
                orange
                138,153,119
            layout: horizontal
            card_mod:
              style: |
                :host {
                ha-card {
it is smaller, and looks like a square
Can I ask where did you get this code? There is a lot here that is either unnecessary or not even working.
For example:
 138,153,119
You can extend the clickable area multiple ways. Here is an alternative…
  primary: test
  icon: mdi:lightbulb
  entity: switch.kitchen_lights
  tap_action:
          action: toggle
  icon_color: |
          {% if is_state('switch.kitchen_lights', 'on') %}
            orange
            red
  layout: horizontal
  card_mod:
    style:
         mushroom-state-info$: |
              .container {
                margin: -10px;
              .primary {
                 padding: 40px;
Used my entities to test so you’ll need to adjust
