Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Hi guys,
anyone maybe knows how to change the purple color of the cover popup window?
Thank you
Please make a seperate post. this question is not related to mushroom cards.
thanks again! you have helped me heaps! apparently i misunderstood the child(x) part but it’s fixed now.
i have but one question left. the
justify-content: center;
does not seem to work, i.e. it does not align the chips centered. i can verify this by changing “center” to anything like “space-evenly” , “flex-end” or whatever. the chips’ alignment does not change :confused:
if i haven’t overstayed my welcome already i’d appreciate if you/anybody could help
thanks!
No need to change chip alignment with card mod.
You can use the built in:
type: custom:mushroom-chips-card
alignment: center
chips:
  - type: template
    icon: mdi:test-tube
  - type: template
    icon: mdi:test-tube
perfect! i have learned a lot here thanks to you :slight_smile:
Whew, I’ve spent the last two weeks reading through this entire thread and trying to learn. I’ve also been through the awesome guides that @dimitri.landerloos put together. Thank you for all your contributions.
I have a functional card outside of mushroom…that worked, but the styling wasn’t great. I’ve been trying to reproduce in mushroom using snippets I’ve gathered along the way, but can’t quite get it.
I use pihole on my network. Occasionally, pihole will block something that it shouldn’t and I need to disable pihole network wide. I have the disable portion working through helpers, automations etc. I want to be able to push a button which disables pihole, but also initiates a timer (this automation is already sorted), but I want to view the countdown on the card. But I also want a slider where I can select the amount of time for the disable (this is also working, but I can’t get the formatting).
Here is my working card (outside of mushroom):
Screenshot 2024-02-18 121039
Screenshot 2024-02-18 121052
and here is the code for that card:
type: custom:stack-in-card
cards:
  - square: false
    type: grid
    columns: 1
    cards:
      - square: false
        type: grid
        columns: 2
        cards:
            entity: input_boolean.pi_hole_timer
            primary: >-
              Disable Time: {{ states('input_number.pi_hole_timer')|round|int }}
              Min.
            secondary: ''
            icon: mdi:power
            icon_color: |
              {% set state=states('input_boolean.pi_hole_timer') %}
              {% if state=='on' %}red
              {% elif state=='off' %}green
            card_mod:
              style: |
                ha-card {
                  --ha-card-border-width: 0;
            layout: vertical
          - type: custom:button-card
            entity: timer.pi_hole_timer
            show_state: true
            show_label: false
            show_icon: false
            height: 40px
            styles:
              img_cell:
                - background-color: rgba(var(--color-theme),0,05)
                - border-radius: 50%
                - place-self: center
                - width: 42px
                - height: 42px
              card:
                - background-color: '#3d5afe02'
                - border: none
                - border-radius: 14px
                - font-size: 15px
                - font-weight: bold
                - height: 70px
                - color: |
                      if(states['input_boolean.pi_hole_timer'].state == 'on') return 'rgb(245,6,54)'
                      else return 'gray';
                - align_self: middle
              name:
                - font-size: 20px
                - color: '#DDDDDD'
                - font-weight: bold
      - type: custom:my-slider
        entity: input_number.pi_hole_timer
        step: '5'
        height: 20px
        radius: 10px
        mainSliderColor: steelblue
        thumbHorizontalPadding: 15px
        styles:
          card:
            - border: none
In my attempt to convert to mushroom, I’ve had varying success but can’t quite get it.
Here is just a number card (I haven’t added the toggle on the icon yet)
Screenshot 2024-02-18 121430
code is here:
type: custom:mushroom-number-card
layout: horizontal
display_mode: slider
card_mod:
  style:
    mushroom-number-value-control$:
      mushroom-slider$: |
        .slider {
          position: absolute !important;
          width: calc(100% - 76px) !important;
          right: 12px;
          height: 42px !important;
    mushroom-state-info$: |
      .container {
        flex-direction: row !important;
        position: absolute;
        width: 79%;
        top: 17px;
        align-items: baseline;
      .primary {
        color: transparent !important;
        position: relative;
        width: max-content !important;
        flex-shrink: 1;
        flex-grow: 1;
      .primary:after {
        content: '{{states('input_boolean.pi_hole_timer')}}';
        position: absolute;
        color: var(--primary-text-color);
        left: 0px;
      .secondary {
        position: relative;
        flex-shrink: 1;
        flex-grow: 0;
      .secondary:after {
        content: '{{states('input_boolean.pi_hole_timer') | round(0)}}';
        position: absolute;
        color: var(--secondary-text-color);
        left: 0px;
      mushroom-state-info {
        padding-left: 6px;
        width: max-content;
        pointer-events: none;
        z-index: 1;
        display: flex;
But this one doesn’t have the time remaining countdown as I’d like
I have this one also:
Screenshot 2024-02-18 122604
The formatting of the primary info is weird and although I was able to get the secondary info in the “tail” of the slider…it doesn’t change to countdown.
code:
layout: horizontal
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          right: 12px;
          border: gray !important;
          --bg-colr: #1d1d1d !important;
      .container {
        position: absolute;
        width: 79%;
        top: 17px;
      .primary {
        position: relative;
        flex-shrink: 1;
        flex-grow: 1;
      .primary:after {
        content: '{{states('input_number.pi_hole_timer')}}';
        position: absolute;
        left: 5px;
      .secondary {
        position: relative;
        flex-shrink: 1;
        flex-grow: 0;
      .secondary:after {
        content: '{{states('timer.pi_hole_timer')}}';
        position: absolute;
        right: 0px;
        padding-right: 10px;
        padding-left: 15px;
        z-index: 1;
        display: flex;
      mushroom-shape-icon {
        --icon-size: 34px;
        position: relative;
        top: 4px;
      ha-card {
        height: 58px !important;
There is probably a lot of unnecessary stuff in my code(s) also because I have been “playing” with different options.
Any help is greatly appreciated. Sorry for the long post.
First thanks a lot for all the awesome ressources in this thread, it’s absolutely stunning what all you guys did.
Then comes my problem, i’m trying to make the icon of a mushroom chip rotate. Search for a way to do it all day but didn’t manage to make it work. The dumb idea was that :
chips:
  - type: entity
    entity: sensor.pinas_fan_speed
    icon: mdi:fan
    icon_color: blue
    card-mod:
      style: |
        ha-state-icon {
          animation: spin 1s linear infinite;
alignment: end
Obviously it doesn’t work, if you guys have any idea, that would be awesome
This would be the simplest way.
chips:
  - type: template
    entity: fan.bedroom_fan
    icon: mdi:fan
    icon_color: blue
    card_mod:
      style: |
        .content {
read through this for additional information page 7726
specifically this section
Thanks a lot for your response
Works like a charm, but maybe too much :smiley:
It makes the text also spin. I should have precised it a bit, but i just want the icon to spin. I’ll try to find a way thanks to the information you provided
EDIT: found a way :
chips:
  - type: entity
    icon: mdi:fan
    icon_color: blue
card_mod:
  style:
    mushroom-entity-chip:nth-child(1)$: |
      ha-state-icon {
@PetitSphincter Yes sir, That is why I wanted you to read through that specific section. The nth-child(1)$: | method is a great way of splitting CSS elements apart for different mods. Good job!
Mushroom has some animations built in now. Spin is one of them, for one that are preprogrammed you’ll have to use @keyframes.
A keyframes example to spin the fan in reverse.
chips:
  - type: template
    content: Mushroom
    icon: mdi:fan
    icon_color: red
  - type: entity
    content_info: name
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
      @keyframes spin {
        100% { transform: rotate(-360deg); }
To add:
The built in animations dont tend to work on all browsers when applied through shadow roots.
So to be safe, when using any $ in your path to the element i would always add keyframes. Just to ensure it has broad browser support.
@PetitSphincter
Hello I have this card:
chips:
  - type: entity
    entity: person.pupetti
    content_info: none
    use_entity_picture: true
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: Federico
          content:
            type: vertical-stack
            cards:
              - type: custom:mushroom-entity-card
                layout: horizontal
                icon_type: entity-picture
                primary_info: state
                secondary_info: last-changed
                tap_action:
                  action: none
                hold_action:
                  action: none
                card_mod:
                  style:
                    mushroom-shape-avatar$: |
                      .picture {
                        /* Style shadow ring around person avatar */
                        box-shadow: 0px 0px 4px 2px var(--state-person);
                        margin-right: var(--mush-title-spacing, 12px);
                      ha-card {
                        /* Remove default card styling */
                        --ha-card-background: none;
                        box-shadow: none;
                        /* Increase icon size */
                        --icon-size: 72px;
                        /* Center card */
                        margin: auto;
                        width: fit-content;
                        /* Add padding to bottom of card */
                        padding: 0px 0px var(--mush-title-spacing, 12px) 0px !important;
                        /* Make card non-responsive to select and pointer */
                        user-select: none;
                        transition: all 0s;
                      :host {
                        /* Define Person State colors. Can be added to theme */
                        --state-person-home: var(--green-color);
                        --state-person-not-home: var(--red-color);
                        --state-person-zone: var(--blue-color);
                        --state-person-unknown: var(--grey-color);
                        /* Set Person State color */
                        --state-person:
                        {% if is_state(config.entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entity) | replace('_', '-') }})
                          var(--state-person-zone)
                        {% endif %};
                        /* Match styling to Mushroom Title */
                        --mush-card-primary-font-size: var(--mush-title-font-size, 24px);
                        --mush-card-primary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-primary-line-height: var(--ush-title-line-height, 1.2);
                        --mush-card-secondary-font-size: var(--mush-title-font-size, 16px);
                        --mush-card-secondary-font-weight: var(--mush-title-font-weight, normal);
                        --mush-card-secondary-line-height: var(--ush-title-line-height, 1.2);
              - type: history-graph
                entities:
                  - entity: person.pupetti
                hours_to_show: 24
                title: Timeline
                card_mod:
                  style:
                      .card-header {
                        /* Style timeline title */
                        padding: 0px 24px !important;
                        font-size: var(--mush-card-primary-font-size, 14px) !important;
                        font-weight: var(--mush-card-primary-font-weight, bold) !important;
                        line-height: var(--mush-card-primary-line-height, 1.5) !important;
                        color: var(--primary-text-color) !important;
                      ha-card {
                        --ha-card-box-shadow: none;
                        user-select: none;
                      .content {
                        /* Add padding on right */
              - type: horizontal-stack
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_average_active_pace_3
                        state_not: '0'
                    card:
                      type: custom:mushroom-template-card
                      primary: >-
                        {{ states(entity) }} {{ state_attr(entity,
                        'unit_of_measurement') }}
                      secondary: '{{ state_attr(entity, ''distance'') | round(1) }} km'
                      icon: mdi:map-marker-path
                      entity: sensor.fede_l_16_distance_3
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                            .primary:after {
                              /* Add destination details */
                              content: "\Ato Home";
                              white-space: pre;
                              text-overflow: ellipsis;
                            ha-card {
                              /* Center card on row */
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                cards:
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_geocoded_location_3
                        state_not: '0'
                    card:
                      primary: >-
                      layout: vertical
                      icon_color: purple
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style:
                            .primary:after {
                              content: "\Ato Work";
                              white-space: pre;
                            ha-card {
                              width: fit-content;
                              margin: auto;
                              user-select: none;
                    primary: '{{ states(entity) }}%'
                    secondary: >
                      {{ 'charging' if
                      is_state('sensor.fede_l_16_battery_state', 'on' ) else
                      'discharging' }}
                    icon: >
                      {% set battery_level = (states(entity) | int / 10) |
                      round(0) | int * 10 %}
                      {% if battery_level == 100 %}
                        mdi:battery
                      {% elif battery_level > 0 %}
                        mdi:battery-{{ battery_level }}
                        mdi:battery-alert-variant-outline
                    icon_color: |-
                      {% set battery_level = states(entity) | int %}
                      {% if battery_level > 90 %}
                        green
                      {% elif battery_level > 60 %}
                        light-green
                      {% elif battery_level > 50 %}
                        lime
                      {% elif battery_level > 40 %}
                        yellow
                      {% elif battery_level > 30 %}
                        amber
                      {% elif battery_level > 20 %}
                        orange
                      {% elif battery_level > 10 %}
                        deep-orange
                        red
                    entity: sensor.fede_l_16_battery_level_3
                    layout: vertical
                    badge_icon: >-
                      {% if is_state('sensor.fede_l_16_battery_state_3', 'on')
                        mdi:lightning-bolt
                      {% elif states(entity) | int < 10 %}
                        mdi:exclamation-thick
                    badge_color: '{{ ''red'' if states(entity) | int < 10 else ''light-blue'' }}'
                    tap_action:
                      action: none
                    hold_action:
                      action: none
                    double_tap_action:
                      action: none
                    card_mod:
                      style:
                        mushroom-shape-icon$: |
                          .shape {
                            /* Radial progress bar */
                            background: radial-gradient(var(--card-background-color) 60%,
                                                        transparent calc(60% + 1px)),
                                        conic-gradient(var(--icon-color) {{ states(config.entity) }}% 0%,
                                                        var(--card-background-color) 0% 100%);
                          .shape:after {
                            /* Add back icon shape */
                            content: "";
                            height: 100%;
                            width: 100%;
                            position: absolute;
                            border-radius: var(--icon-border-radius);
                            background: var(--shape-color);
                          ha-icon {
                            /* Icon charging animation */
                            {{ '--icon-animation: charge 3s linear infinite;' if is_state('binary_sensor.rhys_phone_is_charging', 'on') }}
                          @keyframes charge {
                            0%, 80% { clip-path: inset(0 0 0 0); }
                            10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
                            20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
                            30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
                            40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
                            50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
                            60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
                            70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
                  - type: conditional
                    conditions:
                      - entity: sensor.fede_l_16_connection_type_3
                        state_not: <not connected>
                    card:
                      primary: '{{ states(''sensor.fede_l_16_connection_type_3'') }}'
                      secondary: >-
                        {% set signal_level = states(entity) | int %} {% if
                        signal_level != -1 %}
                          {{ signal_level }} dBm
                      icon: >-
                        {% set signal_level = states(entity) | int | abs %} {%
                        if signal_level > 90 %}
                          mdi:wifi-strength-outline
                        {% elif signal_level > 80 %}
                          mdi:wifi-strength-1
                        {% elif signal_level > 70 %}
                          mdi:wifi-strength-2
                        {% elif signal_level > 60 %}
                          mdi:wifi-strength-3
                        {% elif signal_level > 1 %}
                          mdi:wifi-strength-4
                          mdi:wifi-strength-off
                      layout: vertical
                      fill_container: false
                      icon_color: cyan
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      card_mod:
                        style: |
                          ha-card {
                            width: fit-content;
                            margin: auto;
                            user-select: none;
                chips:
                  - type: template
                    tap_action:
                      action: none;
                    hold_action:
                      action: call-service
                      service: notify.mobile_app_fede_l_16
                        message: Ringing phone...
                        title: Find Phone
                          ttl: 0
                          importance: high
                          priority: high
                          tag: Find
                          channel: alarm_stream
                    icon: mdi:target
                    icon_color: red
                    content: Find Phone
                alignment: center
                card_mod:
                  style: |
                    ha-card {
                      /* Style Chip like Mushroom button */
                      --chip-background: rgba(var(--rgb-red), 0.2);
                      --chip-border-radius: var(--mush-control-border-radius, 12px);
                      --chip-height: var(--mush-control-height, 42px);
                      --chip-box-shadow: none;
                      user-select: none;
                    ha-card:active {
                      /* Add effect to give feedback on button press */
                      --chip-background: rgba(var(--rgb-red), 0.4);
              - type: map
                entities:
                dark_mode: false
                hours_to_show: 24
                aspect_ratio: '4:3'
                card_mod:
                  style:
                    ha-map $ ha-entity-marker $: |
                      .marker {
                        /* Style person marker & adjust position to avoid blocking waypoints */
                        border: 3px solid var(--state-person) !important;
                        border-radius: 50% 50% 50% 0px !important;
                        transform: rotate(-45deg) translate(50%, -50%);
                        overflow: visible !important;
                        background: var(--state-person) !important;
                      .entity-picture {
                        /* Correct orientation of person avatar */
                        transform: rotate(45deg);
                        border-radius: 50%;
                    ha-map $: |
                      path:first-child {
                        /* Style accuracy radius */
                        stroke: var(--state-person);
                        fill: color-mix(in srgb, var(--state-person) 50%, transparent);
                        stroke-width: 0px;
                      path:nth-child(even) {
                        /* Styling for waypoints */
                        stroke: var(--purple-color);
                        stroke-width: 4px;
                      path:nth-child(odd):not(:first-child) {
                        /* Styling for lines */
                        stroke-width: 4px;
                      .leaflet-control-attribution {
                        /* Style attribution text */
                        background: rgba(var(--rgb-card-background-color), 0.4) !important;
                        font-size: 10px;
                      .leaflet-container a {
                        /* Set color of zoom icons & attribution text */
                      .leaflet-control-zoom-in,
                      .leaflet-control-zoom-out {
                        /* Style zoom buttons like Chips */
                        border-radius: var(--mush-chip-border-radius, 19px) !important;
                        padding: 3px;
                        background: rgb(var(--rgb-secondary-text-color), 0.2) !important;
                        margin: 8px 12px 0px;
                        border: var(--ha-card-border-width, 1px) solid var(--ha-card-border-color, var(--divider-color, #e0e0e0)) !important;
                      .leaflet-top {
                        /* Move zoom buttons to bottom of map */
                        bottom: 0px !important;
                      .leaflet-control-zoom {
                        /* Allow buttons to be moved */
                        /* Adjust spacing for border */
                        bottom: calc(2 * var(--ha-card-border-width, 1px) + 56px);
                        /* Remove extra margin */
                        margin: 0px !important;
                        /* Remove zoom control border */
                        border: none !important;
                      .leaflet-container:after {
                        /* Fade out map at top */
                        content: "";
                        position: absolute;
                        height: 100%;
                        width: 100%;
                        background: linear-gradient(to top, transparent 65%, var(--card-background-color));
                    ha-icon-button $ mwc-icon-button $: |
                      button {
                        /* Size center button to match Chip */
                        height: var(--mush-chip-height, 36px) !important;
                        width: var(--mush-chip-height, 36px) !important;
                        --mdc-icon-size: 22px;
                      ha-card {
                        /* Remove default card styling without affecting child elements */
                        box-shadow: none;
                        border-width: 0;
                        border-radius: 0px 0px var(--ha-card-border-radius, 12px) var(--ha-card-border-radius, 12px);
                        transition: all 0s;
                      :host {
                        /* Set person state color */
                        --state-person:
                        {% if is_state(config.entities[0].entity, ['home', 'not_home', 'unknown']) %}
                          var(--state-person-{{ states(config.entities[0].entity) | replace('_', '-') }})
                        {% endif %};
                      ha-icon-button {
                        /* Position center button */
                        bottom: 12px;
                        left: 12px !important;
                        top: auto !important;
                        /* Style center button to match Chip */
                        color: var(--deep-orange-color) !important;
                        background: color-mix(in srgb, var(--deep-orange-color) 20%, transparent);
                        border-radius: var(--mush-chip-border-radius, 19px);
          card_mod:
            style: |
              :host {
                /* Remove border from poup */
                --popup-padding-x: 0px;
                --popup-padding-y: 0px;
                --popup-min-width: 450px;
              .content {
                /* Remove extra bottom border */
                margin: -18px -24px -24px !important;
    card_mod:
      style: |
        /* Color border around avatar to show person status */
        ha-card {
          --chip-background:
            rgb(var(--rgb-state-person-{{ states(config.entity) | replace('_', '-') }} ))
            rgb(var(--rgb-state-person-zone))
          {% endif %};
        /* Slightly enlarge & bring to front on hover */
        ha-card:hover {
          transform: scale(1.2);
          transform-origin: top center;
          z-index: 1;
          transition: all 1s;
But the problem is when im in my office. My zone.work creates this situation in my pop up:
I have both conditions home/not_home by my iPhone device tracker …. Could you help me to solve it? Thank you
Cn you please you be more specific what this situation in my pop up: means? Just we are on the same page.
Yes in my photo I have 2 cards with “Lavoro” but it should appear one only. “Casa” when im at home, “Fuori Casa” when im not_home and “Lavoro” when im working in my office.
Now im working and I have two card with “Lavoro”- “Casa” and “Lavoro”-“Fuori Casa”
I hope to have explained better
Understood! Thank you!
Here is my card:
          icon: |-
            {% if is_state('binary_sensor.bathroom_washing_machine_door_contact', 'on') %}
              mdi:tumble-dryer
              mdi:washing-machine
          icon_color: |-
                {% if is_state('binary_sensor.washing_machine', 'on') %}
                  amber
                {% elif is_state('switch.bathroom_washing_machine_socket','on') %}
                  orange
          primary: |-
                {% if is_state('input_select.washing_machine_state','Washing') %}
                  Washing
                {% elif is_state('input_select.washing_machine_state','Drying') %}
                  Drying
                {% elif is_state('input_select.washing_machine_state','Error') %}
                  ERROR!
                  Power On
                  Power Off
          secondary: |-
              Opened
          layout: vertical
          card_mod:
            style: |
                ha-card {
                    --card-primary-color: red;
                    --card-primary-color: green;
                    --card-primary-color: orange;
                    --card-primary-color: black;
                :host {
                  --icon-size: 64px !important;
                ha-state-icon {
                  {% if states('binary_sensor.washing_machine') == 'on' %}
                  animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
                  transform-origin: 50% 110%;
                  {%- else -%}
                  {%- endif %}
                @keyframes shake {
                  0%, 100% { transform: translate(0, 0) rotate(0); }
                  20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
                  40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
                  60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
                  80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
                @keyframes drum {
                  50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
I would like to insert an electrical connection icon as an overlay, is this possible?
Did you figure out the chip animation without the words animated?
I meant to answer you on that.
I am confused about what you are describing. Can you explain it better and/or provide an edited picture of what you want?
hi all,
can somebody my help me,
the code is again broke,
style: |
              ha-state-icon {
                {{'animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;' if is_state(config.entity, 'on') }}
                  @keyframes cloudy {
                    0%, 100% { transform: translateX(3px); }
                    30% { transform: translateX(-1px); }
                    45% { transform: translateX(1.5px); }
                    75% { transform: translateX(-3.2px); }
                  @keyframes rain {
                    50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
what its wrong he do not animated, thank you for helping
code is working fine, but it seems the colors are defined incorrectly
