I have a button on my dashboard which implements a mode in the system.
My problem is that when I press it I do not know if it is on or off as it doesn’t indicate which state it is in. Is their anyway of showing this from the button? Code below
Copy the following code and paste it into your card (missing fields like secondary are automatically added). As long as an entity is defined, you can use the variable entity:
