Mushroom Cards Card Mod Styling/Config Guide
I have made some progress: I now have a round background behind my picture, but I can’t manage to enlarge my picture (it is still cut off at the bottom corners).
type: custom:mushroom-template-card
icon: ''
picture: /local/floorplan/Buttons/Haus.svg
badge_icon: mdi:home
layout: vertical
fill_container: false
card_mod:
  style: |
    ha-card {
      justify-content: center;
      background:  green !important;
      border-radius: 50px;
      height: 100px !important;
      width: 100px;
      border: 1px solid white !important;
I think I have to do this somehow with ‘mushroom-shape-avatar’ but how?
I don’t think this is correct any longer… - looks like it’s
          --title-color: red;
instead
Hi @all,
im searching for more than 1 hour, I didn’t find it.
It must be easy but I have no idea how …
I use Mushroom-light-card
When on button and slider get orange.
When off grey. But I want it when off Steelblue.
How?
thx
Andreas
EDIT: Or make the Background of the Button Transparent?
I think that’s better …
it’s in the guide first post.
card_mod:
  style:
    mushroom-light-brightness-control$: |
      mushroom-slider {
        --main-color: teal !important;
        --bg-color: #d1eced !important;
    mushroom-light-color-control$: |
      mushroom-slider {
        --gradient: -webkit-linear-gradient(right, red 0%, orange 10%, yellow 20%, lightgreen 30%, green 40%, lightblue 50%, blue 60%, purple 70%, fuchsia 80%, red 100%) !important;
    mushroom-light-color-temp-control$: |
      mushroom-slider {
        --gradient: -webkit-linear-gradient(right, teal 0%, white 100%) !important;
Hi Frosty,
I found that already, but I want the Button (behind the Bulp) transparent. so you only can see the Bulp.
With your code I can color the on status.
Thx
Andreas
EDIT: No one?
good evening, can you tell me how I can enlarge or eliminate the transparent border because it cuts my icon. Thanks
Immagine 2024-10-18 204428
entity: input_boolean.test_pulsante
tap_action:
  action: toggle
custom_fields: null
secondary: |-
  {% if is_state(entity, 'on') %}
    Sicurezza Accesa
  {% else %}
    Sicurezza Spenta
  {% endif %}
primary: Casa
layout: vertical
fill_container: true
picture: |-
    /local/security-camera.gif
  {% else %}
    /local/security-camera off.gif
  {% endif %}
card_mod:
  style:
    mushroom-shape-avatar$: |
      .container {
        --icon-size: 90px;
    mushroom-state-info$: |
      .container {
         --card-secondary-font-size: 16px;
         --card-primary-font-size: 18px;
      ha-card {
        height: 175px !important;
          border-radius: 100px;
          box-shadow: 2px 2px #FFAEBC, -0.1em -0.2em 0em 0em #B4F8C8 ;
        --card-primary-font-size: var(--mush-card-primary-font-size, 10px);
        --card-secondary-font-size: var(--mush-card-secondary-font-size, 10px);
        {% if states('input_boolean.test_pulsante') == 'on' %}
          box-shadow: 2px 2px #A16AE8, -0.1em -0.2em 0em 0em #FFFF00 ; !important
        {% elif states('input_boolean.test_pulsante') == 'off' %}
          background-color: var(--card-background-color); /* Default */
        {% endif %}
Hello, I’m having an issue with my template cards, and I hope someone can help me. I’ve tried making some adjustments, but I can’t get my icons to look like the default ones. The icons appear black instead of grey, and they don’t have the circular backgrounds like the default template icons.
entity: switch.waschmaschine
primary: Waschmaschine
secondary: >
  {% if is_state('switch.waschmaschine', 'on') and
  states('sensor.waschmaschine') in ['arbeitet', 'fertig'] %}
    🕒 {{ states('sensor.waschmaschine') | capitalize }} - Seit:
    {% set time = as_timestamp(now()) - as_timestamp(states.sensor.waschmaschine.last_changed) %}
    {% set hours = (time // 3600) | int %}
    {% set minutes = ((time % 3600) // 60) | int %}
    {% if hours > 0 %}
      {{ hours }} Std. {{ minutes }} Min.
    {% else %}
      {{ minutes }} Min.
    {% endif %}
  {% elif is_state('switch.waschmaschine', 'on') %}
  {% else %}
    {% set no_status = '' %}
    {{ no_status }}
  {% endif %}
icon: mdi:washing-machine
icon_color: |
  {% if is_state('switch.waschmaschine', 'on') %}
    blue
  {% else %}
    gray
  {% endif %}
layout: vertical
tap_action:
  action: more-info
hold_action:
  action: none
double_tap_action:
  action: none
card_mod:
  style: |
    ha-icon {
      background-color: var(--card-background-color, #f0f0f0);
      border-radius: 50%;
      padding: 8px;
      --mdc-icon-size: 24px;
Not really related to the thread, but Its just grey instead of gray
:man_facepalming: i‘m so stupid
Thank you so much, I don’t have seen this mistake
How can I make the icon background invisible?
Example:
In the light icon I only want to see the bulb.
Make the Circle Invisible .
Pls some one?
Thx Andreas
which are you use mushroom card.
like this ?
type: custom:mushroom-light-card
entity: light.lights_off
icon: mdi:lightbulb
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        --shape-color:  !important;
just don’t put a color or transparent
--shape-color: rgba(0,0,0,0) !important;
No it doesn’t work here
any idea why?
If that screen shot is accurate, check indentation of the line that starts mushroom-shape-icon - it needs to be indented 2 further spaces (as will as everything underneath it).
It took me ages to find it, I am using picture as well
card_mod:
  style:
      .picture {
        border-radius: 0px !important;
Yeh check mine with yours. indentation is important
Hey guys,
i got a maybe dump question:
If I use a mushroom:cover-card is it possible to change the secondary information and the Icon in one specific position? This code doesnt work, but I cant figured out why. Maybe someone could help. Maybe template-card? :man_shrugging:t3:
card_mod:
  style: |
    ha-state-icon {
      --card-mod-icon: >
        {% if state_attr(entity, "current_position") == 50 %}
          mdi:weather-sunny-alert
        {% else %}
        {% endif %}
Still not working:
thx for help
It works only if the entity is “on”.
Try this one, if u ever want it transparent:
card_mod:
  style:
      .shape {
        background: transparent !important;
@WeisserWolf611
This did it
