Mushroom Template Card or card-mod?
This is such a simple thing that I’m trying to do but after many hours I’m totally failing.
I simply want to have a card which displays just an entity’s numerical state, and can have the card’s background change to various colours based on that state.
Help please!
Hi Gareth, what have do you have already?
Show by pasting the YAML code by using the </> button in this edit box.
Hi Nick, tried lots of things and deleted them.
The only attempt I’ve still got is this:
type: custom:mushroom-entity-card
entity: sensor.owm_rain_0_probability
primary_info: state
secondary_info: none
icon_type: none
layout: vertical
card_mod:
  style: |
    :host {
      color:
        {% if states(config.entity) | int <= 10 %}
          green
        {% elif states(config.entity) | int <= 20 %}
          greenyellow
        {% elif states(config.entity) | int <= 40 %}
          yellow
        {% elif states(config.entity) | int <= 60 %}
          orange
        {% elif states(config.entity) | int <= 80 %}
          red
        {% endif %}
This is a working example from another type, you could try to incorporate that.
type: entity
entity: binary_sensor.office_motion_occupancy
card_mod:
  style: |
    ha-card {
      background-color: {{ '#AAFFAA' if is_state('binary_sensor.office_motion_occupancy', 'off') else '#FFAAAA' }};
Thanks, Nick.
I’ve finally got there - (as I suspected) one possible answer is a mixture of the Mushroom Template Card and card-mod:
type: custom:mushroom-template-card
entity: sensor.owm_rain_1_probability
primary: "{{states(config.entity)|string + '%'}}"
secondary: ""
layout: vertical
icon: ""
card_mod:
  style: |
    ha-card {
     border: none;
     background:
        {% if states(config.entity) | int <= 20 %}
          {{'lightgrey'}}
          {{'lightblue'}}
          {{'yellow'}}
          {{'orange'}}
        {% elif states(config.entity) | int <= 100 %}
          {{'red'}}
        {% endif %}
     height: 30px !important;
     width: 60px !important;
I will now be able to sleep tonight :slightly_smiling_face:
Good you got it solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
