Icon animation like the radiator.
“icon animation using clip-path”
Yes, you can do that like this:
Mushroom Chip clip-path animation:
type: custom:mushroom-chips-card
chips:
- type: template
icon: mdi:mushroom
icon_color: red
- type: template
icon: mdi:radiator
icon_color: orange
- type: template
icon: mdi:snail
icon_color: green
card_mod:
style:
mushroom-template-chip:nth-child(2)$: |
ha-icon {
animation: clip 1s linear infinite;
@keyframes clip {
0% {
clip-path: inset(50% 0 0 0);
100% {
clip-path: inset(0 0 0 0);
Did you find solution for that?
Great! Thanx alot!
You can change the colors used for the Mushroom Alarm Card/Chip by adding these values to you theme:
mush-rgb-red: 244, 67, 54
mush-rgb-green: 76, 175, 80
mush-rgb-yellow: 255, 235, 59
mush-rgb-state-alarm-disarmed: var(--mush-rgb-green)
mush-rgb-state-alarm-armed: var(--mush-rgb-red)
mush-rgb-state-alarm-triggered: var(--mush-rgb-yellow)
Or you can change it using CSS like this:
type: custom:mushroom-alarm-control-panel-card
entity: alarm_control_panel.downstairs
states:
- armed_home
- armed_away
card_mod:
style: |
:host {
--mush-rgb-state-alarm-disarmed: var(--rgb-green);
--mush-rgb-state-alarm-armed: var(--rgb-red);
--mush-rgb-state-alarm-triggered: var(--rgb-yellow);
Can you plz guide how can I have the same design with mushroom card. This screenshot is from room-card.
Kindly guide
Great, thank you! Works perfekt!!!
Any idea what I’m doing wrong yet with the slider?
Is it possible to get more information by the name or create something like this? now i did used the light card. Can i use an entity bij the name: field?
Hi Can you post the code snipet pls ? newbie here having trouble integrating picture element within the mushroom chip card. thanks again.
Ok sorry to keep bugging you with this, but I have the code working. The fan speed changes as I drag the slider up and down
However if I drag it all the way to 0, it kills it, the animation code won’t work anymore unless I redo the code . Any idea why?
Anddd I fixed it. In case anyone has the same
Issue….had to change input_number slider minimum value to 1 instead of 0. 0 broke the code you gave me.
Thanks for the help
Yes, you can add text to both the primary and secondary info text. This should work for any Mushroom Card and you can apply separate styling to the text.
Mushroom Card - Before primary text:
type: custom:mushroom-light-card
entity: light.office_light
layout: vertical
card_mod:
style:
mushroom-state-info$: |
.primary:before {
content: "({{ states('sensor.rhys_office_sensor_temperature') | round(1) }} °C / {{ states('sensor.rhys_office_sensor_humidity') | round(1) }} %) ";
color: rgb(var(--rgb-orange));
font-weight: 400;
Mushroom Card - After primary text:
layout: vertical
card_mod:
style:
.primary:after {
content: " ({{ states('sensor.rhys_office_sensor_temperature') | round(1) }} °C / {{ states('sensor.rhys_office_sensor_humidity') | round(1) }} %)";
color: rgb(var(--rgb-red));
font-weight: 400;
Mushroom Card - Before secondary text:
layout: vertical
card_mod:
style:
.secondary:before {
color: rgb(var(--rgb-blue));
font-weight: 400;
Mushroom Card - After secondary text:
layout: vertical
card_mod:
style:
.secondary:after {
color: rgb(var(--rgb-green));
font-weight: 400;
I think you will have to use roomcard for a feature to make this.
I have the same design and I’m also using room-card.
ok thank you for the reply
Mushrrom cards have the text below the icon, but you could try something like this:
type: custom:stack-in-card
mode: horizontal
cards:
- type: custom:mushroom-light-card
entity: light.lounge_light
layout: vertical
secondary_info: none
entity: light.lounge_cabinet_light
use_light_color: true
layout: vertical
entity: light.dining_room_light
layout: vertical
entity: light.kitchen_light
layout: vertical
entity: light.kitchen_bench_light
layout: vertical
thank you… I am using like this also. But I need to decrease the spacing between the cards. eg the Lounge, Cabinet, Dining, Kitchen, Bench entities and also decrease the height. Is that possible ???
Kindly guide
WOW, great, thanks a lot, i was also wondering, how or where i can find this information? trought the browser inspector?
.secondary:before {
content: "({{ s
And specialy the : mushroom-state-info$: |, .secondary:after {
What i did created yesterday is: (but this is the vertical-stack-in-card and the 2x mushroom-card)
The spacing will decrease as the width decreases. You can fix overall width and height like this:
mode: horizontal
cards:
layout: vertical
card_mod:
style: |
ha-card {
padding: 12px 0px !important;
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
layout: vertical
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
width: 300px;
height: 96px;
