Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
This is the second chip. I tried this and it’s not working.
card_mod:
  style:
    div:
      mushroom-template-chip:nth-child(2):
          mushroom-chip: |
            ha-icon {
              {% set status = state_attr('climate.daniel_s','fan_mode') %}
              {% if status == 'Low' %}
              animation: rotation 1s linear infinite;
            @keyframes rotation {
              0% {
                transform: rotate(0deg);
              100% {
                transform: rotate(360deg);
Post your complete chip code and we can have a look.
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
        --chip-spacing: 0px;
        --chip-padding: 0 0.2em
    alignment: justify
    chips:
      - type: template
        content: '{{state_attr(entity, ''current_temperature'')}} °F'
        entity: climate.daniel_s
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          grey
        style: |
          ha-card {
            margin-left: 6px;
      - type: template
        content: |
          {{ state_attr(entity,'fan_mode') }}
        icon: |-
          {% set mode = state_attr(entity,'fan_mode') %}
          {% if mode == 'Auto low' %}
           mdi:fan-off
          {% elif mode == 'Low' %}
          fas:fan
        icon_color: |-
          {% set status = state_attr(entity,'fan_mode') %}
          {% if status == 'Auto low' %}
          grey
          {% elif status == 'Low'  and states(entity) == 'cool' %}
          blue
          {% elif status == 'Low'  and states(entity) == 'heat' %}
          red
          grey
        tap_action: none
        card_mod:
          style:
            div:
                  mushroom-chip: |
                    ha-icon {
                      0% {
                      100% {
      - type: template
        tap_action:
          action: more-info
        content: >
          {{ states('sensor.daniels_humidifier_status') | replace('off','Off') |
          replace('on','On') }}
        entity: sensor.daniels_humidifier_status
        icon: mdi:air-humidifier
        icon_color: blue
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) | round(0) }}% Humidity'
        entity: sensor.daniels_humidity
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
card_mod:
  style: |
    ha-card {
      --ha-card-background: transparent
The card_mod for Chip animation needs to be moved to the left to align with the mushroom-chip-card not the Chip.
Got it to work thank you.
You need to keep the input_boolean. It is used to hide/show the dropdown.
Manually assigned lights would be like this:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: auto 42px
      margin: '-4px -4px -8px -4px;'
    cards:
      - type: custom:mushroom-light-card
        entity: group.master_bedroom_lights
        layout: horizontal
        icon: mdi:lightbulb-group
        show_brightness_control: true
        card_mod:
          style: |
            ha-card {
              background: none;
              --ha-card-box-shadow: 0px;
        entity: input_boolean.bedroom_lights_dropdown
        primary: ''
        secondary: ''
        icon: mdi:chevron-down
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style:
            mushroom-shape-icon$: |
              ha-icon {
                transition: transform 0.14s !important;
                {{ 'transform: rotate(-180deg);' if is_state(config.entity, 'on') }}
              ha-card {
                align-items: flex-end;
                background: none;
              mushroom-shape-icon {
                --shape-color: none !important;
  - type: conditional
    conditions:
      - entity: input_boolean.bedroom_lights_dropdown
        state: 'on'
    card:
      cards:
          entity: light.bedroom_light
          use_light_color: false
          layout: horizontal
          card_mod:
            style: |
              ha-card {
                padding: 8px 24px !important;
          entity: light.rhys_bedside_light
          use_light_color: true
          layout: horizontal
          card_mod:
            style: |
              ha-card {
          entity: light.sarahs_bedside_light
          layout: horizontal
          card_mod:
            style: |
              ha-card {
                padding: 8px 24px 12px !important;
      card_mod:
        style: |
          ha-card {
            background: none;
P.S. I’ve added a nice little animation on the dropdown chevron :grin:.
Animated Dropdown
Yes, you can have it dynamically adjusting the color of the Mushroom Bar Card like this:
Mushroom Bar Card - Level 1 Color
Mushroom Bar Card - Level 2 Color
cards:
    layout:
      grid-template-columns: 42px auto
    cards:
        entity: sensor.cpu_temperature
        icon: mdi:thermometer
        icon_color: |
          {% set cpu_temp = states(entity) | int %}
          {% if cpu_temp > 80 %}
            red
          {% elif cpu_temp > 60 %}
            orange
            green
        card_mod:
          style: |
            ha-card {
              background: none;
      - type: custom:bar-card
        height: 42px
        min: '0'
        max: '90'
        entity_row: true
        severity:
          - color: rgb(var(--mush-rgb-green))
            to: 60
          - color: rgb(var(--mush-rgb-orange))
            to: 80
          - color: rgb(var(--mush-rgb-red))
            to: 90
        positions:
          icon: 'off'
          indicator: 'off'
        card_mod:
          style: |
            ha-card {
              padding: 12px;
              margin-left: 12px;
              --bar-card-border-radius: 12px;
              --mush-rgb-red: 244, 67, 54;
              --mush-rgb-pink: 233, 30, 99;
              --mush-rgb-purple: 156, 39, 176;
              --mush-rgb-deep-purple: 103, 58, 183;
              --mush-rgb-indigo: 63, 81, 181;
              --mush-rgb-blue: 33, 150, 243;
              --mush-rgb-light-blue: 3, 169, 244;
              --mush-rgb-cyan: 0, 188, 212;
              --mush-rgb-teal: 0, 150, 136;
              --mush-rgb-green: 76, 175, 80;
              --mush-rgb-light-green: 139, 195, 74;
              --mush-rgb-lime: 205, 220, 57;
              --mush-rgb-yellow: 255, 235, 59;
              --mush-rgb-amber: 255, 193, 7;
              --mush-rgb-orange: 255, 152, 0;
              --mush-rgb-deep-orange: 255, 87, 34;
              --mush-rgb-brown: 121, 85, 72;
              --mush-rgb-grey: 158, 158, 158;
              --mush-rgb-blue-grey: 96, 125, 139;
              --mush-rgb-black: 0, 0, 0;
              --mush-rgb-white: 255, 255, 255;
            bar-card-value {
              margin: 12px;
              font-size: 12px;
              font-weight: bolder;
            bar-card-name {
              margin: 12px;
              font-size: 12px;
            bar-card-backgroundbar {
              opacity: 0.2;
              filter: brightness(1);
You only need to include the --mush-rgb-[color] variables if they are not defined in your theme. You only need to include the ones you will be using.
Thank you for your help.
Be interested in seeing how this works. What type of softener do you have, how big is the salt store?
Well I attempted to flash the d1mini that i had used to make the sensor and it wouldnt boot to enable me to flash it, so ive used another one now with this code (tweaked to use my default esp template) and now going to build the sensor back up.
### DEFAULT DEVICE SETTINGS - Change Friendly Name, IP & Board Type ###
substitutions:
  friendly_name: "salt-level"
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pass
  manual_ip:
    static_ip: 192.168.1.62
    gateway: 192.168.1.254
    subnet: 255.255.255.0
### Set this to devices CURRENT IP if to be changed ###
#  use_address: 192.168.1.X
  ap:
    ssid: "$friendly_name Hotspot"
    password: !secret fall_pass
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret api_pass
ota:
  password: !secret ota_pass
# Exposed Attirbutes/Sensors
switch:
  - platform: restart
text_sensor:
  - platform: version
    name: "$friendly_name ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
  - platform: wifi_signal
    name: $friendly_name WiFi Strength
    update_interval: 60s
  - platform: uptime
### DEFAULT END - Change Friendly Name ###
  - platform: ultrasonic
    trigger_pin: D1
    echo_pin: D2
    name: "Saltlevel in percent"
###    update_interval: 12h
    update_interval: 5s
    filters:
    # Calculates in %
    # Replace 0.43 by the height of your container. From the sensor to the bottom.
    # I used this website to know how I should multiply my values :https://www.skillsyouneed.com/num/percent-change.html
    - lambda: return (0.43-x)*(100/0.43);
    unit_of_measurement: "%"
    trigger_pin: D1
    echo_pin: D2
    name: "Saltlevel in cm"
    update_interval: 5s
    filters:
    # Replace the 0.43 by the height of your container. From the sensor to the bottom.
    # I multiplied by 100 in order to get CM since the sensor works in meters
    - lambda: return (0.43-x)*100;
    unit_of_measurement: "cm"
My Softener is a BWT Water Genie 15, the bin is 43cm from sensor to base.
Does anyone know if i can have these icons represent their state_color when they’re on?
For some reason the bar doesnt show up here, however i’ve installed all HACS for this.
If i use this the bar doesnt show up. unless i change
            to: 60
to
        severity:
          - color: green
            to: 60
If you want to match the Mushroom colors, add these variables to your theme:
Alternatively you can declare them in card_mod. I’ll add it to the example.
Not sure if this is what you want?
cards:
    layout:
      grid-template-columns: 44px auto
    cards:
        cards:
            chips:
              - type: back
            card_mod:
              style: |
                :host([dark-mode]) {
                  #width: 50px;
                :host {
                  #background: #1a1a1a;
                  #margin-top: 15px;
                ha-card  {
                  margin-top: 18px;
                  #margin-left: 0px;
                  --chip-icon-size: 36px;
      - type: custom:banner-card
        entities: null
        heading:
          - Bedroom
        link:
          - window.history.back()
        card_mod:
          style: |
            ha-card  {
              #margin-top: 0px;
              #margin-left: -180px;
              #background: none;
              align-items: flex-start !important;
            ha-card .heading {
              font-size: 3.5em;
              margin: 30px;
              #color: black;
              font-family: 'Amatic SC', cursive;
            ha-card .overlay-strip {
              font-size: 1em;
              font-family: 'Roboto';
              font-weight: 900;
              background: none;
card_mod:
  style: |
    ha-card {
      --ha-card-box-shadow: none;
Still working on adding the back function.
Brilliant thanks, created a decluttering template out of this now but im struggling with trying to colour icon based on a set severity
          icon_color: |
            {% set icon_colour = states(entity) | int %}
            {% if icon_colour < 20 %}
              red
            {% elif icon_colour < 60 %}
              orange
              green
from here:
  bar_gauge:
    default:
      - entity: null
      - min: 0
      - max: 100
      - high: green
      - medium: orange
      - low: red
      - high_max: 100
      - high_min: 61
      - medium_max: 60
      - medium_min: 21
      - low_max: 20
      - low_min: 0
This does not work:
          icon_color: |
            {% if icon_colour < [[low_max]] %}
              red
            {% elif icon_colour < [[medium_max]] 60 %}
              orange
              green
Hey all, was wondering if someone could help me by adding in the styling to remove the boarders for the below please
type: vertical-stack
cards:
  - type: vertical-stack
    cards:
      - type: custom:stack-in-card
        cards:
            primary: Kitchen
            secondary: |-
              {{ states('sensor.average_kitchen_humidity') | round(0) }}% | {{
                    states('sensor.average_kitchen_temperature') | round(0) }}°C
            icon: mdi:pot-steam
            entity: light.area_kitchen_lights_group
            icon_color: '''{{ ''''white'''' if is_state(entity, ''''on'''') else ''''white'''' }}'''
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
            fill_container: true
            layout: vertical
            card_mod:
              style: |
                :host {
                  --mush-icon-size: 79px;
                  height: 150px;
                  --shape-color: rgba(var(--rgb-{{ 'orange' if is_state('light.area_kitchen_lights_group', 'on') else 'grey' }}), 0.3) !important;
      - square: false
        columns: 7
        type: grid
        cards:
            primary: ''
            secondary: ''
            icon: |-
              {% set state=states('light.kitchen_light_switch') %}
              {% if state=='on' %}
              hue:bulb-group-ceiling-round
              {% elif state=='off' %}
            entity: light.kitchen_light_switch
            icon_color: |-
              orange
              disabled
            layout: vertical
            primary: ''
            secondary: ''
            icon: |-
              {% set state=states('light.kitchen_pendant_light_switch') %}
              mdi:vanity-light
              mdi:vanity-light
            entity: light.kitchen_pendant_light_switch
            icon_color: |-
              orange
              disabled
            layout: vertical
            primary: ''
            secondary: ''
            icon: |-
              {% set state=states('light.kitchen_strip_light_switch') %}
              hue:lightstrip
              hue:lightstrip
            entity: light.kitchen_strip_light_switch
            icon_color: |-
              orange
              disabled
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            layout: vertical
            primary: ''
            secondary: ''
            icon: |-
              {% set state=states('cover.ducted_ac_kitchen_zone') %}
              {% if state=='open' %}
              mdi:air-conditioner
              {% elif state=='closed' %}
              mdi:air-conditioner
            entity: cover.ducted_ac_kitchen_zone
            icon_color: |-
              {% set state=states('climate.ducted_ac_controls_interface') %}
              {% if state=='off' %}
              disabled
              {% elif state=='cool' %}
              blue
              orange
              {% elif state=='fan_only' %}
              brown
              {% elif state=='dry' %}
              green
            layout: vertical
            primary: ''
            secondary: ''
            icon: >-
              {% set state=states('binary_sensor.kitchen_motion_sensor') %} {%
              if
              state=='on' %} mdi:motion-sensor {% elif state=='off' %}
              mdi:motion-sensor-off {% endif %}
            entity: binary_sensor.kitchen_motion_sensor
            icon_color: >-
              if
              state=='on' %} blue {% elif state=='off' %} disabled {% endif %}
            layout: vertical
            tap_action:
              action: more-info
            hold_action:
              action: more-info
            double_tap_action:
              action: more-info
            primary: ''
            secondary: ''
            icon: >-
              {% set state=states('binary_sensor.kitchen_sink_leak_sensor') %}
              {% if
              state=='on' %} mdi:pipe-leak {% elif state=='off' %} mdi:pipe-leak
              endif %}
            entity: binary_sensor.kitchen_sink_leak_sensor
            icon_color: >-
              if state=='on' %} orange  {% elif state=='off' %} disabled  {%
              elif
              state=='unavailable' %} red  {% endif %}
            layout: vertical
            primary: ''
            secondary: ''
            icon: |-
              {% set state=states('sensor.electrolux_fridge_appliance_state') %}
              {% if state=='False' %}
              mdi:fridge
              {% elif state=='True' %}
              mdi:fridge-alert
            entity: sensor.electrolux_fridge_appliance_state
            icon_color: |-
              green
              red
            layout: vertical
            tap_action:
              action: more-info
Solved like this:
          entity: '[[entity]]'
          icon: mdi:[[icon]]
          icon_color: |
            {% set colour = states(entity) | int %}
            {% if colour <= [[low_max]] %}
            [[low]]
            {% elif colour <= [[medium_max]] %}
            [[medium]]
            [[high]]
          card_mod:
            style: |
              ha-card {
                background: none;
          height: 42px
          min: '[[min]]'
          max: '[[max]]'
          entity_row: true
          severity:
            - color: rgb(var(--mush-rgb-[[high]]))
              to: '[[high_max]]'
            - color: rgb(var(--mush-rgb-[[medium]]))
              to: '[[medium_max]]'
            - color: rgb(var(--mush-rgb-[[low]]))
              to: '[[low_max]]'
Next question though… is there a variable that can auto set an icon based on the entity?
  - type: custom:decluttering-card
    template: bar_gauge
    variables:
      - entity: sensor.openweathermap_temperature
      - icon: cloud
      - min: -10
      - max: 45
      - low: indigo
      - medium: deep-orange
      - high: red
      - low_min: -10
      - low_max: 10
      - medium_min: 11
      - medium_max: 25
      - high_min: 26
      - high_max: 45
If i remove the icon here or remove it from the decluttering template then the icon just isnt there.
Can mushroom slider have number values? Anothwords, if I want to adjust my fan from low to medium or high. Can I drag the slider, and when it gets a third of the way it will be medium
And then 2/3 of the way it goes to high?
Or would I have to use separate up and down buttons?
I use an ESP to monitor my water softener salt - works like a charm. Project from here: Salt level sensor for water softener in Home Assistant with ESPHome – ADONNO
