Mushroom Cards Card Mod Styling/Config Guide
                      - type: custom:mushroom-update-card
                        entity: update.home_assistant_operating_system_update
                        show_buttons_control: true
                        icon: mdi:home-assistant
                        icon_color: |-
                          {% if is_state('update.home_assistant_supervisor_update', 'on') %}
                            red
                          {% else %}
                            {{ states("input_text.kleur_iconen")}}
                          {% endif %}
the icon (background)color when updated is ok, also when update needed it is ok. But when it is in ā€œupdatingā€ it is blue, and that does not match my theme :wink:
Probably need to add a line for {{ state_attr('update.home_assistant_operating_system_update', 'in_progress')== 'true' }} to the icon_color: template.
Hi
Very new to Home Assistant but learning quickly. I a familar with CSS so some of the styling that can be applied in this set of cards is familar.
I am trying to combine two sets of very simple styling to a Mushroom Cover Card, I want to change the background colour, and the colour of the slider I have followed the code in this great guide, and the card background styles as expected, but the slider does not, what am I missing, I as ure it will be something very simple. My code is:
entity: cover.office
fill_container: true
show_buttons_control: false
show_position_control: true
layout: horizontal
icon_type: icon
card_mod:
  style: |
    mushroom-cover-position-control$:
      mushroom-slider {
          --main-color: teal !important;
          --bg-color: #d1eced !important;
    ha-card
      background-color: #470468;
This is what is produced, no matter what I try the slider does not change colour.
Screenshot 2024-06-22 195000
Thanks in advance, as I say I am still learning.
Ad.
I donā€™t have a cover to test it. but this should work
layout: horizontal
icon_type: icon
card_mod:
  style:
    mushroom-cover-position-control$: |
      mushroom-slider {
      ha-card {
afbeelding
this is my code
    primary: Melding krijgen wanneer er vuilbakken zijn
    icon: >
      {% if is_state("input_boolean.vuilbakken", 'on') %}
      mdi:toggle-switch
      {% else %}
      mdi:toggle-switch-off
      {% endif %}
    entity: input_boolean.vuilbakken
    tap_action:
      action: toggle
    layout: horizontal
    multiline_secondary: false
    card_mod:
          style:
            mushroom-state-info$: |
              .container {
                margin: -10px;
              .primary {
                padding: 15px 0px 55px 10px;
            mushroom-shape-icon$: |
              .shape {
              margin-top: -40px;
              ha-state-icon {
                {% if is_state('input_boolean.vuilbakken','on') %}
                animation:  blink 1s infinite, illumination 1s infinite ;{%- endif %}
                @keyframes blink {
                  50% {opacity: 0;}
                @keyframes illumination {
                    0%, 100% { clip-path: inset(0 0 0 0); }
                    95% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
              ha-card {
                height: 108px !important;
                  background-color: rgb({{ states("input_text.kleur_iconen")}})
                  {%- else -%}
                  {%- endif %}
why is there so muche ā€œemptyā€ space below the text ?
You added it here
type: custom:mushroom-template-card
icon: >
  {% if is_state("input_boolean.vuilbakken", 'on') %} mdi:toggle-switch {% else
  %} mdi:toggle-switch-off  {% endif %}
tap_action:
  action: toggle
layout: horizontal
card_mod:
  style: |
      ha-state-icon {
        @keyframes blink {
          50% {opacity: 0;}
      ha-card {
          {%- else -%}
          {%- endif %}
like this ?
                              {% if state_attr("update.home_assistant_operating_system_update",'in_progress') == 'true' %}
                              {% endif %}
Hi @Frosty
Thanks for the assist, worked perfecty. I had seen the | and .: | characters used but I was not sure what their purpose was and how to use them, could you explain? then I can learn for the future.
Ad.
no problem glad it worked for you.
if you goto post 1 by @dimitri.landerloos and scroll to the bottom youā€™ll see
What the $ and .: | symbols do
that should explain. I cant use developer tools in a browser myself so it goes abit over my head. I do have a rough idea of how there used if you need further help thereā€™s always someone willing to help.
Dimitri,
Aligning text in a chip seems to work with text-align: <start|center|end> under ha-card:
ha-card {
    background-color:
      {% if states(config.entity) == 'on' %}
        rgba(var(--rgb-green),0.2) !important;
      {% else %}
        rgba(var(--rgb-grey),0.2) !important;
      {% endif %}
    box-shadow: none !important;
    margin-left: 5px;
    margin-top: -60px;
    padding: 5px;
    text-align: end;
    width: 100px !important;
    --chip-icon-size: 30px;
    --chip-font-weight: none;
    --chip-font-size: 12px !important;
@Dan010 Can you provide a chip card example with this working?
Below is an example of what you are describing, but the text does not adjust to the end.
You can adjust the chip text alignment via this method
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: light.pc_lights
    content_info: name
card_mod:
  style:
    mushroom-entity-chip:nth-child(1)$: |
      span {
      color: red !important;
      text-align: center !important;
Hi ! Iā€™ve the same problem than Abhi for the mushroom-person and the ā€œphotos-iconā€ size.
Have you got the solution plz ?
Just a heads up, Itā€™s recommended to limit tagging folks. See #16
Dimitri may reach out and Iā€™ll take a look as well.
Can you post your card code?
I added text-align on the level of the custom:mushroom-chips-card
Naamloos
And below the definition:
type: vertical-stack
cards:
  - type: thermostat
    entity: climate.incomfort_1
    show_current_as_primary: true
    name: ' Thermostaat Woonkamer'
    theme: Mushroom
  - type: custom:mushroom-chips-card
    card_mod:
      style: |
        ha-card {
          margin-top: -350px !important;
          text-align: end;
    alignment: justify
    chips:
      - type: template
        icon_color: |
          {% if states(entity) == 'on' %}
            green
          {% else %}
            grey
          {% endif %}
        entity: input_boolean.eco_temperatuur
        content: Eco 15Ā°C
        icon: mdi:leaf
        card_mod:
          style: |
            ha-card {
              background-color:
                {% else %}
                {% endif %}
              margin-left: 5px;
              padding: 5px;
      - type: template
        icon_color: |
            orange
          {% else %}
            grey
          {% endif %}
        entity: input_boolean.comfort_temperatuur
        content: Comfort 18Ā°C
        icon: mdi:thermometer-check
        card_mod:
          style: |
            ha-card {
              background-color:
                  rgba(var(--rgb-orange),0.2) !important;
                {% else %}
                {% endif %}
              margin-right: 5px;
              padding: 5px;
Apologies, didnā€™t mean to offend anyone. Still relatively new to HA and this was my first forum post.
No not at all, itā€™s another approach. I just canā€™t get it to work with certain scenarios. I appreciate the example!
The break in the content: initiates a second line when the width of the span is taken up and the card width is limited to 100px. If the content: is consecutive it will not adjust based off text-align: end
content: Eco15Ā°C
content: Eco 15Ā°C
how to move the remaining time section to the left?
Or the
move the time bar and remaining time section to the left?
type: custom:stack-in-card
mode: vertical
cards:
  - type: horizontal-stack
    cards:
      - type: custom:mushroom-fan-card
        entity: fan.paraelszivo_zuhanyzo_switch_0
        icon_animation: true
        fill_container: false
        collapsible_controls: true
        tap_action:
          action: toggle
        layout: horizontal
        primary_info: null
        secondary_info: none
        card_mod:
          style: |
            ha-card {
              border: none;
            ha-state-icon {
              color: dodgerblue;
              --icon-symbol-size: 40px;
      - type: custom:timer-bar-card
        layout: full_row
        duration:
          fixed: '00:15:00'
        text_width: 60px
        invert: true
        bar_direction: rtl
        bar_width: 60%
        tap_action:
          action: toggle
do you meanā€¦ move the bar and time, left so itā€™s closer to the fan card
or move the time on the bar to the left side of the bar (flip itā€™s direction)
Thanks @Frosty, will do, and thanks again for the first bit
Ad.
Move the bar and time to the left a few px. Donā€™t be on edge.
