Its a work in progress, but this is a portion. Repeat the mushroom template-card to add the second entity to the row.
type: custom:vertical-stack-in-card
cards:
- type: custom:mushroom-title-card
title: Outdoor Lights
style: |
ha-card
{ --title-padding: 12px 12px 4px;
--title-font-size: 16px;
--primary-text-color: ;
--title-font-weight: 100;
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 1fr 1fr
margin: '-10px -4px -15px 0px'
cards:
primary: Patio Lightstrip
secondary: |
{% if is_state('light.patio_lightstrip', 'on') %} On
Off
icon: hue:lightstrip
icon_color: |
{%- if is_state(entity, 'on') %}
{{ '#%02x%02x%02x' % state_attr(entity, 'rgb_color') }}
{%- else %}
entity: light.patio_lightstrip
tap_action:
action: toggle
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-color: none;
ha-card {
background: none;
box-shadow: none;
--ha-card-border-width: 0;
--icon-symbol-size: 36px;
primary: Pond Lights
secondary: |
{%- if is_state(entity, 'on') %} On
Off
icon: hue:floor-spot-group
icon_color: |
{% if is_state('light.pond', 'on') %} yellow
entity: light.pond
tap_action:
action: toggle
card_mod:
style:
.shape {
ha-card {
background: none;
box-shadow: none;
--icon-symbol-size: 38px;
layout:
margin: 0px -4px -14px 0px
cards:
primary: Circle Lights
secondary: |
Off
icon: hue:floor-lantern
icon_color: |
black
{%- else %}
entity: light.circle_lamppost
tap_action:
action: more-info
card_mod:
style:
.shape {
filter: drop-shadow(rgb{{ state_attr(config.entity, "rgb_color")}} 0px 10px 10px);' if states(config.entity) =="on"}}
{% if is_state(config.entity, 'on') %}
ha-state-icon:before {
content: "";
width: 0px;
height:10px;
background: {{"#%02x%02x%02x" % state_attr(config.entity, "rgb_color") }};
border-width: 0px;
border-left: 5px solid transparent;
border-right: 5px solid transparent;
margin-top: 5px;
margin-left: 14px;
position: absolute;
ha-card {
background: none;
box-shadow: none;
--icon-symbol-size: 40px;
entity: light.deatched_lamp_post
icon_color: |
black
{%- else %}
primary: Detached Lamp Post
secondary: |
Off
action: more-info
card_mod:
style:
.shape {
content: "";
width: 0px;
height:10px;
border-width: 0px;
margin-top: 5px;
margin-left: 14px;
position: absolute;
ha-card {
background: none;
box-shadow: none;
layout:
cards:
entity: light.garage_color_spot
icon: hue:wall-flood
tap_action:
action: more-info
icon_color: |
black
{%- else %}
primary: Garage Color Spot
secondary: |
Off
card_mod:
style:
.shape {
filter: drop-shadow(rgb{{ state_attr(config.entity, "rgb_color")}} 0px 7px 8px);' if states(config.entity) =="on"}}
{% if is_state('light.garage_color_spot', 'on') %}
content: "";
width: 27px;
height:20px;
transform: rotate(13deg) skew(-10deg);
border-radius: 0px;
border-width: 0px;
margin-top: 13.5px;
margin-left: 10.5px;
position: absolute;
ha-card {
background: none;
--ha-card-border-width: 0px;
--icon-symbol-size: 45px;
icon_color: |
black
{%- else %}
primary: Garage Lantern
secondary: |
Off
icon: phu:wall-econic-lantern-top
entity: light.garage_latern
tap_action:
action: toggle
card_mod:
style:
.shape {
filter: drop-shadow(rgb{{ state_attr(config.entity, "rgb_color")}} 0px 6px 10px);' if states(config.entity) =="on"}}
content: "";
width: 15px;
height:18px;
border-width: 0px;
border-left: -5px solid transparent;
border-right: 2px solid transparent;
margin-top: 15px;
margin-left: 13px;
position: absolute;
ha-card {
background: none;
box-shadow: none;
card_mod:
style: |
ha-card {
box-shadow: none;
padding-bottom: 14px;
background-color: rgba(var(--mush-rgb-grey), .1);
Fix this bit to:
primary: JanelaBanca
secondary: '{{ states("binary_sensor.contact_sensor")}}'
icon: mdi:window-closed-variant
entity: binary_sensor.contact_sensor_2
card_mod:
style:
.shape {
--icon-color: red!important;
--shape-color: #FBD7D4!important;
ha-card {
width: 110px;
border-style: none;
background-color: #E2E2E2!important;
Cant have 2 instances of style: under card mod. Use .: |
instead. Take note of the indentation. And for further explanation look at the guide in my profile at the section called:
Please post your code formatted, not a screenshot for people.
sorry…new to this and still learning
Fairly common problem with lots of stacks.
Just remove it manually with more card mod.
cards:
- type: horizontal-stack
cards:
- type: custom:vertical-stack-in-card
cards:
primary: Küche
icon: mdi:countertop
tap_action:
action: navigate
navigation_path: mobile_küche
hold_action:
action: toggle
icon_color: ''
fill_container: true
layout: horizontal
multiline_secondary: false
card_mod:
style: |
ha-card {
border: none !important;
chips:
- type: conditional
conditions:
- entity: binary_sensor.fenstersensor_kuche_unten_iaszone
state: 'on'
chip:
type: template
icon: mdi:window-open-variant
content: DF Unten
alignment: end
style: |
ha-card {
--chip-border-width: 2px;
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: none;
--chip-height: 40px;
margin-top: 15px;
margin-right: 5px;
cards:
alignment: end
style: |
ha-card {
--chip-border-width: 0px;
margin-top: 0px;
margin-right: 0px;
chips:
- type: template
content: Licht
icon: mdi:lightbulb
entity: light.lichtschalter_kuche
icon_color: |-
{% if is_state('light.lichtschalter_kuche', 'on') %}
yellow
disabled
tap_action:
action: toggle
hold_action:
action: navigate
This section is what does it:
cards:
primary: Küche
tap_action:
action: navigate
hold_action:
action: toggle
icon_color: ''
layout: horizontal
card_mod:
style: |
ha-card {
But is there any reason for you to have that vertical stack in card there? There is only the 1 card in it.
Should be able to simplify to this:
cards:
cards:
primary: Küche
tap_action:
action: navigate
hold_action:
action: toggle
icon_color: ''
layout: horizontal
chips:
- type: conditional
conditions:
state: 'on'
chip:
type: template
content: DF Unten
alignment: end
style: |
ha-card {
margin-top: 15px;
margin-right: 5px;
cards:
alignment: end
style: |
ha-card {
margin-top: 0px;
margin-right: 0px;
chips:
- type: template
content: Licht
icon: mdi:lightbulb
icon_color: |-
yellow
disabled
tap_action:
action: toggle
hold_action:
action: navigate
Take a look at this post, and for formatting specifically section 11
Before we begin…
This forum is not a helpdesk
The people here don’t work for Home Assistant, that’s an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isn’t a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We can’t help you with e…
Still not entirely sure what you want sorry? You just want the input number at the bottom (to represent your fan modes from 1 - 5) but what do you want at the top that a template card doesnt provide?
wu5
December 13, 2023, 8:42am
9138
I have found that I can get a visual of the current colour effects from WLED by going to http://192.168.1.x/liveview
It’s not an image, but a sort of html page and can be shown with an iframe card.
Code
cards:
cards:
primary: Room
secondary: |-
{{ states('sensor.ble_room_temperature') | round (0, default = 0) }}°C
• {{ states('sensor.ble_room_humidity') | round (0, default = 0) }}%
icon: mdi:sofa
entity: light.wled
icon_color: null
tap_action:
action: toggle
card_mod:
style: |
ha-card {
background: transparent;
border-style: none;
background :rgba(var(--rgb-primary-text-color), 0.03);
:host {
--mush-icon-size: 60px;
- type: iframe
url: http://192.168.1.96/liveview
aspect_ratio: 10%
title: null
- type: custom:mushroom-light-card
entity: light.wled
primary_info: none
secondary_info: none
icon_type: none
show_brightness_control: true
How can I make it appear in the background of the slider or in the mushroom-template-card? Perhaps it will look interesting =)
brewston
(Tim Jones)
December 13, 2023, 8:55am
9139
brilliant! that works. I hide the media players behind a conditional when they are not playing, so don’t see the primary/secondary at that point, thanks for explaining though
Mattia2399
(Mattia2399)
December 13, 2023, 9:01am
9140
Exactly, I would only need the bottom part of input_number.
The template card is fine like this.
Hello
Thanks of a lot …i will see the post
1umnyy
(Viktor)
December 13, 2023, 9:23am
9142
@dimitri.landerloos
Can you please help me with this code? he doesn’t immediately remove the borders, only when I refresh the page
type: custom:mod-card
style:
stack-in-card$:
hui-horizontal-stack-card$: |
mushroom-template-card:nth-of-type(1) {
width: 40%;
flex: unset !important;
card:
type: custom:stack-in-card
mode: horizontal
cards:
entity: light.girlianda2
primary: Гирлянда
card_mod:
style: |
ha-card:active {
box-shadow: 0 0 20px rgba(var(--rgb-disabled), 0.8);
transition: 0s;
tap_action:
action: toggle
icon: mdi:lightbulb-multiple
layout: horizontal
icon_color: |
{{ iif(is_state(entity, "on"), "green", "grey") }}
primary: Стол
secondary: ''
icon: mdi:desk
icon_color: |
layout: horizontal
entity: light.kojima_sr_wi_fi_eu_switch_1
tap_action:
action: toggle
card_mod:
style: |
ha-card:active {
transition: 0s;
entity: light.yandexrozetka_socket_1
primary: Окно
secondary: ''
icon_color: |
layout: horizontal
tap_action:
action: toggle
card_mod:
style: |
ha-card:active {
transition: 0s;
So i dont see how my original response doesnt cover this usecase.
dimitri.landerloos:
Combine 2 cards + some card mod:
Code
cards:
icon: mdi:test-tube
primary: TEST
secondary: '{{state_attr(''climate.office_heating'', ''current_temperature'')}}'
card_mod:
style: |
ha-card {
box-shadow: none !important;
padding-bottom: 0px !important;
- type: custom:mushroom-number-card
entity: input_number.dishwasher_pod_add
display_mode: buttons
card_mod:
style: |
mushroom-state-item {
display: none;
ha-card {
Now the top bit is fully templatable, like a normal mushroom template card (because it is).
If you need something else you will need to show me with editing a picture or something, cause i am failing to understand what it is that you want.
Mattia2399
(Mattia2399)
December 13, 2023, 11:38am
9144
Sorry Dimitri, we actually don’t understand each other.
I’m trying to recreate this card:
So, with your help I created the card on the left because the climate.stufa entity automatically supports the input_number.
Now on the right, I would like to recreate the same card but to set the fan modes.
However I don’t have an input_number entity for the fan, but it is part of the attributes of the climate.stufa entity.
It should be more or less like this:
Oh i see, so you basically need fake buttons that arent assigned to an entity but for example called a script that changes the climate fan mode between 1-5.
Am i correct?
You could also create an input_number helper for the climate fan mode and then have an automation that checks if the input_number was changed and set the fan mode appropriately.
Then you could just use the card i provided already.
Mattia2399
(Mattia2399)
December 13, 2023, 11:56am
9146
Okay, I thought about this solution.
But could you tell me how to update the input_number value even when it is changed directly from the stove control panel?
So you would have an automation that checks if either the input_number was changed or the climate fan mode was changed.
If input_number is changed then set climate fan mode to number of input_number.
If climate fan mode was changed set input number to number of climate fan mode.
You could make this 2 seperate automations or edit the trigger id for each change and then only execute the appropriate bit depending on what was triggered.
Hard to show you an example because i dont have an entity with the same mode as yours.
Something like this might get you closer:
description: ""
- platform: state
entity_id:
- input_number.fan_mode_helper
- platform: state
entity_id:
- climate.bedroom_heating
condition: []
- if:
- condition: trigger
id:
- HELPER
then:
- service: climate.set_fan_mode
entity_id: climate.bedroom_heating
fan_mode: "{{states('input_number.fan_mode_helper') | int }}"
- if:
id:
- MANUAL
then:
entity_id: input_number.fan_mode_helper
value: "{{state_attr('climate.bedroom_heating', 'fan_mode') | int}}"
You will likely need to change the trigger for the state of the climate entity to something more specific so it doesnt trigger all the time when anything changes on the climate entity. But since mine doesnt have a fan mode i cant really help there.
Dont think it is possible because its the background of a different element. but you could cheat and layer them together in a stack-in-card like this maybe:
cards:
primary: Room
secondary: |-
icon: mdi:sofa
entity: light.wled
icon_color: null
tap_action:
action: toggle
card_mod:
style: |
ha-card {
border-style: none;
background: rgba(var(--rgb-primary-text-color), 0.03);
:host {
- type: iframe
url: http://192.168.68.221/liveview
aspect_ratio: 10%
title: null
card_mod:
style: |
ha-card {
position: absolute;
z-index: 1;
border-radius: 11.5px !important;
width: calc(100% - 26px) !important;
left: 13px;
bottom: 11.2px;
#root {
height: 5px;
entity: light.office_desk_light
primary_info: none
icon_type: none
card_mod:
style: |
mushroom-light-brightness-control {
z-index: 2;
--slider-bg-color: transparent !important;
card_mod:
style: |
ha-card {
isolation: isolate;
This looks really cool - but unfortunately it seems this doesnt work when accessing HA via HTTPS… unfortunate as i would definitely use this then!
@Still_ill sorry for the tag, but you might like this for your control card if you can implement it
WLED control card
In this community post, I introduce a comprehensive Home Assistant configuration that enhances my lighting control and makes my WLED lighting more efficient. I will explain the code and the functions of each card step by step.
[image]
I also use the WLED Strip in this example as an Ambielight for my TV via Hyperion.ng. When I operate it in normal mode, I would like to have 2 different colours displayed, as it is aesthetically more appealing. Therefore it is divided i…
Not sure if this helps but I combined attributes to create a sensor that was based off the direction and speed. That helped pair down the if then results.
sensors:
fan_direction:
friendly_name: "Fan Direction"
unique_id: fan1
value_template: "{{ state_attr('fan.bedroom_fan', 'direction') }}"
fan_direction_speed:
friendly_name: "Fan Direction Speed"
unique_id: fan2
value_template: |
{% set direction = state_attr('fan.bedroom_fan', 'direction') %}
{% set speed = state_attr('fan.bedroom_fan', 'percentage') %}
{{[direction,speed]|join("")}}
Snellingen
(Matias Snellingen)
December 13, 2023, 1:24pm
9150
mushroom-slider support min max properties so this should be possible to add. Don’t have any workaround we can do right now and have to wait for the feature to be added. I need this feature as well so might create a PR to add this when I get the time.
Edit: actually, there’s already a pending PR that add this exact feature:
piitaya:main
← wilco375:bugfix/light-brightness
opened 03:40PM - 12 Nov 22 UTC
## Description
This PR updates the light brightness slider such that it goes do… wn to 1% instead of 0%. See related issue for reasoning.
## Related Issue
This PR fixes or closes issue: fixes #847
## Motivation and Context
Allows setting a light to its lowest brightness without turning it off
## How Has This Been Tested
New code has been compiled and added to HA as described in the README under _Manual_
## Types of changes
- [ ] 🐛 Bug fix (non-breaking change which fixes an issue)
- [ ] 🚀 New feature (non-breaking change which adds functionality)
- [ ] 🌎 Translation (addition or update a translation)
- [x] ⚠️ Breaking change (fix or feature that would cause existing functionality to change)
## Checklist
- [x] My code follows the code style of this project.
- [ ] My change requires a change to the documentation.
- [ ] I have updated the documentation accordingly.
- [x] I have tested the change locally.
- [ ] I followed [the steps](https://github.com/piitaya/lovelace-mushroom#maintainer-steps-to-add-a-new-language
) if I add a new language .
