IgorZg
(Igor Simić)
August 11, 2024, 9:36am
1
Dear comunity,
I found something interesting (at least for me) and I want to share in order to save time to somebody.
Thanks to the masive badges incompatibility introduced in 2024.8, (argh: 2024.8: Beautiful badges!), I was forced to rewrite one dashboard. I decided to use mushroom-chips card. Its template kind was almost ideal for my purpose except the content which is allways showed in one line. Googling and experimentig I found the way to display multi line text in template chip.
There is the code:
type: custom:mushroom-chips-card
chips:
- type: template
entity: switch.grijanje_termostat
use_entity_picture: true
content: |
Grijanje
{{ state_attr("sensor.grijanje_termostat_state", "desc_hr") }}
picture: '{{ state_attr("sensor.grijanje_termostat_state","picture") }}'
tap_action:
action: more-info
card_mod:
style: |
::slotted(span) {
content: "\a";
white-space: pre;
ha-card
--chip-background: {%- if is_state('var.plamenik_greska', 'on') -%}#ffd0d0{%- else -%}{%- if is_state('binary_sensor.thermostat_on', 'on') -%}#ffe4b3{%- else -%}#d0ffd0{%- endif -%}{%- endif -%};
--chip-border-color: {%- if is_state('var.plamenik_greska', 'on') -%}red{%- else -%}{%- if is_state('binary_sensor.thermostat_on', 'on') -%}orange{%- else -%}green{%- endif -%}{%- endif -%};
--card-mod-icon-color: {%- if is_state('var.plamenik_greska', 'on') -%}red{%- else -%}{%- if is_state('binary_sensor.thermostat_on', 'on') -%}orange{%- else -%}green{%- endif -%}{%- endif -%};
This produces:
fugley
August 11, 2024, 9:47am
2
you might wish to check out THIS thread then
IgorZg
(Igor Simić)
August 11, 2024, 10:19am
3
Excuse me, but how is this related?
There is nothing about mushroom-chips.
Don’t get me wrong, but your comment is nothing than noise in channel.
Dondonut
(Daan)
February 5, 2025, 2:20pm
4
Hello! I was using your solution before but it appears to not work anymore in producing multi-line chip cards - have you figured out another solution? I tried a couple of things but so far no success…
What card_mod version do you have installed? If it’s v3.5, please install v3.4.4
IgorZg
(Igor Simić)
February 6, 2025, 7:47am
6
Still working for me and I have all latest versions.
Could be card_mod related as @LiQuid_cOOled said.
Dondonut
(Daan)
February 7, 2025, 3:39pm
7
That did the trick! Much obliged for your tip good sir, hadnt noticed it was rolled back!
ausfas
(Ausfas)
September 25, 2025, 11:16am
8
Can you please share the code as the link from @fugley doesn’t have an example of multi-line chip card. Something like this
IgorZg
(Igor Simić)
October 3, 2025, 5:37pm
9
Here is one of mine:
- type: template
entity: binary_sensor.nodejs_update
icon: mdi:update
content: >
{% from "binary_sensor_negated_to_words.jinja" import binary_sensor_negated_to_words %}
{{ config.name }}
Actual: {{ binary_sensor_negated_to_words("binary_sensor.nodejs_update", "No","Yes") }}
tap_action:
action: more-info
card_mod:
style: |
::slotted(span) {
content: "\a";
white-space: pre;
ha-card {
--chip-border-color: {% if is_state('binary_sensor.nodejs_update', 'off') %} green {% elif is_state('binary_sensor.nodejs_update', 'on') %} orange {% else %} blue {% endif %};
--chip-background: {% if is_state('binary_sensor.nodejs_update', 'off') %} #d0ffd0 {% elif is_state('binary_sensor.nodejs_update', 'on') %} #ffe4b3 {% else %} #d0d0ff {% endif %};
ha-card:active { --chip-border-width: 4px; --chip-border-color: maroon; --chip-background: rgba(var(--rgb-red), 0.8); }
