Mushroom Cards Card Mod Styling/Config Guide
This topic is technically a cross post from a reply to the Mushroom Card Topic found here: Part 1.
But it was suggested in a comment to post it here as a guide instead.
Below info is true as of Mushroom Version 4.4.0 and Card Mod Version 3.4.4
(you can also optionally use a theme like i do. i use Minimalist Version 1.3.18).
links to each post:
Alarm Control Panel Card
Chips Card
Climate Card
Cover Card
Entity Card
Fan Card
Humidifier Card
Number Card
Lock Card
Light Card
Media Card
Person Card
Select Card
Template Card
Title Card
Update Card
Vacuum Card
More Information:
What the $ and .: | symbols do
$ is used when we want to access the shadow-root of an object. like this here:
the .shape is within the shadow-root of mushroom-shape-icon so to access it and modify it, we would write this:
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: red !important;
you cant just write this, as this wont access the element through the shadow root.
card_mod:
  style: |
    .shape {
the | is just written to denote that you are done with going through elements and that you will now list your final element. so if i have stacked with multiple shadow-roots. it would look like this:
card_mod:
  style:
    mushroom-light-brightness-control$:
      mushroom-slider$:
        .container:
          .slider: |
            .slider-track-active {
              background-color: red !important;
Notice how the last 2 in the stack dont have a $? thats because those elements dont have a shadow-root. and i am technically not required to write the .container: or the .slider: |at all. this works just fine too.
card_mod:
  style:
      mushroom-slider$: |
card mod has a built in fuction to let you reset yourself back to style: | which is what you need for when your initial element is not in a shadow root at all.
it is using .: if you use it at the right indentation (same line as anything you first place under style:)
so like this:
card_mod:
  style:
      .shape {
        background: blue !important;
      ha-card {
        background: red;
note where the .: starts is the exact same place as where you initial mushroom-shape-icon$: | starts. basically treat writing .: | as writting a whole new style: | again.
Colors
Anytime that color is being referred to you tend to have a few options on how to give a color.
Named color.
card_mod:
  style: |
    ha-state-icon {
      color: red;
Hex color.
card_mod:
  style: |
    ha-state-icon {
      color: #fcba03;
Hex color with an alpha channel to give opacity. (not supported for some browsers, namely internet explorer.)
card_mod:
  style: |
    ha-state-icon {
      color: #fcba0380;
RGB color.
card_mod:
  style: |
    ha-state-icon {
      color: rgb(10, 200, 250)
RGBA color has an alpha channel to give opacity .
card_mod:
  style: |
    ha-state-icon {
      color: rgba(200, 10, 250, 0.4 )
there may be more options for colors like hsl hsla that work. but these are the main ones :slight_smile:
You can also use gradients like this. (however it seems to only work for backgrounds. i have also removed the border of the card as the color seems to spill onto it.) linear gradient options here.
card_mod:
  style: |
    ha-card {
      background: linear-gradient(to bottom right, rgba(0, 150, 4, 1) 30%, rgba(3, 74, 255, 1) 100%);
      border: none;
You can also set an entity image instead like this. courtesy of @rhysb. (again ive removed the border as it seems to have some color spill.)
card_mod:
  style: |
    ha-card {
      background-image: url( '{{ state_attr( "media_player.dimitris_pc", "entity_picture" ) }}' );
      background-blend-mode: overlay;
      border: none;
Templating inside card mod
if you have if statements or any other templating i find following the below principles works best.
card mod is very forgiving however.
if statements. i find it best to follow the below structure with if statements. it is just the easiest to read (at least in my opinion.)
put any variable that isnt chaging depending on the if statement at the top. then have your if statement and indent you variable one in after the if statements to show the blocks properly.
card_mod:
  style: |
    ha-card {
      border: white 1px dashed;
      {% if states('media_player.dimitris_pc') == 'playing' %}
        background: blue;
      {% else %}
        background: grey;
      {% endif %}
i wouldnt recommend doing this for example despite the fact that card mod will allow it and it works the same. it just makes the config hard to read.
card_mod:
  style: |
      ha-card {
        background: blue;
    {% else %}
      ha-card {
        background: grey;
    {% endif %}
You can add comments to you code like this:
just wrap your comment in /* comment */
card_mod:
  style: |
    ha-card {
      /* Sets a white border */
      /* checks if the media player is playing */
        /* if media player is playing sets background blue */
        background: blue;
      {% else %}
        /* if media player is anything other than playing sets background grey */
        background: grey;
      {% endif %}
Style mushroom card inside of browser mod pop up
You just need to put your card mod config under the pop up card rather than the main card.
type: custom:mushroom-template-card
primary: Hello, Community
secondary: How are you?
icon: mdi:home
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      content:
        icon: mdi:home
        card_mod:
          style: |
            ha-card {
                background: blue;
              {% else %}
                background: grey;
              {% endif %}
@rhysb’s amazing animation resource link here. please however check my animation link here with an update on these animations as the way that animations are applied to icons has changed since these posts. however if you like any of these animations dont like my post like the original post. I didnt put the effort into creating them, i just updated them.
@Ildar_Gabdullin’s amazing resources on general card mod information here.
and then of course a massive thanks to the creators of the card and utilities being used @piitaya for mushroom cards and @thomasloven for the card mod utility.
πŸ”Ή Card-mod - Add css styles to any lovelace card
πŸ”Ή Card-mod - Super-charge your themes!
Trying to change the icon colour on a custom mushroom chips chip
3D printer Mushroom style card
Mushroom Cards - Build a beautiful dashboard easily πŸ„ (Part 1)
Mushroom Cards - Build a beautiful dashboard easily πŸ„ (Part 2)
Can you change icon to a new icon in mushroom-chip-cards?
How do I make text color equal entity state color?
How to change the mdi icon color based on the state of a sensor
Expander (Collapsible) Card
Change icon style and text color in mushroom template card
Card-mod for Tile card: icon & tile color
Mushroom Chip Template for changing Colour and Icon
Custom Mushroom Card possible?
Want to make a simple room overview
Card-Mod Mushroom Template Card personalization problem
Basic Dashboard Templating with Mushroom Template card
Custom fan card for govee fans using govee2mqtt - styling help
Vertical cover card
How to change font-size of entity card? I'm lost
Mushroom-template-card icon/scripts
Help with using variables in template
Monitor animation
Mushroom Chips Card icon colour change
Merging Lists in Lovelace YAML mode
Venetian blind card?
πŸ”Ή Browser_mod - turn your browser into a controllable device, and a media_player
Convert sensor to a device tracker?
Area name on entity tile card?
Certain icons can color others cannot?
Mushroom Chips cards - Fixing Width
Mushroom card for gate?
Fun with custom:button-card
Change text color of a mushroom title card
How to combine two code sections?
Can I show icons inside templates
Mushroom chips card with badge
"Mushroom like" to choose between 3 actions
Mushroom entity card - change icon color depending the value
Mushroom chip card entity change icon color with state change
Mushroom card remove button
[Custom Component] Alarmo - browser managed alarm system
Mushroom-climate-card, Showing additional information
Tile / Bar Combo Card
How to move Badge
Mushroom card not shown
Just want to increase Font size on a Tile Card past 20px
Possible to animate mushroom-light-card collapsible_controls?
Mushroom chips - cant change text color
Entity Card with 4 Buttons
Sections are split:
Main Icon Styling
You can style the main icon like this:
Change the icon type/mdi.
card_mod:
  style: |
    ha-state-icon {
      --card-mod-icon: mdi:mushroom;
Change the icon color.
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
      --icon-symbol-size: 40px;
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
This one there is a couple different ones you can use, and also some different value types. i would just play around with it until you find what you like.
card_mod:
  style: |
    ha-state-icon {
      padding-right: 30px;
      padding-left: 10px;
      padding-bottom: -20px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (4)
If you are using an animation you need to put your keyframes outside of the ha-state-icon, like the below.
card_mod:
  style: |
    ha-state-icon {
      animation: wobbling 0.7s linear infinite alternate;
    @keyframes wobbling {
      0% {transform: rotate(-80deg);}
      100% {transform: rotate(40deg);}
End Icon Styling Section
Main Icon Background/Shape Styling
You can style the main icon background/shape like this:
Shape Color.
card_mod:
  style:
      .shape {
        --shape-color: orange !important;
Shape Size.
You should set the icon size to 21px as this is the standard size for mushroom cards. you are then free to change the size of the shape without affecting the icon.
card_mod:
  style:
      .shape {
        --icon-symbol-size: 21px;
        --icon-size: 100px;
Shape Shadow.
Left with shadow, right standard without shadow. !important seems to be required.
card_mod:
  style:
      .shape {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.36) !important;
Shape β€œShape”?
Note that it doesnt seem like you can use negative values here.
card_mod:
  style:
      .shape {
        padding-right: 40px;
        padding-left: 10px;
        padding-bottom: 10px;
Shape Outline/Border.
the different border types can be found here.
card_mod:
  style:
      .shape {
        border: 2.5px outset green
Shape Animation.
Untitled video - Made with Clipchamp (5)
If you are using an animation you need to put your keyframes outside of the .shape, like the below.
card_mod:
  style:
      .shape {
        --shape-animation: ping 2s infinite;
      @keyframes ping {
          0% {box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7);}
          70% {box-shadow: 0 0 0 10px transparent;}
          100% {box-shadow: 0 0 0 0 transparent;}
End Shape/Icon Background Styling Section
Card Styling
The card body itself can be styled like this:
Background Color.
Note that any buttons also seem to change color according to this color. you can style the buttons seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
      background-color: #002f7a;
Background outline/border.
Note that setting a border size does seem to change the actual card size slightly. border types can be found here.
card_mod:
  style: |
    ha-card {
      border: 2.5px outset blue
Card shadow.
You can use this to both add a shadow and remove one if your theme has a shadow by default like mine does (minimalist).
Add Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.66);
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
This changes the outside size of the card. not any of the interior contents. you have to use !important it seems for height to actually change.
card_mod:
  style: |
    ha-card {
      height: 200px !important;
      width: 200px;
Card padding.
This adds interior padding to the card and therefore squishes the internals into the dimensions of the card more. the interior items will get smaller. you have to use !important it seems for padding to take effect.
card_mod:
  style: |
    ha-card {
      padding-right: 150px !important;
      padding-left: 150px !important;
      padding-bottom: 30px !important;
      padding-top: 30px !important;
Card margins.
Card margin adds blank space to the outside of the card squeezing the entire card (interiror and exterior) into a smaller space, making the whole card smaller.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-bottom: 30px;
      margin-left: 30px;
      margin-right: 30px;
Card Border/Corner Radius.
Changes the radius of the corners. this is set to 0. so sharp corners.
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Card Shape Animation
Untitled video - Made with Clipchamp (25)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
End of Card Styling Section
Text Styling
Primary (or first line) text can be styled like this:
Change Font.
maybe dont use Wingdings :wink:
card_mod:
  style: |
    ha-card {
      font-family: "Wingdings 2";
Change Font Style.
Font styles can be found here.
card_mod:
  style: |
    ha-card {
      font-style: italic;
Change Font Variant.
Font variants can be found here.
card_mod:
  style: |
    ha-card {
      font-variant: small-caps;
Change Font Size.
I have not found a way to change font size for text accross the board. you have to do them individually it seems.
card_mod:
  style:
    mushroom-state-info$: |
      .container {
       --card-secondary-font-size: 20px;
       --card-primary-font-size: 20px;
Change Font Color.
I have not found a way to change color for text accross the board. you have to do them individually it seems.
card_mod:
  style:
      .container {
        --card-primary-color: blue;
        --card-secondary-color: orange;
Change Alligment
Different allignment options can be found here.
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
Gap will need to be adjusted depending on your primary text length. you can find the different types of flex direction here. yaml courtesy of @zanixmechanix
card_mod:
  style:
      .container {
        flex-direction: row !important;
        align-items: baseline;
        gap: 10px;
End of Text Styling Section
Selection Value Styling
N/A Alarm Control Panel Card does not a selection value.
End of Selection Value Styling Section
Badge Icon Styling
N/A Alarm Control Panel Card does not have badge icons.
End of Badge Icon Styling Section
Badge Icon Background/Shape Styling
End of Badge Icon Shape Styling Section
Slider Styling
N/A Alarm Control Panel Card does not have a slider.
End of Slider Styling Section
Buttons Styling
If you have control buttons they can be styled like this:
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit.
card_mod:
  style:
    mushroom-button:nth-child(1)$: |
      .button ::slotted(*) {
card_mod:
  style:
        --card-mod-icon-color: orange;
Change icon size.
card_mod:
  style:
        --control-icon-size: 30px;
Rotate Icon.
card_mod:
  style:
        rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
        padding-left: 10px;
        height: 40px;
        width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (8)
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. you will need to put your keyframes outside of the ha-icon as per the below.
card_mod:
  style:
Button Background.
card_mod:
  style:
      .button {
        --bg-color: #780000;
Button Size.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. !important is required.
card_mod:
  style:
      .button {
        height: 50px !important;
        width: 50px !important;
Button Rotation.
card_mod:
  style:
      .button {
        rotate: 30deg;
Button Location.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. Only margin top and left work, but negative values are allowed so you can move them anywhere you please.
card_mod:
  style:
      .button {
        margin-top: -50px !important;
        margin-left: 375px !important;
Button Border/Outline.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. border types can be found here.
card_mod:
  style:
      .button {
        border: dashed blue !important;
Button Reverse Order.
yaml courtesy of @rhysb. keep in mind if you do any styling now that the nth-child(1) is now at the end instead as the order was reversed.
card_mod:
  style: |
    mushroom-button-group {
      transform: scalex(-1);
Animate buttons shape.
Untitled video - Made with Clipchamp (24)
you will need to put your keyframes outside of the .button, like the below.
card_mod:
  style:
      .button {
      @keyframes ping {
End of Button Styling Section
End of Alarm Control Panel Card Section
Chips Card
Sections are split:
Main Icon Styling
You can style the main icon of each chip type like this:
The weather chip icon cannot be modified as it is not a normal HA icon.
Note that when you have a conditional chip (like the first chip in this config is) with another chip inside of it you need to go 1 layer deeper.
card_mod:
  style:
    mushroom-conditional-chip:nth-child(1):
      mushroom-template-chip$: |
        ha-state-icon {
    mushroom-entity-chip:nth-child(2)$: |
      ha-state-icon {
    mushroom-action-chip:nth-child(3)$: |
      ha-state-icon {
    mushroom-light-chip:nth-child(4)$: |
      ha-state-icon {
    mushroom-weather-chip:nth-child(5)$: |
      ha-state-icon {
        # Cant be changed as it is not a normal HA icon.
    mushroom-template-chip:nth-child(6)$: |
      ha-state-icon {
    mushroom-alarm-control-panel-chip:nth-child(7)$: |
      ha-state-icon {
    mushroom-back-chip:nth-child(8)$: |
      ha-state-icon {
    mushroom-menu-chip:nth-child(9)$: |
      ha-state-icon {
Some use --color and some use --icon-color. and some use both 1 for on state and 1 for off state (the light chip only.). use the appropriate one as per the below.
!important is needed for the alarm panel chip.
card_mod:
  style:
        ha-state-icon {
          --color: red;
      ha-state-icon {
        --color: red;
      ha-state-icon {
        --color: red;
      ha-state-icon {
        --color: red;
        --icon-color: blue;
      ha-state-icon {
      ha-state-icon {
        --color: red;
      ha-state-icon {
        --color: red !important;
      ha-state-icon {
        --icon-color: blue;
      ha-state-icon {
        --icon-color: blue;
You can also change the icon color for some of all of the chips in a card at once with the below instead. (not recommended, as it doesnt affect all icons).
card_mod:
  style: |
    ha-card {
      --color: blue;
Change icon size.
card_mod:
  style:
        ha-state-icon {
          --chip-icon-size: 30px;
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
Rotate Icon.
card_mod:
  style:
        ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
      ha-state-icon {
          rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style:
        ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
      ha-state-icon {
          padding-left: 10px;
          height: 40px;
          width: 20px;
Animate the Icon.
Untitled video - Made with Clipchamp (9)
card_mod:
  style:
        ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
      ha-state-icon {
Shape Color.
This can be done in 2 ways. either globally for all chips in the card. or 1 at a time for each chip.
Globally. right under (or at the bottom of) the chips card.
type: custom:mushroom-chips-card
card_mod:
  style: |
    ha-card {
      --chip-background: blue;
for each chip. under the individual chip type (or at the bottom of that chip type). if you have a conditional chip make sure your code is under the chip that gets shown by the conditional chip. not under the conditional chip itself.
  - type: conditional
    conditions:
      - entity: light.office_desk_lamp
        state: 'on'
    chip:
      type: template
      icon: mdi:lightbulb
      card_mod:
        style: |
          ha-card {
Shape Size.
You should set the icon size to 18px as this is the standard icon size for mushroom chips. you are then free to change the size of the shape without affecting the icon.
      card_mod:
        style: |
          ha-card {
            justify-content: center;
            --chip-height: 64px;
            --chip-border-radius: 50%;
            --chip-icon-size: 18px;
Shape Shadow.
Top standard for my theme (minimalist) with shadow (just extra shadow added for effect), bottom without shadow. !important seems to be required.
Add Shadow
      card_mod:
        style: |
          ha-card {
            box-shadow: 0px 2px 5px 0px rgba(0,0,0,0.8) !important;
Remove Shadow.
      card_mod:
        style: |
          ha-card {
            box-shadow: none !important;
Shape β€œShape”?
N/A doesnt seem like you can influence the shape much other than the border radius. covered in the Shape Size section above.
card_mod:
  style: |
    ha-card {
      border: 2.5px outset green !important;
Shape Animation.
Untitled video - Made with Clipchamp (11)
If you are using an animation you need to put your keyframes outside of the ha-card, like the below.
      card_mod:
        style: |
          ha-card {
          @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
      background-color: blue !important;
Note that setting a border size does seem to change the actual card size slightly. !important is required. border types can be found here.
card_mod:
  style: |
    ha-card {
      border: 4px blue dashed !important;
Card shadow.
You can use this to both add a shadow and remove one of course the Chip Card itself has no shadow by default. !important is required.
Add Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.66) !important;
Remove Shadow.
card_mod:
  style: |
    ha-card {
Card size.
This changes the outside size of the card. not any of the interior contents. you have to use !important it seems for height to actually change. i have added a border here to illustrate. but it isnt actually required.
card_mod:
  style: |
    ha-card {
      width: 200px;
      border: 2px blue dashed !important;
Card padding.
This adds interior padding to the card for chip card it doesnt make the chips any smaller, but rather makes the card larger with a larger empty volume. border added to illustrate but not required.
card_mod:
  style: |
    ha-card {
      padding-right: 50px !important;
      padding-left: 50px!important;
      padding-bottom: 50px !important;
      padding-top: 50px !important;
Card margins.
Card margin adds blank space to the outside of the card. hard to show, but the screenshot is taken to show the added blank space on the outside of the card.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
Changes the radius of the corners. border added to illustrate but not required.
card_mod:
  style: |
    ha-card {
      border-radius: 20px !important;
Card Content Rows/Columns
You can change the way that chips are in rows and columns with the below.
Check out the below 2 links to find out what your options are. in general display changes the way that your chips themselves are displayed in the column/row. and flex-flow changes the layout of the chips.
https://developer.mozilla.org/en-US/docs/Web/CSS/flex-flow
https://www.w3schools.com/cssref/pr_class_display.php
card_mod:
  style: |
    .chip-container {
      flex-flow: column wrap !important;
      display: inline-block !important;
Chip Spacing
You can change the space between chips like this.
card_mod:
  style: |
    .chip-container {
      --chip-spacing: 20px;
Text Styling
Chip text can be styled like this:
Change Font.
You can place this under the major chip card to affect all chips in the card. or you can place it under the chip that you want to style individually. doesnt matter, code is the same.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style: |
    ha-card {
       --chip-font-size: 20px;
Change Font Color.
You can change the color of text in 2 ways for chips. either accros the entire card for all chips like the below. (keep in mind that this also changes icon colours at the same time for most chip types, so it is really not recommended).
card_mod:
  style: |
    ha-card {
      --primary-text-color: blue;
i would however recommend that you change the color on an individual level instead by placing it under the chip you are trying to style specifically. like the below:
chips:
  - type: conditional
    conditions:
        state: 'on'
    chip:
      type: template
      icon: mdi:lightbulb
  - type: entity
    entity: person.dimitri_landerloos
    card_mod:
      style: |
        ha-card {
          --text-color: blue;
Change Alligment
Separate allignment of text with Card-Mod does not seem to work for chips unfortunately. if someone finds out a way to adjust internal text alligment in the chips let me know, or update it here! :slight_smile:
Change Rows.
Only 1 row of text in the chips. so no rows can be adjusted.
N/A Chips Card does not a selection value.
Badge Icon Styling
N/A Chips Card does not have badge icons.
Slider Styling
N/A Chips Card does not have a slider.
Buttons Styling
N/A Chips Card does not have control buttons.
End of Buttons Styling Section
End of Chips Card Section
Climate Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (12)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (13)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (27)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
I have not found a way to change font size for text accross the board. you have to do them individually it seems. note that this doesnt affect the value in the selection. if you want to style this go to the selection value styling section.
card_mod:
  style:
      .container {
Change Font Color.
I have not found a way to change color for text accross the board. you have to do them individually it seems. note that this doesnt affect the value in the selection. if you want to style this go to the selection value styling section.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
You can style the number that results from you selection with buttons like this:
Change Font.
card_mod:
  style:
    mushroom-climate-temperature-control$:
      mushroom-input-number$: |
        .value {
Change Font Style.
card_mod:
  style:
        .value {
          font-style: italic;
Font Variants do not seem to be supported for the selection value unfortunately. you will have to use a different font entirely to get the desired look.
Change Font Size.
card_mod:
  style:
        .value {
          font-size: 30px;
Change Font Color.
card_mod:
  style:
        .value {
          color: green !important;
Change Alligment
note that this does only seem to affect the vertical position of the value.
card_mod:
  style:
        .container {
          align-items: start !important;
Badge Icon Styling
You can style the badge icon like this:
card_mod:
  style: |
    mushroom-badge-icon {
card_mod:
  style: |
      --icon-color: orange;
Change icon size.
card_mod:
  style: |
      --badge-icon-size: 40px;
Rotate Icon.
card_mod:
  style: |
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style:
    mushroom-badge-icon$: |
      ha-icon {
        padding-right: 10px;
        padding-left: 5px;
        height: 20px;
        width: 0px;
Animate the Icon.
Untitled video - Made with Clipchamp (15)
If you are using an animation you need to put your keyframes outside of the mushroom-badge-icon, like the below.
card_mod:
  style: |
You can style the badge icon background/shape like this:
Shape Color.
looks like !important is required.
card_mod:
  style: |
      --main-color: blue !important;
Shape Size.
You should set the icon size to 12px as this is the standard size for badges in mushroom cards. you are then free to change the size of the shape without affecting the icon.
card_mod:
  style: |
      --badge-icon-size: 12px;
      --badge-size: 30px;
Shape Shadow.
card_mod:
  style:
      .badge {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.36);
Shape β€œShape”?
card_mod:
  style:
      .badge {
        padding-left: 10px;
card_mod:
  style:
      .badge {
Shape Animation.
Untitled video - Made with Clipchamp (16)
If you are using an animation you need to put your keyframes outside of the .badge, like the below.
card_mod:
  style:
      .badge {
      @keyframes ping {
Slider Styling
N/A Climate Card does not have a slider.
Buttons Styling
For some reason for these the 2 buttons are nth-child(1) and nth-child(3) and there is no 2? so just keep that in mind :slight_smile:
card_mod:
  style:
        #container .button:nth-child(1) {
card_mod:
  style:
Change icon size.
card_mod:
  style:
          --control-icon-size: 50px;
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-right: 100px;
          padding-left: 10px;
          padding-bottom: 20px;
          width: 150px;
Animate the Icon.
Untitled video - Made with Clipchamp (14)
For some reason for these the 2 buttons are nth-child(1) and nth-child(3) and there is no 2? so just keep that in mind :slight_smile: you will need to put your keyframes outside of the #container .button:nth-child(1) as per the below.
card_mod:
  style:
Button Background.
card_mod:
  style:
          background: #780000;
Button Size.
For some reason for these the 2 buttons are nth-child(1) and nth-child(3) and there is no 2? so just keep that in mind :slight_smile: !important is required. (color added to show size, not needed).
card_mod:
  style:
Button Location.
For some reason for these the 2 buttons are nth-child(1) and nth-child(3) and there is no 2? so just keep that in mind :slight_smile: Only margin top and left work, but negative values are allowed so you can move them anywhere you please.
card_mod:
  style:
          margin-top: 20px !important;
          margin-left: 37px !important;
For some reason for these the 2 buttons are nth-child(1) and nth-child(3) and there is no 2? so just keep that in mind :slight_smile: border types can be found here.
card_mod:
  style:
You can flip the order of the buttons, but it also flips the selection value. you can flip the selection value back again though, with the .value added code at the bottom.
card_mod:
  style:
        :host {
        .value {
Untitled video - Made with Clipchamp (23)
card_mod:
  style:
        @keyframes ping {
        #container .button:nth-child(3) {
        @keyframes ping {
End of Climate Card Section
Cover Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (17)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (18)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
Note that any buttons and sliders also seem to change color according to this color. you can style the buttons seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (28)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
I have not found a way to change font size for text across the board. you have to do them individually it seems.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Cover Card has no Selection Value.
Badge Icon Styling
N/A Cover Card has no Badge Icon.
Slider Styling
If you have sliders they can be controlled like this:
Change color.
card_mod:
  style:
    mushroom-cover-position-control$: |
      mushroom-slider {
          --main-color: teal !important;
          --bg-color: #d1eced !important;
    mushroom-cover-tilt-position-control$: |
      mushroom-slider {
Change Size
There isnt enough space to make the slider any bigger so if that is your aim i would recommend making the box that they live in bigger as well. like the below. of course this doesnt apply if you are making the buttons smaller. !important is required.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          width: 200px !important;
      mushroom-slider$: |
        .slider {
      mushroom-cover-position-control {
        height: 200px;
      mushroom-cover-tilt-position-control {
        height: 200px;
Rotate slider
I would not recommend using this. the control doesnt follow the direction of the slider. it is just a bad idea.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
        height: 200px;
Offset/Pad Slider
You have to use margin instead of padding. padding only seems to make the slider itself bigger.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          margin-right: 100px;
          margin-top: 30px !important;
      mushroom-slider$: |
        .slider {
        height: 74px;
        height: 74px;
Animate Slider Shape.
Untitled video - Made with Clipchamp (20)
Untitled video - Made with Clipchamp (22)
i would recommend adding some padding so that the animation has the space to show. you need to put your keyframes outside of the .slider, like the below.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
        padding: 10px;
        height: 40px;
Slider Border.
Maybe add some padding the the box the slider lives in.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
Buttons Styling
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. if you have the tilt or position control button it needs to be styled seperately.
card_mod:
  style:
    mushroom-cover-buttons-control$:
    mushroom-button$: |
card_mod:
  style:
    mushroom-button$: |
Change icon size.
card_mod:
  style:
    mushroom-button$: |
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
    mushroom-button$: |
        rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          width: 150px;
    mushroom-button$: |
        padding-left: 10px;
        width: 150px;
Animate the Icon.
Untitled video - Made with Clipchamp (19)
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. if you have the tilt or position control button it needs to be styled seperately. you will need to put your keyframes outside of the ha-icon as per the below.
card_mod:
  style:
    mushroom-button$: |
Button Background.
card_mod:
  style:
        .button {
          background: #780000 !important;
    mushroom-button$: |
      .button {
Button Size.
There isnt enough space to make the button any bigger so if that is your aim i would recommend making the boxes that they live in bigger as well. like the below. of course this doesnt apply if you are making the buttons smaller.
card_mod:
  style:
        .button {
          height: 100px !important;
          width: 100px !important;
    mushroom-button$: |
      .button {
      mushroom-cover-buttons-control {
      mushroom-button {
Button Location.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. if you have the tilt or position control button it needs to be styled seperately. Only margin top and left work, but negative values are allowed so you can move them anywhere you please. you can add extra space like the above by making the boxes that the buttons live in bigger if you need it.
card_mod:
  style:
        .button {
    mushroom-button$: |
      .button {
        margin-top: -10px !important;
        margin-left: -37px !important;
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. if you have the tilt or position control button it needs to be styled seperately. border types can be found here.
card_mod:
  style:
        .button {
    mushroom-button$: |
      .button {
You can flip the order of the main buttons, but unfortunately since the tilt/position button is seperate that wont flip with it.
card_mod:
  style:
    mushroom-cover-buttons-control$: |
        :host {
Untitled video - Made with Clipchamp (21)
i would recommend adding some padding to the boxes that the buttons live in just so that there is space for the animation. you will need to put your keyframes outside of the .button, like the below.
card_mod:
  style:
        .button {
        @keyframes ping {
    mushroom-button$: |
      .button {
      @keyframes ping {
        padding: 10px;
        height: 40px;
      mushroom-button {
        padding: 10px;
        height: 40px;
End of Cover Card Section
Entity Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (29)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (30)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (31)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Entity Card does not have a selection value.
Badge Icon Styling
N/A Entity Card does not have badge icons.
Slider Styling
N/A Entity Card does not have a slider.
Buttons Styling
N/A Entity Card does not have control buttons.
End of Entity Card Section
Media player card plz? :revolving_hearts:
Fan Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (32)
for this card you can also just turn on spin animation for when the fan is on via the visual editor.
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (33)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (34)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Fan Card has no Selection Value.
Badge Icon Styling
N/A Fan Card has no Badge Icon.
Slider Styling
Change color.
card_mod:
  style:
    mushroom-fan-percentage-control$: |
      mushroom-slider {
Change Size
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-fan-percentage-control {
        height: 200px;
Rotate slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
Offset/Pad Slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        height: 74px;
Untitled video - Made with Clipchamp (35)
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
Slider Border.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
Buttons Styling
card_mod:
  style:
    mushroom-fan-oscillate-control$:
card_mod:
  style:
Change icon size.
card_mod:
  style:
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          width: 150px;
Animate the Icon.
Untitled video - Made with Clipchamp (36)
card_mod:
  style:
Button Background.
card_mod:
  style:
        .button {
Button Size.
card_mod:
  style:
        .button {
      mushroom-fan-oscillate-control {
Button Location.
Only margin top and left work, but negative values are allowed so you can move them anywhere you please. you can add extra space like the below by making the boxes that the buttons live in bigger if you need it.
card_mod:
  style:
        .button {
card_mod:
  style:
        .button {
N/A only 1 button for the fan card.
Untitled video - Made with Clipchamp (37)
card_mod:
  style:
        .button {
        @keyframes ping {
        padding: 10px;
        height: 40px;
End of Fan Card Section
Humidifier Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (38)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (39)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
Note that any buttons and sliders also seem to change color according to this color. you can style the slider seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (40)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Humidifier Card has no Selection Value.
Badge Icon Styling
N/A Humidifier Card has no Badge Icon.
Slider Styling
Change color.
card_mod:
  style:
    mushroom-humidifier-humidity-control$: |
      mushroom-slider {
Change Size
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        height: 200px;
Rotate slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
Offset/Pad Slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        height: 74px;
Untitled video - Made with Clipchamp (41)
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
Slider Border.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
Buttons Styling
N/A Humidifier Card does not have control buttons.
End of Humidifier Card Section
Number Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (42)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (43)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (44)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Number Card has no Selection Value.
Badge Icon Styling
N/A Number Card has no Badge Icon.
Slider Styling
Change color.
card_mod:
  style:
    mushroom-number-value-control$: |
      mushroom-slider {
Change Size
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-number-value-control {
        height: 200px;
Rotate slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
Offset/Pad Slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        height: 74px;
Untitled video - Made with Clipchamp (45)
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
Slider Border.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
Buttons Styling
Refer to climate card button styling. but change references to mushroom-climate-temperature-control$: to mushroom-number-value-control$:
This section didnt exist initially when the guide was created, and there is now no space in the post for this addition. i may make a seperate post again for the number card to fix this issue eventually.
End of Number Card Section
Lock Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (52)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (53)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
      border-radius: 0px;
Untitled video - Made with Clipchamp (54)
you will need to put your keyframes outside the ha-card like the below.
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Lock Card does not a selection value.
Badge Icon Styling
N/A Lock Card does not have badge icons.
Slider Styling
N/A Lock Card does not have a slider.
Buttons Styling
There is unfortunately a limitation that i have not been able to get around for any button that when clicked cycles to a different button. any change of icon for this button is lost and does not come back until a refresh of the page… @piitaya this could technically be solved by giving each button a name that is separate like you have done in other cards :slight_smile:
card_mod:
  style:
    mushroom-lock-buttons-control$:
card_mod:
  style:
Change icon size.
card_mod:
  style:
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          height: 40px;
          width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (55)
card_mod:
  style:
Button Background.
card_mod:
  style:
        .button {
Button Size.
i have added some padding to the button so that you can see the size difference. !important is required.
card_mod:
  style:
        .button {
        mushroom-button {
          padding: 10px;
Button Rotation.
card_mod:
  style:
        .button {
          rotate: 30deg;
Button Location.
card_mod:
  style:
        .button {
          margin-left: 30px !important;
card_mod:
  style:
        .button {
N/A only 1 button on the lock card.
Untitled video - Made with Clipchamp (56)
i have added some extra padding to the button so there is room for the animation. you will need to put your keyframes outside of the .button, like the below.
card_mod:
  style:
        .button {
        @keyframes ping {
        mushroom-button {
          padding: 7px;
Light Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (46)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
        border-radius: 0px !important;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (47)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
Note that any buttons and also seem to change color according to this color. you can style the buttons and slider seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (48)
you need to put your keyframes outside of the ha-card like the below.
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Light Card has no Selection Value.
Badge Icon Styling
N/A Light Card has no Badge Icon.
Slider Styling
Change color.
This will override any color already there (like for example if you have use light color turned on).
card_mod:
  style:
    mushroom-light-brightness-control$: |
      mushroom-slider {
    mushroom-light-color-control$: |
      mushroom-slider {
        --gradient: -webkit-linear-gradient(right, red 0%, orange 10%, yellow 20%, lightgreen 30%, green 40%, lightblue 50%, blue 60%, purple 70%, fuchsia 80%, red 100%) !important;
    mushroom-light-color-temp-control$: |
      mushroom-slider {
        --gradient: -webkit-linear-gradient(right, teal 0%, white 100%) !important;
Change Size
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
      mushroom-light-brightness-control {
        height: 200px;
      mushroom-light-color-control {
        height: 200px;
      mushroom-light-color-temp-control {
        height: 200px;
Rotate slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
        height: 200px;
        height: 200px;
Offset/Pad Slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
        height: 74px;
        height: 74px;
        height: 74px;
Untitled video - Made with Clipchamp (49)
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
      mushroom-slider$: |
        .slider {
        @keyframes ping {
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
        padding: 10px;
        height: 40px;
        padding: 10px;
        height: 40px;
Slider Border.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
      mushroom-slider$: |
        .slider {
Buttons Styling
for the light card it seems that nth-child starts at 2 for some reason?
add + 1 to the nth-child for each button in your card. light card starts at 2 for some reason.
card_mod:
  style:
    mushroom-button:nth-child(2)$: |
card_mod:
  style:
Change icon size.
card_mod:
  style:
Rotate Icon.
card_mod:
  style:
        rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
        padding-left: 10px;
        width: 150px;
Animate the Icon.
Untitled video - Made with Clipchamp (50)
card_mod:
  style:
Button Background.
card_mod:
  style:
      .button {
Button Size.
card_mod:
  style: |
    mushroom-button:nth-child(2) {
Button Location.
card_mod:
  style: |
card_mod:
  style:
    mushroom-button:nth-child(2) $: |
      .button {
this doesnt work very well unless you also move the slider. i have done that in this example.
card_mod:
  style:
      mushroom-slider {
      mushroom-slider {
      mushroom-slider {
      .actions {
Untitled video - Made with Clipchamp (51)
card_mod:
  style:
      .button {
      @keyframes ping {
      .button {
      @keyframes ping {
      mushroom-button {
        padding: 10px;
        height: 40px;
End of Light Card Section
Media Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (57)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (58)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (59)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Media Card has no Selection Value.
Badge Icon Styling
N/A Media Card has no Badge Icon.
Slider Styling
Change color.
This will override any color already there.
card_mod:
  style:
    mushroom-media-player-volume-control$: |
      mushroom-slider {
Change Size
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      mushroom-media-player-volume-control {
        height: 200px;
Rotate slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
          rotate: 90deg;
        height: 200px;
Offset/Pad Slider
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        height: 74px;
Untitled video - Made with Clipchamp (60)
card_mod:
  style:
      mushroom-slider$: |
        .slider {
        @keyframes ping {
        padding: 10px;
        height: 40px;
Slider Border.
card_mod:
  style:
      mushroom-slider$: |
        .slider {
Buttons Styling
add + 1 to the nth-child for each button in your card. if you have the volume controls enabled that button needs to be styled seperately. the first button on the volume control page is nth-child(2).
card_mod:
  style:
    mushroom-media-player-media-control$:
    mushroom-button$: |
add + 1 to the nth-child for each button in your card. the first button on the volume control page is nth-child(2).
card_mod:
  style:
    mushroom-button$: |
Change icon size.
card_mod:
  style:
    mushroom-button$: |
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
          rotate: 40deg;
    mushroom-button$: |
        rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          width: 150px;
          padding-left: 10px;
          width: 150px;
    mushroom-button$: |
        padding-left: 10px;
        width: 150px;
Animate the Icon.
Untitled video - Made with Clipchamp (61)
add + 1 to the nth-child for each button in your card. the first button on the volume control page is nth-child(2). you will need to put your keyframes outside of the ha-icon as per the below.
card_mod:
  style:
    mushroom-button$: |
Button Background.
add + 1 to the nth-child for each button in your card. the first button on the volume control page is nth-child(2). !important seems to be required.
card_mod:
  style:
        .button {
        .button {
    mushroom-button$: |
      .button {
Button Size.
card_mod:
  style:
        .button {
        .button {
    mushroom-button$: |
      .button {
Button Location.
add + 1 to the nth-child for each button in your card. the first button on the volume control page is nth-child(2).Only margin top and left work, but negative values are allowed so you can move them anywhere you please.
card_mod:
  style:
    mushroom-media-player-media-control$: |
      mushroom-button:nth-child(1) {
      mushroom-button {
add + 1 to the nth-child for each button in your card. the first button on the volume control page is nth-child(2). border types can be found here.
card_mod:
  style:
        .button {
        .button {
    mushroom-button$: |
      .button {
You could then also flip each of the buttons around so they look right using rotation :slight_smile:
card_mod:
  style:
      mushroom-slider {
      .actions {
Untitled video - Made with Clipchamp (62)
card_mod:
  style:
        .button {
        @keyframes ping {
        .button {
        @keyframes ping {
    mushroom-button$: |
      .button {
      @keyframes ping {
      mushroom-media-player-media-control {
        padding: 10px;
        height: 40px;
        padding: 10px;
        height: 40px;
      mushroom-button {
        padding: 10px;
        height: 40px;
End of Media Card Section
Person Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (63)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
        border-radius: 10px !important;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (64)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (65)
you will need to put your keyframes outside of the ha-card, like the below.
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Person card does not have selection value.
Badge Icon Styling
card_mod:
  style: |
card_mod:
  style: |
Change icon size.
card_mod:
  style: |
Rotate Icon.
card_mod:
  style: |
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style:
      ha-icon {
        padding-left: 5px;
        height: 20px;
        width: 0px;
Animate the Icon.
Untitled video - Made with Clipchamp (66)
card_mod:
  style: |
Shape Color.
card_mod:
  style: |
Shape Size.
card_mod:
  style: |
      --badge-size: 30px;
Shape Shadow.
card_mod:
  style:
      .badge {
Shape β€œShape”?
card_mod:
  style:
      .badge {
        padding-left: 10px;
card_mod:
  style:
      .badge {
Shape Animation.
Untitled video - Made with Clipchamp (67)
card_mod:
  style:
      .badge {
      @keyframes ping {
Badge Location.
card_mod:
  style: |
      margin-right: 32px !important;
Slider Styling
N/A Person Card does not have a slider.
Buttons Styling
N/A Person Card does not have control buttons.
End of Person Card Section
Select Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (70)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
Note that the selection box also changes color… you can style this seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (72)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Text can be styled like this:
Change Font.
Note that this doesnt affect the selection value. this can be styled seperately, which you will see in the selection value section. maybe dont use Wingdings :wink:
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
Note that this doesnt affect the selection value. this can be styled seperately, which you will see in the selection value section. I have not found a way to change font size for text accross the board. you have to do them individually it seems.
card_mod:
  style:
      .container {
Change Font Color.
Note that this doesnt affect the selection value. this can be styled seperately, which you will see in the selection value section. I have not found a way to change color for text accross the board. you have to do them individually it seems.
card_mod:
  style:
      .container {
Change Alligment
Note that this doesnt affect the selection value. this can be styled seperately, which you will see in the selection value section. Different allignment options can be found here.
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
Note that this doesnt affect the selection value. this can be styled seperately, which you will see in the selection value section. types of flex direction here. yaml courtesy of @zanixmechanix
card_mod:
  style:
      .container {
        gap: 10px;
You can style the text that results from you selection with the dropdown like this:
Change Font.
!important is required. maybe dont use Wingdings :wink:
card_mod:
  style:
    mushroom-select-option-control$:
      mushroom-select$: |
        .mdc-select__selected-text {
          font-family: "Wingdings 2" !important;
Change Font Style.
card_mod:
  style:
      mushroom-select$: |
           font-style: italic;
Change Font Size.
!important is reqired. Careful, the dropdown doesnt grow with the font size.
card_mod:
  style:
      mushroom-select$: |
          font-size: 30px !important;
Change Font Color.
card_mod:
  style:
      mushroom-select$: |
Change Alligment
note that this does only seem to affect the vertical position of the value. it also doesnt move very much in general.
card_mod:
  style:
      mushroom-select$: |
        .mdc-select__selected-text-container {
Background
card_mod:
  style:
      mushroom-select$: |
        .mdc-select__anchor{
          background: red !important
Dropdown icon color.
You can style it overall one color. or seperate for open and closed.
Overall:
card_mod:
  style:
      mushroom-select$: |
        .mdc-select__dropdown-icon {
          fill: red !important
Open/Closed.
card_mod:
  style:
      mushroom-select$: |
        .mdc-select__dropdown-icon-inactive {
          fill: red !important;
        .mdc-select__dropdown-icon-active {
          fill: green !important;
Border.
card_mod:
  style:
      mushroom-select$: |
          border: 1px red dashed !important
List items box size.
credit @Ildar_Gabdullin for his amazing resource on mdc styling. check it out here.
card_mod:
  style:
      mushroom-select$:
        mwc-menu $: |
          mwc-list {
            max-height: 96px !important;
list items spacing.
card_mod:
  style:
      mushroom-select$:
        mwc-menu $: |
          mwc-list {
            --mdc-menu-item-height: 16px;
list item color.
colors current selection, background and other options seperately.
card_mod:
  style:
      mushroom-select$: |
        mwc-menu {
          --mdc-theme-text-primary-on-background: red;
          --mdc-theme-primary: green;
          --mdc-theme-surface: lightyellow;
Badge Icon Styling
N/A Select Card does not have a badge icon.
Slider Styling
N/A Select Card does not have a slider.
Buttons Styling
N/A Select Card does not have control buttons.
End of Select Card Section
Template Card
Sections are split:
Main Icon Styling
You can style the main icon like this:
Change the icon type/mdi.
Of course for the template card you could also just use the visual editor…
card_mod:
  style: |
    ha-state-icon {
      --card-mod-icon: mdi:mushroom;
Change the icon color.
card_mod:
  style: |
    ha-state-icon {
      color: orange;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
      --icon-symbol-size: 40px;
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
This one there is a couple different ones you can use, and also some different value types. i would just play around with it until you find what you like.
card_mod:
  style: |
    ha-state-icon {
      padding-right: 30px;
      padding-left: 10px;
      padding-bottom: -20px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (73)
If you are using an animation you need to put your keyframes outside of the ha-state-icon, like the below.
card_mod:
  style: |
    ha-state-icon {
      animation: wobbling 0.7s linear infinite alternate;
    @keyframes wobbling {
      0% {transform: rotate(-80deg);}
      100% {transform: rotate(40deg);}
End Icon Styling Section
Main Icon Background/Shape Styling
You can style the main icon background/shape like this:
Shape Color.
card_mod:
  style:
      .shape {
        --shape-color: orange !important;
Shape Size,
You should set the icon size to 21px as this is the standard size for mushroom cards. you are then free to change the size of the shape without affecting the icon.
card_mod:
  style:
      .shape {
        --icon-symbol-size: 21px;
        --icon-size: 100px;
Shape Shadow.
Left with shadow, right standard without shadow. !important seems to be required.
card_mod:
  style:
      .shape {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.36) !important;
Shape β€œShape”?
Note that it doesnt seem like you can use negative values here.
card_mod:
  style:
      .shape {
        padding-right: 40px;
        padding-left: 10px;
        padding-bottom: 10px;
Shape Outline/Border.
the different border types can be found here.
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (74)
If you are using an animation you need to put your keyframes outside of the .shape, like the below.
card_mod:
  style:
      .shape {
        --shape-animation: ping 2s infinite;
      @keyframes ping {
          0% {box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7);}
          70% {box-shadow: 0 0 0 10px transparent;}
          100% {box-shadow: 0 0 0 0 transparent;}
End Shape/Icon Background Styling Section
Card Styling
The card body itself can be styled like this:
Background Color.
card_mod:
  style: |
    ha-card {
      background-color: #002f7a;
Background outline/border.
Note that setting a border size does seem to change the actual card size slightly. border types can be found here.
card_mod:
  style: |
    ha-card {
      border: 2.5px outset blue
Card shadow.
You can use this to both add a shadow and remove one if your theme has a shadow by default like mine does (minimalist).
Add Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.66);
Remove Shadow.
card_mod:
  style: |
    ha-card {
        box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      height: 200px !important;
      width: 200px;
Card padding.
This adds interior padding to the card and therefore squishes the internals into the dimensions of the card more. the interior items will get smaller. you have to use !important it seems for padding to take effect.
card_mod:
  style: |
    ha-card {
      padding-right: 150px !important;
      padding-left: 150px !important;
      padding-bottom: 30px !important;
      padding-top: 30px !important;
Card margins.
Card margin adds blank space to the outside of the card squeezing the entire card (interiror and exterior) into a smaller space, making the whole card smaller.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-bottom: 30px;
      margin-left: 30px;
      margin-right: 30px;
Card Border/Corner Radius.
Changes the radius of the corners. this is set to 0. so sharp corners.
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Card Shape Animation
Untitled video - Made with Clipchamp (75)
remember to put your keyframes outside of your ha-card.
card_mod:
  style: |
    ha-card {
    @keyframes ping {
End of Card Styling Section
Text Styling
Primary (or first line) text can be styled like this:
Change Font.
card_mod:
  style: |
    ha-card {
      font-family: "Wingdings 2";
Change Font Style.
Font styles can be found here.
card_mod:
  style: |
    ha-card {
      font-style: italic;
Change Font Variant.
Font variants can be found here.
card_mod:
  style: |
    ha-card {
      font-variant: small-caps;
Change Font Size.
card_mod:
  style:
    mushroom-state-info$: |
      .container {
       --card-secondary-font-size: 20px;
       --card-primary-font-size: 20px;
Change Font Color.
card_mod:
  style:
      .container {
        --card-primary-color: blue;
        --card-secondary-color: orange;
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
You can find the different types of flex direction here. yaml courtesy of @zanixmechanix
card_mod:
  style:
      .container {
        flex-direction: row !important;
        align-items: baseline;
        gap: 10px;
End of Text Styling Section
Selection Value Styling
N/A Template Card does not have a selection value.
End of Selection Value Styling Section
Badge Icon Styling
card_mod:
  style: |
card_mod:
  style: |
Change icon size.
card_mod:
  style: |
Rotate Icon.
card_mod:
  style: |
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style:
      ha-icon {
        padding-left: 5px;
        height: 20px;
        width: 0px;
Animate the Icon.
Untitled video - Made with Clipchamp (88)
card_mod:
  style: |
End of Badge Icon Styling Section
Badge Icon Background/Shape Styling
Shape Color.
card_mod:
  style: |
Shape Size.
card_mod:
  style: |
      --badge-size: 30px;
Shape Shadow.
card_mod:
  style:
      .badge {
Shape β€œShape”?
card_mod:
  style:
      .badge {
        padding-left: 10px;
card_mod:
  style:
      .badge {
Shape Animation.
Untitled video - Made with Clipchamp (89)
card_mod:
  style:
      .badge {
      @keyframes ping {
Badge Location.
card_mod:
  style: |
End of Badge Icon Shape Styling Section
Slider Styling
N/A Template Card does not have a slider.
End of Slider Styling Section
Buttons Styling
N/A Template Card does not have control buttons.
End of Template Card Section
Title Card
Sections are split:
Main Icon Styling
N/A Title Card does not have an icon.
N/A Title Card does not have an icon background/shape.
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
      background-color: #002f7a !important;
!important is required. Note that setting a border size does seem to change the actual card size slightly. border types can be found here.
card_mod:
  style: |
    ha-card {
      border: 2.5px outset blue !important;
Card shadow.
You can use this to both add a shadow and remove one.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
      box-shadow: none;
Card size.
I have set a border for this just so you can see the change. This changes the outside size of the card. not any of the interior contents. you have to use !important it seems for height to actually change.
card_mod:
  style: |
    ha-card {
      width: 200px;
      border: white solid 1px !important;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
I have set a border for this just so you can see the change. Card margin adds blank space to the outside of the card squeezing the entire card (interiror and exterior) into a smaller space, making the whole card smaller.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
I have set a border for this just so you can see the change. Changes the radius of the corners. this is set to 0. so sharp corners.
card_mod:
  style: |
    ha-card {
        border-radius: 0px;
Untitled video - Made with Clipchamp (76)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style: |
    ha-card {
      --title-font-size: 40px !important;
      --subtitle-font-size: 10px !important;
Change Font Color.
card_mod:
  style: |
    ha-card {
Change Alligment
There doesnt seem to be a way to do this with card mod. just use the visual editor :slight_smile:
Change Rows.
There doesnt seem to be a way to do this with card mod unfortunately.
N/A Title Card does not have a selection value.
Badge Icon Styling
N/A Title Card does not have badge icons.
Slider Styling
N/A Title Card does not have a slider.
Buttons Styling
N/A Title Card does not have control buttons.
End of Button Styling Section
End of Title Card Section
Update Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: red;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (77)
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
        --shape-color: blue !important;
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
Shape Animation.
Untitled video - Made with Clipchamp (78)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
Note that any buttons also seem to change color according to this color. you can style the buttons seperately which you will see later in the guide.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
      border: 2.5px outset blue;
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
      box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
      border-radius: 0px;
Untitled video - Made with Clipchamp (79)
remember to put your keyframes outside of the ha-card.
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Update Card does not a selection value.
Badge Icon Styling
N/A Update Card does not have badge icons.
Slider Styling
N/A Update Card does not have a slider.
Buttons Styling
If you have control buttons they can be styled like this:
card_mod:
  style:
    mushroom-update-buttons-control$:
      mushroom-button:nth-child(1)$: |
        .button ::slotted(*) {
card_mod:
  style:
          --card-mod-icon-color: orange;
Change icon size.
card_mod:
  style:
          --control-icon-size: 30px;
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          height: 40px;
          width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (80)
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. you will need to put your keyframes outside of the ha-icon as per the below.
card_mod:
  style:
Button Background.
card_mod:
  style:
        .button {
Button Size.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. !important is required.
card_mod:
  style:
        .button {
          height: 50px !important;
          width: 50px !important;
Button Rotation.
card_mod:
  style:
        .button {
          rotate: 30deg;
Button Location.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. Only margin top and left work, but negative values are allowed so you can move them anywhere you please.
card_mod:
  style:
        .button {
          margin-top: 10px !important;
          margin-left: 35px !important;
Button Border/Outline.
increment the nth-child(1) by +1 for every button that you have in your card. and then style them individually as you see fit. border types can be found here.
card_mod:
  style:
        .button {
          border: dashed blue !important;
Button Reverse Order.
yaml courtesy of @rhysb. keep in mind if you do any styling now that the nth-child(1) is now at the end instead as the order was reversed.
card_mod:
  style: |
    mushroom-update-buttons-control {
      transform: scalex(-1);
Animate buttons shape.
Untitled video - Made with Clipchamp (81)
i have added a bit of padding so the animation fits. you will need to put your keyframes outside of the .button, like the below.
card_mod:
  style:
        .button {
        @keyframes ping {
        height: 40px !important;
        padding: 10px;
End of Update Card Section
Vacuum Card
Sections are split:
Main Icon Styling
card_mod:
  style: |
    ha-state-icon {
card_mod:
  style: |
    ha-state-icon {
      color: red;
Change icon size.
card_mod:
  style: |
    ha-state-icon {
Rotate Icon.
card_mod:
  style: |
    ha-state-icon {
      rotate: 30deg;
Offset/Pad Icon.
card_mod:
  style: |
    ha-state-icon {
      padding-left: 10px;
      height: 20px;
      width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (82)
You can set that the icon is animated when running from the visual editor already but you are restricted to that specific animation and only condition is on vs off. If you are using an animation you need to put your keyframes outside of the ha-state-icon, like the below.
card_mod:
  style: |
    ha-state-icon {
Shape Color.
card_mod:
  style:
      .shape {
Shape Size.
card_mod:
  style:
      .shape {
        --icon-size: 100px;
Shape Shadow.
card_mod:
  style:
      .shape {
Shape β€œShape”?
card_mod:
  style:
      .shape {
        padding-left: 10px;
card_mod:
  style:
      .shape {
        border: 2.5px outset green
Shape Animation.
Untitled video - Made with Clipchamp (83)
card_mod:
  style:
      .shape {
      @keyframes ping {
Card Styling
Background Color.
card_mod:
  style: |
    ha-card {
card_mod:
  style: |
    ha-card {
Card shadow.
Add Shadow.
card_mod:
  style: |
    ha-card {
Remove Shadow.
card_mod:
  style: |
    ha-card {
      box-shadow: none;
Card size.
card_mod:
  style: |
    ha-card {
      width: 200px;
Card padding.
card_mod:
  style: |
    ha-card {
Card margins.
card_mod:
  style: |
    ha-card {
      margin-top: 30px;
      margin-left: 30px;
      margin-right: 30px;
card_mod:
  style: |
    ha-card {
      border-radius: 0px;
Untitled video - Made with Clipchamp (84)
card_mod:
  style: |
    ha-card {
    @keyframes ping {
Text Styling
Change Font.
card_mod:
  style: |
    ha-card {
Change Font Style.
card_mod:
  style: |
    ha-card {
      font-style: italic;
card_mod:
  style: |
    ha-card {
Change Font Size.
card_mod:
  style:
      .container {
Change Font Color.
card_mod:
  style:
      .container {
Change Alligment
card_mod:
  style:
      .container {
        align-items: end;
Change Rows.
card_mod:
  style:
      .container {
        gap: 10px;
N/A Vacuum Card does not a selection value.
Badge Icon Styling
N/A Vacuum Card does not have badge icons.
Slider Styling
N/A Vacuum Card does not have a slider.
Buttons Styling
card_mod:
  style:
    mushroom-vacuum-commands-control$:
card_mod:
  style:
Change icon size.
card_mod:
  style:
Rotate Icon.
card_mod:
  style:
          rotate: 40deg;
Offset/Pad Icon.
card_mod:
  style:
          padding-left: 10px;
          height: 40px;
          width: 50px;
Animate the Icon.
Untitled video - Made with Clipchamp (85)
card_mod:
  style:
Button Background.
card_mod:
  style:
        .button {
          --bg-color: #780000;
Button Size.
card_mod:
  style:
        .button {
Button Rotation.
card_mod:
  style:
        .button {
          rotate: 30deg;
Button Location.
card_mod:
  style:
        .button {
card_mod:
  style:
        .button {
card_mod:
  style: |
    mushroom-vacuum-commands-control {
Untitled video - Made with Clipchamp (86)
card_mod:
  style:
        .button {
        @keyframes ping {
        padding: 10px;
End of Vacuum Card Section
just posted :slight_smile:
That is one hell of an impressive guide you wrote! :+1: :partying_face: Wow! :slight_smile:
Thanks so much, already set a bookmark, because I know, I’ll need and use this guide a lot! :slight_smile:
Thanks for this, it’s very helpful
Is there a way to swap around Icon and Text? Align-items End but first goes Icon and to the left of it goes text?
Like this?
card_mod:
  style:
      .container {
        align-items: end;
      ha-card {
yes, but my end result wasn’t as good as yours :slight_smile:
      style:
          .container {
            align-items: end;
          ha-card {
            background: none;
            border-width: 0;
