I have a problem with Mushroom cards. After I’ve dowloaded Mushroom Card via HACS, mushroom card are not loaded and I get this error in HACS:
Not loaded in Lovelace
You have 1 Lovelace elements that are not loaded properly in Lovelace.
And in HACS the Mushroom card is colored red and has “Not loaded” error.
I’ve tried to add it manually by adding the mushroom.js file into your config/www folder and creating the resource with the url /local/mushroom.js and resource type a s JavaScript Module but still doesn’t load.
Am I doing something wrong?
Same issue. Deleted and reinstalled mushroom and mushroom themes, but not showing up. Rebooted HA… no cards. Deleted browser cache, no cards
Update: works now after going into HACS, selecting Mushroom, 3 dots on upper right, Redownload.
