Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
Had this same issue as well. Try adding margin-bottom and change -XXpx to adjust the height. See example below.
type: custom:stack-in-card
cards:
    primary: Wohnzimmer
    secondary: >-
      🌡️ {{ states('sensor.wohnzimmer_raumthermostat_temperature') | round(1)
      }} °C
    icon: mdi:sofa
    entity: light.wohnzimmer
    tap_action:
      action: navigate
      navigation_path: wohnzimmer
    hold_action:
      action: toggle
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
          margin-bottom: -XXpx !important; <---------- Add this to change the height
  - type: custom:mushroom-chips-card
    chips:
      - type: conditional
        conditions:
          - entity: climate.wohnzimmer_thermostat
            state_not: 'off'
        chip:
          type: template
          icon: |-
            {% if is_state(entity, 'heat') %}
              mdi:fire
            {% endif %}
          icon_color: red
      - type: conditional
        conditions:
          - entity: binary_sensor.wohnzimmer_balkontur
            state: 'on'
        chip:
          type: template
          icon_color: amber
          icon: mdi:door-open
          tap_action:
            action: more-info
      - type: light
        content_info: none
        use_light_color: true
        icon: mdi:lightbulb
        tap_action:
          action: toggle
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('light.wohnzimmer', 'on') %}
         background: rgba(255, 152, 0, 0.1);
      {% endif %}
possibly width: var(--chip-height) !important;
Remove it temporarily and see what changes///
Sorry, its not clear what the issue is?
The animation is working based off the state of the TV and the tap action on the TV icon is disable.
chrome-capture-2024-3-23
Many thanks for your reply.
Do you mean removing it from the code (but that line isn’t used)?
Or do you mean I should add it? :slight_smile:
Sections is limited by total width and you are trying to fit too many entities into one row. I’d recommend three and then start a second row.
4 in a row will work
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    margin: 0px 0px 0px 0px
    layout:
      grid-template-columns: 1fr 1fr 1fr 1fr
    cards:
        primary: Woonkamer
        layout: vertical
        icon: mdi:sofa
        tap_action:
          action: navigate
          navigation_path: null
        icon_color: blue
        multiline_secondary: true
        card_mod:
          style: |
            ha-card {
              --ha-card-background: none;
              --ha-card-box-shadow: none;
              --ha-card-border-width: 0;
              z-index: 1;
            :host {
              --mush-icon-border-radius: 12px;
      - type: custom:mushroom-climate-card
        entity: climate.living
        icon: none
        show_temperature_control: false
        primary_info: none
        secondary_info: none
        layout: horizontal
        tap_action:
          action: more-info
        card_mod:
          style:
            mushroom-shape-icon$: |
              .shape:after {
                content: "{{ state_attr(config.entity, 'current_temperature')|replace('.', ',') }}°";
                font-size: 12px;
                font-weight: bolder;
                color: white;
                position: absolute;
              .shape {
                {% set mode = state_attr(config.entity, 'hvac_action') %}
                --shape-color: rgba(var(--rgb-
                {%- if mode == 'heating' -%}
                  orange
                {%- elif mode == 'cooling' -%}
                  blue
                {%- else -%}
                  grey
                {% endif %}));
            mushroom-badge-icon$: |
              .badge {
                {{ 'display: none !important;' if state_attr(config.entity, 'hvac_action') == 'idle' }}
              mushroom-badge-icon:after {
                content: "{{ states(sensor.alpha2_heat_control_ezr012b5_glv_1_valve_opening') }}";
                position: absolute;
                display: flex;
                justify-content: center;
                align-items: center;
                background: rgb(var(--rgb-green));
                color: rgb(var(--rgb-white));
                border-radius: 50%;
                border-width: 0;
                top: 0px;
                width: 100%;
                height: 100%;
                font-size: 0.6em;
              mushroom-shape-icon {
                --icon-size: 34px;
                position: relative;
                top: 4px;
              ha-card {
               border: none;
        icon: mdi:lightbulb
        icon_color: >-
          {%if is_state('sensor.lichten_aan_woonkamer', '0') %} grey {% else %}
          amber {% endif %}
        entity: light.all_lights
        badge_icon: none
        badge_color: transparent
        tap_action:
          action: fire-dom-event
          browser_mod:
            service: browser_mod.popup
              title: Lichten
              style: |
                --popup-border-radius: 12px;
              content:
                type: custom:auto-entities
                filter:
                  include:
                    - area: Woonkamer
                      domain: light
                      options:
                        type: custom:mushroom-light-card
                        show_brightness_control: true
                        layout: horizontal
                        tap_action:
                          action: toggle
                  exclude:
                    - domain: light
                      attributes:
                        device_class: DNDMode
                card:
                  layout:
                    border-radius: 12px
                  cards: []
                  layout_type: masonry
                  sort:
                    method: friendly_name
          target: {}
        card_mod:
          style: |
              content: "{{ expand(area_entities('woonkamer')) | selectattr ( 'domain' ,'eq' , 'light' ) | selectattr ( 'state' , 'eq' , 'on' ) | rejectattr ('attributes.device_class','eq','DNDMode') | list | count }}";
              position: absolute;
              display: flex;
              background: red
              color: var(--card-background-color);
              border-radius: 50%;
              top: 0px;
              width: 100%;
              height: 100%;
              font-size: 0.7em;
                --icon-size: 34px;
                position: relative;
                top: 4px;
            ha-card {
               border: none;
        icon: mdi:window-shutter-open
        icon_color: >-
          {%if  expand(area_entities('woonkamer')) | selectattr ( 'domain' ,
          'eq' , 'cover' ) | selectattr ( 'state' , 'eq' , 'open' ) | list |
          count > 0 %} blue {% else %} grey {% endif %}
        entity: cover.alle_rolluiken
        badge_icon: none
        tap_action:
          browser_mod:
              title: Rolluiken
              style: |
              content:
                filter:
                  include:
                    - area: Woonkamer
                      domain: cover
                      options:
                        type: custom:mushroom-cover-card
                        show_buttons_control: true
                        layout: horizontal
                        card_mod:
                          style: |
                            ha-card {
                              padding: 4px 12px !important;
                  exclude:
                    - domain: cover
                      attributes:
                        types: browser_mod
                card:
                  layout:
                    margin: 0px 10px 10px 10px
                    border-radius: 12px
                  cards: []
                  sort:
        card_mod:
          style: |
              content: "{{ expand(area_entities('woonkamer')) | selectattr ( 'domain' , 'eq' , 'cover' ) | selectattr ( 'state' , 'eq' , 'open' ) | list | count}}";
              position: absolute;
              display: flex;
              background: rgb(var(--rgb-orange));
              border-radius: 50%;
              top: 0px;
              width: 100%;
              height: 100%;
              font-size: 0.7em;
              --icon-size: 35px;
              position: relative;
              top: 4px;
            ha-card {
             border: none;
        icon_color: >-
          'eq' , 'cover' ) | selectattr ( 'state' , 'eq' , 'closed' ) | list |
        badge_icon: none
        tap_action:
          browser_mod:
              title: Rolluiken
              style: |
              content:
                filter:
                  include:
                    - area: Woonkamer
                      domain: cover
                      options:
                        layout: horizontal
                        card_mod:
                          style: |
                            ha-card {
                  exclude:
                    - domain: cover
                      attributes:
                        types: browser_mod
                card:
                  layout:
                    border-radius: 12px
                  cards: []
                  sort:
        card_mod:
          style: |
              content: "{{ expand(area_entities('woonkamer')) | selectattr ( 'domain' , 'eq' , 'cover' ) | selectattr ( 'state' , 'eq' , 'closed' ) | list | count}}";
              position: absolute;
              display: flex;
              border-radius: 50%;
              top: 0px;
              width: 100%;
              height: 100%;
              font-size: 0.7em;
              --icon-size: 34px;
              position: relative;
              top: 4px;
            ha-card {
             border: none;
thank you!
Can I please get your code?
can you please send the code without a black background? to have a regular theme
Hi i love the looks of the mushroom cards and use it for most of things except for lights… and thats because i often wanto to tim my lights down to 1% but then if i use mushroom lights sliders they often go down to 0% and turn off… is it possible to add a value that the lowest value on the slider is 1%?
and can you please share the scripts for the timer?
Can you specify a specific post or a visual of the card?
HI,
Thanks for the reply.
The icon does not function as a button but with the animation it should let me know that the TV is on.
I would like to remove the animation that is there now and put that of the monitor but using the TV icon.
It’s possible!?
Hi, many thanks for the insights!
I changed the design a little bit :slight_smile:.
I removed the 2 cover cards (open & closed). And changed it to just one cover card with 2 badges. The upper badge shows the nr of open covers, the bottom badge shows the nr of closed covers.
Very nice. You could share the code. Thank you
Hi sure … here you go :slight_smile:
It’s a room card:
  • Graph of the room temperature for the last 24h on the left side
  • Climate card with the actual temperature. The color changes depending on the hvac action state: orange when heating, blue when cooling, grey when idle. The green badge on top is the valve % opening of the floor heating in the room. The badge is removed when the action state is idle.
  • Nr of active lights in the room. Color yellow >= 1 light active, else color is grey (no active lights). Tap action: : pop-up of al lights in the room.
  • The last one is the state of the covers. The color and icon change depending on state of all cover in the room. In this example I have 5 covers in the room (living area). When all covers are open → blue icon: open cover. When all covers are closed → blue icon: closed cover. When mixed open/closed covers → grey icon: alert cover
    The upper badge shows the nr of open covers, the bottom badge shows the nr of closed covers in the room.
    Tap action: pop-up of al covers in the room.
Code
mode: horizontal
cards:
  - type: custom:stack-in-card
    card_mod:
      style: |
        ha-card {
          border: none !important;
    cards:
        primary: Woonkamer
        secondary: '‎ '
        icon: mdi:sofa
        tap_action:
          action: navigate
        icon_color: blue
        card_mod:
          style: |
            ha-card {
              z-index: 1;
            :host {
      - type: custom:mini-graph-card
        entities:
          - entity: climate.living
            attribute: current_temperature
        hours_to_show: 24
        line_width: 3
        font_size: 50
        animate: true
        show:
          icon: false
          state: false
          legend: false
          fill: fade
        color: orange
        card_mod:
          style: |
            ha-card {
              position: absolute !important;
              height: 100%;
              width: 100%;
              top: 0px;
            ha-card:after {
              content: "";
              position: absolute;
              width: 100%;
              height: 100%;
              background: linear-gradient(to right, var(--card-background-color) 25%, transparent);
    mode: horizontal
    card_mod:
      style: |
        ha-card {
          top: 5px;
    cards:
        icon: none
        primary_info: none
        layout: horizontal
        tap_action:
          action: more-info
        card_mod:
          style:
              .shape:after {
                font-size: 14px;
                color: white;
                position: absolute;
              .shape {
                  orange
                  blue
                {%- else -%}
                  grey
                {% endif %}));
              .badge {
                content: "{{ states('sensor.alpha2_heat_control_ezr012b5_glv_1_valve_opening') }}";
                position: absolute;
                display: flex;
                border-radius: 50%;
                border-width: 0;
                top: 0;
                width: 100%;
                height: 100%;
                font-size: 0.7em;
              ha-card {
                margin-left: -10px;
                margin-right: 0px;
        primary: null
        icon: mdi:lightbulb
        icon_color: >-
          {%if  expand(area_entities('woonkamer')) | selectattr ( 'domain' , 'eq' ,
          'light' ) | selectattr ( 'state' , 'eq' , 'on' ) | list | count > 0 %}
          amber {% else %} grey {% endif %}
        badge_icon: none
        tap_action:
          browser_mod:
              title: Lichten
              style: |
              content:
                filter:
                  include:
                    - area: Woonkamer
                      domain: light
                      options:
                        layout: horizontal
                        tap_action:
                          action: toggle
                        card_mod:
                          style: |
                            ha-card {
                  exclude:
                    - domain: light
                      attributes:
                card:
                  layout:
                    border-radius: 12px
                  cards: []
                  sort:
          target: {}
        card_mod:
          style: |
              position: absolute;
              display: flex;
              border-radius: 50%;
              top: 0;
              width: 100%;
              height: 100%;
              font-size: 0.8em;
            ha-card {
              margin-left: -10px;
              margin-right: 0px;
        primary: null
        icon: >-
          count == 5 %} mdi:window-shutter-open  {%elif
          'cover' ) | selectattr ( 'state' , 'eq' , 'closed' ) | list | count ==
          5 %} mdi:window-shutter  {% else %} mdi:window-shutter-alert  {% endif
        icon_color: >-
          count == 5  or expand(area_entities('woonkamer')) | selectattr (
          | list | count == 5 %} blue {% else %} grey {% endif %}
        badge_icon: none
        tap_action:
          browser_mod:
              title: Rolluiken
              style: |
              content:
                filter:
                  include:
                    - area: Woonkamer
                      domain: cover
                      options:
                        layout: horizontal
                        card_mod:
                          style: |
                            ha-card {
                  exclude:
                    - domain: cover
                      attributes:
                        types: browser_mod
                card:
                  layout:
                    border-radius: 12px
                  cards: []
                  sort:
        card_mod:
          style: |
              position: absolute;
              display: flex;
              border-radius: 50%;
              top: 0px;
              right: 0px;
              width: 100%;
              height: 100%;
              font-size: 0.8em;
            mushroom-badge-icon:before {
              position: absolute;
              display: flex;
              border-radius: 50%;
              top: 30px;
              right: 0px;
              width: 100%;
              height: 100%;
              font-size: 0.8em;
            ha-card {
              margin-left: -10px;
              margin-right: 0px;
Good evening guys,
I still need you.
Through your invaluable help I have managed to create my counter of lights on.
The entity is “sensor.luci_accese_soggiorno”.
However, now I should insert the counter into my icon with animation in a chip card but I can’t.
Can you please help me.
Thank you
Here is the code
type: custom:button-card
icon: mdi:sofa
show_state: false
show_label: true
label: |
    return Math.round(states['sensor.weather_station_temperature'].state) + "°C" + "&nbsp&nbsp" + Math.round(states['sensor.weather_station_humidity'].state) + " %";
tap_action:
  action: navigate
  navigation_path: '#soggiorno'
custom_fields:
  btn1:
    card:
      chips:
        - type: template
          tap_action:
            action: none
          entity: light.luci_soggiorno
          icon: |
            {% if is_state(entity, 'on') %}
              mdi:lightbulb-on
            {% else %}
              mdi:lightbulb-outline
            {% endif %}
          icon_color: |
              black
            {% else %}
              white
            {% endif %}
      card_mod:
        style:
          mushroom-template-chip:nth-child(1)$:
            mushroom-chip$: |
              ha-card {
                --chip-background: {{'rgba(235, 204, 52, 1)' if is_state('light.luci_soggiorno', 'on') else 'rgba(199, 239, 207, 0.3)' }};
                animation: {{ 'ping 2s ease-out infinite' if is_state('light.luci_soggiorno', 'on') }};
                padding: 5px !important;
                border-radius: 100px !important;
                --chip-icon-size: 34px;
                --chip-height: 40px;
              @keyframes ping {
                0% {
                  box-shadow: 0 0 5px 1px rgba(var(--rgb-amber), 1);
                100% {
                  box-shadow: 0 0 5px 10px rgba(var(--rgb-amber), 0);
              ha-card:active {
                transform: translateY(1.5px);
                transition: 0s;
                box-shadow: 0 0.5px 2px 0 rgba(0, 0, 0, 0.16);
              ha-state-icon {
                animation: {{ 'illumination 2s infinite' if is_state('light.luci_soggiorno', 'on') }};
              @keyframes illumination {
                0%, 100% { clip-path: inset(0 0 0 0); }
                95% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
styles:
  grid:
    - grid-template-areas: '"n btn btn1" "l btn btn1" "i btn btn1"'
    - grid-template-columns: 1fr min-content min-content
    - grid-template-rows: min-content min-content 1fr
  img_cell:
    - justify-content: center
    - position: absolute
    - width: 80px
    - height: 80px
    - left: 0
    - bottom: 0
    - margin: 0 0 -25px -25px
    - background: '#FFF'
    - border-radius: 200px
  icon:
    - width: 35px
    - color: black
    - opacity: '0.6'
    - margin: 0 0 18px 15px
  card:
    - padding: 10px 20px 10px 10px
type or paste code here
So something like this?
chrome-capture-2024-3-23 (1)
type: custom:mushroom-template-card
      tap_action:
        action: none
      icon: |
          mdi:lightbulb-on
        {% else %}
        {% endif %}
      icon_color: |
          black
        {% else %}
          white
        {% endif %}
      card_mod:
        style: |
          ha-card:after {
                    content: " {{ states.light | rejectattr('attributes.entity_id', 'defined') | selectattr('state', 'eq', 'on') | list | count }}";
                    position: absolute;
                    display: flex;
                    border-radius: 50% 50%;
                    top: -5px;
                    right: -15px;
                    width: 20px;
                    height: 20px;
                    font-size: 10px;
          ha-card {
              padding: 0px !important;
              border-radius: 50% !important;
            @keyframes ping {
              0% {
              100% {
            ha-card:active {
              transition: 0s;
            ha-state-icon {
              animation: {{ 'illumination 2s infinite' if is_state(light.luci_soggiorno', 'on') }};
