Mushroom Cards - Build a beautiful dashboard easily πŸ„ (Part 2)
Try to playing with the next settings:
            ha-card {
              height: XXXpx;
apologies - here is the yaml.
type: custom:stack-in-card
cards:
  - type: custom:mushroom-entity-card
    entity: switch.linktap_tap_front
    fill_container: true
    card_mod:
      style: |
        ha-card {
          border: none;
          box-shadow: none;
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        entity: sensor.linktap_tap_front_battery
        icon: mdi:battery-charging
        icon_color: >-
          {% if states ('sensor.linktap_tap_front_battery') | int(0) < 30 %}
          red  {% elif states ('sensor.linktap_tap_front_battery') | int(0) < 50
          %} orange  {% else %} green  {% endif %}
        content: '{{ states (''sensor.linktap_tap_front_battery'') }}%'
        tap_action:
          action: more-info
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
      - type: template
        entity: sensor.linktap_tap_front_signal
        icon: mdi:wifi
        icon_color: >-
          {% if states ('sensor.linktap_tap_front_signal') | int < 30 %} red  {%
          elif states ('sensor.linktap_tap_front_signal') | int < 50 %} orange
        content: '{{ states (''sensor.linktap_tap_front_signal'') }}%'
        tap_action:
          action: more-info
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
    alignment: justify
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 5px;
          right: 15px;
          width: 60px;
          --chip-spacing: -12px;
          --chip-background: none;
I have several fans and when turned off, they all show the last used percentage and do not reset to zero, although they are turned off. Moreover, the Code provided by the standard card works correctly (it is attached to the letter). Apparently it monitors the fan turning off in some other way.
type: custom:mushroom-fan-card
entity: fan.esphome_web_a345e4_pwm_fan
icon_animation: true
show_percentage_control: false
show_oscillate_control: false
collapsible_controls: false
Then we need to come up with a slightly different approach. It’s still doable.
Is this the style you are looking for?
Thank you for your help, your opinion is very valuable to me. Perhaps this is a nuance of the ESP32. All fans work through the ESPhome add-on. Just in case, I’ll attach the code that was used to flash the ESP32. Maybe this will somehow help solve this problem. Thank you!!!
  - platform: pulse_counter
    pin: GPIO13
    name: PWM Fan RPM
    unit_of_measurement: 'RPM'
    filters:
      - multiply: 0.5
    count_mode:
      rising_edge: INCREMENT
      falling_edge: DISABLE
    update_interval: 3s
    output:
  - platform: ledc
    pin: GPIO12
    frequency: 10000 Hz
    fan:
  - platform: speed
    output: fanhub_pwm1
100% yes! Can you explain how you have achieved this?
I combined the stack-in-card with a layout-card. This gives you control over the columns and define them evenly.
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 1fr 1fr
      margin: 0px 0px 0px 0px
    cards:
        chips:
          - type: template
            icon_color: >-
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
          - type: template
            icon: mdi:wifi
            icon_color: >-
              {% elif states ('sensor.linktap_tap_front_signal') | int < 50 %}
            tap_action:
              action: more-info
            alignment: justify
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
        card_mod:
          style: |
            ha-card {
             position: absolute;
             top: 5px;
              right: 25px;
              width: 60px;
I’ll just rewrite the code to include the off state in a different way. Give me a little bit.
What is the fan speed range 1 thru ? I see the step size is 1.
Let’s try this…
type: custom:mushroom-template-card
entity: fan.bedroom_fan
icon: mdi:fan
card_mod:
  style: |
    ha-state-icon {
          animation:
          {% set pwr = states(config.entity) %}
          {% set perc = state_attr(config.entity,'percentage')|int %}
          {% set spd = 'rotation infinite linear' %}
          {% if ( pwr == 'off') %} 0s {{spd}}
          {% elif (perc <= 17 and pwr == 'on') %} 2.5s {{spd}}
          {% elif (perc <= 34 and pwr == 'on') %}  2s {{spd}}
          {% elif (perc <= 51 and pwr == 'on') %}  1.5s {{spd}}
          {% elif (perc <= 67 and pwr == 'on') %}  1s {{spd}}
          {% elif (perc <= 84 and pwr == 'on') %}  .75s {{spd}}
          {% elif (perc <= 100 and pwr == 'on') %}  .5s {{spd}}
          {% endif %};
          @keyframes rotation {
          0% {transform: rotate(0deg);}
          100% {transform: rotate(-360deg);}
First of all, as a silent reader - thank you very much for your work! Is is absolutely incredible what y’all @rhysb @LiQuid_cOOled @dimitri.landerloos etc. etc. etc. are doing. I spent some nights to get my mobile dashboard up & running.
My attepmt was to create a dense mobile dashboard where you can see nearly anything whats going on.
used:
  • HASS.agent to read your pc
  • many integrations, as well als custom sensors
  • theme: waves
  • custom:weather-card
  • mini-graph-card
  • bubble-card
  • mushroom
  • card-mod
  • conditional-card
  • apex-charts
  • auto-entities
  • stack-in-card
  • better-thermostat
  • etc.
Ask, if you like to see the code.
Thank you - I have modified the grid to include an additional row and is working well on PC but does not render correctly on a mobile as the column widths are less than on the computer.
I think I need a way to align the chips in relation to the grid cell rather than absolute. Is this possible?
pic below is from my phone so you can see the issue I have with placement of the chips
Here is my yaml
cards:
    layout:
      grid-template-rows: 75px 75px
      margin: 5px 0px -10px 0px
    cards:
        primary: Watering Setup
        secondary: |
          Profile: {{ states ('input_select.watering_schedule') }}
        icon: mdi:sprinkler-variant
        tap_action:
          action: call-service
          service: script.set_watering_schedule
          target: {}
        hold_action:
          action: none
        multiline_secondary: true
        fill_container: false
        double_tap_action:
          action: none
        entity: script.set_watering_schedule
        icon_color: >-
          {% if state_attr ('script.set_watering_schedule', 'last_triggered') +
          timedelta (hours = 24) < now() %} red {% else %} green {% endif %}
        entity: input_boolean.watering_smart
        icon: mdi:toggle-switch
        layout: horizontal
        tap_action:
          action: toggle
        double_tap_action:
          action: none
        entity: switch.linktap_tap_back
        chips:
          - type: template
            icon_color: >-
              < 50 %} orange  {% else %} green  {% endif %}
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
          - type: template
            icon: mdi:wifi
            icon_color: >-
              red  {% elif states ('sensor.linktap_tap_front_signal') | int < 50
            tap_action:
              action: more-info
            alignment: justify
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
        card_mod:
          style: |
            ha-card {
             position: absolute;
             top: 85px;
              left: 160px;
              width: 60px;
        chips:
          - type: template
            entity: sensor.linktap_tap_back_battery
            icon_color: >-
              {% if states ('sensor.linktap_tap_back_battery') | int(0) < 30 %}
              red  {% elif states ('sensor.linktap_tap_back_battery') | int(0) <
            content: '{{ states (''sensor.linktap_tap_back_battery'') }}%'
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
          - type: template
            entity: sensor.linktap_tap_back_signal
            icon: mdi:wifi
            icon_color: >-
              {% if states ('sensor.linktap_tap_back_signal') | int < 30 %} red
              {% elif states ('sensor.linktap_tap_back_signal') | int < 50 %}
            content: '{{ states (''sensor.linktap_tap_back_signal'') }}%'
            tap_action:
              action: more-info
            alignment: justify
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
        card_mod:
          style: |
            ha-card {
             position: absolute;
             top: 85px;
              right: 20px;
              width: 60px;
Let me see if I can reduce the padding on the chips. You can also set a different set of rules for mobile with @media
Let me know how this looks on the PC and mobile?
cards:
    layout:
    cards:
        chips:
          - type: template
            icon_color: >-
              {% if states ('sensor.linktap_tap_front_battery') | int(0) < 30 %} red  {%
              elif states ('sensor.linktap_tap_front_battery') | int(0) < 50 %} orange  {%
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
          - type: template
            icon: mdi:wifi
            icon_color: >-
              {% if states ('sensor.linktap_tap_front_battery') | int < 30 %} red  {% elif
              states ('sensor.linktap_tap_front_battery') | int < 50 %} orange  {% else %}
              green  {% endif %}
            tap_action:
              action: more-info
            alignment: justify
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
        card_mod:
          style: |
            ha-card {
             position: absolute;
             top: 5px;
             left: 125px;
              width: 60px;
            @media screen and (max-width: 400px) {
             ha-card {
             position: absolute;
             top: 5px;
             left: 110px;
              width: 60px;
        chips:
          - type: template
            icon_color: >-
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
          - type: template
            icon: mdi:wifi
            icon_color: >-
              green  {% endif %}
            tap_action:
              action: more-info
            alignment: justify
            card_mod:
              style: |
                ha-card {
                border: none;
                box-shadow: none;
        card_mod:
          style: |
            ha-card {
             position: absolute;
             top: 5px;
              right: 30px;
              width: 60px;
             ha-card {
             position: absolute;
             top: 5px;
             right: 20px;
              width: 60px;
Thanks @LiQuid_cOOled - much appreciated. Working fine on both PC and iphone now. Had to tweak a few things to get the prefect placement but all good.
That grid layout card is quite powerful. Is it possible to configure a 4 column grid and then then customise each row to span across a number of columns?
I’m thinking I would like to do something like the this - see below
Each row in your declaration needs to have the same number of cells, so yes if you have four columns like your diagram.
Only issue with this setup now is if I change my phone from portrait to landscape the chip cards are not placed correctly.
I think I will see if I can get the chips β€˜stacked’ into the entity card or if there was a way to map/align the chips with the cells of the grid it would be a more robust and repeatable approach.
Any ideas?
Thanks for this I was just looking at the CSS grid trick docs. I will see if I can make progress and report back if I need any more help.
I need a way to align chips to the grid cell first then I can try to play with spanning columns.
When you rotate your phone, your @media settings are affected because its a 3rd layout. This is why the new sections dashboard was created. It helps with cross media platforms.
All good. There is a lot to learn for sure. Thanks for helping me out with this stuff.
