Mushroom first steps with template
I have created a couple of helpers
input_text.next_refuse
input_datetime.next_refuse_date
I want to display this information in a card on my dashboard. I thought I would try to use the mushroom template card.
I want to display something like
Next Refuse : Non-Recyclable
Collection: Fri 2nd February
This is my input starting with the example template card:
type: custom:mushroom-template-card
primary: {{ states('input_text._refuse') }}
secondary: How are you {{states('input_datetime.refuse_date')}}
icon: mdi:dump-truck
entity_id: input_text.refuse
When I hit save the contents get corrupted:
primary:
  '[object Object]': null
with this error message:
Visual editor is not supported for this configuration:
At path: primary -- Expected a string, but received: [object Object]
You can still edit your config in YAML.
I tried to find the documentation and ended up at https://github.com/piitaya/lovelace-mushroom/blob/d1905fd945110820db32459c4fa2ae7009fb0776/docs/cards/template.md but that is much too terse for a beginner.
Hi @stevegroom
Try putting quite around your templates:
primary: "{{ states('input_text._refuse') }}"
secondary: "How are you {{states('input_datetime.refuse_date')}}"
Thank you - making progress now. But where do I find docs on mushroom templates and these functions such as states(…?
See Templating
Templating isn’t just for mushroom cards. It is used all across Home Assistant.
Aha !!
Thank you! I read the first paragraph of the Templating docs a few times and did not think that was describing the same sort of templating:
Templating is a powerful feature that allows you to control information going into and out of the system. It is used for:
That paragraph mentions several areas where I have not (yet) done much more than the basics.
Cheers!
