Mushroom Chips Card Battery Color based on percentage
Hi, i have a custom mushroom chips card, and i want to cahnge the color of the battery icon based on battery percentage.
My following code doesnt work, it shows the right color, but no percentage
can anyone help?
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: sensor.lights_on_count
    double_tap_action:
      action: none
    use_entity_picture: false
    icon_color: amber
    tap_action:
      action: none
    hold_action:
      action: none
  - type: entity
    entity: sensor.windows_on_count
    double_tap_action:
      action: none
    icon: mdi:window-open-variant
    tap_action:
      action: none
    hold_action:
      action: none
  - type: template
    entity: sensor.batterie_ladezustand
    icon: mdi:car-battery
    tap_action:
      action: none
    hold_action:
      action: none
    value_template: '{{ states(''sensor.batterie_ladezustand'') }}'
    icon_color: |
      {% set battery_level = states('sensor.batterie_ladezustand')|int %}
      {% if battery_level | int > 60 %}
       green
      {% elif battery_level | int > 20 %}
       yellow
      {% else %}
       red
      {% endif %}
  - type: weather
    entity: weather.forecast_home
    show_conditions: false
    show_temperature: true
alignment: center
Screenshot 2023-06-14 233311
The mushroom chip template uses a property called content: not value_template: for primary info. Check your property names.
