Mushroom Cards Card Mod Styling/Config Guide
Dear Dimitri,
thanks for your feedback. This works, but I want additonally change other attributes of the chip, like setting the border to 0. When I’m adding e.g. border: 0px; this does not work. I there an easy way to set border: 0px; and max-width: 80px; min-width: 80px; to all chips?
Best regards and happy new year
Yes! Very easy :slight_smile:
card_mod:
  style: |
    mushroom-template-chip,
    mushroom-conditional-chip,
    mushroom-entity-chip,
    mushroom-weather-chip,
    mushroom-light-chip,
    mushroom-menu-chip,
    mushroom-spacer-chip {
      max-width: 80px;
      min-width: 80px;
    ha-card {
      --chip-border-width: 0px !important;
Can also do it like this:
card_mod:
  style: |
    mushroom-menu-chip,
      max-width: 80px;
      min-width: 80px;
Thank you a lot. Now there is (I hope) only one puzzle piece missing, which I could not solve until now. Is it now also possible to center the icon in the chips?
grafik
I could not find the correct css command.
Enclose my current code (border in the screenhsot above is only temporaly set to 1px to show better the position of the icon):
card_mod:
      style: |
        mushroom-menu-chip,
          max-width: 3em;
          min-width: 3em;
          --chip-background: none;
          --chip-font-size: 0.6em;
          --chip-height: 1.25em;
          --chip-icon-size: 0.9em;
        ha-card {
          padding-top: 0px !important;
          padding-right: 10px !important;
          padding-left: 15px;
hello already and a big thank you to you Dimitri for your explanations which allowed me to modify my mushroom cards, on the other hand I have a problem with the mushroom-shape-icon it only changes the background when the lights are on or that my entities are activated, how can I remedy this? all my cards are configured the same
type: custom:mushroom-light-card
entity: light.la_salle_a_manger
use_light_color: true
show_color_temp_control: true
collapsible_controls: false
show_brightness_control: true
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        --shape-color: transparent !important;
      @keyframes blink {
      0% {opacity: 1}
      50% {opacity: 0.2}
      100% {opacity: 1}
      ha-card {
       --ha-card-background: transparent;
       border-color: transparent;
      mushroom-button{
      background-color: transparent;
      --bg-color: transparent;
      ha-state-icon {
      {% if is_state('light.la_salle_a_manger', 'on') %}
        animation: blink 1s linear infinite;
        filter: drop-shadow(#ffffff 0rem 0rem 6px);
      {% else %}
      {% endif %}
Hey, I’m searching for few hours now, but can’t find any option to show only the icon of a chips light card. I don’t need any text, because the color indicats the state. How can I do it?
type: custom:stack-in-card
mode: vertical
cards:
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: custom:mushroom-entity-card
        entity: sensor.temperatur_nicole_taster
        hide_icon: true
        tap_action:
          action: navigate
          navigation_path: nicole
      - type: custom:mushroom-chips-card
        chips:
          - type: light
            entity: light.nicole_spots
            use_light_color: false
        alignment: end }
    style: |
      ha-card {
        background-color: rgba(0,0,0,0);
        box-shadow: none;
  - type: custom:mini-graph-card
Hi, just use background: transparent !important; instead. This will then apply regardless of entity state.
card_mod:
  style:
      .shape {
      @keyframes blink {
        0% {opacity: 1}
        50% {opacity: 0.2}
        100% {opacity: 1}
      ha-card {
      mushroom-button{
      ha-state-icon {
        {% else %}
        {% endif %}
It was mentioned here, but i need to get some time and mention it in the guide itself:
A few ways to do that, but the simplest would just be to use a template chip instead:
mode: vertical
cards:
    mode: horizontal
    cards:
        hide_icon: true
        tap_action:
          action: navigate
        chips:
          - type: template
            entity: light.lounge_main_light
            icon: mdi:lightbulb
            icon_color: |-
              {% if states(config.entity) == 'on' %}
                amber
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: toggle
        alignment: end }
    style: |
      ha-card {
        box-shadow: none;
thank you, super responsive, I read everything but this little detail had to get through :wink: :+1:
Thank you a lot! It works. I added twi chips and want to remove the spacing but padding-right or padding doesn’t work. I also use it with !important but nothing. Any idea? I want the icons in one row:
If the card is widther you see the spacing
May I ask you, how you show on the “Bad” card the additional information like 18,1 and 17,0 and 19,0?
try like this:
mode: vertical
cards:
    mode: horizontal
    cards:
        entity: sensor.lounge_downstairs_temperature
        hide_icon: true
        tap_action:
          action: navigate
        chips:
          - type: template
            icon: mdi:lightbulb
            icon_color: |-
                amber
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: toggle
          - type: template
            icon: mdi:lightbulb
            icon_color: |-
                amber
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: toggle
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0px;
    style: |
      ha-card {
        box-shadow: none;
    entities:
      - entity: sensor.lounge_downstairs_temperature
the --chip-spacing: 0px; is the important bit. you can also set this to a negative number to get them even closer.
its a climate card and chips together like this:
cards:
  - type: custom:mushroom-climate-card
    entity: climate.office_heating
    show_temperature_control: true
    chips:
      - type: template
        icon: mdi:test-tube
        icon_color: deep-orange
        content: |-
          {{state_attr('climate.office_heating','current_temperature')}}
    alignment: end
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 12px;
          right: 12px;
No, this is not working. I also tried .chip-container, but nothing happens.
Here is my full code @RkcCorian
mode: vertical
cards:
    mode: horizontal
    cards:
        entity: sensor.temperatur_flur
        hide_icon: true
        tap_action:
          action: navigate
          navigation_path: flur-og
        chips:
          - type: template
            entity: binary_sensor.prasenz_flur_og
            icon: mdi:human-male
            icon_color: |-
                green
              {% else %}
                disabled
              {% endif %}
          - type: template
            entity: light.flur
            icon: mdi:lightbulb
            icon_color: |-
                amber
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: toggle
        alignment: end
        card_mod:
          style: |
            .chip-container {
    hours_to_show: 24
    graph: line
    entities:
      - sensor.temperatur_flur
    show:
      state: false
      icon: false
    color_thresholds:
      - value: 0
        color: '#800080'
      - value: 10
        color: '#0000FF'
      - value: 21
        color: '#008000'
      - value: 23
        color: '#FFFF00'
      - value: 24
        color: '#FF6600'
      - value: 25
        color: '#FF0000'
      - value: 26
        color: '#FF69B4'
    points_per_hour: 1
it does. like i said if you use a negative value the chips will get even closer. even overlap. you ust dont have a lot of space left on a mobile dashboard.
mode: vertical
cards:
    mode: horizontal
    cards:
        hide_icon: true
        tap_action:
          action: navigate
        chips:
          - type: template
            icon_color: |-
                green
              {% else %}
                disabled
              {% endif %}
          - type: template
            entity: light.flur
            icon: mdi:lightbulb
            icon_color: |-
                amber
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: toggle
        alignment: end
        card_mod:
          style: |
            .chip-container {
              --chip-spacing: -10px;
    hours_to_show: 24
    graph: line
    entities:
    show:
      state: false
      icon: false
    color_thresholds:
      - value: 0
        color: '#800080'
      - value: 10
        color: '#0000FF'
      - value: 21
        color: '#008000'
      - value: 23
        color: '#FFFF00'
      - value: 24
        color: '#FF6600'
      - value: 25
        color: '#FF0000'
      - value: 26
        color: '#FF69B4'
    points_per_hour: 1
very confusing… I copied your code into a new view and it is not working…
I also set the value to -20 and more
I also checked hacs and I using v3.2.2. Any idea, where the problem could be?
Maybe try a !important; after
--chip-spacing: -20px; like this:
--chip-spacing: -20px !important;
Unsure why it would change anything, but worthb a shot.
Many thanks! Unfortunately the custom Stack-In-Card is not working and is not maintained since 2020, if I’m right. :grimacing:
Compare also Card is nor working after install (HACS) · Issue #45 · custom-cards/stack-in-card (github.com)
Works fine if you have it installed. If you are concerned you can use the vertical-stack-in-card instead in mode: horizontal like this:
type: custom:vertical-stack-in-card
mode: horizontal
cards:
    chips:
      - type: template
        icon: mdi:test-tube
        content: |-
    alignment: end
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 12px;
          right: 12px;
I try but this is also not working. I might be stupid in installation. I download via HACS and add it to my configuration.yaml like. You might have a hint for me?
frontend:
  themes: !include_dir_merge_named themes
  extra_module_url:
    - /config/www/community/lovelace-card-mod/card-mod.js
    - /config/www/community/vertical-stack-in-card/vertical-stack-in-card.js
If you have HACS and use HAOS you should not need to do anything after downloading, you only need to refresh the page.
