Spartacus
(Spartacus)
April 8, 2024, 2:58pm
1
Hi all,
I am using this code:
type: custom:mushroom-template-card
primary: 'IR Empfänger: {{ ''ein'' if states(entity) == ''on'' else ''aus'' }}'
multiline_secondary: true
secondary: ''
icon: mdi:leak
tap_action:
action: toggle
icon_color: '{{ ''green'' if states(entity) == ''on'' else ''#636363'' }}'
badge_icon: ''
fill_container: false
entity: binary_sensor.ir_input
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--icon-symbol-size: 20px;
--icon-size: 40px;
{% set light_state = states(config.entity) %}
{% if light_state == 'on' %}
--shape-animation: ping 8s infinite;
@keyframes ping {
0% {box-shadow: 0 0 0 0 green }
90% {box-shadow: 0 0 0 10px transparent;}
100% {box-shadow: 0 0 0 0 transparent;}
{% else %}
{% endif %}
mushroom-state-info$: |
.container {
--card-primary-font-size: 12px;
ha-card{
border: none !important;
--card-primary-color: grey;
as soon as the ir-sensor switches from off to on, the animation starts. (@keyframe ping). The detection sequense off-on-off is very short, and you will not see really a detection.
Is there a possibliliy to set the icon color to green for at least 5s and to repeat the keyframe ping during this time or do I have to set the delay within the automation when the ir switches from off to on!
What is beste way to get this solved?
Spartacus:
{% else %}
{% endif %}
I believe the easiest way is to adjust the delay within the automation or create a script. The animation and the color change are only looking at the state of the entity.
Spartacus
(Spartacus)
April 8, 2024, 8:13pm
3
hm!
ok, let me try to understand.
I use the entity trigger of “binary_sensor.ir_input” (edge from off-> on) to set a helper entity to “on” for e.g. 2s
Then this helper entity triggers my automation and is also used as entity in the template-card.
Yes sir…The delay is built into the automation and the automation is triggered by the binary sensor.
secondary: ''
icon: mdi:leak
tap_action:
action: toggle
badge_icon: ''
entity: input_boolean.test4
card_mod:
style:
.shape {
{% set light_state = states('input_boolean.test4') %}
--shape-animation: ping 1s infinite;
@keyframes ping {
0% {box-shadow: 0 0 0 0 green;}
70% {box-shadow: 0 0 0 10px transparent;}
{% endif %}
Spartacus
(Spartacus)
April 10, 2024, 9:09pm
5
I have it now implemented and it works fine! Now, I wanted to add the icon wobbling, but I do not find a way to integrate this code
card_mod:
style: |
ha-state-icon {
animation: wobbling 0.7s linear infinite alternate;
@keyframes wobbling {
0% {transform: rotate(-80deg);}
100% {transform: rotate(40deg);}
into my existing code.
primary: |-
IR Empfänger:
{{ 'aus' if (states("switch.k05_ir_sender") == 'off') else
'idle' if (states("switch.k05_ir_sender") == 'on') else
'detect' if (states(entity) == 'on')
secondary: ''
icon: mdi:leak
tap_action:
action: none
icon_color: |-
{{ '#636363' if (states("switch.k05_ir_sender") == 'off') else
'green' if (states("switch.k05_ir_sender") == 'on') else
'#FFC107' if (states(entity) == 'on')
badge_icon: ''
entity: input_boolean.delay_ir_detection
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
--shape-color: transparent !important;
{% set state = states(config.entity) %}
{% if state == 'on' %}
--shape-animation: ping 2s infinite;
{% else %}
{% endif %}
@keyframes ping
0% {box-shadow: 0 0 0 0 #DC143C }
90% {box-shadow: 0 0 0 3px transparent;}
.container {
--card-primary-font-size: 14px;
ha-card{
--card-primary-color: #E0E0E0;
If I try to add the “ha.state-icon”-section, it get a “configuration error”.
This should do it for you…
primary: |-
IR Empfänger:
secondary: ''
icon: mdi:leak
tap_action:
action: none
icon_color: |-
badge_icon: ''
hold_action:
action: toggle
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
--shape-animation: ping 2s infinite, wobbling 0.7s linear infinite alternate;
{% else %}
{% endif %}
@keyframes ping
.container {
ha-card{
Spartacus
(Spartacus)
April 11, 2024, 6:20am
7
LiQuid_cOOled:
.shape
--icon-size: 40px;
{% else %}
{% endif %}
@keyframes ping
Thank you very much!
I tried it in a similar way, but it seems to be that there are some errors in my code! I will check it again!
Try the code I posted in it’s own card and use a different entity like a light. That will determine if its the automation or your code.
Spartacus
(Spartacus)
April 11, 2024, 9:07am
9
Hi again,
now it is clear and thanks for support. I found the issue and everthing is fine!
Great support, thanks!
yngwiebach
(Mart Steensma)
March 6, 2025, 1:26pm
10
Hello i have stolen this code. However whatever i try it won’t change the background color. The animations work. I managed to change the icon. But it’s either a background or an animation but i cannot get both to work.
Does anyone have an idea? Thank you so much.
primary: ""
secondary: ""
icon: >-
{{ 'mdi:radiator-disabled' if (states("climate.kachel_kinderkam") == 'off')
else
'mdi:fire' if (states("climate.kachel_kinderkam") == 'heat') else
'mdi:radiator-off' if (states(entity) == 'unavailable')
tap_action:
action: toggle
icon_color: |-
{{ 'green' if (states("climate.kachel_kinderkam") == 'off') else
'orange' if (states("climate.kachel_kinderkam") == 'heat') else
'#FFC107' if (states(entity) == 'unavailable')
badge_icon: ""
entity: climate.kachel_kinderkam
hold_action:
action: more-info
double_tap_action:
action: none
card_mod:
style:
.shape
--icon-size: 40px;
{% if state == 'heat' %}
{% else %}
{% endif %}
@keyframes ping
0% {box-shadow: 0 0 0 0 orange }
90% {box-shadow: 0 0 0 4px transparent;}
0% {transform: rotate(-20deg);}
100% {transform: rotate(20deg);}
.container {
ha-card{
--card-primary-color: blue;
Edit:
Changed the latter part to
ha-card {
background: blue;
box-shadow: none;
And now it all works.
Can anyone confirm this working on mushroom template badge cards?
Yes it works with the Mushroom-Template-Badge , but needs nested under a custom:mod-card
type: custom:mod-card
card:
type: custom:mushroom-template-badge
content: ""
icon: mdi:fan
color: blue
card_mod:
style:
mushroom-template-badge$: |
ha-state-icon {
animation: spin 1s linear infinite;
@keyframes spin {
100% {
transform: rotate(360deg);
Works great!! Thanks. Here’s the full code for others interested…
card:
content: Tablet {{ states('sensor.living_tablet_battery') }} %
icon: |-
{% if is_state('switch.living_tablet_switch', 'on') %}
mdi:battery-high
{% elif is_state('switch.living_tablet_switch', 'off') %}
mdi:battery-80
{% endif %}
color: |-
{% set battery = states('sensor.living_tablet_battery') |
int %}
{% if battery < 35 %}
red
{% elif battery < 50 %}
orange
{% elif battery < 70 %}
yellow
{% else %}
green
{% endif %}
card_mod:
style:
ha-state-icon {
animation: charge 3s steps(1) infinite;
@keyframes charge {
0% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
