Mushroom Chips card icon_color changing based on state
this is my script for my chips card on top of my dashboard. I would like the color of the battery icon to change, based on its sensor’s state:
  - type: custom:mushroom-chips-card
    chips:
      - type: entity
        entity: sensor.tabingresso_battery_level
        double_tap_action:
          action: none
        use_entity_picture: false
        hold_action:
          action: none
        icon_color: >-
          {% set level = state('sensor.tabingresso_battery_level') %}
          {% if level >= 7 %}
            green
          {% else %}
            red
          {% endif %}
…but con is always white:
immagine
This below code works if used for a custom:mushroom-template-card (still not works for chips card), but only if I tell the script to look for a specific value (29):
{% if is_state('sensor.tabingresso_battery_level', '29') %}
  yellow
{% endif %}
Any idea??
Thanks! :wink:
The function is states() not state()… but there are other changes you need to make as well.
States are always strings, so you need to convert them to a integer or float before using mathematical operations or comparisons.
Optionally, Mushroom allows use of a variable entity so you don’t need to use the whole entity_id
    chips:
      - type: template
        double_tap_action:
          action: none
        hold_action:
          action: none
        icon: mdi:battery
        icon_color: >-
          {% set level = states(entity) | int(0) %}
          {% if level >= 7 %}
            green
          {% else %}
            red
          {% endif %}
Thank you very much for the explanation, but it is still not working.
If it helps, this is the entity:
I want an icon color based on energy consumption. I tried some things out of a few topics but I can not het it to work:
chips:
  - type: entity
    entity: sensor.electricity_meter_power_consumption
 icon_color: >
     {% if state(entity) | float > 1500 and states(entity) | float < 2500 }
       orange
     {% elif states(entity) | float > 2500 %}
       red
     {% else %}
       green
     {%- endif %}
also tried this (also with state instead of states. Not sure which one is right)
 {% if is_states(entity, > 1500) and is_states(entity, < 2500) | float < 2500 %
    orange
  {% elif is_states(entity) | float > 2500 %}
    red
  {% else %}
    green
  {% endif %}
I got it :slight_smile: Had to use template (mushroom chip btw)… Duh…
type: template
icon_color: >-
  {% if states('sensor.electricity_meter_power_consumption') | float > 1500 and
  states('sensor.electricity_meter_power_consumption') | float < 2500 %} orange
  {% elif states('sensor.electricity_meter_power_consumption') | float > 2500 %}
  red
  {% else %} green
  {% endif %}
chips:
entity: sensor.home_assistant_core_cpu_percent
type:
icon_color: >-
  {% if states(entity) | float > 1 and
  states(entity) | float < 2 %}
  orange
  red
  {% else %}
  green
  {% endif %}
Configuration error
Error in parsing YAML: duplicated mapping key (line: 4, column: 1)
I was hoping you might offer a fix? Thank you, Anthony
The duplicate mapping error is from type: added twice
A example to understand the formatting
chips:
  - type: template
    entity: sensor.xxxxxxx
    icon: mdi:thermometer
    content: |
      {{ states('sensor.xxxxxxx') | int(0)}}
    icon_color: |
      {% set state = states('sensor.xxxxxx') | int(0) %}
      {% if state >= 50 %} red
      {% elif state >= 30 %} orange
      {% else %}
      blue
      {% endif %}
THANK YOU!!!
Just so my response is a little clearer. You can use states(entity). I just provided an example with two different entity data points.
content: is also not a necessity
chips:
  - type: template
    entity: input_number.number
    icon: mdi:mushroom
    content: |
      {{ states(entity) | int(0)}}
    icon_color: |
      {% set state = states(entity) | int(0) %}
      {% else %}
      blue
      {% endif %}
Thank you again, thanks to you I now have the ceiling fan chips working along with garage door status. Your taking time is greatly appreciated!
@LiQuid_cOOled Hey, A long time ago you created an animated washing machine icon where the drum rotated and the machine was shaking.
type: custom:mushroom-template-card
icon: mdi:washing-machine
icon_color: amber
primary: Washing Machine
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        --icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
        transform-origin: 50% 110%;
      @keyframes shake {
        0%, 100% { transform: translate(0, 0) rotate(0); }
        20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
        40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
        60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
        80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
      @keyframes drum {
        50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
But that was before they made changes that broke the animations.
Wondering if there are any updates in particular to the washing machine icon.
Would love to get it working again.
I’ll take a look this evening. It should be fixable!
ha-icon: changed to ha-state-icon:
The —icon-animation: format changed as well to animation:
do let me know how you get on because i replaced the old syntax with what you posted but nothing happened.
icon_color: amber
card_mod:
  style:
      ha-state-icon: {
        --animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
      @keyframes shake {
      @keyframes drum {
Here you go
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
    @keyframes shake {
    @keyframes drum {
Here is another slightly fancier version I put together.
Untitled video - Made with Clipchamp
entity: input_boolean.test
primary: |-
  {% if is_state(config.entity, 'off') %}
   Idle
  {% elif is_state(config.entity, 'on') %}
   On
  {% else %}
   Full
  {% endif %}
icon_color: |-
  {% if is_state(config.entity, 'on') -%}
    orange
  {%- else -%}
    blue
  {%- endif %}
card_mod:
  style:
      .shape:before {
       content: '';
       z-index: 1;
       position: absolute;
       justify-content: center;
       align-items: center;
       width: 22%;
       height: 11.5%;
       border: 1px solid black;
       border-radius: 1rem 1rem 0 0;
       background: {{ 'deepskyblue' if
        is_state(config.entity, 'on') else
        'black' }};
       animation: {{ 'spin 2s linear infinite alternate'if
        'animation: none;' }};
       transform-origin: 50% 85%;
       @keyframes spin {
       0% {transform: rotate(0deg);}
       100% {transform:rotate(360deg);}
      .shape:after {
       content: '';
       position: absolute;
       width: 27%;
       height: 27%;
       border-radius: 100%;
       border: 1px solid white !important;
       background:black;
       top: 14px;
Amazing! Thanks @LiQuid_cOOled
