Mushroom Cards error "Unavailable"
I hope this is in the correct forum.
I’m building a Mushroom Card. All was going well until one of my ‘Rooms’ showed an orange backgrounded ?. I’ve checked everything but cannot see what I’ve done wrong!
I’ve attached 2 screen shots.
Any help is much appreciated.
TIA
John
I don’t use the UI, but I imagine Bench Light is either not an entity or it is unavailable to HA right now.
Is the entity field for the entity_id (maybe light.bench_light) or the entity name (Bench light)? …just checking the field is filled in correctly. If it is (please remember I don’t use the UI) then the entity is probably unavailable right now. You can check this by going to Developer tools > states and search for that entity.
Thanks for the pointer, jchh. I’ll check it out.
I finally worked it out. I’d somehow entered the incorrect Tuya Local key!
