Hi!
I’m trying to set up a mushroom chips card with coditional logic to show if our livingroom tv is on or not.
This is the yaml fort it:
type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: input_boolean.v_rum_tv_state
state: 'on'
chip:
type: entity
icon_color: green
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
- type: conditional
conditions:
state: 'off'
chip:
type: entity
icon_color: red
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
alignment: center
It works when the state is “on”, then the icon becomes green but when state is “off” the icon becomes white.
Cant understand why it doesnt want to go red like ive set it up to be.
Please help…
AldoQ
(Aldo Quispel)
July 13, 2022, 5:49pm
2
For Entity it’s depended on the state I believe, so colored if it’s ‘on’ and else not showing the color. Depended on the type of entity you use. You could use a template card and set the color based on the state manually and gain full control.
{% if is_state('binary_sensor.deur_tuin_sensor_open', 'on') %}
red
{% else %}
grey
{% endif %}
Actually can be used to also change the icon basd on the state. For example I use a open icon when the door is open vs when it is closed.
mdi:door-sliding-open
{% else %}
mdi:door-sliding
{% endif %}
Full yaml (not of a chip, but you can also do this for a chip, pick the template one).
type: custom:mushroom-template-card
primary: Tuindeur
secondary: |-
Open
{% else %}
Dicht
{% endif %}
icon: |-
{% else %}
mdi:door-sliding
{% endif %}
entity: binary_sensor.deur_tuin_sensor_open
icon_color: |-
red
{% else %}
grey
{% endif %}
badge_icon: |-
{% if is_state('binary_sensor.tuin_global_motion_sensor', 'on')
or is_state('binary_sensor.schuur_sensor_motion', 'on')
mdi:motion-sensor
{% endif %}
badge_color: light-green
Cool!
Thanks for your quick answer, I’m gonna try that
I’m trying to do the same thing and have the following code:
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: binary_sensor.badezimmer_fenster
icon: |-
{% if is_state('binary_sensor.badezimmer_fenster', 'on') %}
mdi:window-open-variant
{% else %}
mdi:window-closed-variant
{% endif %}
The dashboard does not show any icon when using the code. Can anyone help me figuring out what is wrong?
Anyone who can help me here?
Try using the template chip in mushroom. Here’s an example of mine:
chips:
- type: entity
entity: binary_sensor.aqara_lumi_motion_ac01_occupancy_3
content_info: none
- type: entity
entity: binary_sensor.lumi_lumi_motion_ac02_iaszone_2
content_info: none
- type: entity
entity: binary_sensor.lumi_lumi_sensor_magnet_aq2_opening_2
content_info: none
- type: template
icon: |-
{% if is_state('switch.innr_sp_222_switch', 'on') %}
mdi:wall-sconce
{% else %}
mdi:wall-sconce-outline
{% endif %}
entity: switch.innr_sp_222_switch
tap_action:
action: toggle
- type: template
icon: |-
{% if is_state('automation.bedroom_heating', 'on') %}
mdi:thermometer-auto
{% else %}
mdi:thermometer-off
{% endif %}
entity: automation.bedroom_heating
tap_action:
action: toggle
alignment: justify
note the last two items. For example the lamp icon looks like this:
