pLeX
July 22, 2022, 3:24pm
2003
Hi rhysb,
im little bit struggling with your code. Im trying to use your code and just changed the entities, but im always getting this result:
Do you have an idea whats wrong here?
type: custom:stack-in-card
cards:
- type: custom:apexcharts-card
chart_type: radialBar
series:
- entity: sensor.docker_cpu
color: rgb(255, 87, 34)
max: 90
show:
legend_value: false
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: -108
endAngle: 108
hollow:
dataLabels:
name:
show: false
value:
show: false
track:
strokeWidth: 80%
margin: 0
fill:
type: gradient
gradient:
shade: light
type: horizontal
shadeIntensity: 0.3
inverseColors: false
opacityFrom: 1
opacityTo: 1
stops:
- 0
- 50
- 55
- 90
legend:
show: false
chart:
height: 240
- type: custom:mushroom-entity-card
primary_info: state
secondary_info: name
icon_color: deep-orange
layout: vertical
card_mod:
style: |
ha-card {
margin-top: -90px;
width: 140px;
margin-left: auto;
margin-right: auto;
berkans
(Berkan Sezer)
July 22, 2022, 3:38pm
2004
That works like a charm. Thank you very much.
I have a last question and I think that question could also interest others as well.
Can we change the color of the chip picture depending on the state ?
For example an air condition. I have a white picture of an air condition.
So can the color of this picture change depending on whether its on “cool” state or other. I would like it to be red when it’s on heat mode and blue when on cool.
- type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: input_boolean.ana_sayfa_menu
state: 'off'
chip:
type: template
entity: climate.146235046506144_climate
icon: mdi:home-thermometer
tap_action:
action: more-info
icon_color: |-
{% set state=states(entity) %}
{% if state=='cool' %}
blue
{% elif state=='heat' %}
red
{% else %}
grey
{% endif %}
card_mod:
style: |
ha-card {
--chip-icon-size: 22px;
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0px;
--chip-padding: 15px;
margin-left: 15px;
margin-bottom: -auto;
width: 400px;
alignment: start
I know I can easily change it with using conditional card but I guess card mode will be a shorter way.
berkans
(Berkan Sezer)
July 22, 2022, 3:47pm
2005
Nice one. I was achieving the same purpose with use conditional cards but I can also use this one too.
rolfokevin
(Kevin Rolfo)
July 22, 2022, 4:26pm
2006
you probably need to adjust the max value, to the max of whatever youre trying to graph. So for disk space, youd put your total amount of space avaliable. and for cpu temp, set it to the highest it could get, depending on if its F or C
pLeX
July 22, 2022, 5:38pm
2007
Hi Kevin,
im sorry… I mean not the values. This was just a quick test and I know ive to changes the values. My question was about the visualization. I dont understand why the entity part CPU temp is not inside of the apex circle like the pictures from rhysb post.
rolfokevin
(Kevin Rolfo)
July 22, 2022, 6:06pm
2008
idk man maybe I’m still misunderstanding, but the code you provided, has the same MAX value as his does… Id image you both have entirely different hardware. Right under your sensor.docker_cpu theirs a MAX: value of 90. So the radial bar is showing you 2.71% out of 90… im pretty sure its working correct. You need to change that MAX value to whatever yours is, id image its different. Again if im misunderstanding you im sorry!
rolfokevin
(Kevin Rolfo)
July 22, 2022, 6:09pm
2011
nevermind, lol I think I got what you meant. The icon inside the radial bar? That im not sure of tbh
pLeX
July 22, 2022, 6:12pm
2012
Yes! I mean the position of the icon:
rolfokevin
(Kevin Rolfo)
July 22, 2022, 6:19pm
2013
Just checked mine, heres my code. Mine looks exactly like his does.
cards:
series:
- entity: sensor.glances_acpitz_1_temperature
max: 130
show:
legend_value: false
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: -108
endAngle: 108
hollow:
dataLabels:
name:
show: false
value:
show: false
track:
strokeWidth: 80%
margin: 0
fill:
type: gradient
gradient:
shade: light
type: horizontal
shadeIntensity: 0.3
opacityFrom: 1
opacityTo: 1
stops:
- 0
- 50
- 55
- 90
legend:
show: false
chart:
height: 240
entity: sensor.glances_core_0_temperature
primary_info: state
layout: vertical
card_mod:
style: |
ha-card {
margin-top: -90px;
width: 140px;
margin-left: auto;
margin-right: auto;
pLeX
July 22, 2022, 6:33pm
2014
same result
my code:
cards:
series:
max: 130
show:
legend_value: false
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: -108
endAngle: 108
hollow:
dataLabels:
name:
show: false
value:
show: false
track:
strokeWidth: 80%
margin: 0
fill:
type: gradient
gradient:
shade: light
type: horizontal
shadeIntensity: 0.3
opacityFrom: 1
opacityTo: 1
stops:
- 0
- 50
- 55
- 90
legend:
show: false
chart:
height: 240
primary_info: state
layout: vertical
card_mod:
style: |
ha-card {
margin-top: -90px;
width: 140px;
margin-left: auto;
margin-right: auto;
I dont understand it…
Step
July 22, 2022, 6:34pm
2015
Did you install all the possible mods for this? Like card-mod, I think you are missing stack-in-card mod.
pLeX
July 22, 2022, 6:39pm
2016
ah… I think Im missing the card-mod addon. thanks!
… sorry but there are so many posts here. I just found the mushroom stuff a few days ago. Really hard to find all informations.
Step
July 22, 2022, 6:50pm
2017
Encountered the same thing a while ago. Would be nice to have a summary of needed mods and code for specific instances. You are welcome!
GuySie
(Guy Sie)
July 22, 2022, 10:33pm
2018
I’m looking into converting my Lovelace UI Minimalist setup into Mushroom, as it turns out to be much harder to keep a YAML-based dashboard up to date than I thought when I built it. For most stuff, this should be no problem at all, but the one big thing I’m missing is an equivalent for UI Minimalist’s Room Card (card_room), which the front page of my dashboard is based on (it lists all rooms with a room card, and each card clicks through to a room-specific view).
https://ui-lovelace-minimalist.github.io/UI/usage/cards/card_room/
Did anyone else take the same route from UI Minimalist to Mushroom and have a good alternative for this card?
rolfokevin
(Kevin Rolfo)
July 22, 2022, 10:59pm
2019
I highly recommend @rhysb work with his room card. Its been great for my use case.
Here is an update of my room card.
Light:
[Room Card Light]
Dark:
[Room Card Dark]
Example rooms.
Bedroom:
cards:
primary: Master
secondary: '{{ states(''sensor.master_bedroom_sensor_temperature'') | round(0) }} °C'
icon: mdi:bed-double
entity: group.master_bedroom_lights
tap_action:
action: navigate
navigation_path: master_bedroom
hold_action:
action: toggle
icon_color: '{{ …
rhysb
(Rhys)
July 23, 2022, 12:03am
2020
This should do what you need. It offsets the hue of the color elements in degrees:
Cool:
Heat:
chips:
- type: template
entity: climate.office_air_conditioner
picture: /local/aircon.png
content: '{{ state_attr(entity, ''friendly_name'') }}'
card_mod:
style: |
ha-card {
{{ 'filter: hue-rotate(140deg);' if is_state('climate.office_air_conditioner', 'heat') }}
rhysb
(Rhys)
July 23, 2022, 12:16am
2021
Glad you finally got this sorted. I have updated the original post to list the cards required.
rhysb
(Rhys)
July 23, 2022, 12:28am
2022
This is what I am seeing.
home:
not_home:
type: custom:mushroom-person-card
entity: person.rhys
primary_info: none
secondary_info: none
use_entity_picture: true
card_mod:
style: |
mushroom-shape-avatar {
{{ 'filter: grayscale(100%);' if is_state('person.rhys', 'not_home') }}
Step
July 23, 2022, 8:13am
2024
Thanks for sharing Rhys! So I used your code with my person, this doesn’t work on Safari (on Mac and iOS) but it does work in Firefox.
So I’ve narrowed it down to the culprit being CSS in Safari.
Currently messing around with
-webkit-transform: translateZ(0);
-webkit-perspective: 1000;
-webkit-backface-visibility: hidden;
Not sure if this syntax is correct, it doesn’t work yet:
{{ '-webkit-transform: translateZ(0);-webkit-perspective: 1000;-webkit-backface-visibility: hidden;-webkit-filter: grayscale(100%);filter: grayscale(100%);' if is_state('person.step', 'not_home') }} }
