Mushroom climate card adjustments
I’m currently fiddling with these cards.
They are controlling my AC fine, but 2 small things annoy me :
1/ Turning it on always starts the AC in Heat mode instead of Cool ?
2/ There is a button to toggle between temp. adjustments and heat/cool/off mode. I’d like to have the power button to toggle between on/off instead of only OFF ?
Indeed, i have the same suggestion to change the labels.
Say it is 20°C and you are running on automate.
Now you manually change to 16°C the card will show the label Heating. This confuses my users because they think the heating is on while it just means that the heating is not in automation mode but has an manually set setpoint.
Is it possible to change this label to ‘manualy’ instead of ‘heating’?
